fran6v 0 Posted May 28, 2022 Posted May 28, 2022 I have tried multiple solutions but none seem to work. When setting up Emby with my various libraries, I can see the directories I need on the NAS, but they are rejected. Of course previous to this I had setup the emby user with the approriate privilegeson those drives. I am now using a PC as an Emby server, and will wait till a solution is found.
fran6v 0 Posted May 28, 2022 Author Posted May 28, 2022 I mean they are shows in the selection window when creating a mediatech but Emby refuses to validate the path, probably not the right privileges. Never had any such issue with DSM 6. I and so far I have not found anything on ths topic in the Emby installation guide. Thanks for your help
FrostByte 5454 Posted May 28, 2022 Posted May 28, 2022 19 minutes ago, fran6v said: I mean they are shows in the selection window when creating a mediatech but Emby refuses to validate the path, probably not the right privileges. Never had any such issue with DSM 6. I and so far I have not found anything on ths topic in the Emby installation guide. Thanks for your help Are you sure you set up permissions on the shared folder? It sounds like they aren't correct according to your description.
FrostByte 5454 Posted May 28, 2022 Posted May 28, 2022 Please post a pic of you shared folder permissions from DSM?
FrostByte 5454 Posted May 28, 2022 Posted May 28, 2022 Or, see if this helps. I think this may be where you problem is.
Carlo 4561 Posted May 28, 2022 Posted May 28, 2022 Make sure it's the Internal System User if DSM 7. https://support.emby.media/support/solutions/articles/44002311271-synology-nas If you just upgraded to DSM 7 from DSM 6 and trying Emby again for the first time you need to do the Migration steps mentioned first.
