FrAllard 11 Posted September 10, 2022 Author Posted September 10, 2022 Just did a test on latest version. I run in docker on a linux server on NFS mounts. When the stream I'm recording is perfect without any glitches the playback during recording works. As soon as the stream as one little glitch the playback during recording doesn't work, but will work when then recording is done. The same stream in live mode also works. I don't have any more log to add since it's still the same problem for me.
nikdom 1 Posted September 13, 2022 Posted September 13, 2022 it seems the latest atv app update 1.6.3 solved it for me 1
FrAllard 11 Posted September 15, 2022 Author Posted September 15, 2022 If atv mean Android TV I too did not have issue lately with it. I was testing with Windows App, but I really don't care about Windows app it was only more convenient to test with it. I use a nVidia Shield and tv show I'm interested with just started back this week and I could watch and skip commercial while recording without a hitch. Those recordings were from a very stable signal though, when Survivor start later this month I'll see, this one come from a channel that isn't as stable as my other channels. So fart so good, before at the begining of this issue I was having problems with all channels even the highly stable ones. Keep up the good work, love the system! - Lifetime subscriber! 1
MBSki 1115 Posted September 18, 2022 Posted September 18, 2022 I just tried watching an NFL game while it was recording. I skipped every huddle and commercial break and it worked well until I caught up to real time. At that point it stopped playing. It did show up on the continue watching line, but when I chose "resume" it started back at the beginning and I could no longer skip. So, I guess that's improvement, but still needs improvement. Here's a pic of when I tried to resume.
MBSki 1115 Posted September 21, 2022 Posted September 21, 2022 @Luke Are you able to replicate the issue identified above? There's no way to resume a recorded show that's been paused.
MBSki 1115 Posted September 27, 2022 Posted September 27, 2022 @Luke Are you looking into this issue?
FrAllard 11 Posted October 11, 2022 Author Posted October 11, 2022 It's good for me. I've tried it many times in the last month since the shows that we listen on live tv are back. Sunday we listen to a 1.5h long show while it being recorded and skipping commercials without any issue. Thanks for the followup, this shows a lot about the project, I'm very proud to be part of this community. FrAllard, a very happy premium subscriber! 2
MBSki 1115 Posted October 24, 2022 Posted October 24, 2022 @Luke This is broken again. The issue appears to be Emby not knowing when transcoding is needed. If I manually switch a in-progress recording to transcode, it works. If I leave it on Auto, it doesn't.
snaprjohn 0 Posted October 7, 2023 Posted October 7, 2023 This issue occurs for me when using Apple TV. IOS mobile app works as expected.
tree2369 16 Posted June 28, 2024 Posted June 28, 2024 Just started using Emby as my main PMS and DVR and just ran into this issue while using an Apple TV. Any fix for this? Using xteve with a buffer (ffmpeg) causes channels to ‘lock up’, not sure what else I could try to do.
Luke 42241 Posted July 1, 2024 Posted July 1, 2024 On 6/28/2024 at 8:01 AM, tree2369 said: Just started using Emby as my main PMS and DVR and just ran into this issue while using an Apple TV. Any fix for this? Using xteve with a buffer (ffmpeg) causes channels to ‘lock up’, not sure what else I could try to do. HI, we are working on improving this. Thanks for the feedback. 1
