Spaceboy 2573 Posted May 28, 2022 Posted May 28, 2022 2 minutes ago, Cadkey said: Yes, I have a scan in progress to verify. ah - also you have this option selected in the library config?
Spaceboy 2573 Posted May 28, 2022 Posted May 28, 2022 final question before i tap out and defer to someone with more experience then. not 100% sure this matters but you have both folders added under the same library in emby like so?
Cadkey 54 Posted May 28, 2022 Author Posted May 28, 2022 Yes, the two folders are added in same library 'series'
Spaceboy 2573 Posted May 28, 2022 Posted May 28, 2022 ok - AFAIK it should just work then. perhaps one of the devs can take a look
Cadkey 54 Posted May 28, 2022 Author Posted May 28, 2022 Waiting for 'scan media folder' to finish. It's quite long now with 'scan intro' on a big library.
Cadkey 54 Posted May 28, 2022 Author Posted May 28, 2022 (edited) what do you mean? And another question, all your media are on cloud? Edited May 28, 2022 by Cadkey
Spaceboy 2573 Posted May 28, 2022 Posted May 28, 2022 If you are testing something like this you can just rescan single shows rather than your whole library. Will save you some time. no my media is local but on separate machines. But I don’t think that should make any difference
Cadkey 54 Posted May 28, 2022 Author Posted May 28, 2022 6 minutes ago, Spaceboy said: If you are testing something like this you can just rescan single shows rather than your whole library. Will save you some time. Yes I was too fast and I clicked where it shouldn't be
