SalluMe10 0 Posted May 31, 2022 Posted May 31, 2022 (edited) I was following this tutorial This is how I installed the service: and when I try to start the service I get this error. I would appreciate any help Edited May 31, 2022 by SalluMe10
Luke 42234 Posted May 31, 2022 Posted May 31, 2022 Hi, this is a newer one I would suggest following instead:
SalluMe10 0 Posted May 31, 2022 Author Posted May 31, 2022 this is how I fixed this problem for my machine: when I tried to run run nginx.exe it gave me an error saying that the "MSVCR100.dll", so I simply fixed this issue by adding the dll is MSVCR100.dll (64-Bit) in System32 folder and also adding MSVCR100.dll (32-Bit) in SysWOW64 folder, since my machine is 64-bit. For people using 32-bit machine can simply download the MSVCR100.dll (32-Bit) and add it System32 folder.
