johnrobsonuk 1 Posted March 28, 2023 Posted March 28, 2023 Ah many thanks I use an nvidia shield as my server and also how I watch my files. I can't see a section within the guidelines provided for nvida shield
Cheesegeezer 3106 Posted March 28, 2023 Author Posted March 28, 2023 8 minutes ago, johnrobsonuk said: Ah many thanks I use an nvidia shield as my server and also how I watch my files. I can't see a section within the guidelines provided for nvida shield I think you are the first we have had that uses the shield as a server, hence no instructions yet. Maybe Rich, @rbjtechcan help you as he has one too. Let me have a look also. Did you manage to install the plugin? Now you are stuck on installing mediaInfoCLI and mkvpropedit? if we get this working we will add these to the wiki. cheers
johnrobsonuk 1 Posted March 28, 2023 Posted March 28, 2023 Sorry am just at work I will install the add-on tonight. Wow, nvidia shield is a good server:...I think
Cheesegeezer 3106 Posted March 28, 2023 Author Posted March 28, 2023 1 minute ago, johnrobsonuk said: Sorry am just at work I will install the add-on tonight. Wow, nvidia shield is a good server:...I think I think you might be goosed fella. mediaInfo is available in google play. However, i can only find that mkvtoolnix is only available on mac, pc and linux. Maybe some crazy dood has made a custom version for android and created an apk on a git repo but ill do some more digging. cheers
Cheesegeezer 3106 Posted March 28, 2023 Author Posted March 28, 2023 Quote MKVToolnix Alternatives for Android MKVToolnix is not available for Android but there are a few alternatives with similar functionality. The best Android alternative is Video Transcoder, which is both free and Open Source. If that doesn't work for you, our users have ranked more than 25 alternatives to MKVToolnix, but unfortunately only two of them are available for Android. If you can't find an alternative you can try to remove all filters. MKVToolnix alternatives are mainly Video Convertersbut may also be Audio Converters or Video Editors. Filter by these if you want a narrower list of alternatives or looking for a specific functionality of MKVToolnix. Source - https://alternativeto.net/software/mkvtoolnix/?platform=android
rbjtech 5345 Posted March 28, 2023 Posted March 28, 2023 Just now, Cheesegeezer said: I think you might be goosed fella. mediaInfo is available in google play. However, i can only find that mkvtoolnix is only available on mac, pc and linux. Maybe some crazy dood has made a custom version for android and created an apk on a git repo but ill do some more digging. cheers I think you are correct Dave, unless the mkvtoolnix utilities are available for Android, then its a non-starter. Mkv editing is not normally done on Android platforms (only playback) but i'll also have a look later. The other option is to actually run a 2nd instance of emby on another platform to change the mkv's (they only need to be changed once) ..
rbjtech 5345 Posted March 28, 2023 Posted March 28, 2023 4 minutes ago, Cheesegeezer said: Source - https://alternativeto.net/software/mkvtoolnix/?platform=android Ok.. so confirmed. It cannot run on the shield. I'll update the wiki later to say this.
MAX92 93 Posted March 28, 2023 Posted March 28, 2023 Hello, It is me again. I'm looking why some of my movies has no information. In the log, I have this : 2023-03-28 09:15:14.855 Info Media Info: PROCESSING OF The Whale HAS STARTED 2023-03-28 09:15:14.855 Info Media Info: Item FilePath = /volume2/video/Films/Films HD/The Whale (2022)/The Whale - 1080p.h264.ac3.mkv 2023-03-28 09:15:15.223 Info Media Info: Video Track successfully Written & Exited with Code 0 2023-03-28 09:15:15.224 Info Media Info: Video Track Title Set to HD 1080p AVC [3.5Mb/s] 2023-03-28 09:15:15.787 Error App: Error reading existng nfo *** Error Report *** Version: 4.7.11.0 Command line: /volume1/@appstore/EmbyServer/system/EmbyServer.dll -programdata /var/packages/EmbyServer/var -ffdetect /var/packages/EmbyServer/target/bin/ffdetect -ffmpeg /var/packages/EmbyServer/target/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/bin/ffprobe -nolocalportconfig -ignore_vaapi_enabled_flag -pidfile /var/packages/EmbyServer/var/EmbyServer.pid -defaultdirectory /volume1/Public -updatepackage emby-server-synology7_{version}_x86_64.spk -noautorunwebapp Operating system: Linux version 4.4.180+ (root@build2) (gcc version 8.5.0 (GCC) ) #42962 SMP Tue Jan 31 23:18:09 CST 2023 Framework: .NET 6.0.8 OS/Process: x64/x64 Runtime: volume1/@appstore/EmbyServer/system/System.Private.CoreLib.dll Processor count: 2 Data path: /var/packages/EmbyServer/var Application path: /volume1/@appstore/EmbyServer/system System.Xml.XmlException: System.Xml.XmlException: Data at the root level is invalid. Line 152, position 9. at System.Xml.XmlTextReaderImpl.Throw(Exception e) at System.Xml.XmlTextReaderImpl.Throw(String res, String arg) at System.Xml.XmlTextReaderImpl.ParseRootLevelWhitespace() at System.Xml.XmlTextReaderImpl.ParseDocumentContent() at NfoMetadata.Savers.BaseNfoSaver.AddCustomTags(String path, List`1 xmlTagsUsed, XmlWriter writer, ILogger logger, IFileSystem fileSystem) at NfoMetadata.Savers.BaseNfoSaver.Save(BaseItem item, LibraryOptions libraryOptions, Stream stream, String xmlPath) Source: System.Private.Xml TargetSite: Void Throw(System.Exception) 2023-03-28 09:15:16.074 Info Media Info: Audio Track successfully Written & Exited with Code 0 2023-03-28 09:15:16.074 Info Media Info: Audio Stream #1 Updated to: Dolby Digital 5.1 (48Khz) [32-Bit] (Default) 2023-03-28 09:15:16.287 Info Media Info: Audio Track successfully Written & Exited with Code 0 2023-03-28 09:15:16.287 Info Media Info: Audio Stream #2 Updated to: Dolby Digital 5.1 (48Khz) [32-Bit] 2023-03-28 09:15:16.294 Info Media Info: Item Tags found = 2023-03-28 09:15:16.294 Info Media Info: PROCESSING OF The Whale HAS COMPLETED And in EMBY, I have this Can someone help me ? Thanks
johnrobsonuk 1 Posted March 28, 2023 Posted March 28, 2023 Ah many thanks for trying guys. Not the end of the world along as I can play my 4K with Dolby atmos and no buffering il be happy.
MAX92 93 Posted March 28, 2023 Posted March 28, 2023 And sometimes I have this : 2023-03-28 09:18:02.194 Info Media Info: PROCESSING OF Partie 16 HAS STARTED 2023-03-28 09:18:02.194 Info Media Info: Item FilePath = /volume2/A faire/Séries/Your Honor/Saison 02/Your Honor - S02E06 - Partie 16.mkv 2023-03-28 09:18:02.200 Error Media Info: UNABLE TO PROCESS MEDIA INFO 2023-03-28 09:18:02.200 Info Media Info: PROCESSING OF Partie 16 HAS COMPLETED
MAX92 93 Posted March 28, 2023 Posted March 28, 2023 Some other example 2023-03-28 09:15:22.603 Info Media Info: PROCESSING OF Une Intime conviction HAS STARTED 2023-03-28 09:15:22.603 Info Media Info: Item FilePath = /volume2/video/Films/New/Une Intime conviction (2019)/Une Intime conviction - 1080p.h264.dca.mkv 2023-03-28 09:15:22.737 Info Media Info: Video Track successfully Written & Exited with Code 0 2023-03-28 09:15:22.738 Info Media Info: Video Track Title Set to HD 1080p AVC [8.8Mb/s] 2023-03-28 09:15:22.754 Info Media Info: Audio Track successfully Written & Exited with Code 0 2023-03-28 09:15:22.754 Info Media Info: Audio Stream #1 Updated to: DTS 5.1 (48Khz) [24-Bit] (Default) 2023-03-28 09:15:22.768 Info Media Info: Only 1 Audio Stream - Removing *Default* from Title - Updated to: DTS 5.1 (48Khz) [24-Bit] 2023-03-28 09:15:22.768 Info Media Info: Item Tags found = 2023-03-28 09:15:22.768 Info Media Info: PROCESSING OF Une Intime conviction HAS COMPLETED 2023-03-28 09:15:22.770 Info Media Info: PROCESSING OF L'associé Du Diable HAS STARTED 2023-03-28 09:15:22.770 Info Media Info: Item FilePath = /volume2/video/Films/Films HD/L'Associé du Diable (1997)/L'Associé du Diable - 1080p.h264.ac3.mkv 2023-03-28 09:15:22.776 Error Media Info: UNABLE TO PROCESS MEDIA INFO 2023-03-28 09:15:22.776 Info Media Info: PROCESSING OF L'associé Du Diable HAS COMPLETED
rbjtech 5345 Posted March 28, 2023 Posted March 28, 2023 12 minutes ago, johnrobsonuk said: Ah many thanks for trying guys. Not the end of the world along as I can play my 4K with Dolby atmos and no buffering il be happy. No worries. I've updated the Wiki for future users. https://github.com/Cheesegeezer/MediaInfoWiki/wiki/Various-OS-Installation-Help#6-nvidia-shield-server 1
Cheesegeezer 3106 Posted March 28, 2023 Author Posted March 28, 2023 @MAX92hi there the only thing i think might be that somehow you have reversed the setting to show embedded titles please look at this https://github.com/Cheesegeezer/MediaInfoWiki/wiki#4-getting-the-titles-to-display-in-emby-ui-clients see if this fixes it
Cheesegeezer 3106 Posted March 28, 2023 Author Posted March 28, 2023 4 minutes ago, rbjtech said: No worries. I've updated the Wiki for future users. https://github.com/Cheesegeezer/MediaInfoWiki/wiki/Various-OS-Installation-Help#6-nvidia-shield-server Rich, you’ve put it in the middle of No.5 Docker section
rbjtech 5345 Posted March 28, 2023 Posted March 28, 2023 (edited) 12 minutes ago, MAX92 said: Some other example 2023-03-28 09:15:22.603 Info Media Info: PROCESSING OF Une Intime conviction HAS STARTED 2023-03-28 09:15:22.603 Info Media Info: Item FilePath = /volume2/video/Films/New/Une Intime conviction (2019)/Une Intime conviction - 1080p.h264.dca.mkv 2023-03-28 09:15:22.737 Info Media Info: Video Track successfully Written & Exited with Code 0 2023-03-28 09:15:22.738 Info Media Info: Video Track Title Set to HD 1080p AVC [8.8Mb/s] 2023-03-28 09:15:22.754 Info Media Info: Audio Track successfully Written & Exited with Code 0 2023-03-28 09:15:22.754 Info Media Info: Audio Stream #1 Updated to: DTS 5.1 (48Khz) [24-Bit] (Default) 2023-03-28 09:15:22.768 Info Media Info: Only 1 Audio Stream - Removing *Default* from Title - Updated to: DTS 5.1 (48Khz) [24-Bit] 2023-03-28 09:15:22.768 Info Media Info: Item Tags found = 2023-03-28 09:15:22.768 Info Media Info: PROCESSING OF Une Intime conviction HAS COMPLETED 2023-03-28 09:15:22.770 Info Media Info: PROCESSING OF L'associé Du Diable HAS STARTED 2023-03-28 09:15:22.770 Info Media Info: Item FilePath = /volume2/video/Films/Films HD/L'Associé du Diable (1997)/L'Associé du Diable - 1080p.h264.ac3.mkv 2023-03-28 09:15:22.776 Error Media Info: UNABLE TO PROCESS MEDIA INFO 2023-03-28 09:15:22.776 Info Media Info: PROCESSING OF L'associé Du Diable HAS COMPLETED So on the first issue - can you check if the files (the MKV's) are actually being changed ? It is returning a code 0 - which means it successfully did it. The NFO error message is from emby itself, not the plugin. On the other issues - check the files are not in use by some other program - they cannot be modified if in use by emby itself or another app such as torrent client for example. Edited March 28, 2023 by rbjtech
rbjtech 5345 Posted March 28, 2023 Posted March 28, 2023 2 minutes ago, Cheesegeezer said: Rich, you’ve put it in the middle of No.5 Docker section Ah yea - lol - fixed
MAX92 93 Posted March 28, 2023 Posted March 28, 2023 4 minutes ago, Cheesegeezer said: @MAX92hi there the only thing i think might be that somehow you have reversed the setting to show embedded titles please look at this https://github.com/Cheesegeezer/MediaInfoWiki/wiki#4-getting-the-titles-to-display-in-emby-ui-clients see if this fixes it I try, no change. But did you see the error messages : 2023-03-28 09:15:22.776 Error Media Info: UNABLE TO PROCESS MEDIA INFO and 2023-03-28 09:15:15.224 Info Media Info: Video Track Title Set to HD 1080p AVC [3.5Mb/s] 2023-03-28 09:15:15.787 Error App: Error reading existng nfo *** Error Report *** Version: 4.7.11.0 Command line: /volume1/@appstore/EmbyServer/system/EmbyServer.dll -programdata /var/packages/EmbyServer/var -ffdetect /var/packages/EmbyServer/target/bin/ffdetect -ffmpeg /var/packages/EmbyServer/target/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/bin/ffprobe -nolocalportconfig -ignore_vaapi_enabled_flag -pidfile /var/packages/EmbyServer/var/EmbyServer.pid -defaultdirectory /volume1/Public -updatepackage emby-server-synology7_{version}_x86_64.spk -noautorunwebapp Operating system: Linux version 4.4.180+ (root@build2) (gcc version 8.5.0 (GCC) ) #42962 SMP Tue Jan 31 23:18:09 CST 2023 Framework: .NET 6.0.8 OS/Process: x64/x64 Runtime: volume1/@appstore/EmbyServer/system/System.Private.CoreLib.dll Processor count: 2 Data path: /var/packages/EmbyServer/var Application path: /volume1/@appstore/EmbyServer/system System.Xml.XmlException: System.Xml.XmlException: Data at the root level is invalid. Line 152, position 9. at System.Xml.XmlTextReaderImpl.Throw(Exception e) at System.Xml.XmlTextReaderImpl.Throw(String res, String arg) at System.Xml.XmlTextReaderImpl.ParseRootLevelWhitespace() at System.Xml.XmlTextReaderImpl.ParseDocumentContent() at NfoMetadata.Savers.BaseNfoSaver.AddCustomTags(String path, List`1 xmlTagsUsed, XmlWriter writer, ILogger logger, IFileSystem fileSystem) at NfoMetadata.Savers.BaseNfoSaver.Save(BaseItem item, LibraryOptions libraryOptions, Stream stream, String xmlPath) Source: System.Private.Xml TargetSite: Void Throw(System.Exception) 2023-03-28 09:15:16.074 Info Media Info: Audio Track successfully Written & Exited with Code 0
Cheesegeezer 3106 Posted March 28, 2023 Author Posted March 28, 2023 Just now, MAX92 said: I try, no change. But did you see the error messages : 2023-03-28 09:15:22.776 Error Media Info: UNABLE TO PROCESS MEDIA INFO and 2023-03-28 09:15:15.224 Info Media Info: Video Track Title Set to HD 1080p AVC [3.5Mb/s] 2023-03-28 09:15:15.787 Error App: Error reading existng nfo *** Error Report *** Version: 4.7.11.0 Command line: /volume1/@appstore/EmbyServer/system/EmbyServer.dll -programdata /var/packages/EmbyServer/var -ffdetect /var/packages/EmbyServer/target/bin/ffdetect -ffmpeg /var/packages/EmbyServer/target/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/bin/ffprobe -nolocalportconfig -ignore_vaapi_enabled_flag -pidfile /var/packages/EmbyServer/var/EmbyServer.pid -defaultdirectory /volume1/Public -updatepackage emby-server-synology7_{version}_x86_64.spk -noautorunwebapp Operating system: Linux version 4.4.180+ (root@build2) (gcc version 8.5.0 (GCC) ) #42962 SMP Tue Jan 31 23:18:09 CST 2023 Framework: .NET 6.0.8 OS/Process: x64/x64 Runtime: volume1/@appstore/EmbyServer/system/System.Private.CoreLib.dll Processor count: 2 Data path: /var/packages/EmbyServer/var Application path: /volume1/@appstore/EmbyServer/system System.Xml.XmlException: System.Xml.XmlException: Data at the root level is invalid. Line 152, position 9. at System.Xml.XmlTextReaderImpl.Throw(Exception e) at System.Xml.XmlTextReaderImpl.Throw(String res, String arg) at System.Xml.XmlTextReaderImpl.ParseRootLevelWhitespace() at System.Xml.XmlTextReaderImpl.ParseDocumentContent() at NfoMetadata.Savers.BaseNfoSaver.AddCustomTags(String path, List`1 xmlTagsUsed, XmlWriter writer, ILogger logger, IFileSystem fileSystem) at NfoMetadata.Savers.BaseNfoSaver.Save(BaseItem item, LibraryOptions libraryOptions, Stream stream, String xmlPath) Source: System.Private.Xml TargetSite: Void Throw(System.Exception) 2023-03-28 09:15:16.074 Info Media Info: Audio Track successfully Written & Exited with Code 0 The error is coming from Emby App not the plugin. The plugin doesn’t deal with xml files at all. Its just been put in the log at a point after a plugin log. https://github.com/Cheesegeezer/MediaInfoWiki/wiki/How-to-Debug-MediaInfo
MAX92 93 Posted March 28, 2023 Posted March 28, 2023 (edited) 50 minutes ago, Cheesegeezer said: The error is coming from Emby App not the plugin. The plugin doesn’t deal with xml files at all. Its just been put in the log at a point after a plugin log. https://github.com/Cheesegeezer/MediaInfoWiki/wiki/How-to-Debug-MediaInfo This is an exemple, One Ok and one Ko I hope it could help. Exemple.txt Edited March 28, 2023 by MAX92
Cheesegeezer 3106 Posted March 28, 2023 Author Posted March 28, 2023 (edited) 24 minutes ago, MAX92 said: This is an exemple, One Ok and one Ko I hope it could help. Exemple.txt 12.75 kB · 0 downloads I think i know what it might be… it could be the special characters in the french language or any other language that uses them, acutes, etc. can you try to rename the first file, and change things like é to just e etc. Also see if the file has read/write access and is isn't just Read only access. many thanks for the info using mediainfoGUI see if media info can read the file with the special chars. Edited March 28, 2023 by Cheesegeezer
Cheesegeezer 3106 Posted March 28, 2023 Author Posted March 28, 2023 I’m tied up at the minute doing some unit testing on another project otherwise i would try this myself. Thanks
MAX92 93 Posted March 28, 2023 Posted March 28, 2023 (edited) 3 hours ago, Cheesegeezer said: I think i know what it might be… it could be the special characters in the french language or any other language that uses them, acutes, etc. can you try to rename the first file, and change things like é to just e etc. Also see if the file has read/write access and is isn't just Read only access. many thanks for the info using mediainfoGUI see if media info can read the file with the special chars. Congratulation ! You go it. It is files with french special chars "é, à, è..." witch don't work. So happy you found it. Next question : what can we do ? Edited March 28, 2023 by MAX92
Cheesegeezer 3106 Posted March 28, 2023 Author Posted March 28, 2023 46 minutes ago, MAX92 said: Congratulation ! You go it. It is files with french special chars "é, à, è..." witch don't work. So happy you found it. Next question : what can we do ? Awesome... this is what i thought. i will have to handle these somehow in the code behind. leave it with me. Cheers 1
Cheesegeezer 3106 Posted March 30, 2023 Author Posted March 30, 2023 On 28/03/2023 at 12:56, MAX92 said: Congratulation ! You go it. It is files with french special chars "é, à, è..." witch don't work. So happy you found it. Next question : what can we do ? I should have a fix for this shortly, would you be able to test for me please, before I release
rbjtech 5345 Posted March 30, 2023 Posted March 30, 2023 21 minutes ago, Cheesegeezer said: I should have a fix for this shortly, would you be able to test for me please, before I release is this just a Unix issues Dave - As I've just checked using accents on one of my files and the current version appears to work ok ? (some of the lines look a little funky, but it appears to write the correct info to the MKV - log attached for 'Lèon the Professional' leon.txt
