broskratos 0 Posted May 29, 2022 Posted May 29, 2022 Hello, I have exact same problem This site can’t be reached 11.1.1.7 refused to connect. Try: Checking the connection Checking the proxy and the firewall ERR_CONNECTION_REFUSED I use local IP, and have no problems to access it on web.
broskratos 0 Posted May 29, 2022 Posted May 29, 2022 Hello, I have a problem This site can’t be reached 11.1.1.7 refused to connect. Try: Checking the connection Checking the proxy and the firewall ERR_CONNECTION_REFUSED I use local IP, and have no problems to access it on web. Emby server started.
keithsrobertson 11 Posted May 29, 2022 Posted May 29, 2022 Did u try specifying the port that Emby Server is using? Mine is http://192.168.1.2:8096 I guess you can try http://11.1.1.7:8096 Also you may need to add an entry in your Qnap firewall to allow connection from local lan
broskratos 0 Posted May 29, 2022 Posted May 29, 2022 Thank for your reply, but it is indeed port 8096, and lan, with no firewall.
Luke 42239 Posted May 31, 2022 Author Posted May 31, 2022 Hi, what model QNAP? What package file did you install?
Luke 42239 Posted May 31, 2022 Author Posted May 31, 2022 12 hours ago, broskratos said: Latest pakage, qnap tvs882 What was the package file name?
Luke 42239 Posted June 1, 2022 Author Posted June 1, 2022 9 hours ago, broskratos said: emby-server-qnap_4.7.1.0_x86_64.qpkg Can you download it again from our website and install on top of your existing version? Thanks.
keithsrobertson 11 Posted June 2, 2022 Posted June 2, 2022 You can access it locally on lan? but not via an ip address externally? Is ip address external a static ip address or a dynamic one? Quote I use local IP, and have no problems to access it on web You access local lan of your qnap server via web browser? but cant access the emby server. Did you click start on the emby server app? did you try clicking open when it has started? did you check the box to ignore certificate errors, and/or ignore that in security counselor (if its relevant)? I have the TS-453A running version 5.0.0.1986 of qnap os. I have the 4.8.0.0 Beta of the Emby app installed. I access my qnap on local lan via http://192.168.1.2:8080 and the emby server at http://192.168.1.2:8096
broskratos 0 Posted June 2, 2022 Posted June 2, 2022 Yes, all above I have done, also I do not want to access it externally, only on LAN. I have all default ports, I can access my QNAP on LAN no problems on port 8080, but EMBY port 8096 connection refused.
broskratos 0 Posted June 2, 2022 Posted June 2, 2022 Installed emby-server-qnap_4.8.0.0_x86_64.qpkg .... same.
keithsrobertson 11 Posted June 3, 2022 Posted June 3, 2022 Only useful thing I found in relation to that ERR_CONNECTION_REFUSED is this: https://wpastra.com/fix-err-connection-refused-error/ Might be worth going through that list to check if anything needs attention. Hopefully something will work.
Luke 42239 Posted June 3, 2022 Author Posted June 3, 2022 I think the issue is the server is crashing on this QNAP model. Is any emby server log file generated under /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata/logs ?
