Cheesegeezer 3106 Posted February 18, 2023 Author Posted February 18, 2023 1 hour ago, Teddyknuddel said: After a long, long scan everything fits now after all - very, very fine plugin - thank you very much to the creators. 5 minutes ago, rbjtech said: Yes, remember it modifies the actual MKV file with the new track titles - so once emby picks this up - via the real time monitor or library scan - THEN, assuming you've told emby to use the Titles, then you'll see the updates in Emby. Explained in the Wiki - Home · Cheesegeezer/MediaInfoWiki Wiki (github.com) Enjoy The plugin now forces to use embedded titles to aid in removing users finding other settings. should i add that in the UI or log? i think there is a notification that states this on the UI. Sorry i haven’t visited it for ages coz it’s working perfectly for me.
rbjtech 5345 Posted February 18, 2023 Posted February 18, 2023 8 minutes ago, Cheesegeezer said: The plugin now forces to use embedded titles to aid in removing users finding other settings. should i add that in the UI or log? i think there is a notification that states this on the UI. Sorry i haven’t visited it for ages coz it’s working perfectly for me. I'll update the Wiki Dave. All working perfectly for me too since we(you..) wrote it - a fantastic plugin which I see the results of every time I play something 2
Teddyknuddel 136 Posted February 18, 2023 Posted February 18, 2023 2 hours ago, rbjtech said: Yes, remember it modifies the actual MKV file with the new track titles - so once emby picks this up - via the real time monitor or library scan - THEN, assuming you've told emby to use the Titles, then you'll see the updates in Emby. Explained in the Wiki - Home · Cheesegeezer/MediaInfoWiki Wiki (github.com) Enjoy But it actually states: "This determines the title displayed as default if no local or Internet metadata is available." But there is local or internet metadata available - why can this be read anyway?
Happy2Play 9814 Posted February 18, 2023 Posted February 18, 2023 1 hour ago, Teddyknuddel said: But it actually states: "This determines the title displayed as default if no local or Internet metadata is available." But there is local or internet metadata available - why can this be read anyway? But that setting is not used and is the wrong setting for embedded track titles. The embedded track titles setting is in Library-Advanced tab per the image in the wiki in step 9. 1 1
Teddyknuddel 136 Posted February 21, 2023 Posted February 21, 2023 Since I installed the plugin, new movies and episodes are no longer read cleanly. For example, I added a new episode the day before yesterday, which is still not read into Emby. Did I miss something?
Cheesegeezer 3106 Posted February 21, 2023 Author Posted February 21, 2023 35 minutes ago, Teddyknuddel said: Since I installed the plugin, new movies and episodes are no longer read cleanly. For example, I added a new episode the day before yesterday, which is still not read into Emby. Did I miss something? Hi Teddy, im gonna need more info to help you out. Can you do a debug log for me and run it on same episode by adding the episode id to the reprocess field. show me what the mediainfo json output looks like too. if you can screen shot your settings please for the plugin.
Teddyknuddel 136 Posted February 21, 2023 Posted February 21, 2023 I just deactivated it to see if anything is read in now. Apparently, for every little tool (especially now MediaInfo and Mkvtool) must be released extra rights in the Synology. What I had done earlier. The problem is, how should I be able to enter for the ID of the episode, if Emby does not want to read in? embyserver.txt
Cheesegeezer 3106 Posted February 21, 2023 Author Posted February 21, 2023 3 minutes ago, Teddyknuddel said: I just deactivated it to see if anything is read in now. Apparently, for every little tool (especially now MediaInfo and Mkvtool) must be released extra rights in the Synology. What I had done earlier. The problem is, how should I be able to enter for the ID of the episode, if Emby does not want to read in? embyserver.txt 1.03 MB · 0 downloads Thanks for the log. So... you deactivated the plugin before giving me the server log... and i have no info for MediaToolbox in there. BUT..... I think you have much bigger issues with your server and setup. I have never seen a log with sooo many errors in it for a very long time. I will walk you thru what to do. First enable debug logging Then find an episode that you think has issues in the web UI, you will find the episode id in the address bar Take copy only the number (617994) and add this to the plugin reprocess field and then hit save Go to schedule tasks and rotate the log Finally Run the mediainfo task in the log you will see information like this, it will also show you the exact json output from mediaInfoCLI itself (further down) here is the JSON that you should find in the log also Spoiler { "creatingLibrary": { "name": "MediaInfoLib", "version": "22.03", "url": "https://mediaarea.net/MediaInfo" }, "media": { "@ref": "D:\\Emby_Test\\TV Shows\\The Last of Us\\Season 01\\The Last of Us - 1x01 - When You're Lost in the Darkness.mkv", "track": [ { "@type": "General", "UniqueID": "325415128851993379140709851685414708911", "VideoCount": "1", "AudioCount": "1", "FileExtension": "mkv", "Format": "Matroska", "Format_Version": "4", "FileSize": "5454983794", "Duration": "4847.328", "OverallBitRate_Mode": "VBR", "OverallBitRate": "9002871", "FrameRate": "23.976", "FrameCount": "116219", "StreamSize": "108576899", "IsStreamable": "Yes", "File_Created_Date": "UTC 2023-02-06 17:50:33.728", "File_Created_Date_Local": "2023-02-06 18:50:33.728", "File_Modified_Date": "UTC 2023-02-21 09:06:36.115", "File_Modified_Date_Local": "2023-02-21 10:06:36.115", "Encoded_Application": "Lavf59.27.100", "Encoded_Library": "Lavf59.27.100", "extra": { "ErrorDetectionType": "Per level 1" } }, { "@type": "Video", "StreamOrder": "0", "ID": "1", "UniqueID": "13582461508220067608", "Format": "AVC", "Format_Profile": "High", "Format_Level": "4", "Format_Settings_CABAC": "Yes", "Format_Settings_RefFrames": "4", "CodecID": "V_MPEG4/ISO/AVC", "Duration": "4847.300000000", "BitRate_Mode": "VBR", "BitRate": "8250000", "BitRate_Maximum": "12374976", "Width": "1920", "Height": "1080", "Stored_Height": "1088", "Sampled_Width": "1920", "Sampled_Height": "1080", "PixelAspectRatio": "1.000", "DisplayAspectRatio": "1.778", "FrameRate_Mode": "CFR", "FrameRate": "23.976", "FrameCount": "116219", "ColorSpace": "YUV", "ChromaSubsampling": "4:2:0", "BitDepth": "8", "ScanType": "Progressive", "Delay": "0.000", "StreamSize": "4881063407", "Title": "HD 1080p AVC [8.3Mb/s]", "Encoded_Library": "x264 - core 157 r2965 861cec4", "Encoded_Library_Name": "x264", "Encoded_Library_Version": "core 157 r2965 861cec4", "Encoded_Library_Settings": "cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=34 / lookahead_threads=5 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=96 / keyint_min=96 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=8250 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=12375 / vbv_bufsize=6187 / nal_hrd=vbr / filler=0 / ip_ratio=1.40 / aq=1:1.00", "Default": "Yes", "Forced": "No", "BufferSize": "6186992", "colour_description_present": "Yes", "colour_description_present_Source": "Container / Stream", "colour_range": "Limited", "colour_range_Source": "Container / Stream", "colour_primaries": "BT.709", "colour_primaries_Source": "Container / Stream", "transfer_characteristics": "BT.709", "transfer_characteristics_Source": "Container / Stream", "matrix_coefficients": "BT.709", "matrix_coefficients_Source": "Container / Stream" }, { "@type": "Audio", "StreamOrder": "1", "ID": "2", "UniqueID": "16136102018133430746", "Format": "E-AC-3", "Format_Commercial_IfAny": "Dolby Digital Plus with Dolby Atmos", "Format_Settings_Endianness": "Big", "Format_AdditionalFeatures": "JOC", "CodecID": "A_EAC3", "Duration": "4847.328000000", "BitRate_Mode": "CBR", "BitRate": "768000", "Channels": "6", "ChannelPositions": "Front: L C R, Side: L R, LFE", "ChannelLayout": "L R C LFE Ls Rs", "SamplesPerFrame": "1536", "SamplingRate": "48000", "SamplingCount": "232671744", "FrameRate": "31.250", "BitDepth": "32", "Compression_Mode": "Lossy", "Delay": "0.000", "Delay_Source": "Container", "StreamSize": "465343488", "StreamSize_Proportion": "0.08531", "Title": "Dolby Digital Plus Atmos 5.1 ", "Language": "en", "ServiceKind": "CM", "Default": "Yes", "Forced": "No", "extra": { "ComplexityIndex": "16", "NumberOfDynamicObjects": "15", "BedChannelCount": "1", "BedChannelConfiguration": "LFE", "bsid": "16", "dialnorm": "-29", "compr": "-0.28", "acmod": "7", "lfeon": "1", "dialnorm_Average": "-29", "dialnorm_Minimum": "-29", "compr_Average": "2.40", "compr_Minimum": "0.53", "compr_Maximum": "4.22", "compr_Count": "106" } } ] } } 1
Teddyknuddel 136 Posted February 21, 2023 Posted February 21, 2023 Ok. I'll do it later - right now I need to fix guest toilet.
Cheesegeezer 3106 Posted February 21, 2023 Author Posted February 21, 2023 1 minute ago, Teddyknuddel said: Ok. I'll do it later - right now I need to fix guest toilet. Hahaha, enjoy your bog diving session!! Good luck Oh don't forget to enable the plugin before you do all that
Cheesegeezer 3106 Posted February 21, 2023 Author Posted February 21, 2023 One final thing... Ensure you haven't changed this setting
Cheesegeezer 3106 Posted February 21, 2023 Author Posted February 21, 2023 @rbjtech I have added the above to the Wiki, however you might want to check or edit it, to keep in line with your current formatting
rbjtech 5345 Posted February 21, 2023 Posted February 21, 2023 6 hours ago, Cheesegeezer said: @rbjtech I have added the above to the Wiki, however you might want to check or edit it, to keep in line with your current formatting Looks good Dave ! 1
Teddyknuddel 136 Posted February 21, 2023 Posted February 21, 2023 Somehow I can't get anything done right now - for two weeks we've been clearing out the house, so much crap that no one needs anymore. Renovation is also not going as planned. I switched off MediaInfo for TV series, but still didn't want to read anything - after an hour it was always at 86.7% and I could do whatever I wanted. Went nothing forward. And my wife is of course waiting for her new TV episodes. Since I can not wait forever until everything is there. Long story short. Deleted the series library completely, and recreated it over a new library. I'll have to try again later - but first I'm glad that MediaInfo works for the movies.
lorac 120 Posted February 22, 2023 Posted February 22, 2023 Not sure how the above relates to MediaInfo though.
Teddyknuddel 136 Posted February 22, 2023 Posted February 22, 2023 1 hour ago, lorac said: Not sure how the above relates to MediaInfo though. Why not?
spongebob69 10 Posted February 28, 2023 Posted February 28, 2023 For me Bif Generator tab is not working. Please help me. I have bigtool selected Running schedule task gets me: 2023-02-28 12:45:45.513 Info Media Info-HDRConvert: HDR Conversion TASK IS STARTING 2023-02-28 12:45:45.513 Info Media Info-HDRConvert: HDR Reprocess Items is ON - Resetting Lists... 2023-02-28 12:45:45.513 Info Media Info-HDRConvert: Resetting Lists for HDR Movies Only... 2023-02-28 12:45:45.513 Info Media Info-HDRConvert: Lists for HDR Movies successfully Reset 2023-02-28 12:45:45.513 Info Media Info-HDRConvert: BIF Individual ID list has been cleared 2023-02-28 12:45:45.513 Info Media Info-HDRConvert: Getting All Movies in Library 2023-02-28 12:45:45.520 Info Media Info-HDRConvert: Filtering HDR Movies 2023-02-28 12:45:45.528 Info Media Info-HDRConvert: Total Movies in Library = 49 2023-02-28 12:45:45.528 Info Media Info-HDRConvert: Total Movies with HDR to Process = 42 2023-02-28 12:45:45.528 Info Media Info-HDRConvert: Total HDR Items to process = 150 ==== other movies ==== 2023-02-28 12:45:45.555 Info Media Info-HDRConvert: Running HD-SD ToneMapping BIF file generator for Szeregowiec Ryan - ID = 35 2023-02-28 12:45:45.555 Info Media Info-HDRConvert: Movie to extract HDR = Szeregowiec Ryan 2023-02-28 12:45:45.555 Info Media Info-HDRConvert: HDR-SDR Conversion completed for Szeregowiec Ryan 2023-02-28 12:45:45.555 Info Media Info-HDRConvert: HDR-SDR TASK HAS COMPLETED SUCCESSFULLY but no bif files in movie folder
rbjtech 5345 Posted February 28, 2023 Posted February 28, 2023 21 minutes ago, spongebob69 said: For me Bif Generator tab is not working. Please help me. I have bigtool selected Running schedule task gets me: 2023-02-28 12:45:45.513 Info Media Info-HDRConvert: HDR Conversion TASK IS STARTING 2023-02-28 12:45:45.513 Info Media Info-HDRConvert: HDR Reprocess Items is ON - Resetting Lists... 2023-02-28 12:45:45.513 Info Media Info-HDRConvert: Resetting Lists for HDR Movies Only... 2023-02-28 12:45:45.513 Info Media Info-HDRConvert: Lists for HDR Movies successfully Reset 2023-02-28 12:45:45.513 Info Media Info-HDRConvert: BIF Individual ID list has been cleared 2023-02-28 12:45:45.513 Info Media Info-HDRConvert: Getting All Movies in Library 2023-02-28 12:45:45.520 Info Media Info-HDRConvert: Filtering HDR Movies 2023-02-28 12:45:45.528 Info Media Info-HDRConvert: Total Movies in Library = 49 2023-02-28 12:45:45.528 Info Media Info-HDRConvert: Total Movies with HDR to Process = 42 2023-02-28 12:45:45.528 Info Media Info-HDRConvert: Total HDR Items to process = 150 ==== other movies ==== 2023-02-28 12:45:45.555 Info Media Info-HDRConvert: Running HD-SD ToneMapping BIF file generator for Szeregowiec Ryan - ID = 35 2023-02-28 12:45:45.555 Info Media Info-HDRConvert: Movie to extract HDR = Szeregowiec Ryan 2023-02-28 12:45:45.555 Info Media Info-HDRConvert: HDR-SDR Conversion completed for Szeregowiec Ryan 2023-02-28 12:45:45.555 Info Media Info-HDRConvert: HDR-SDR TASK HAS COMPLETED SUCCESSFULLY but no bif files in movie folder Emby now has a built in HDR BIF Generator (certainly in the latest Beta it does as I use it) - so I believe this function now may well be disabled ? Try turning on debug logging - as it should give you more details on the output, but I would personally use the core version - it's no better than the plugin version, but it will be better integrated with the other non HDR BIF file creation.
Cheesegeezer 3106 Posted February 28, 2023 Author Posted February 28, 2023 1 hour ago, rbjtech said: Emby now has a built in HDR BIF Generator (certainly in the latest Beta it does as I use it) - so I believe this function now may well be disabled ? Try turning on debug logging - as it should give you more details on the output, but I would personally use the core version - it's no better than the plugin version, but it will be better integrated with the other non HDR BIF file creation. I agree but if the user is still on release 4.7.11 then the plugin might be of use. However, when the beta hits release stage… we can remove this element. But i am interested in doing the ac3 track insert you have spoken about for a while now. 1
rbjtech 5345 Posted February 28, 2023 Posted February 28, 2023 1 minute ago, Cheesegeezer said: I agree but if the user is still on release 4.7.11 then the plugin might be of use. However, when the beta hits release stage… we can remove this element. But i am interested in doing the ac3 track insert you have spoken about for a while now. Sounds good. I noticed some other HDR 'bugs' as well the other day on certain files. They had HDR colour space (BT2020) but they had no 'HDR text based description' in media Info - they are HDR PQ files - so thus the plugin didn't tag them as HDR. We probably need to just fall back to using the colour space field if the HDR description field is blank or missing. And yea, tagging the other standard Audio tracks would be a great option (AAC, AC3 etc) - as filtering by Tag is far superior to any of the Emby filtering options. Other than that - a rock solid Plugin ! - a must have for AV Enthusiasts imo .. 1
Darkseidd 59 Posted March 1, 2023 Posted March 1, 2023 hi wanna ask. this plugin will modify .mkv container, correct? will it also modify "Date Creation" metadata of the file? for example i add the media at 2020, if u use this plugin, will the metadata "Date Creation" refreshed to 2023?
rbjtech 5345 Posted March 1, 2023 Posted March 1, 2023 2 hours ago, Darkseidd said: hi wanna ask. this plugin will modify .mkv container, correct? will it also modify "Date Creation" metadata of the file? for example i add the media at 2020, if u use this plugin, will the metadata "Date Creation" refreshed to 2023? It will not modify Date Created - but it will modify Date Modified - as it has been modified.
Darkseidd 59 Posted March 1, 2023 Posted March 1, 2023 47 minutes ago, rbjtech said: It will not modify Date Created - but it will modify Date Modified - as it has been modified. sorry wrong variable used. ok let me use screenshot from emby.. will it modify this?
Cheesegeezer 3106 Posted March 1, 2023 Author Posted March 1, 2023 1 hour ago, Darkseidd said: sorry wrong variable used. ok let me use screenshot from emby.. will it modify this? Yify rocks lol !! No it wont change your date added at all. So everything in your library will not be changed in order. 2 1
lorac 120 Posted March 1, 2023 Posted March 1, 2023 Will the plugin be updated to allow the new versions of mediainfo w/o the override? I know there were a couple versions that had issues but I haven't seen any problems with the changed metadata using 22.12 version. 1
