Controlling ET with Harmony Elite Hub
Go to solution Solved by AviatorBimmer,
AviatorBimmer
Is there a guide or tutorial on how to add my PC via Bluetooth to my Harmony Elite Hub? I would like to be able to control my ET setup with my Harmony remote but I just can't find a good guide or tutorial. Thanks!
  • Solution
AviatorBimmer
Nevermind, figured it out. 👍🏼
Hi, what was the solution?
AviatorBimmer
I turned my PC's BT connection on and set it to discoverable. I then went to the Harmony software and added a new device called Windows Computer. After pairing it to my PC, I am now able to control the PC and ET with the remote control. Pretty strait forward, actually.
  • Thanks 1
