rtfibra1991 0 Posted May 27, 2022 Posted May 27, 2022 FIZ UPGRADE DO PLANO PARA 75 DISPOSITIVOS MAIS NAO LIBEROU, O QUE DEVO FAZER? verifiquei que paguei uma chave life time, porem o meu é mensal
Solution ebr 16307 Posted May 27, 2022 Solution Posted May 27, 2022 Hi. Please check your emails. You purchased the incorrect subscription. Since you do not have a Lifetime key, you need to select a monthly option, NOT an upgrade for a Lifetime key option.
