Cheesegeezer 3106 Posted May 31, 2022 Author Posted May 31, 2022 5 minutes ago, FrostByte said: DV5 appears correct, no HDR10 compatibility added Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5@High HDR format : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU Codec ID : V_MPEGH/ISO/HEVC Duration : 42 min 24 s Bit rate : 15.7 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 24.000 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Bits/(Pixel*Frame) : 0.079 Stream size : 4.65 GiB (95%) Title : 4K DV5 HEVC Default : No Forced : No Color range : Full Can you check HLG also please
FrostByte 5456 Posted May 31, 2022 Posted May 31, 2022 Quick check of different codecs and I don't see any issues. Default flag is working too. All seems good on my end 2
Cheesegeezer 3106 Posted May 31, 2022 Author Posted May 31, 2022 5 minutes ago, FrostByte said: Quick check of different codecs and I don't see any issues. Default flag is working too. All seems good on my end Is HLG working?
FrostByte 5456 Posted May 31, 2022 Posted May 31, 2022 Oops, forgot about HLG. Looks like it's working Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@Main Codec ID : V_MPEGH/ISO/HEVC Duration : 53 min 14 s Bit rate : 18.7 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 25.000 FPS Standard : Component Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Bits/(Pixel*Frame) : 0.090 Stream size : 6.95 GiB (94%) Title : 4K HLG HEVC Default : Yes Forced : No Color range : Limited Color primaries : BT.2020 Transfer characteristics : HLG transfer_characteristics_Original : HLG / BT.2020 (10-bit) Matrix coefficients : BT.2020 non-constant 1
Cheesegeezer 3106 Posted May 31, 2022 Author Posted May 31, 2022 24 minutes ago, FrostByte said: Oops, forgot about HLG. Looks like it's working Excellent stuff! Thanks again Frosty! Your input has be repeatedly invaluable
MagicDoubleM 121 Posted May 31, 2022 Posted May 31, 2022 Two little bugs, there is a space missing before the geeky stuff and some dolby tracks seem to be too shy to show their bitrate, even though they're 24.
Cheesegeezer 3106 Posted May 31, 2022 Author Posted May 31, 2022 1 minute ago, MagicDoubleM said: Two little bugs, there is a space missing before the geeky stuff and some dolby tracks seem to be too shy to show their bitrate, even though they're 24. Nice catch for the space. As for bitDepth not sure if there is limitations to number of characters in different clients. If you ditch the Default tag do they show? In the log.. debug on .. you can see what the embedded title is output as
Cheesegeezer 3106 Posted May 31, 2022 Author Posted May 31, 2022 (edited) @MagicDoubleM i fixed the spacing issue. but i didn't do anything else, the bitrate and bitdepth are showing fine in Web and on Emby Theatre. I guess you are using these settings? NEW DLL ON FIRST POST AGAIN Also all the Emphasised colors now come from your Accent color from your Server Theme. Edited May 31, 2022 by Cheesegeezer
MagicDoubleM 121 Posted May 31, 2022 Posted May 31, 2022 7 minutes ago, Cheesegeezer said: @MagicDoubleM i fixed the spacing issue. but i didn't do anything else, the bitrate and bitdepth are showing fine in Web and on Emby Theatre. I guess you are using these settings? NEW DLL ON FIRST POST AGAIN Also all the Emphasised colors now come from your Accent color from your Server Theme. Yes, those are exactly the settings I use for now. 24bit shows up for some, but then for others not, haven't found an obvious reason for now.
Cheesegeezer 3106 Posted May 31, 2022 Author Posted May 31, 2022 4 minutes ago, MagicDoubleM said: Yes, those are exactly the settings I use for now. 24bit shows up for some, but then for others not, haven't found an obvious reason for now. I would double check mediaInfo gui for those files
FrostByte 5456 Posted May 31, 2022 Posted May 31, 2022 If not too late, is it possible to only write (Default) if there are more than one audio track? Doesn't really make sense to have (Default) when there is only one.
MagicDoubleM 121 Posted June 1, 2022 Posted June 1, 2022 9 hours ago, Cheesegeezer said: I would double check mediaInfo gui for those files Good point, they're indeed 16bit. Emby seems to get it wrong here. So only 24bit is supposed to show up? I ask, because i have a movie with a DTS 2.0 track that gets tagged with 16-bit, others don't. Also found a 4k file with a slightly off resolution (3836x1912) that doesn't get recognized as 4k. Similar to those earlier mentioned HD-movies. 1
Cheesegeezer 3106 Posted June 1, 2022 Author Posted June 1, 2022 13 minutes ago, MagicDoubleM said: Good point, they're indeed 16bit. Emby seems to get it wrong here. So only 24bit is supposed to show up? I ask, because i have a movie with a DTS 2.0 track that gets tagged with 16-bit, others don't. That will be down to whether the Bitdepth field is populated or not in the media container and what is in the mediaInfo file. I don’t think i put any conditions in to show only 24-bit or higher, but I’ll double check. 13 minutes ago, MagicDoubleM said: Also found a 4k file with a slightly off resolution (3836x1912) that doesn't get recognized as 4k. Similar to those earlier mentioned HD-movies. Nice catch again. 1
neik 874 Posted June 2, 2022 Posted June 2, 2022 Cheese, any chance to select a specific (test) library to run this? For now, I just found an option to run this on either all movies or all tv shows.
Cheesegeezer 3106 Posted June 2, 2022 Author Posted June 2, 2022 9 minutes ago, neik said: Cheese, any chance to select a specific (test) library to run this? For now, I just found an option to run this on either all movies or all tv shows. you will need to set up your own test library or Emby server instance to test. Sorry 1
MrLinford 62 Posted June 2, 2022 Posted June 2, 2022 I'm running EMBY Server in a Docker and i'm not sure what are the correct MediaInfoCLI and MKVToolNix files to use with this plugin. Anyone able to point me in the correct direction?
Cheesegeezer 3106 Posted June 2, 2022 Author Posted June 2, 2022 3 minutes ago, MrLinford said: I'm running EMBY Server in a Docker and i'm not sure what are the correct MediaInfoCLI and MKVToolNix files to use with this plugin. Anyone able to point me in the correct direction? As long as you have downloaded the MediaInfoCLI you need to select MediaInfo executable MKVToolNix Requires mkvpropedit executable
MrLinford 62 Posted June 2, 2022 Posted June 2, 2022 That the problem I'm sure what one I need for the official EMBY unRIAD docker
neik 874 Posted June 2, 2022 Posted June 2, 2022 30 minutes ago, Cheesegeezer said: you will need to set up your own test library or Emby server instance to test. Sorry No worries. Just one further question: If I start the process and interrupt it to see the created results, will it then pick up where I stopped it? That would already be good enough for me to give it a try.
neik 874 Posted June 2, 2022 Posted June 2, 2022 On 5/29/2022 at 10:20 PM, FrostByte said: It's a type of HDR, but it isn't HDR10. I think it should replace it, maybe rbjtech has an opinion These are the HDR formats I'm aware of DV5,7,8, etc (DV7 and DV8 have a DV and HDR10 layer) HDR10/HDR10+ HLG Hybrid Log Gamma: everything you need to know about HLG HDR | TechRadar Does anyone have a good overview of all the DV/HDR flavours that exist? I didn't know that DV7/8 always have a HDR10 layer addtionally to the DV layer and that is quite interesting tbh.
Cheesegeezer 3106 Posted June 2, 2022 Author Posted June 2, 2022 4 minutes ago, neik said: No worries. Just one further question: If I start the process and interrupt it to see the created results, will it then pick up where I stopped it? That would already be good enough for me to give it a try. Yes, it adds processed items to a list so they are ignored next run. 1
Cheesegeezer 3106 Posted June 2, 2022 Author Posted June 2, 2022 2 minutes ago, neik said: Does anyone have a good overview of all the DV/HDR flavours that exist? I didn't know that DV7/8 always have a HDR10 layer addtionally to the DV layer and that is quite interesting tbh. I can give you a snippet out of the code. it relies on color primaries being bt2020, if they are then it has some variety of hdr in the stream. If bt709 then no hdr and DV5 has no hdr
Cheesegeezer 3106 Posted June 2, 2022 Author Posted June 2, 2022 (edited) @neik HDR Available formats with and without Dolby vision The Case is what is commonly found in the stream and what MediaInfo looks at. The output is our friendly term such as HDR case "SMPTE ST 2086": output = "HDR10"; break; case "SMPTE ST 2086, HDR10 compatible": output = "HDR10"; break; case "SMPTE ST 2094 App 4": output = "HDR10+"; break; case "Dolby Vision / SMPTE ST 2086": output = "DV" + GetHdrFormatProfile(hdrFormatProfile) + " HDR10"; break; case "Dolby Vision / SMPTE ST 2094 App 4": output = "DV" + GetHdrFormatProfile(hdrFormatProfile) + " HDR10+"; break; Edited June 2, 2022 by Cheesegeezer 1
Cheesegeezer 3106 Posted June 2, 2022 Author Posted June 2, 2022 40 minutes ago, MrLinford said: That the problem I'm sure what one I need for the official EMBY unRIAD docker After doing some Googling found this thread Which version of Unix is unRaid based on? - General Support - Unraid Which points to this The Slackware Linux Project: Configuration Help So you should download Slackware Linux MediaInfo MediaInfo - Download MediaInfo for Slackware (mediaarea.net)
