rbjtech 5345 Posted March 5, 2023 Posted March 5, 2023 4 minutes ago, Teddyknuddel said: What will actually become of MediaInfo for Emby when Dolby Vision info is integrated in the new server version 4.8? Because I think it's cool if I can see in advance that the faulty DV5 has been loaded, then I can correct it in advance. No change - the core is only adding DV, it is not adding any other recognition of the advanced audio codecs - Atmos etc. And I suspect the core will not differentiate between DV5, DV7 and DV8 either.. 1
Teddyknuddel 136 Posted March 5, 2023 Posted March 5, 2023 4 minutes ago, rbjtech said: No change - the core is only adding DV, it is not adding any other recognition of the advanced audio codecs - Atmos etc. And I suspect the core will not differentiate between DV5, DV7 and DV8 either.. So can we continue to use the plugin?
rbjtech 5345 Posted March 5, 2023 Posted March 5, 2023 2 minutes ago, Teddyknuddel said: So can we continue to use the plugin? I will be yes. Recognising DV in the core will be useful for things such as transcoding - ie don't attempt to tone map a DV5 file for example. A DV7 and DV8 will drop to HDR anyway - so nothing to be gained from recognising that. If you have a DV capable TV - then it may also not accept DV7 playback, but I'm unsure if emby is going to have that layer of detail as I said above. DV is unfortunately a bit of a nightmare full stop for media playback software ... 1
Teddyknuddel 136 Posted March 5, 2023 Posted March 5, 2023 DV is just another pitiful attempt to stop piracy. But as we already know - new today, already cracked yesterday. 1
Teddyknuddel 136 Posted March 5, 2023 Posted March 5, 2023 @rbjtech @MAX92 What I forgot to mention: Under Synology you have to give the internal system users "sc-mediainfo" and "sc-mkvtoolnix" read and write permissions to the folders, drives where the libraries are stored. Synology is very particular about this - needs an extra share for everything.
MAX92 93 Posted March 6, 2023 Posted March 6, 2023 12 hours ago, Teddyknuddel said: @rbjtech @MAX92 What I forgot to mention: Under Synology you have to give the internal system users "sc-mediainfo" and "sc-mkvtoolnix" read and write permissions to the folders, drives where the libraries are stored. Synology is very particular about this - needs an extra share for everything. I didn't do that but It works fine.
Cheesegeezer 3106 Posted March 6, 2023 Author Posted March 6, 2023 17 hours ago, rbjtech said: I will be yes. Recognising DV in the core will be useful for things such as transcoding - ie don't attempt to tone map a DV5 file for example. A DV7 and DV8 will drop to HDR anyway - so nothing to be gained from recognising that. If you have a DV capable TV - then it may also not accept DV7 playback, but I'm unsure if emby is going to have that layer of detail as I said above. DV is unfortunately a bit of a nightmare full stop for media playback software ... Rich, sent you a Teams message
Teddyknuddel 136 Posted March 6, 2023 Posted March 6, 2023 2 hours ago, MAX92 said: I didn't do that but It works fine. It is better to add it now than to have it not work later. In any case, it can't do any harm.
MAX92 93 Posted March 6, 2023 Posted March 6, 2023 (edited) 4 hours ago, Teddyknuddel said: It is better to add it now than to have it not work later. In any case, it can't do any harm. I do it because I have some problems for some movies. I have no information : Do you know why ? There are this informations at the end Edited March 6, 2023 by MAX92
Teddyknuddel 136 Posted March 6, 2023 Posted March 6, 2023 17 minutes ago, MAX92 said: Do you know why ? Probably because of the write permissions for "sc-mkvtoolnix". It was described also again here in this Threat, how one can let individual elements read in again extra, without having to read in completely again.
MAX92 93 Posted March 7, 2023 Posted March 7, 2023 16 hours ago, Teddyknuddel said: Probably because of the write permissions for "sc-mkvtoolnix". It was described also again here in this Threat, how one can let individual elements read in again extra, without having to read in completely again. Before I posted a new message, I gave the permissions. Could you please give me the solution for let individual elements read again ? Thanks a lot
Teddyknuddel 136 Posted March 7, 2023 Posted March 7, 2023 1 hour ago, MAX92 said: Could you please give me the solution for let individual elements read again ? And you can find the ID of your video in the URL But it may take a while until MediaInfo & MKVToolnix do their job and you can see it. You will have to be patient for a while. 1
MAX92 93 Posted March 7, 2023 Posted March 7, 2023 (edited) thanks @Teddyknuddel I try but I didn't succeed. To give a feed back : Check the permission on my NAS : take the ID EMBY : 1253838 Put in Reprocess Specific Items Lauch Wait And check the result Another movie create the same day, no problem Edited March 7, 2023 by MAX92
Teddyknuddel 136 Posted March 7, 2023 Posted March 7, 2023 @MAX92 As I said, it takes a while. Even quite a while - had that with me also only a few hours later in. After maybe 5 minutes, Emby/MediaInfo certainly hasn't updated it yet. Calm blood, comfortably drink a coffee, maybe two or three - that will be fine 1
rbjtech 5345 Posted March 7, 2023 Posted March 7, 2023 (edited) Check the emby log - if you turn on debug logging, it gives a detailed log of everything it changes. To test, just use the 'reprocess' option on an individual item. As above, changes will only get recognised by emby if real time monitoring picks them up, or you force with a item refresh. Remember, the plugin is changing the MKV - it is not directly changing Emby - so it is up to Emby to then re-read the MKV to pick up the change. Edited March 7, 2023 by rbjtech 1
Teddyknuddel 136 Posted March 7, 2023 Posted March 7, 2023 @MAX92 Check from Windows with the program MediaInfo whether something was entered now in the title. If this is in here, then it is only up to Emby, until it was taken over. Or also with MKVToolnix 1
MAX92 93 Posted March 7, 2023 Posted March 7, 2023 (edited) This is the log 2023-03-07 11:14:21.887 Info Media Info: MEDIAINFO TASK IS STARTING 2023-03-07 11:14:21.887 Info Media Info: Performing MKV Version Checks......... 2023-03-07 11:14:21.897 Info Media Info: MKVPropEdit Process Version: mkvpropedit v22.0.0 ('At The End Of The World') 64-bit 2023-03-07 11:14:21.897 Info Media Info: MKVPropEdit Process Version Check Completed with Exit Code: 0 2023-03-07 11:14:21.898 Info Media Info: MKVPROPEDIT VERSION IS 22 - CONGRATS..... THIS VERSION IS SUPPORTED!! 2023-03-07 11:14:21.898 Info Media Info: No. of Libraries selected is 6 2023-03-07 11:14:21.898 Info Media Info: Getting Folder(s) Items 2023-03-07 11:14:22.720 Info Media Info: Total No. of items in Library 6262 2023-03-07 11:14:22.720 Info Media Info: Une drôle d'histoire sur la route du marteau de Thor with ITEM ID: 1253838 will be reprocessed 2023-03-07 11:14:22.721 Info Media Info: 1253838 ITEM ID has been removed from processed list and new MediaInfo Titles will be generated 2023-03-07 11:14:22.721 Info Media Info: MediaInfo Individual ID list has been cleared 2023-03-07 11:14:23.861 Info Media Info: Actual Items to process = 2989 2023-03-07 11:14:23.861 Info Media Info: PERFORMING MEDIAINFO EXTRACTION 2023-03-07 11:14:23.862 Info Media Info: PROCESSING OF Earth from Space HAS STARTED 2023-03-07 11:14:23.862 Info Media Info: Item FilePath = /volume2/video/Documentaires/Earth from Space (2019- )/Earth from Space - 720p.h264.AAC.mkv 2023-03-07 11:14:24.253 Info Media Info: Video Track successfully Written & Exited with Code 2 2023-03-07 11:14:24.253 Info Media Info: Video Track Title Set to HD 720p AVC [2.3Mb/s] 2023-03-07 11:14:24.270 Warn Media Info: Replace Audio Track Failed to update Track Title & Exited with Code 2 2023-03-07 11:14:24.273 Info Media Info: Item Tags found = 2023-03-07 11:14:24.273 Info Media Info: PROCESSING OF Earth from Space HAS COMPLETED 2023-03-07 11:14:24.277 Info Media Info: PROCESSING OF Une drôle d'histoire sur la route du marteau de Thor HAS STARTED 2023-03-07 11:14:24.277 Info Media Info: Item FilePath = /volume2/video/Films/Films HD/Une drôle d'histoire sur la route du marteau de Thor (2011)/Une drôle d'histoire sur la route du marteau de Thor - 1080p.h264.ac3.mkv 2023-03-07 11:14:24.283 Error Media Info: UNABLE TO PROCESS MEDIA INFO 2023-03-07 11:14:24.283 Info Media Info: PROCESSING OF Une drôle d'histoire sur la route du marteau de Thor HAS COMPLETED 2023-03-07 11:14:25.320 Info Media Info: MEDIAINFO TITLES Completed for 2989 Videos 2023-03-07 11:14:25.320 Warn Media Info: Item ID 288126 has been removed from the processed List and will be processed next MediaInfo Scheduled Task 2023-03-07 11:14:27.431 Info Server: http/1.1 POST http://host4:400/emby/Sessions/Capabilities/Full?X-Emby-Client=Emby Web&X-Emby-Device-Name=Microsoft Edge Windows&X-Emby-Device-Id=cd10237d-02ad-4c84-b512-4c38a74a5999&X-Emby-Client-Version=4.7.11.0&X-Emby-Language=fr&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/110.0.0.0 Safari/537.36 Edg/110.0.1587.63 2023-03-07 11:14:27.433 Info Server: http/1.1 Response 204 to host10. Time: 2ms. http://host4:400/emby/Sessions/Capabilities/Full?X-Emby-Client=Emby Web&X-Emby-Device-Name=Microsoft Edge Windows&X-Emby-Device-Id=cd10237d-02ad-4c84-b512-4c38a74a5999&X-Emby-Client-Version=4.7.11.0&X-Emby-Language=fr&reqformat=json I have an error. Edited March 7, 2023 by MAX92
rbjtech 5345 Posted March 7, 2023 Posted March 7, 2023 Unfortunately that's a generic 'catch all' error - it's not going to tell us the exact issue. Does the account running emby have write permissions to the MKV file ? Is the file 'in use' - is something else using it perhaps ?
Teddyknuddel 136 Posted March 7, 2023 Posted March 7, 2023 (edited) @rbjtechI already said here at that time that you still have to do that. Maybe you still take over that in your guide. Edited March 7, 2023 by Teddyknuddel
MAX92 93 Posted March 7, 2023 Posted March 7, 2023 6 minutes ago, rbjtech said: Does the account running emby have write permissions to the MKV file ? Yes The file has write permission 7 minutes ago, rbjtech said: Is the file 'in use' - is something else using it perhaps ? No
MAX92 93 Posted March 7, 2023 Posted March 7, 2023 For example if it can help A working movie not working movie
Teddyknuddel 136 Posted March 7, 2023 Posted March 7, 2023 @MAX92 Let's do this differently: You restart the NAS completely, not Emby, but the whole NAS. You create a new directory for this movie and name it like this: Captain America The First Avenger (2011) tt0458339 Then you name the video that way: Captain America The First Avenger (2011) tt0458339.mkv and move it into the new folder. And then you delete the old movie folder. 1
rbjtech 5345 Posted March 7, 2023 Posted March 7, 2023 21 minutes ago, MAX92 said: For example if it can help A working movie not working movie Simply put - if it works on some titles but not others - then the issue is going to be file permissions on those files or the files are in use. It uses the same 3rd party programs to make every change on the 'Title' substreams in each MKV - it just repeats it on each file. 1
MAX92 93 Posted March 7, 2023 Posted March 7, 2023 1 hour ago, Teddyknuddel said: @MAX92 Let's do this differently: You restart the NAS completely, not Emby, but the whole NAS. You create a new directory for this movie and name it like this: Captain America The First Avenger (2011) tt0458339 Then you name the video that way: Captain America The First Avenger (2011) tt0458339.mkv and move it into the new folder. And then you delete the old movie folder. Done but no changement. I have a lot of my videos like this. Nevermind, it is a bonus. However I hate to not understand why It appends.
