rbjtech 5345 Posted December 28, 2025 Posted December 28, 2025 On 16/11/2025 at 17:14, Luke said: HI, DTS-X and Atmos detection will be coming when we update our ffmpeg build. This will be happening on the server beta channel in the near future, thanks. any news on this please @Luke if emby is detecting these codecs, then I can probably start to sunset the MediaInfo plugin or modify it to just use the Emby built in detection functions without the need for the 3rd party mediaInfo app. Tks.
Luke 42250 Posted December 28, 2025 Posted December 28, 2025 Hi, we are still working on it. Thanks. 1 1
Pejamas 58 Posted January 8 Posted January 8 @rbjtechHaving an issue with DV + HDR files losing the DV in the embedded title, not sure why. 2026-01-09 07:57:36.344 Debug SqliteItemRepository: GetitemById Movie 353153 J:\Parasite (2019)\Parasite (2019).mkv 2026-01-09 07:57:36.344 Info Media Info: Parasite with ITEM ID: 353153 will be reprocessed 2026-01-09 07:57:36.344 Debug Media Info: No of mediasources found = 1 2026-01-09 07:57:36.344 Info Media Info: 353153 ITEM ID has been removed from processed list and new MediaInfo Titles will be generated 2026-01-09 07:57:36.344 Info Media Info: MediaInfo Individual ID list has been cleared 2026-01-09 07:57:36.364 Info Media Info: Actual Items to process = 1 2026-01-09 07:57:36.364 Info Media Info: PERFORMING MEDIAINFO EXTRACTION 2026-01-09 07:57:36.364 Info Media Info: PROCESSING OF Parasite HAS STARTED 2026-01-09 07:57:36.364 Info Media Info: Item FilePath = J:\Parasite (2019)\Parasite (2019).mkv 2026-01-09 07:57:36.364 Debug Media Info: Starting MediaInfo.exe process 2026-01-09 07:57:36.364 Debug Media Info: using MediaSource Path: J:\Parasite (2019)\Parasite (2019).mkv 2026-01-09 07:57:36.364 Debug Media Info: Args= --Output=JSON "J:\Parasite (2019)\Parasite (2019).mkv" 2026-01-09 07:57:36.364 Debug Media Info: MediaInfoCLI Path = E:\Emby Media Info\MediaInfo.exe 2026-01-09 07:57:36.364 Debug Media Info: about to start Media Info Actual process for debug purposes only 2026-01-09 07:57:36.402 Debug SessionsService-0HNIEU8R5LVFQ:00000001: http/1.1 GET http://192.168.1.147:8096/Sessions. Source Ip: 192.168.1.147, UserAgent: node 2026-01-09 07:57:36.402 Debug AuthenticationRepository: GetInternalId reportedDeviceId: tracearr-server 2026-01-09 07:57:36.402 Debug SessionsService-0HNIEU8R5LVFQ:00000001: http/1.1 Response 200 to 192.168.1.147. Time: 1ms. GET http://192.168.1.147:8096/Sessions. 2026-01-09 07:57:36.829 Debug Media Info: Reset Embedded Titles = False 2026-01-09 07:57:36.862 Debug Media Info: ********* REFERENCE ITEM = J:\Parasite (2019)\Parasite (2019).mkv 2026-01-09 07:57:36.862 Debug Media Info: GENERAL INFO 2026-01-09 07:57:36.862 Debug Media Info: Video Tracks = 1 2026-01-09 07:57:36.862 Debug Media Info: Audio Tracks = 1 2026-01-09 07:57:36.862 Debug Media Info: Subtitle Tracks = 2 2026-01-09 07:57:36.862 Debug Media Info: Overall Bitrate = 20398163 2026-01-09 07:57:36.862 Debug Media Info: ********************* 2026-01-09 07:57:36.862 Debug Media Info: VIDEO INFO 2026-01-09 07:57:36.862 Debug Media Info: Track Format = HEVC 2026-01-09 07:57:36.862 Debug Media Info: BitRate = 19615856 2026-01-09 07:57:36.862 Debug Media Info: Height =1604 2026-01-09 07:57:36.862 Debug Media Info: Width =3840 2026-01-09 07:57:36.863 Debug Media Info: Aspect Ration =2.394 2026-01-09 07:57:36.863 Debug Media Info: HDR Format =Dolby Vision 2026-01-09 07:57:36.863 Debug Media Info: HDR Format Profile =dvhe.08 2026-01-09 07:57:36.863 Debug Media Info: HDR Compatibility = 2026-01-09 07:57:36.863 Debug Media Info: ********************* 2026-01-09 07:57:36.863 Debug Media Info: Show HDR Value with DV = True 2026-01-09 07:57:36.980 Debug LibraryMonitor: Change detected to J:\Parasite (2019)\Parasite (2019).mkv 2026-01-09 07:57:36.980 Debug LibraryMonitor: New file refresher created for J:\Parasite (2019)\Parasite (2019).mkv 2026-01-09 07:57:36.981 Info Media Info: Video Track successfully Written & Exited with Code 0 2026-01-09 07:57:36.981 Info Media Info: Video Track Title Set to UHD HEVC [19.6Mb/s] 2026-01-09 07:57:36.990 Debug App: Saving nfo metadata for J:\Parasite (2019)\Parasite (2019).mkv to J:\Parasite (2019)\Parasite (2019).nfo.
rbjtech 5345 Posted January 9 Posted January 9 12 hours ago, Pejamas said: @rbjtechHaving an issue with DV + HDR files losing the DV in the embedded title, not sure why. 2026-01-09 07:57:36.344 Debug SqliteItemRepository: GetitemById Movie 353153 J:\Parasite (2019)\Parasite (2019).mkv 2026-01-09 07:57:36.344 Info Media Info: Parasite with ITEM ID: 353153 will be reprocessed 2026-01-09 07:57:36.344 Debug Media Info: No of mediasources found = 1 2026-01-09 07:57:36.344 Info Media Info: 353153 ITEM ID has been removed from processed list and new MediaInfo Titles will be generated 2026-01-09 07:57:36.344 Info Media Info: MediaInfo Individual ID list has been cleared 2026-01-09 07:57:36.364 Info Media Info: Actual Items to process = 1 2026-01-09 07:57:36.364 Info Media Info: PERFORMING MEDIAINFO EXTRACTION 2026-01-09 07:57:36.364 Info Media Info: PROCESSING OF Parasite HAS STARTED 2026-01-09 07:57:36.364 Info Media Info: Item FilePath = J:\Parasite (2019)\Parasite (2019).mkv 2026-01-09 07:57:36.364 Debug Media Info: Starting MediaInfo.exe process 2026-01-09 07:57:36.364 Debug Media Info: using MediaSource Path: J:\Parasite (2019)\Parasite (2019).mkv 2026-01-09 07:57:36.364 Debug Media Info: Args= --Output=JSON "J:\Parasite (2019)\Parasite (2019).mkv" 2026-01-09 07:57:36.364 Debug Media Info: MediaInfoCLI Path = E:\Emby Media Info\MediaInfo.exe 2026-01-09 07:57:36.364 Debug Media Info: about to start Media Info Actual process for debug purposes only 2026-01-09 07:57:36.402 Debug SessionsService-0HNIEU8R5LVFQ:00000001: http/1.1 GET http://192.168.1.147:8096/Sessions. Source Ip: 192.168.1.147, UserAgent: node 2026-01-09 07:57:36.402 Debug AuthenticationRepository: GetInternalId reportedDeviceId: tracearr-server 2026-01-09 07:57:36.402 Debug SessionsService-0HNIEU8R5LVFQ:00000001: http/1.1 Response 200 to 192.168.1.147. Time: 1ms. GET http://192.168.1.147:8096/Sessions. 2026-01-09 07:57:36.829 Debug Media Info: Reset Embedded Titles = False 2026-01-09 07:57:36.862 Debug Media Info: ********* REFERENCE ITEM = J:\Parasite (2019)\Parasite (2019).mkv 2026-01-09 07:57:36.862 Debug Media Info: GENERAL INFO 2026-01-09 07:57:36.862 Debug Media Info: Video Tracks = 1 2026-01-09 07:57:36.862 Debug Media Info: Audio Tracks = 1 2026-01-09 07:57:36.862 Debug Media Info: Subtitle Tracks = 2 2026-01-09 07:57:36.862 Debug Media Info: Overall Bitrate = 20398163 2026-01-09 07:57:36.862 Debug Media Info: ********************* 2026-01-09 07:57:36.862 Debug Media Info: VIDEO INFO 2026-01-09 07:57:36.862 Debug Media Info: Track Format = HEVC 2026-01-09 07:57:36.862 Debug Media Info: BitRate = 19615856 2026-01-09 07:57:36.862 Debug Media Info: Height =1604 2026-01-09 07:57:36.862 Debug Media Info: Width =3840 2026-01-09 07:57:36.863 Debug Media Info: Aspect Ration =2.394 2026-01-09 07:57:36.863 Debug Media Info: HDR Format =Dolby Vision 2026-01-09 07:57:36.863 Debug Media Info: HDR Format Profile =dvhe.08 2026-01-09 07:57:36.863 Debug Media Info: HDR Compatibility = 2026-01-09 07:57:36.863 Debug Media Info: ********************* 2026-01-09 07:57:36.863 Debug Media Info: Show HDR Value with DV = True 2026-01-09 07:57:36.980 Debug LibraryMonitor: Change detected to J:\Parasite (2019)\Parasite (2019).mkv 2026-01-09 07:57:36.980 Debug LibraryMonitor: New file refresher created for J:\Parasite (2019)\Parasite (2019).mkv 2026-01-09 07:57:36.981 Info Media Info: Video Track successfully Written & Exited with Code 0 2026-01-09 07:57:36.981 Info Media Info: Video Track Title Set to UHD HEVC [19.6Mb/s] 2026-01-09 07:57:36.990 Debug App: Saving nfo metadata for J:\Parasite (2019)\Parasite (2019).mkv to J:\Parasite (2019)\Parasite (2019).nfo. Hmm - that's strange. Can you show the MediaInfo json output from that file ? (use MediaInfo GUI version, then go into View and post the JSOn output. The reason I'm asking - is DV8 usually detects with the first line below and has HDR10 compatibility - according to the log, yours does not - thus it is not picking it up as DV8. An example below on what DV8 should look like : "HDR_Format":"Dolby Vision / SMPTE ST 2086", "HDR_Format_Version":"1.0 / ", "HDR_Format_Profile":"dvhe.08 / ", "HDR_Format_Level":"06 / ", "HDR_Format_Settings":"BL+RPU / ", "HDR_Format_Compression":"None / ", "HDR_Format_Compatibility":"HDR10 / HDR10",
kaledi 42 Posted March 10 Posted March 10 Think I'm having a similar issue. Recently migrated my Emby server that I use this plug in with from Windows 11 to another Windows 11 machine. Everything went fine and the plug in works. However very oddly, for DV 8.1 files, it doesn't write that information. It does Fort DV7, HDR10+ etc, but not DV8.1. It just writes UHD (bitrate). I've also just realised it is not correctly writing if it is a hybrid DV HDR10+ file. Any ideas? Where is the latest version for the plug in available to download?
rbjtech 5345 Posted March 11 Posted March 11 16 hours ago, kaledi said: Think I'm having a similar issue. Recently migrated my Emby server that I use this plug in with from Windows 11 to another Windows 11 machine. Everything went fine and the plug in works. However very oddly, for DV 8.1 files, it doesn't write that information. It does Fort DV7, HDR10+ etc, but not DV8.1. It just writes UHD (bitrate). I've also just realised it is not correctly writing if it is a hybrid DV HDR10+ file. Any ideas? Where is the latest version for the plug in available to download? Hi - As per the post above, can you provide the JSON output and I'll take a look. Use the MediaInfo GUI version to get the JSON output from the file in question - this is what the Plugin reads to determine the codecs.
rbjtech 5345 Posted March 12 Posted March 12 11 hours ago, kaledi said: Here you go DV example.json 11.46 kB · 0 downloads Thanks. Checking the code - the strange new format from mediaInfo (it says SMPTE ST 2086 twice for some reason) was already fixed - so maybe I just didn't publish the fix .. "HDR_Format":"Dolby Vision / SMPTE ST 2086 / SMPTE ST 2086", "HDR_Format_Version":"1.0 / ", "HDR_Format_Profile":"dvhe.08 / ", "HDR_Format_Level":"06 / ", "HDR_Format_Settings":"BL+RPU / ", "HDR_Format_Compression":"None / ", "HDR_Format_Compatibility":"HDR10 / HDR10 / HDR10", Save the previous DLL - below is the latest DLL version that I reviewed the code for - this is the very latest but please test on a sample first. v1.0.2.1 Emby.MediaInfo.dll
kaledi 42 Posted March 12 Posted March 12 Thanks - will try this tonight. The strange thing is that the migration from one PC to another involved me restoring an existing emby back up and the mediainfo files were directly transfered - i.e. same versions. Therefore, I can't see why this should have changed. The one application that may have updated was handbrake and wonde if this is the cause - it has been the cause of previous issues (if I recall correct), by inserting multiple flags for the same thing in the same field e.g. HDR HDR HDR
rbjtech 5345 Posted March 12 Posted March 12 1 hour ago, kaledi said: Thanks - will try this tonight. The strange thing is that the migration from one PC to another involved me restoring an existing emby back up and the mediainfo files were directly transfered - i.e. same versions. Therefore, I can't see why this should have changed. The one application that may have updated was handbrake and wonde if this is the cause - it has been the cause of previous issues (if I recall correct), by inserting multiple flags for the same thing in the same field e.g. HDR HDR HDR The Plugin uses two external apps - mediainfo (command line) and mkvtoolnix. It's possible the version of mediainfo that you are/were using is/was different, thus the issue - but the DLL version I posted above, caters for both the old format and new, so it should not matter what version of mediainfo you are using. Can you also let me know what version of mediainfo you are using ? Tks. 1
Gaevonn 2 Posted March 13 Posted March 13 23 hours ago, rbjtech said: Thanks. Checking the code - the strange new format from mediaInfo (it says SMPTE ST 2086 twice for some reason) was already fixed - so maybe I just didn't publish the fix .. "HDR_Format":"Dolby Vision / SMPTE ST 2086 / SMPTE ST 2086", "HDR_Format_Version":"1.0 / ", "HDR_Format_Profile":"dvhe.08 / ", "HDR_Format_Level":"06 / ", "HDR_Format_Settings":"BL+RPU / ", "HDR_Format_Compression":"None / ", "HDR_Format_Compatibility":"HDR10 / HDR10 / HDR10", Save the previous DLL - below is the latest DLL version that I reviewed the code for - this is the very latest but please test on a sample first. v1.0.2.1 Emby.MediaInfo.dll 504 kB · 3 downloads I was testing this on my end and found a strange error, where it updates the General Title field to say the "Folder name - se - title", where before it did not touch this field and only updated the Video Track and Audio Track title fields, in my setup. Was this intended? I tried updating the MediaInfo and even used a current version of mkpropedit (vs the v70 i have been using), but it still changes that Title field. I swapped back for now and after correcting that field, it is not updating it after setting it for reprocessing. 1
rbjtech 5345 Posted March 13 Posted March 13 (edited) 46 minutes ago, Gaevonn said: I was testing this on my end and found a strange error, where it updates the General Title field to say the "Folder name - se - title", where before it did not touch this field and only updated the Video Track and Audio Track title fields, in my setup. Was this intended? I tried updating the MediaInfo and even used a current version of mkpropedit (vs the v70 i have been using), but it still changes that Title field. I swapped back for now and after correcting that field, it is not updating it after setting it for reprocessing. Hmm - I added this to my own version about 6 months ago to get a consistent (with Emby) MKV General|Movie Name for both TV Episodes and Movies - the version I uploaded above now contains this. (v1.0.2.1) I agree this should be a toggle/option - so I'll add this and release a new version over the weekend. Default will be off. FYI For Movies - it sets the MKV General|Movie Name to : Emby Movie Name + (Production Year) - ie Alien (1979) For Episodes - it sets the MKV General|Movie Name to : Show/Series Name + (Original Production Year) + Season# + Episode# + Episode Name - ie Young Sherlock (2026) - s1e8 - The Case of Beatrice Holmes Edited March 13 by rbjtech
rbjtech 5345 Posted March 14 Posted March 14 On 13/03/2026 at 09:52, rbjtech said: Hmm - I added this to my own version about 6 months ago to get a consistent (with Emby) MKV General|Movie Name for both TV Episodes and Movies - the version I uploaded above now contains this. (v1.0.2.1) I agree this should be a toggle/option - so I'll add this and release a new version over the weekend. Default will be off. FYI For Movies - it sets the MKV General|Movie Name to : Emby Movie Name + (Production Year) - ie Alien (1979) For Episodes - it sets the MKV General|Movie Name to : Show/Series Name + (Original Production Year) + Season# + Episode# + Episode Name - ie Young Sherlock (2026) - s1e8 - The Case of Beatrice Holmes @Gaevonn I've now added this as an option rather than just overwrite it .. If you don't enable the option highlighted below (default is Off) then it will keep the previous MKV General Title value. You may need to clear the cache to load the new js. v 1.0.2.2 Emby.MediaInfo.dll 1
Gaevonn 2 Posted March 15 Posted March 15 (edited) Thanks, I have tried the 1.0.2.2 version. With the slider not engaged, it works as it did before, only updating the Video and Sound Track Titles (per my config). It still renames the General Tile to the wrong thing; however, when the slider is engaged. I am including examples. Thanks all the work on this. Unchanged-General-Title-The Rip (2026).mkv.MediaInfo.txt Wrong-General-Tile-The Rip (2026).mkv.MediaInfo.txt Edited March 15 by Gaevonn forgot a line
MagicDoubleM 121 Posted March 15 Posted March 15 Mega random thought here... How about a executable version of this, so one could integrate it into other tools (like tdarr) as well?
rbjtech 5345 Posted March 16 Posted March 16 21 hours ago, Gaevonn said: Thanks, I have tried the 1.0.2.2 version. With the slider not engaged, it works as it did before, only updating the Video and Sound Track Titles (per my config). It still renames the General Tile to the wrong thing; however, when the slider is engaged. I am including examples. Thanks all the work on this. Unchanged-General-Title-The Rip (2026).mkv.MediaInfo.txt 5.87 kB · 1 download Wrong-General-Tile-The Rip (2026).mkv.MediaInfo.txt 5.88 kB · 1 download Tks - I guess the main issue of not being able to turn it off is fixed, but I'll take another look on the logic. I can see the issue (thanks for the example) as you are using multiple layers of folders, so it's using the Parent folder as the name not the folder itself.
Gaevonn 2 Posted March 18 Posted March 18 On 16/03/2026 at 19:05, rbjtech said: Tks - I guess the main issue of not being able to turn it off is fixed, but I'll take another look on the logic. I can see the issue (thanks for the example) as you are using multiple layers of folders, so it's using the Parent folder as the name not the folder itself. Hi and Thanks again. I apologize if it seemed I was not acknowledging the main issue resolution. I appreciate the work and can validate that turning it of makes all the difference while this secondary issue exists. I am happy that you can see the weirdness in the General Title field. If you need me to test anything, let me know. We all appreciate the continued support of this plugin. 1
MagicDoubleM 121 Posted Monday at 12:15 PM Posted Monday at 12:15 PM On 3/14/2026 at 4:07 PM, rbjtech said: @Gaevonn I've now added this as an option rather than just overwrite it .. If you don't enable the option highlighted below (default is Off) then it will keep the previous MKV General Title value. You may need to clear the cache to load the new js. v 1.0.2.2 Emby.MediaInfo.dll 505.5 kB · 6 downloads This is pretty interesting. What immediately comes to mind is the idea of populating a few mkv-tags along the way, basically the stuff that mkv-tag-manager does. Okay, I know the way out.
