Dzintars 2 Posted May 29, 2022 Posted May 29, 2022 I'm Emby premiere user now for few months. I too hope there will be option for Audio syncing settings in Emby, ASAP. I'm especially looking for such an option in Emby Theater. If that would be possible using Keyboard shorcuts, that would be great. Using external player (which can adjust audio sync) with Emby Theater is not an option - too much annoying bugs and problems. 1
Dzintars 2 Posted May 30, 2022 Author Posted May 30, 2022 My post was moved from other thread and I can't edit it's contents to make it look OK. My post is not about fixing bug in Emby Theatre, but about feature to be able to adjust audio sync during playback when it is necessary. There are a lot of cases when media audio sync is not OK, so there should be way to fix it manually - using keyboard shortcuts or through menu.
Luke 42234 Posted May 31, 2022 Posted May 31, 2022 Quote to be able to adjust audio sync during playback when it is necessary. Hi, yes this is certainly possible for future updates. Thanks for the feedback. 2
ninefast 1 Posted August 19, 2023 Posted August 19, 2023 it's 2023 and has this feature been implemented? 1
Luke 42234 Posted September 7, 2023 Posted September 7, 2023 You just need a configurable audio delay? 2
lukmcd 2 Posted September 7, 2023 Posted September 7, 2023 It would amazing, sometimes files aren’t synced perfectly, it’s probably the feature I miss most from plex. Being able to in the app advance or slow the audio. 1 1
hukt_own_fonikz 10 Posted October 10, 2023 Posted October 10, 2023 I agree, being able to offset audio would be a great feature. 1 1
CouchPotato4649 1 Posted January 12, 2024 Posted January 12, 2024 Curious if this feature was implemented. I am also very interested in something like this.
lukmcd 2 Posted January 12, 2024 Posted January 12, 2024 Yours is the first update I’ve seen to the initial post.
CouchPotato4649 1 Posted January 12, 2024 Posted January 12, 2024 First post was in May 2022. Next ask was in August 2023. Then you and Luke 3 weeks later. Then hukt 1 month later. Now me 3 months later. So, not sure I follow you in the "initial" post thing. Are you still interested in this feature?
lukmcd 2 Posted January 12, 2024 Posted January 12, 2024 I still think it would be helpful, I have changed hardware for the stereo and now have an adjustable delay so I CAN fix an issue but it would be great to do it in app rather than getting the other remote out and changing for a single video.
AndaPlays 5 Posted January 25, 2024 Posted January 25, 2024 I would also like a feature like this. Sometimes Audio is not in sync and I literally have to change the file itself. This is really annoying If I‘m not home where I could change It… 1
Vahn84 1 Posted February 16, 2024 Posted February 16, 2024 (edited) I need this feat. I’ve a bunch of high quality media files with audio sync issues…and I don’t know how to fix them Edited February 16, 2024 by Vahn84 1
kwirky88 6 Posted May 17, 2024 Posted May 17, 2024 Being able to delay the audio would be amazing for me. My home theater receiver maxes out at a 200ms audio delay but my Sony OLED has more than 200ms of video delay (when not in game mode), so I can never get the audio and video in sync for all content. This has got to be a problem for others with Sony OLED tvs. For example, my standalone 4k bluray player has dual HDMI output so that one can go to the TV and the other to the home theater, to help with audio sync issues, but even on that, the Sony OLED introduces more than 200ms of video delay. Sony's not an uncommon brand and they don't have boatloads of OLED models to choose from. The benefit of this would be for quite a few people, by my estimate. If this were implemented I'd finally have a home theatre which beats out the local movie theatres. 1
Guest Posted May 18, 2024 Posted May 18, 2024 (edited) Just make an mpv.conf and add it. https://mpv.io/manual/master/#files-on-windows https://mpv.io/manual/master/#options-audio-delay Edited May 18, 2024 by generiq
GabbiKat 1 Posted May 24, 2024 Posted May 24, 2024 Interested in this feature also. Something similar to what VLC has where there is a tab for audio delay in ms. 1
kwirky88 6 Posted June 20, 2024 Posted June 20, 2024 On 18/05/2024 at 09:42, generiq said: Just make an mpv.conf and add it. https://mpv.io/manual/master/#files-on-windows https://mpv.io/manual/master/#options-audio-delay That doesn't work on android tv (nvidia shield), does it?
Guest Posted June 22, 2024 Posted June 22, 2024 On 6/20/2024 at 2:39 PM, kwirky88 said: That doesn't work on android tv (nvidia shield), does it? If using mpv, it could. Is the Shield app still using mpv? This question is best answered by @ebr I haven't played around with that in a long time
Luke 42234 Posted June 23, 2024 Posted June 23, 2024 6 hours ago, generiq said: If using mpv, it could. Is the Shield app still using mpv? This question is best answered by @ebr I haven't played around with that in a long time No, it is using exoplayer.
andyespi 5 Posted June 24, 2024 Posted June 24, 2024 Thank you for a great product. I am a paying monthly subscriber. I use an XGIMI projector which has Android built in, and when sending audio to my receiver using eARC, the audio gets delayed - probably in passthru processing, etc., etc. Running audio directly thru the XGIMI speakers results in good sync, so no problem with Emby. I solve this in Kodi by setting 250ms audio difference, and apply to all. I wish I could do the same with Emby (delay video vs audio, or advance audio from video). Therefore I too wish for this feature. Thanks/Andy 1
nospotify 187 Posted August 16, 2024 Posted August 16, 2024 Bump. Audio delay is built into many modern TVs, but with limitations and/or awkward UI to use. I am genuinely surprised this isn't already built-in to Emby, perhaps reachable through the same gear menu as zoom, playback speed, etc. Can this be implemented soon?
simonlange1971 3 Posted August 17, 2024 Posted August 17, 2024 (edited) Just to make it clear. Adjusting audio sync is not a new feature, its a mandatory feature which had ti be implemented in the first place. That more than 2y after being reminded that they did miss an essential function, is poor and pathetic in the least, bad support and shows lack of knowledge and/or focus on the job. [redacted]. Edited August 17, 2024 by GrimReaper Language 1
Gryzor 27 Posted August 24, 2024 Posted August 24, 2024 +1. This is such a basic and very needed feature, and so many run of the mill players have it. I don't understand how this hasn't been a feature for al ong time now.
beens 9 Posted September 4, 2024 Posted September 4, 2024 +1 I need this feature. It's impossible to sync the audio with some devices when using external audio gear that can't be fed by the TV's audio output, especially when using a TV that doesn't support HDMI or have an audio passthrough. 1
