crusher11 1145 Posted May 31, 2022 Posted May 31, 2022 Rather than having toggles for every little thing, why not let the user string together variables in whichever order they please? Make it a text box, and one user might enter "{{codec}} {{channels}} {{samplerate}}" and get "Dolby Digital 2.0 (48kHz)", and another might enter "{{channels}} {{bitrate}}" and just get "2.0 192kbps", for example. Makes it easy to customise per-user without explicitly having to have a toggle for every variable.
Cheesegeezer 3106 Posted May 31, 2022 Author Posted May 31, 2022 5 minutes ago, crusher11 said: Rather than having toggles for every little thing, why not let the user string together variables in whichever order they please? Make it a text box, and one user might enter "{{codec}} {{channels}} {{samplerate}}" and get "Dolby Digital 2.0 (48kHz)", and another might enter "{{channels}} {{bitrate}}" and just get "2.0 192kbps", for example. Makes it easy to customise per-user without explicitly having to have a toggle for every variable. Because it's Regex and I hate Regex it's like japenese hyroglifics mixed together. But if you would like to code a custom Formatter for me, please be my guest. 1
crusher11 1145 Posted May 31, 2022 Posted May 31, 2022 32 minutes ago, Cheesegeezer said: Because it's Regex and I hate Regex it's like japenese hyroglifics mixed together. But if you would like to code a custom Formatter for me, please be my guest. I don't follow. How does regex fit in?
Cheesegeezer 3106 Posted May 31, 2022 Author Posted May 31, 2022 45 minutes ago, FrostByte said: I need to pop outside for about 30 minutes. I'll take a look as soon as I get back. New dll up on First post I have update the first post on this thread. Please read thru. Download Plugin - Replace plugin in server plugin directory --> Restart Emby Server --> Clear Browser Cache I think this is the final version, however will be up down to how testing goes with Frostbyte
Cheesegeezer 3106 Posted May 31, 2022 Author Posted May 31, 2022 (edited) 9 minutes ago, crusher11 said: I don't follow. How does regex fit in? This is a very small snippit of the code to rename an episode (not as involved as selecting many different fields from a media info, however it is essentally the same as toggles). Anyways - Toggles are staying and there are no plans to add in custom naming conventions. EpisodeExpressions = new[] { // *** Begin Kodi Standard Naming // <!-- foo.s01.e01, foo.s01_e01, S01E02 foo, S01 - E02 --> new EpisodeExpression(@".*(\\|\/)(?<seriesname>((?[][ ._-]*[Ee]([0-9]+))[^\\\/])*)?[Ss](?<seasonnumber>[0-9]+)[][ ._-]*[Ee](?<epnumber>[0-9]+)([^\\/]*)$") { IsNamed = true }, // <!-- foo.ep01, foo.EP_01 --> new EpisodeExpression(@"[\._ -]()[Ee][Pp]_?([0-9]+)([^\\/]*)$"), new EpisodeExpression("([0-9]{4})[\\.-]([0-9]{2})[\\.-]([0-9]{2})", true) { DateTimeFormats = new [] { "yyyy.MM.dd", "yyyy-MM-dd", "yyyy_MM_dd" } }, new EpisodeExpression("([0-9]{2})[\\.-]([0-9]{2})[\\.-]([0-9]{4})", true) { DateTimeFormats = new [] { "dd.MM.yyyy", "dd-MM-yyyy", "dd_MM_yyyy" } }, new EpisodeExpression("[\\\\/\\._ \\[\\(-]([0-9]+)x([0-9]+(?:(?:[a-i]|\\.[1-9])(?![0-9]))?)([^\\\\/]*)$") { SupportsAbsoluteEpisodeNumbers = true }, new EpisodeExpression(@"[\\\\/\\._ -](?<seriesname>(?![0-9]+[0-9][0-9])([^\\\/])*)[\\\\/\\._ -](?<seasonnumber>[0-9]+)(?<epnumber>[0-9][0-9](?:(?:[a-i]|\\.[1-9])(?![0-9]))?)([\\._ -][^\\\\/]*)$") { IsOptimistic = true, IsNamed = true, SupportsAbsoluteEpisodeNumbers = false }, new EpisodeExpression("[\\/._ -]p(?:ar)?t[_. -]()([ivx]+|[0-9]+)([._ -][^\\/]*)$") { SupportsAbsoluteEpisodeNumbers = true }, // *** End Kodi Standard Naming new EpisodeExpression(@".*(\\|\/)[sS]?(?<seasonnumber>\d{1,4})[xX](?<epnumber>\d{1,3})[^\\\/]*$") { IsNamed = true }, new EpisodeExpression(@".*(\\|\/)[sS](?<seasonnumber>\d{1,4})[x,X]?[eE](?<epnumber>\d{1,3})[^\\\/]*$") { IsNamed = true }, new EpisodeExpression(@".*(\\|\/)(?<seriesname>((?![sS]?\d{1,4}[xX]\d{1,3})[^\\\/])*)?([sS]?(?<seasonnumber>\d{1,4})[xX](?<epnumber>\d{1,3}))[^\\\/]*$") { IsNamed = true }, new EpisodeExpression(@".*(\\|\/)(?<seriesname>[^\\\/]*)[sS](?<seasonnumber>\d{1,4})[xX\.]?[eE](?<epnumber>\d{1,3})[^\\\/]*$") { IsNamed = true }, // "01.avi" new EpisodeExpression(@".*[\\\/](?<epnumber>\d{1,3})(-(?<endingepnumber>\d{2,3}))*\.\w+$") { IsOptimistic = true, IsNamed = true }, // "1-12 episode title" new EpisodeExpression(@"([0-9]+)-([0-9]+)") { }, // "01 - blah.avi", "01-blah.avi" new EpisodeExpression(@".*(\\|\/)(?<epnumber>\d{1,3})(-(?<endingepnumber>\d{2,3}))*\s?-\s?[^\\\/]*$") { IsOptimistic = true, IsNamed = true }, // "01.blah.avi" new EpisodeExpression(@".*(\\|\/)(?<epnumber>\d{1,3})(-(?<endingepnumber>\d{2,3}))*\.[^\\\/]+$") { IsOptimistic = true, IsNamed = true }, // "blah - 01.avi", "blah 2 - 01.avi", "blah - 01 blah.avi", "blah 2 - 01 blah", "blah - 01 - blah.avi", "blah 2 - 01 - blah" new EpisodeExpression(@".*[\\\/][^\\\/]* - (?<epnumber>\d{1,3})(-(?<endingepnumber>\d{2,3}))*[^\\\/]*$") { IsOptimistic = true, IsNamed = true }, // "01 episode title.avi" new EpisodeExpression(@"[Ss]eason[\._ ](?<seasonnumber>[0-9]+)[\\\/](?<epnumber>\d{1,3})([^\\\/]*)$") { IsOptimistic = true, IsNamed = true }, // "Episode 16", "Episode 16 - Title" new EpisodeExpression(@".*[\\\/][^\\\/]* (?<epnumber>\d{1,3})(-(?<endingepnumber>\d{2,3}))*[^\\\/]*$") { IsOptimistic = true, IsNamed = true } }; Edited May 31, 2022 by Cheesegeezer
crusher11 1145 Posted May 31, 2022 Posted May 31, 2022 I was figuring you went into MediaInfo, got all the codec details, stored each of them in a variable, then spat the variables out. In which case, what I suggested simply involves changing the order in which you call the variables. I'm not sure why regex would be required, since you would just be overwriting what was there (which should be nothing anyway, right?) with a new thing, instead of replacing certain pieces.
Cheesegeezer 3106 Posted May 31, 2022 Author Posted May 31, 2022 13 minutes ago, crusher11 said: I was figuring you went into MediaInfo, got all the codec details, stored each of them in a variable, then spat the variables out. In which case, what I suggested simply involves changing the order in which you call the variables. I'm not sure why regex would be required, since you would just be overwriting what was there (which should be nothing anyway, right?) with a new thing, instead of replacing certain pieces. As i said, i have no intentions of changing the way it works now. Sorry.
rbjtech 5345 Posted May 31, 2022 Posted May 31, 2022 54 minutes ago, crusher11 said: I was figuring you went into MediaInfo, got all the codec details, stored each of them in a variable, then spat the variables out. In which case, what I suggested simply involves changing the order in which you call the variables. I'm not sure why regex would be required, since you would just be overwriting what was there (which should be nothing anyway, right?) with a new thing, instead of replacing certain pieces. Take a look at what you get from MediaInfo - you explain it like it was an 'easy' thing to take all that conditional info and compress it into a single 'title' per track - it very much isn't an easy thing to do as there are all sorts of if, buts, when's and why's ... Thus you cannot do it 'manually'. 1
crusher11 1145 Posted May 31, 2022 Posted May 31, 2022 47 minutes ago, Cheesegeezer said: As i said, i have no intentions of changing the way it works now. Sorry. I name all my tracks manually (where necessary) so I don't have a dog in this fight, it was just a thought I had is all. 1
FrostByte 5456 Posted May 31, 2022 Posted May 31, 2022 still erroring for tv 2022-05-31 11:54:44.732 Info App: Application version: 4.8.0.02022-05-31 11:54 - Pastebin.com
Cheesegeezer 3106 Posted May 31, 2022 Author Posted May 31, 2022 1 minute ago, FrostByte said: still erroring for tv 2022-05-31 11:54:44.732 Info App: Application version: 4.8.0.02022-05-31 11:54 - Pastebin.com really need the debug info turned on as i've added extra logging. Sorry
Cheesegeezer 3106 Posted May 31, 2022 Author Posted May 31, 2022 Yeah i see, you look at your log, you have got heaps of erros in there and lots of path deletions going on.
FrostByte 5456 Posted May 31, 2022 Posted May 31, 2022 hmm...I'll see if I can get a cleaner log. Movies is running right now and I did a refresh
FrostByte 5456 Posted May 31, 2022 Posted May 31, 2022 ahh, crap. I reran Movies as a refresh again. Be another 10 mins
Cheesegeezer 3106 Posted May 31, 2022 Author Posted May 31, 2022 3 minutes ago, FrostByte said: hmm...I'll see if I can get a cleaner log. Movies is running right now and I did a refresh sure no worries I'm expecting to see this in the log Log.Info("PERFORMING MEDIAINFO EXTRACTION ON TV EPISODES"); and this is the next log line after Actual Episodes to process = 579 the only thing stopping is if (config.EnableTVEpisodes) which is saying if EnableTVEpisodes is enabled, lets do some work.
FrostByte 5456 Posted May 31, 2022 Posted May 31, 2022 When running Movies only I see that line and I can see it adding information. I even checked the files and all was good. However, TV just starts and stops in 2 seconds.
Cheesegeezer 3106 Posted May 31, 2022 Author Posted May 31, 2022 1 minute ago, FrostByte said: When running Movies only I see that line and I can see it adding information. I even checked the files and all was good. However, TV just starts and stops in 2 seconds. i think i've found it 2 secs chief 1
Cheesegeezer 3106 Posted May 31, 2022 Author Posted May 31, 2022 @FrostByte i can re create the fault now, so i will have a fix for you 1
Cheesegeezer 3106 Posted May 31, 2022 Author Posted May 31, 2022 37 minutes ago, FrostByte said: When running Movies only I see that line and I can see it adding information. I even checked the files and all was good. However, TV just starts and stops in 2 seconds. plugin dll is updated in first post. This is fixed now and should work like a charm buddy. Great catch on the bug by the way!!! Thanks 1
FrostByte 5456 Posted May 31, 2022 Posted May 31, 2022 That was it. Appears to be updating now. Thank you 1
Cheesegeezer 3106 Posted May 31, 2022 Author Posted May 31, 2022 1 minute ago, FrostByte said: That was it. Appears to be updating now. Thank you Awesome.... Thanks for your patience. You can turn off Debug logging now lol!! 1
FrostByte 5456 Posted May 31, 2022 Posted May 31, 2022 If anyone else wants to run this on their Synology just add the "SynoCommunity" repository to Package Center and you will see the mediainfo and mkvtoolnix packages to install. CLI only. 1
FrostByte 5456 Posted May 31, 2022 Posted May 31, 2022 DV5 appears correct, no HDR10 compatibility added Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5@High HDR format : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU Codec ID : V_MPEGH/ISO/HEVC Duration : 42 min 24 s Bit rate : 15.7 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 24.000 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Bits/(Pixel*Frame) : 0.079 Stream size : 4.65 GiB (95%) Title : 4K DV5 HEVC Default : No Forced : No Color range : Full 1
