supermood 71 Posted May 14, 2024 Posted May 14, 2024 it worked. many thanks Mr for that add on!!! lib scan now needs also 2h I guess but I checked a movie and the info is there!! really really great!!!
supermood 71 Posted May 14, 2024 Posted May 14, 2024 if I would now see if the dv mkv has fel or not, I would say that add on is the answer to everything
supermood 71 Posted May 14, 2024 Posted May 14, 2024 ah and hey sorry what do I have to do after an docker update? they sending out a new image every week, I have no clue why there are not so many updates on emby side
rbjtech 5345 Posted May 14, 2024 Posted May 14, 2024 Looks good - you set the tag option - once it's finished, you should see all codecs as searchable/filterable options in the Tag dropdown. You 'may' need to do a library scan afterwards, but this may not be necessary. Enjoy. 1
rbjtech 5345 Posted May 14, 2024 Posted May 14, 2024 btw - if you haven't set this already, then I also suggest you do so - as this will display all the track names/formatting you specified in the plugin directly from the MKV files. 1
supermood 71 Posted May 14, 2024 Posted May 14, 2024 both done lib scan went also 1h and embedded is set since yesterday I think I did it (or better Mrlindford did it!!) do you know what to do in case of an upgraded emby docker?
supermood 71 Posted May 14, 2024 Posted May 14, 2024 nobody knows the update commands for me pls? next step for me, difference between true HD atmos and eac3 atmos also for the tags. did I do something wrong? I have the info in the track but not in the tag. there I have atmos one time good night
supermood 71 Posted May 14, 2024 Posted May 14, 2024 that's what I mean with update / new container = updated emby? how to set dependencies?
supermood 71 Posted May 17, 2024 Posted May 17, 2024 In order to reprocess one specific upgraded movie I need the emby movie id. why can I not see that id via browser or Android app. where is it? thanks!!! and why does it have to be so complicated all the time
MrLinford 62 Posted May 18, 2024 Posted May 18, 2024 (edited) On 14/05/2024 at 22:52, supermood said: that's what I mean with update / new container = updated emby? how to set dependencies? Okay, the docker container does not hold the dependencies so with my method you have to run the script every time. @SimCitytook what I did a step further. Check his guide here: https://github.com/SimCity/emby-mediainfo-plugin-prereq This is a Linuxserver Docker Mod, so will run automatically every time the container restarts or updates. Edited May 18, 2024 by MrLinford
supermood 71 Posted May 18, 2024 Posted May 18, 2024 5 hours ago, MrLinford said: Okay, the docker container does not hold the dependencies so with my method you have to run the script every time. @SimCitytook what I did a step further. Check his guide here: https://github.com/SimCity/emby-mediainfo-plugin-prereq This is a Linuxserver Docker Mod, so will run automatically every time the container restarts or updates. thanks. sorry which script was my question. all ssh commands from page 37? or just a few? thanks!!!
MrLinford 62 Posted May 18, 2024 Posted May 18, 2024 25 minutes ago, supermood said: thanks. sorry which script was my question. all ssh commands from page 37? or just a few? thanks!!! I created a script you can run within the container I shared, should be a GitHub link. Run the whole thing. 1
supermood 71 Posted May 18, 2024 Posted May 18, 2024 ah that was the script. many thanks! ähmmm how do I run a script within a container? sorry
supermood 71 Posted May 18, 2024 Posted May 18, 2024 2 hours ago, MrLinford said: I created a script you can run within the container I shared, should be a GitHub link. Run the whole thing. so now there's an Linux emby docker update im still a bit lost. sorry!! my whole container looks exactly like your github compose description (other uid of course..) does that mean I can just update emby now? or do I need to ssh something again? what do you mean with run the whole script? you mean docker compose? but it's already there everything good I'm only talking about an upgrade 1
supermood 71 Posted May 19, 2024 Posted May 19, 2024 upgrade Linux emby docker image / container works without any problems. I didn't do anything and MediaInfo is still working 1
supermood 71 Posted May 27, 2024 Posted May 27, 2024 can someone pls explain how to see the emby id? i only find the external in metadata and google is also not helping
rbjtech 5345 Posted May 27, 2024 Posted May 27, 2024 4 hours ago, supermood said: can someone pls explain how to see the emby id? i only find the external in metadata and google is also not helping Just use a web browser - and the id will be shown there as part of the URL. ie 1
Kyrunner 86 Posted May 27, 2024 Posted May 27, 2024 Would like to try this plugin. Looked through the Wiki does the Emby server need to be running on a Windows local machine? I have my Emby running on Qnap does anyone have any setup guide for Emby on Qnap?
rbjtech 5345 Posted May 27, 2024 Posted May 27, 2024 19 minutes ago, Kyrunner said: Would like to try this plugin. Looked through the Wiki does the Emby server need to be running on a Windows local machine? I have my Emby running on Qnap does anyone have any setup guide for Emby on Qnap? Not sure about Qnap - have a look here - https://github.com/Cheesegeezer/MediaInfoWiki/wiki/Various-OS-Installation-Help
Kyrunner 86 Posted May 27, 2024 Posted May 27, 2024 17 minutes ago, rbjtech said: Not sure about Qnap - have a look here - https://github.com/Cheesegeezer/MediaInfoWiki/wiki/Various-OS-Installation-Help I looked through the Wiki so do I install all the tools on my windows PC and in the Emby server do I put to my PC where the tools are installed
supermood 71 Posted May 27, 2024 Posted May 27, 2024 2 hours ago, rbjtech said: Just use a web browser - and the id will be shown there as part of the URL. ie thanks!! and oh my, should be integrated in the GUI
rbjtech 5345 Posted May 27, 2024 Posted May 27, 2024 1 hour ago, Kyrunner said: I looked through the Wiki so do I install all the tools on my windows PC and in the Emby server do I put to my PC where the tools are installed The tools relevant to your platform need to be installed alongside the emby server. I believe the wiki explains this - if your platform is not there, then unfortunately the external tools are likely not available for that platform.
arsim 1 Posted May 28, 2024 Posted May 28, 2024 (edited) Has anyone had their MKV files corrupted after using this plugin? Out of 6700 files, about 150 had their MKV header corrupted, resulting in the files thinking their is no audio. Luckily I had backups. I thought maybe the original files were corrupt, but I scanned and recreated MKV from the backups and there are no errors. Using Emby 4.8 on Synology DSM 7.2, and latest plugin. Any ideas? Edited May 28, 2024 by arsim
rbjtech 5345 Posted May 28, 2024 Posted May 28, 2024 8 hours ago, arsim said: Has anyone had their MKV files corrupted after using this plugin? Out of 6700 files, about 150 had their MKV header corrupted, resulting in the files thinking their is no audio. Luckily I had backups. I thought maybe the original files were corrupt, but I scanned and recreated MKV from the backups and there are no errors. Using Emby 4.8 on Synology DSM 7.2, and latest plugin. Any ideas? Check the version of mkvpropedit - there was a case a while back where it corrupted the MKV's (not the plugin per say) but we ensured that version was detected and removed. If you have not overwritten the mkvpropedit check, then there is no reports of corrupt MKV's. After the restore, try an individual file to see if you can re-produce. If you can then maybe share one with me (pm) and I'll see if I can re-produce as all the plugin does is pass a command line to mkvpropedit itself to modify the file header title tracks.
supermood 71 Posted June 2, 2024 Posted June 2, 2024 upgrading a movie the plug in works I can see the add info in video and audio track on top, BUT the tags are not maintained / are missing / still empty is this known? am I doing something wrong? lib scan was not helping I had to reprocess the movie
