LeJacobin 1 Posted May 28, 2022 Posted May 28, 2022 I am using Emby on WD PR4100 and I just upgraded to version 4.7.1.0 and now all I get is the Emby logo. Please help.
alucryd 318 Posted May 29, 2022 Posted May 29, 2022 Is your firmware up to date? What kernel version are you on? The following command via SSH will tell you: uname -a
Luke 42237 Posted June 4, 2022 Posted June 4, 2022 Also can you please try the new Emby Server 4.7.2 release? Thanks.
explor202 4 Posted June 7, 2022 Posted June 7, 2022 On 5/27/2022 at 9:32 PM, LeJacobin said: all I get is the Emby logo. Same issue here after updating to 4.7.2, but a reboot of the PR4100 resolved it.
LeJacobin 1 Posted June 8, 2022 Author Posted June 8, 2022 I installed Emby Server 4.7.2 release as per @Luke advice and Emby is working again. Thanks. 1
