rbjtech 5345 Posted January 6, 2023 Posted January 6, 2023 3 minutes ago, purger500 said: Plugin has stopped working on Synology, server version 4.7.11.0 2023-01-06 11:15:44.761 Info Media Info: Current OS = LINUX 2023-01-06 11:15:44.761 Info Media Info: MEDIAINFO TASK IS STARTING 2023-01-06 11:15:44.761 Info Media Info: Performing MKV Version Checks......... 2023-01-06 11:15:44.933 Info Media Info: MKVPropEdit Process Version: mkvpropedit v22.0.0 ('At The End Of The World') 64-bit 2023-01-06 11:15:44.939 Info Media Info: MKVPropEdit Process Version Check Completed with Exit Code: 0 2023-01-06 11:15:44.939 Info Media Info: MKVPROPEDIT VERSION IS 22 - CONGRATS..... THIS VERSION IS SUPPORTED!! 2023-01-06 11:15:44.946 Info Media Info: No. of Libraries selected is 3 2023-01-06 11:15:44.946 Info Media Info: Getting Folder(s) Items 2023-01-06 11:15:45.868 Info Media Info: Total No. of items in Library 3719 2023-01-06 11:15:45.876 Info Media Info: Actual Items to process = 1 2023-01-06 11:15:45.876 Info Media Info: PERFORMING MEDIAINFO EXTRACTION 2023-01-06 11:15:45.877 Info Media Info: PROCESSING OF The Outfit HAS STARTED 2023-01-06 11:15:45.877 Info Media Info: Item FilePath = /volume1/FILMOVI/FILMOVI/KRIMINALISTIČKI/The.Outfit.2022.1080p.BluRay.REMUX.AVC.DTS-HD.MA.TrueHD.7.1.Atmos-FGT/The Outfit (2022) - 1080p.BluRay.REMUX.AVC.DTS-HD.MA.TrueHD.7.1.Atmos-FGT.mkv 2023-01-06 11:15:46.039 Error Media Info: UNABLE TO PROCESS MEDIA INFO 2023-01-06 11:15:46.039 Info Media Info: PROCESSING OF The Outfit HAS COMPLETED Nothing has changed - so if it was working but now isn't - then something on your system may have changed ? Is that file in use perhaps ?
Cheesegeezer 3106 Posted January 6, 2023 Author Posted January 6, 2023 5 minutes ago, purger500 said: Plugin has stopped working on Synology, server version 4.7.11.0 2023-01-06 11:15:44.761 Info Media Info: Current OS = LINUX 2023-01-06 11:15:44.761 Info Media Info: MEDIAINFO TASK IS STARTING 2023-01-06 11:15:44.761 Info Media Info: Performing MKV Version Checks......... 2023-01-06 11:15:44.933 Info Media Info: MKVPropEdit Process Version: mkvpropedit v22.0.0 ('At The End Of The World') 64-bit 2023-01-06 11:15:44.939 Info Media Info: MKVPropEdit Process Version Check Completed with Exit Code: 0 2023-01-06 11:15:44.939 Info Media Info: MKVPROPEDIT VERSION IS 22 - CONGRATS..... THIS VERSION IS SUPPORTED!! 2023-01-06 11:15:44.946 Info Media Info: No. of Libraries selected is 3 2023-01-06 11:15:44.946 Info Media Info: Getting Folder(s) Items 2023-01-06 11:15:45.868 Info Media Info: Total No. of items in Library 3719 2023-01-06 11:15:45.876 Info Media Info: Actual Items to process = 1 2023-01-06 11:15:45.876 Info Media Info: PERFORMING MEDIAINFO EXTRACTION 2023-01-06 11:15:45.877 Info Media Info: PROCESSING OF The Outfit HAS STARTED 2023-01-06 11:15:45.877 Info Media Info: Item FilePath = /volume1/FILMOVI/FILMOVI/KRIMINALISTIČKI/The.Outfit.2022.1080p.BluRay.REMUX.AVC.DTS-HD.MA.TrueHD.7.1.Atmos-FGT/The Outfit (2022) - 1080p.BluRay.REMUX.AVC.DTS-HD.MA.TrueHD.7.1.Atmos-FGT.mkv 2023-01-06 11:15:46.039 Error Media Info: UNABLE TO PROCESS MEDIA INFO 2023-01-06 11:15:46.039 Info Media Info: PROCESSING OF The Outfit HAS COMPLETED Hi mate, can you enqble debug logging and re run the task please.
purger500 13 Posted January 6, 2023 Posted January 6, 2023 (edited) 24 minutes ago, rbjtech said: Nothing has changed - so if it was working but now isn't - then something on your system may have changed ? Is that file in use perhaps ? I update MKVtoolnix (v 73.0.0) today on my PC, when I was muxing that file. Maybe new version of MKVtoolnix is the problem. Edited January 6, 2023 by purger500
rbjtech 5345 Posted January 6, 2023 Posted January 6, 2023 18 minutes ago, purger500 said: I update MKVtoolnix (v 73.0.0) today on my PC, when I was muxing that file. Maybe new version of MKVtoolnix is the problem. Possibly - it's a new release from a few days ago but a quick look at the release notes suggests nothing was changed with mkvpropedit .. I'll try and test when I get some time - but unless you need the latest, maybe rollback to the previous version.
purger500 13 Posted January 6, 2023 Posted January 6, 2023 (edited) i will try that and report back. Thanks. Edited January 6, 2023 by purger500
Cheesegeezer 3106 Posted January 6, 2023 Author Posted January 6, 2023 26 minutes ago, purger500 said: I update MKVtoolnix (v 73.0.0) today on my PC, when I was muxing that file. Maybe new version of MKVtoolnix is the problem. exactly! currently there have been no tests conducted on v73 in order to test this, you need to override the mkvtoolnix version and run it on a test library. We had huge issues with v71 and it actually trashed a few users media. so now i have put in logic to only be able to run on tested versions to safe guard the users media. if you turn on debug logging and run the tool without overriding the version check then the log should tell you that the version is unsupported. then if you turn on the override check and TEST on your TEST library!! It will allow it to run once overriding the check and you should see something like "EEk good luck" in the log. 1
Andy2k 77 Posted January 6, 2023 Posted January 6, 2023 The log said mkvpropedit V22 on a Linux system. I guess mkvtoolnix V73 was used for pre-processing on a windows machine. Maybe the (very) old V22 mkvpropedit cant handle some stuff mkvtoolnix v73 wrote to the mkv. What version of mkvtoolnix you used before for pre-processing? Maybe upgrading mkvpropedit (on the linux machine) to version V70.x or 72.x (dont use V71 versions!) is the way to go.... @cheesegeezer Is a v72 (the one im using atm) enabled version on the cataloge now? Btw i could do some tests after upgrading to v73 on my system, but right now i dont have many new stuff to process;)
purger500 13 Posted January 6, 2023 Posted January 6, 2023 1 hour ago, Cheesegeezer said: Hi mate, can you enqble debug logging and re run the task please. Hi mate, there is advanced log: 2023-01-06 12:58:00.279 Info Media Info: MKVPropEdit Process Version Check Completed with Exit Code: 0 2023-01-06 12:58:00.279 Info Media Info: MKVPROPEDIT VERSION IS 22 - CONGRATS..... THIS VERSION IS SUPPORTED!! 2023-01-06 12:58:00.280 Info Media Info: No. of Libraries selected is 3 2023-01-06 12:58:00.280 Debug Media Info: Internal Library Folder Id = 1694 - Folder Name: Movies 2023-01-06 12:58:00.280 Debug Media Info: Internal Library Folder Id = 1698 - Folder Name: TV Shows 2023-01-06 12:58:00.280 Debug Media Info: Internal Library Folder Id = 1699 - Folder Name: TV shows DV 2023-01-06 12:58:00.280 Info Media Info: Getting Folder(s) Items 2023-01-06 12:58:01.135 Info Media Info: Total No. of items in Library 3719 2023-01-06 12:58:01.143 Info Media Info: Actual Items to process = 1 2023-01-06 12:58:01.143 Info Media Info: PERFORMING MEDIAINFO EXTRACTION 2023-01-06 12:58:01.144 Info Media Info: PROCESSING OF The Outfit HAS STARTED 2023-01-06 12:58:01.144 Info Media Info: Item FilePath = /volume1/FILMOVI/FILMOVI/KRIMINALISTIČKI/The.Outfit.2022.1080p.BluRay.REMUX.AVC.DTS-HD.MA.TrueHD.7.1.Atmos-FGT/The Outfit (2022) - 1080p.BluRay.REMUX.AVC.DTS-HD.MA.TrueHD.7.1.Atmos-FGT.mkv 2023-01-06 12:58:01.144 Debug Media Info: Starting MediaInfo.exe process 2023-01-06 12:58:01.144 Debug Media Info: using MediaSource Path: /volume1/FILMOVI/FILMOVI/KRIMINALISTIČKI/The.Outfit.2022.1080p.BluRay.REMUX.AVC.DTS-HD.MA.TrueHD.7.1.Atmos-FGT/The Outfit (2022) - 1080p.BluRay.REMUX.AVC.DTS-HD.MA.TrueHD.7.1.Atmos-FGT.mkv 2023-01-06 12:58:01.144 Debug Media Info: Args= --Output=JSON "/volume1/FILMOVI/FILMOVI/KRIMINALISTIČKI/The.Outfit.2022.1080p.BluRay.REMUX.AVC.DTS-HD.MA.TrueHD.7.1.Atmos-FGT/The Outfit (2022) - 1080p.BluRay.REMUX.AVC.DTS-HD.MA.TrueHD.7.1.Atmos-FGT.mkv" 2023-01-06 12:58:01.167 Debug Media Info: MediaInfoCLI Path = /var/packages/mediainfo/target/bin/mediainfo 2023-01-06 12:58:01.167 Debug Media Info: about to start Media Info Actual process for debug purposes only 2023-01-06 12:58:01.307 Debug Media Info: Reset Embedded Titles = False 2023-01-06 12:58:01.308 Error Media Info: UNABLE TO PROCESS MEDIA INFO 2023-01-06 12:58:01.308 Debug Media Info: Object reference not set to an instance of an object. 2023-01-06 12:58:01.308 Info Media Info: PROCESSING OF The Outfit HAS COMPLETED 2023-01-06 12:58:01.309 Debug Media Info: MediaInfo processing for The Outfit and took 165 milliseconds 2023-01-06 12:58:01.309 Debug XmlSerializer: Serializing to file /var/packages/EmbyServer/var/plugins/configurations/Emby.MediaInfo.xml 2023-01-06 12:58:01.327 Info Media Info: MEDIAINFO TITLES Completed for 1 Videos 2023-01-06 12:58:01.327 Debug XmlSerializer: Serializing to file /var/packages/EmbyServer/var/plugins/configurations/Emby.MediaInfo.xml 2023-01-06 12:58:01.427 Debug TaskManager: Advanced Media Information Completed after 0 minute(s) and 1 seconds
Cheesegeezer 3106 Posted January 6, 2023 Author Posted January 6, 2023 12 minutes ago, Andy2k said: The log said mkvpropedit V22 on a Linux system. I guess mkvtoolnix V73 was used for pre-processing on a windows machine. Maybe the (very) old V22 mkvpropedit cant handle some stuff mkvtoolnix v73 wrote to the mkv. What version of mkvtoolnix you used before for pre-processing? Maybe upgrading mkvpropedit (on the linux machine) to version V70.x or 72.x (dont use V71 versions!) is the way to go.... Agree. V71 is black listed and can't be used 12 minutes ago, Andy2k said: @cheesegeezer Is a v72 (the one im using atm) enabled version on the cataloge now? Btw i could do some tests after upgrading to v73 on my system, but right now i dont have many new stuff to process;) v72 is in the allowed list. Test away buddy, would appreciate it. Thanks
Cheesegeezer 3106 Posted January 6, 2023 Author Posted January 6, 2023 13 minutes ago, purger500 said: Hi mate, there is advanced log: 2023-01-06 12:58:00.279 Info Media Info: MKVPropEdit Process Version Check Completed with Exit Code: 0 2023-01-06 12:58:00.279 Info Media Info: MKVPROPEDIT VERSION IS 22 - CONGRATS..... THIS VERSION IS SUPPORTED!! 2023-01-06 12:58:00.280 Info Media Info: No. of Libraries selected is 3 2023-01-06 12:58:00.280 Debug Media Info: Internal Library Folder Id = 1694 - Folder Name: Movies 2023-01-06 12:58:00.280 Debug Media Info: Internal Library Folder Id = 1698 - Folder Name: TV Shows 2023-01-06 12:58:00.280 Debug Media Info: Internal Library Folder Id = 1699 - Folder Name: TV shows DV 2023-01-06 12:58:00.280 Info Media Info: Getting Folder(s) Items 2023-01-06 12:58:01.135 Info Media Info: Total No. of items in Library 3719 2023-01-06 12:58:01.143 Info Media Info: Actual Items to process = 1 2023-01-06 12:58:01.143 Info Media Info: PERFORMING MEDIAINFO EXTRACTION 2023-01-06 12:58:01.144 Info Media Info: PROCESSING OF The Outfit HAS STARTED 2023-01-06 12:58:01.144 Info Media Info: Item FilePath = /volume1/FILMOVI/FILMOVI/KRIMINALISTIČKI/The.Outfit.2022.1080p.BluRay.REMUX.AVC.DTS-HD.MA.TrueHD.7.1.Atmos-FGT/The Outfit (2022) - 1080p.BluRay.REMUX.AVC.DTS-HD.MA.TrueHD.7.1.Atmos-FGT.mkv 2023-01-06 12:58:01.144 Debug Media Info: Starting MediaInfo.exe process 2023-01-06 12:58:01.144 Debug Media Info: using MediaSource Path: /volume1/FILMOVI/FILMOVI/KRIMINALISTIČKI/The.Outfit.2022.1080p.BluRay.REMUX.AVC.DTS-HD.MA.TrueHD.7.1.Atmos-FGT/The Outfit (2022) - 1080p.BluRay.REMUX.AVC.DTS-HD.MA.TrueHD.7.1.Atmos-FGT.mkv 2023-01-06 12:58:01.144 Debug Media Info: Args= --Output=JSON "/volume1/FILMOVI/FILMOVI/KRIMINALISTIČKI/The.Outfit.2022.1080p.BluRay.REMUX.AVC.DTS-HD.MA.TrueHD.7.1.Atmos-FGT/The Outfit (2022) - 1080p.BluRay.REMUX.AVC.DTS-HD.MA.TrueHD.7.1.Atmos-FGT.mkv" 2023-01-06 12:58:01.167 Debug Media Info: MediaInfoCLI Path = /var/packages/mediainfo/target/bin/mediainfo 2023-01-06 12:58:01.167 Debug Media Info: about to start Media Info Actual process for debug purposes only 2023-01-06 12:58:01.307 Debug Media Info: Reset Embedded Titles = False 2023-01-06 12:58:01.308 Error Media Info: UNABLE TO PROCESS MEDIA INFO 2023-01-06 12:58:01.308 Debug Media Info: Object reference not set to an instance of an object. 2023-01-06 12:58:01.308 Info Media Info: PROCESSING OF The Outfit HAS COMPLETED 2023-01-06 12:58:01.309 Debug Media Info: MediaInfo processing for The Outfit and took 165 milliseconds 2023-01-06 12:58:01.309 Debug XmlSerializer: Serializing to file /var/packages/EmbyServer/var/plugins/configurations/Emby.MediaInfo.xml 2023-01-06 12:58:01.327 Info Media Info: MEDIAINFO TITLES Completed for 1 Videos 2023-01-06 12:58:01.327 Debug XmlSerializer: Serializing to file /var/packages/EmbyServer/var/plugins/configurations/Emby.MediaInfo.xml 2023-01-06 12:58:01.427 Debug TaskManager: Advanced Media Information Completed after 0 minute(s) and 1 seconds Thanks for the log. So it's failing when it hits the mediaInfo part... it's not even getting the mkvpropedit part. so i think this might be something to do with the json that is being extracted. Can you double check that you have correct mediaInfo installed and that this can read a media file and output info. Select the JSON option from view menu and you get good readable information in the json
purger500 13 Posted January 6, 2023 Posted January 6, 2023 I have installed V72.0.0. on my PC for preprocessing purposes, and mux file with that version (that was the version that I had when all did well) but with the same result, failed. On my Synology DS1817+ version 22.0.0-2 is the latest version on Synocommunity. Maybe it is only that one file because i did completely refresh (refresh all items) and all files are good except that one movie. Thanks you both for your help. I will try with another movie and come with results. 1
purger500 13 Posted January 6, 2023 Posted January 6, 2023 There is JSON: { "creatingLibrary": { "name": "MediaInfoLib", "version": "22.09", "url": "https://mediaarea.net/MediaInfo" }, "media": { "@ref": "Z:\\FILMOVI\\KRIMINALISTIČKI\\The.Outfit.2022.1080p.BluRay.REMUX.AVC.DTS-HD.MA.TrueHD.7.1.Atmos-FGT\\The Outfit (2022) - 1080p.BluRay.REMUX.AVC.DTS-HD.MA.TrueHD.7.1.Atmos-FGT.mkv", "track": [ { "@type": "General", "UniqueID": "195179996658928933669894737660619280613", "VideoCount": "1", "AudioCount": "1", "TextCount": "1", "MenuCount": "1", "FileExtension": "mkv", "Format": "Matroska", "Format_Version": "4", "FileSize": "7243807351", "Duration": "6298.292", "OverallBitRate_Mode": "VBR", "OverallBitRate": "9200980", "FrameRate": "23.976", "FrameCount": "151008", "StreamSize": "54175058", "IsStreamable": "Yes", "Title": "The.Outfit.2022.1080p.BluRay.REMUX.AVC.DTS-HD.MA.TrueHD.7.1.Atmos-FGT", "Movie": "The.Outfit.2022.1080p.BluRay.REMUX.AVC.DTS-HD.MA.TrueHD.7.1.Atmos-FGT", "Encoded_Date": "UTC 2023-01-06 12:24:45", "File_Created_Date": "UTC 2023-01-06 12:27:57.393", "File_Created_Date_Local": "2023-01-06 13:27:57.393", "File_Modified_Date": "UTC 2023-01-06 12:27:28.484", "File_Modified_Date_Local": "2023-01-06 13:27:28.484", "Encoded_Application": "mkvmerge v72.0.0 ('Minuano (Six-eight)') 64-bit", "Encoded_Library": "libebml v1.4.4 + libmatroska v1.7.1 / Lavf58.76.100" }, { "@type": "Video", "StreamOrder": "0", "ID": "1", "UniqueID": "2856776251006202328", "Format": "HEVC", "Format_Profile": "Main", "Format_Level": "4.1", "Format_Tier": "Main", "CodecID": "V_MPEGH/ISO/HEVC", "Duration": "6298.292000000", "BitRate": "5999161", "Width": "1920", "Height": "1080", "Sampled_Width": "1920", "Sampled_Height": "1080", "PixelAspectRatio": "1.000", "DisplayAspectRatio": "1.778", "FrameRate_Mode": "CFR", "FrameRate": "23.976", "FrameCount": "151008", "ColorSpace": "YUV", "ChromaSubsampling": "4:2:0", "BitDepth": "8", "Delay": "0.000", "StreamSize": "4723059131", "Encoded_Library": "x265 - 3.5+1-f0c1022b6:[Windows][clang 12.0.0][64 bit] 8bit+10bit+12bit", "Encoded_Library_Name": "x265", "Encoded_Library_Version": "3.5+1-f0c1022b6:[Windows][clang 12.0.0][64 bit] 8bit+10bit+12bit", "Encoded_Library_Settings": "cpuid=1111039 / frame-threads=3 / numa-pools=12 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=1920x1080 / interlace=0 / total-frames=0 / level-idc=41 / high-tier=1 / uhd-bd=0 / ref=3 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=24 / keyint=240 / gop-lookahead=0 / bframes=4 / b-adapt=0 / b-pyramid / bframe-bias=0 / rc-lookahead=15 / lookahead-slices=6 / scenecut=40 / hist-scenecut=0 / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=0 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / no-strong-intra-smoothing / max-merge=2 / limit-refs=3 / no-limit-modes / me=1 / subme=2 / merange=57 / temporal-mvp / no-frame-dup / no-hme / weightp / no-weightb / no-analyze-src-pics / deblock=0:0 / sao / no-sao-non-deblock / rd=2 / selective-sao=4 / no-early-skip / rskip / fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=0.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=abr / bitrate=6000 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=2 / cplxblur=20.0 / qblur=0.5 / ipratio=1.40 / pbratio=1.30 / aq-mode=1 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=1 / transfer=1 / colormatrix=1 / chromaloc=0 / display-window=0 / cll=0,0 / min-luma=0 / max-luma=255 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / hist-threshold=0.03 / no-opt-cu-delta-qp / no-aq-motion / no-hdr10 / no-hdr10-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=0 / analysis-save-reuse-level=0 / analysis-load-reuse-level=0 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 / scenecut-aware-qp=0conformance-window-offsets / right=0 / bottom=0 / decoder-max-rate=0 / no-vbv-live-multi-pass", "Default": "Yes", "Forced": "No", "colour_description_present": "Yes", "colour_description_present_Source": "Container / Stream", "colour_range": "Limited", "colour_range_Source": "Container / Stream", "colour_primaries": "BT.709", "colour_primaries_Source": "Container / Stream", "transfer_characteristics": "BT.709", "transfer_characteristics_Source": "Container / Stream", "matrix_coefficients": "BT.709", "matrix_coefficients_Source": "Container / Stream" }, { "@type": "Audio", "StreamOrder": "1", "ID": "2", "OriginalSourceMedium_ID": "4352", "UniqueID": "2", "Format": "MLP FBA", "Format_Commercial_IfAny": "Dolby TrueHD with Dolby Atmos", "Format_AdditionalFeatures": "16-ch", "CodecID": "A_TRUEHD", "Duration": "6297.458000000", "BitRate_Mode": "VBR", "BitRate": "3133371", "BitRate_Maximum": "4392000", "Channels": "8", "ChannelPositions": "Front: L C R, Side: L R, Back: L R, LFE", "ChannelLayout": "L R C LFE Ls Rs Lb Rb", "SamplesPerFrame": "40", "SamplingRate": "48000", "SamplingCount": "302277984", "FrameRate": "1200.000", "FrameCount": "7556949", "BitDepth": "24", "Compression_Mode": "Lossless", "Delay": "0.000", "Delay_Source": "Container", "StreamSize": "2466534530", "StreamSize_Proportion": "0.34050", "Title": "TrueHD 7.1 Atmos", "Language": "en", "Default": "Yes", "Forced": "No", "extra": { "OriginalSourceMedium": "Blu-ray", "NumberOfDynamicObjects": "13", "BedChannelCount": "1", "BedChannelConfiguration": "LFE" } }, { "@type": "Text", "StreamOrder": "2", "ID": "3", "UniqueID": "16992795320247175068", "Format": "UTF-8", "CodecID": "S_TEXT/UTF8", "Duration": "5959.620000000", "BitRate": "51", "FrameRate": "0.173", "FrameCount": "1032", "ElementCount": "1032", "StreamSize": "38632", "Language": "hr", "Default": "Yes", "Forced": "No" }, { "@type": "Menu", "extra": { "_00_00_00_000": ":Chapter 1", "_00_05_45_929": ":Chapter 2", "_00_10_16_032": ":Chapter 3", "_00_15_10_660": ":Chapter 4", "_00_18_41_746": ":Chapter 5", "_00_20_57_131": ":Chapter 6", "_00_28_42_512": ":Chapter 7", "_00_32_40_584": ":Chapter 8", "_00_36_29_229": ":Chapter 9", "_00_40_49_072": ":Chapter 10", "_00_43_23_601": ":Chapter 11", "_00_50_55_970": ":Chapter 12", "_00_57_51_385": ":Chapter 13", "_01_04_17_354": ":Chapter 14", "_01_09_23_076": ":Chapter 15", "_01_14_58_285": ":Chapter 16", "_01_21_42_648": ":Chapter 17", "_01_27_56_605": ":Chapter 18", "_01_32_29_461": ":Chapter 19", "_01_39_29_755": ":Chapter 20" } } ] } }
Cheesegeezer 3106 Posted January 6, 2023 Author Posted January 6, 2023 2 minutes ago, purger500 said: There is JSON: { "creatingLibrary": { "name": "MediaInfoLib", "version": "22.09", "url": "https://mediaarea.net/MediaInfo" }, "media": { "@ref": "Z:\\FILMOVI\\KRIMINALISTIČKI\\The.Outfit.2022.1080p.BluRay.REMUX.AVC.DTS-HD.MA.TrueHD.7.1.Atmos-FGT\\The Outfit (2022) - 1080p.BluRay.REMUX.AVC.DTS-HD.MA.TrueHD.7.1.Atmos-FGT.mkv", "track": [ { "@type": "General", "UniqueID": "195179996658928933669894737660619280613", "VideoCount": "1", "AudioCount": "1", "TextCount": "1", "MenuCount": "1", "FileExtension": "mkv", "Format": "Matroska", "Format_Version": "4", "FileSize": "7243807351", "Duration": "6298.292", "OverallBitRate_Mode": "VBR", "OverallBitRate": "9200980", "FrameRate": "23.976", "FrameCount": "151008", "StreamSize": "54175058", "IsStreamable": "Yes", "Title": "The.Outfit.2022.1080p.BluRay.REMUX.AVC.DTS-HD.MA.TrueHD.7.1.Atmos-FGT", "Movie": "The.Outfit.2022.1080p.BluRay.REMUX.AVC.DTS-HD.MA.TrueHD.7.1.Atmos-FGT", "Encoded_Date": "UTC 2023-01-06 12:24:45", "File_Created_Date": "UTC 2023-01-06 12:27:57.393", "File_Created_Date_Local": "2023-01-06 13:27:57.393", "File_Modified_Date": "UTC 2023-01-06 12:27:28.484", "File_Modified_Date_Local": "2023-01-06 13:27:28.484", "Encoded_Application": "mkvmerge v72.0.0 ('Minuano (Six-eight)') 64-bit", "Encoded_Library": "libebml v1.4.4 + libmatroska v1.7.1 / Lavf58.76.100" }, { "@type": "Video", "StreamOrder": "0", "ID": "1", "UniqueID": "2856776251006202328", "Format": "HEVC", "Format_Profile": "Main", "Format_Level": "4.1", "Format_Tier": "Main", "CodecID": "V_MPEGH/ISO/HEVC", "Duration": "6298.292000000", "BitRate": "5999161", "Width": "1920", "Height": "1080", "Sampled_Width": "1920", "Sampled_Height": "1080", "PixelAspectRatio": "1.000", "DisplayAspectRatio": "1.778", "FrameRate_Mode": "CFR", "FrameRate": "23.976", "FrameCount": "151008", "ColorSpace": "YUV", "ChromaSubsampling": "4:2:0", "BitDepth": "8", "Delay": "0.000", "StreamSize": "4723059131", "Encoded_Library": "x265 - 3.5+1-f0c1022b6:[Windows][clang 12.0.0][64 bit] 8bit+10bit+12bit", "Encoded_Library_Name": "x265", "Encoded_Library_Version": "3.5+1-f0c1022b6:[Windows][clang 12.0.0][64 bit] 8bit+10bit+12bit", "Encoded_Library_Settings": "cpuid=1111039 / frame-threads=3 / numa-pools=12 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=1920x1080 / interlace=0 / total-frames=0 / level-idc=41 / high-tier=1 / uhd-bd=0 / ref=3 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=24 / keyint=240 / gop-lookahead=0 / bframes=4 / b-adapt=0 / b-pyramid / bframe-bias=0 / rc-lookahead=15 / lookahead-slices=6 / scenecut=40 / hist-scenecut=0 / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=0 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / no-strong-intra-smoothing / max-merge=2 / limit-refs=3 / no-limit-modes / me=1 / subme=2 / merange=57 / temporal-mvp / no-frame-dup / no-hme / weightp / no-weightb / no-analyze-src-pics / deblock=0:0 / sao / no-sao-non-deblock / rd=2 / selective-sao=4 / no-early-skip / rskip / fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=0.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=abr / bitrate=6000 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=2 / cplxblur=20.0 / qblur=0.5 / ipratio=1.40 / pbratio=1.30 / aq-mode=1 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=1 / transfer=1 / colormatrix=1 / chromaloc=0 / display-window=0 / cll=0,0 / min-luma=0 / max-luma=255 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / hist-threshold=0.03 / no-opt-cu-delta-qp / no-aq-motion / no-hdr10 / no-hdr10-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=0 / analysis-save-reuse-level=0 / analysis-load-reuse-level=0 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 / scenecut-aware-qp=0conformance-window-offsets / right=0 / bottom=0 / decoder-max-rate=0 / no-vbv-live-multi-pass", "Default": "Yes", "Forced": "No", "colour_description_present": "Yes", "colour_description_present_Source": "Container / Stream", "colour_range": "Limited", "colour_range_Source": "Container / Stream", "colour_primaries": "BT.709", "colour_primaries_Source": "Container / Stream", "transfer_characteristics": "BT.709", "transfer_characteristics_Source": "Container / Stream", "matrix_coefficients": "BT.709", "matrix_coefficients_Source": "Container / Stream" }, { "@type": "Audio", "StreamOrder": "1", "ID": "2", "OriginalSourceMedium_ID": "4352", "UniqueID": "2", "Format": "MLP FBA", "Format_Commercial_IfAny": "Dolby TrueHD with Dolby Atmos", "Format_AdditionalFeatures": "16-ch", "CodecID": "A_TRUEHD", "Duration": "6297.458000000", "BitRate_Mode": "VBR", "BitRate": "3133371", "BitRate_Maximum": "4392000", "Channels": "8", "ChannelPositions": "Front: L C R, Side: L R, Back: L R, LFE", "ChannelLayout": "L R C LFE Ls Rs Lb Rb", "SamplesPerFrame": "40", "SamplingRate": "48000", "SamplingCount": "302277984", "FrameRate": "1200.000", "FrameCount": "7556949", "BitDepth": "24", "Compression_Mode": "Lossless", "Delay": "0.000", "Delay_Source": "Container", "StreamSize": "2466534530", "StreamSize_Proportion": "0.34050", "Title": "TrueHD 7.1 Atmos", "Language": "en", "Default": "Yes", "Forced": "No", "extra": { "OriginalSourceMedium": "Blu-ray", "NumberOfDynamicObjects": "13", "BedChannelCount": "1", "BedChannelConfiguration": "LFE" } }, { "@type": "Text", "StreamOrder": "2", "ID": "3", "UniqueID": "16992795320247175068", "Format": "UTF-8", "CodecID": "S_TEXT/UTF8", "Duration": "5959.620000000", "BitRate": "51", "FrameRate": "0.173", "FrameCount": "1032", "ElementCount": "1032", "StreamSize": "38632", "Language": "hr", "Default": "Yes", "Forced": "No" }, { "@type": "Menu", "extra": { "_00_00_00_000": ":Chapter 1", "_00_05_45_929": ":Chapter 2", "_00_10_16_032": ":Chapter 3", "_00_15_10_660": ":Chapter 4", "_00_18_41_746": ":Chapter 5", "_00_20_57_131": ":Chapter 6", "_00_28_42_512": ":Chapter 7", "_00_32_40_584": ":Chapter 8", "_00_36_29_229": ":Chapter 9", "_00_40_49_072": ":Chapter 10", "_00_43_23_601": ":Chapter 11", "_00_50_55_970": ":Chapter 12", "_00_57_51_385": ":Chapter 13", "_01_04_17_354": ":Chapter 14", "_01_09_23_076": ":Chapter 15", "_01_14_58_285": ":Chapter 16", "_01_21_42_648": ":Chapter 17", "_01_27_56_605": ":Chapter 18", "_01_32_29_461": ":Chapter 19", "_01_39_29_755": ":Chapter 20" } } ] } } doesn't look like there is anything wrong with that. is the file locked. Can you check in mkvtoolnix to see if you can edit something in the headers or a chapter name or something and see if it processes. cheers
purger500 13 Posted January 6, 2023 Posted January 6, 2023 The file is not locked. I tried to rename an chapter and it went fine.
neik 874 Posted January 6, 2023 Posted January 6, 2023 If I got it right, the server is running on Synology, so you would probably need to have a look at the JSON of Synology's mediainfo rather the one being created on your PC as the plugin is relying on the mediainfo within the Synology. The version on Synology pretty old (22 vs. 72ish). Hope I'm not mixing stuff up here. 2
purger500 13 Posted January 6, 2023 Posted January 6, 2023 You got it righet, except I don't know how to update MKXtoolnix on Synology because iz is latest version available on Synocommunity. I will try to cjeck JSON on Synology.
Cheesegeezer 3106 Posted January 6, 2023 Author Posted January 6, 2023 1 minute ago, purger500 said: You got it righet, except I don't know how to update MKXtoolnix on Synology because iz is latest version available on Synocommunity. I will try to cjeck JSON on Synology. this might help you out Various OS Installation Help · Cheesegeezer/MediaInfoWiki Wiki (github.com) 1
rbjtech 5345 Posted January 6, 2023 Posted January 6, 2023 1 minute ago, purger500 said: You got it righet, except I don't know how to update MKXtoolnix on Synology because iz is latest version available on Synocommunity. I will try to cjeck JSON on Synology. If the version on Synology hasn't changed - then we are back to the original point I made - what's changed ?
rbjtech 5345 Posted January 6, 2023 Posted January 6, 2023 3 minutes ago, Cheesegeezer said: this might help you out Various OS Installation Help · Cheesegeezer/MediaInfoWiki Wiki (github.com) Hi Dave - you should probably add that Wiki link into the Plugin Intro itself ? I see there are links to d/l the s/w but not the Wiki ?
purger500 13 Posted January 6, 2023 Posted January 6, 2023 I will try to reinstall everything on Synology
Cheesegeezer 3106 Posted January 6, 2023 Author Posted January 6, 2023 2 minutes ago, rbjtech said: Hi Dave - you should probably add that Wiki link into the Plugin Intro itself ? I see there are links to d/l the s/w but not the Wiki ? Click the big help button and it takes you to the wiki
purger500 13 Posted January 6, 2023 Posted January 6, 2023 I have update: One folder (in which this problematic movie is) has croatian letter "Č" (KRIMINALISTIČKI). I have replace that letter with "C" and all works well now. I don't know what changed as older movies in that folder were processed without any problem. But it works now!!! Many thanks to both of you for your help! Cheers!! 2
rbjtech 5345 Posted January 6, 2023 Posted January 6, 2023 14 minutes ago, purger500 said: I have update: One folder (in which this problematic movie is) has croatian letter "Č" (KRIMINALISTIČKI). I have replace that letter with "C" and all works well now. I don't know what changed as older movies in that folder were processed without any problem. But it works now!!! Many thanks to both of you for your help! Cheers!! ah ha - I wonder what app can't handle the extended character - probably media info cli by the sounds of it. Good catch !
lorac 120 Posted January 23, 2023 Posted January 23, 2023 I've found that if the plugin is running when emby gets restarted or shutdown it reverts back to the default settings and needs to be restored from backup.
Cheesegeezer 3106 Posted January 23, 2023 Author Posted January 23, 2023 20 minutes ago, lorac said: I've found that if the plugin is running when emby gets restarted or shutdown it reverts back to the default settings and needs to be restored from backup. There is nothing i can do about that. It’s obviously forced by an admin or possibly a windows update. the task should be cancelled and the plugin will gracefully exit after it has completed. At no stage during the task itself does it adjust any user settings, so why they are lost is beyond me. only reset functions are set to off when everything has completed. if you have a log with enabled debug mode or more info on what version you are running and what system, this is really helpful. but coming to me with a box of scrap parts and saying it doesn’t work right is a little vague. thanks for reporting and i will test out this for myself tomorrow.
