Andy2k 77 Posted November 16, 2022 Posted November 16, 2022 Quote * mkvpropedit, MKVToolNix GUI's chapter & header editors: updated the list of deprecated Matroska elements. The applications will no longer try to write those elements, even if they're found in the file to be modified. The programs will no longer abort with error messages such as `assertion "false" failed`. Fixes #3416 It's this one, at least on my destroyed files. 1
rbjtech 5345 Posted November 16, 2022 Posted November 16, 2022 33 minutes ago, Andy2k said: It's this one, at least on my destroyed files. Ah ok - I haven't followed too closely tbh, I'm still using .64 haha. But as long as the latest release is tested and confirmed by a few people - then Cheese can just exclude the bad release and allow all the others imo. @Cheesegeezer 1
Regista 7 Posted November 24, 2022 Posted November 24, 2022 On 6/19/2022 at 1:22 PM, Cheesegeezer said: It's released Thanks again everyone Hello i had to reinstall my Synology NAS System. Also my emby server but i do not see this MEDIAINFO PlUGIN in my Emby server. I have installed mediainfo by synocommunity and mkvtoolnix, but i can't see this one in my emby server. Before i had to reinstall everything i had this mediainfo plugin under METADATA, but i do not know what i'm i'm doing wrong right now. Can someone please help me? THANKS
Cheesegeezer 3106 Posted November 24, 2022 Author Posted November 24, 2022 4 minutes ago, Regista said: Hello i had to reinstall my Synology NAS System. Also my emby server but i do not see this MEDIAINFO PlUGIN in my Emby server. I have installed mediainfo by synocommunity and mkvtoolnix, but i can't see this one in my emby server. Before i had to reinstall everything i had this mediainfo plugin under METADATA, but i do not know what i'm i'm doing wrong right now. Can someone please help me? THANKS replied to your PM chief. You're in the right place. for the plugin.
Regista 7 Posted November 24, 2022 Posted November 24, 2022 Everything is working fine again. THANK YOU
Cheesegeezer 3106 Posted November 24, 2022 Author Posted November 24, 2022 10 minutes ago, Regista said: Everything is working fine again. THANK YOU Cheers and glad to hear it. Enjoy fella and keep on Embying haha
lorac 120 Posted November 29, 2022 Posted November 29, 2022 I'm not sure what causes it but this plug-in tends to reset itself frequently. It's rather annoying.
Cheesegeezer 3106 Posted November 29, 2022 Author Posted November 29, 2022 (edited) 6 minutes ago, lorac said: I'm not sure what causes it but this plug-in tends to reset itself frequently. It's rather annoying. Can you elaborate? Do you refresh your metadata every 30days? Edited November 29, 2022 by Cheesegeezer
lorac 120 Posted December 2, 2022 Posted December 2, 2022 No. It seems to have something to do with restarting the server. Maybe during a scan? In any case it's been present since day 1. See attached files. Emby.MediaInfo.xml Emby.MediaInfo.xml.7z
Kevster1968 3 Posted December 6, 2022 Posted December 6, 2022 (edited) I’m useing unraid and the official embyserver docker ,in terms of useing the Mediainfo plugin am I useing the correct docker for this to work? I have the mkvtoolnix docker installed as well on unraid,is that the correct one also ? I read the info on Mediainfo plugin but couldn’t find any information concerning unraid…….I’m after some pointers please to point me in the right direction so I can make this plugin work …..many thanks in advance. Edited December 6, 2022 by Kevster1968
Medic97 4 Posted December 7, 2022 Posted December 7, 2022 Anyone set this up on a qnap? I really want to use this but both apps from qnap club won't work with anything greater than qts 5.0.
neik 874 Posted December 9, 2022 Posted December 9, 2022 Today I just saw a new error: 2022-12-09 05:15:02.469 Info Media Info: PROCESSING OF Das Original HAS STARTED 2022-12-09 05:15:02.469 Info Media Info: Item FilePath = /media/cry/4K/series/Westworld (2016)/S1/Westworld-1x01_Das Original.mkv 2022-12-09 05:15:02.472 Debug Media Info: Starting MediaInfo.exe process 2022-12-09 05:15:02.472 Debug Media Info: using MediaSource Path: /media/cry/4K/series/Westworld (2016)/S1/Westworld-1x01_Das Original.mkv 2022-12-09 05:15:02.472 Debug Media Info: Args= --Output=JSON "/media/cry/4K/series/Westworld (2016)/S1/Westworld-1x01_Das Original.mkv" 2022-12-09 05:15:02.472 Debug Media Info: MediaInfoCLI Path = /usr/bin/mediainfo 2022-12-09 05:15:02.472 Debug Media Info: about to start Media Info Actual process for debug purposes only 2022-12-09 05:15:02.876 Error Media Info: UNABLE TO PROCESS MEDIA INFO 2022-12-09 05:15:02.876 Debug Media Info: Could not load file or assembly 'System.Text.Json, Version=7.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51'. The system cannot find the file specified. 2022-12-09 05:15:02.876 Info Media Info: PROCESSING OF Das Original HAS COMPLETED 2022-12-09 05:15:02.876 Debug Media Info: MediaInfo processing for Das Original and took 407 milliseconds The only difference I could determine is that my system (Ubuntu) did some updates yesterday (not mediainfo or mkvtoolnix though). Anyone else seeing this?
Cheesegeezer 3106 Posted December 9, 2022 Author Posted December 9, 2022 I updated system.text.json in the plugin and maybe emby hasn’t updated theirs. I will revert it to same version in emby server folder 2
sh0rty 728 Posted December 9, 2022 Posted December 9, 2022 (edited) 2022-12-10 00:34:32.085 Info Server: http/1.1 Response 204 to host1. Time: 1ms. http://emby_remote_ip/emby/ScheduledTasks/Running/3dbe52b9c75f0629c3d9b9865b2a1cf8?X-Emby-Client=Emby Web&X-Emby-Device-Name=Google Chrome Windows&X-Emby-Device-Id=d357c2b3-2a4e-41b0-8efd-1c2f084f5fe3&X-Emby-Client-Version=4.7.10.0 2022-12-10 00:34:32.085 Debug TaskManager: Executing Advanced Media Information 2022-12-10 00:34:32.086 Info Media Info: Current OS = WINDOWS 2022-12-10 00:34:32.086 Info Media Info: MEDIAINFO TASK IS STARTING 2022-12-10 00:34:32.086 Debug Media Info: isEnabled = True 2022-12-10 00:34:32.086 Info Media Info: Performing MKV Version Checks......... 2022-12-10 00:34:32.086 Debug Media Info: MKVPROPEDIT EXE: C:\Users\blingbling\Documents\MKVToolNix\mkvpropedit.exe 2022-12-10 00:34:32.348 Info Media Info: MKVPropEdit Process Version: mkvpropedit v70.0.0 ('Caught A Lite Sneeze') 64-bit 2022-12-10 00:34:32.351 Info Media Info: MKVPropEdit Process Version Check Completed with Exit Code: 0 2022-12-10 00:34:32.351 Info Media Info: MKVPROPEDIT VERSION IS 70 - CONGRATS..... THIS VERSION IS SUPPORTED!! 2022-12-10 00:34:32.351 Info Media Info: No. of Libraries selected is 3 2022-12-10 00:34:32.351 Debug Media Info: Internal Library Folder Id = 93129 - Folder Name: Filme 4K 2022-12-10 00:34:32.351 Debug Media Info: Internal Library Folder Id = 3358 - Folder Name: Filme 2022-12-10 00:34:32.351 Debug Media Info: Internal Library Folder Id = 3363 - Folder Name: Serien 2022-12-10 00:34:32.351 Info Media Info: Getting Folder(s) Items 2022-12-10 00:34:32.660 Info Media Info: Total No. of items in Library 2072 2022-12-10 00:34:32.661 Info Media Info: Blade: Trinity with ITEM ID: 106659 will be reprocessed 2022-12-10 00:34:32.661 Debug Media Info: No of mediasources found = 1 2022-12-10 00:34:32.661 Info Media Info: 106659 ITEM ID has been removed from processed list and new MediaInfo Titles will be generated 2022-12-10 00:34:32.661 Info Media Info: MediaInfo Individual ID list has been cleared 2022-12-10 00:34:32.959 Info Media Info: Actual Items to process = 695 2022-12-10 00:34:32.959 Info Media Info: PERFORMING MEDIAINFO EXTRACTION 2022-12-10 00:34:33.055 Info Media Info: PROCESSING OF Blade: Trinity HAS STARTED 2022-12-10 00:34:33.055 Info Media Info: Item FilePath = V:\MOVIES\Movie\Movie.mkv 2022-12-10 00:34:33.055 Debug Media Info: Starting MediaInfo.exe process 2022-12-10 00:34:33.055 Debug Media Info: using MediaSource Path: V:\MOVIES\Movie\Movie.mkv 2022-12-10 00:34:33.055 Debug Media Info: Args= --Output=JSON "V:\MOVIES\Movie\Movie.mkv" 2022-12-10 00:34:33.055 Debug Media Info: MediaInfoCLI Path = C:\Users\blingbling\Documents\MediaInfoCLI\MediaInfo.exe 2022-12-10 00:34:33.056 Debug Media Info: about to start Media Info Actual process for debug purposes only 2022-12-10 00:34:34.491 Error Media Info: UNABLE TO PROCESS MEDIA INFO 2022-12-10 00:34:34.492 Debug Media Info: Could not load file or assembly 'System.Text.Json, Version=7.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51'. Das System kann die angegebene Datei nicht finden. 2022-12-10 00:34:34.492 Info Media Info: PROCESSING OF Movie HAS COMPLETED 2022-12-10 00:34:34.493 Debug Media Info: MediaInfo processing for Movie and took 1438 milliseconds 2022-12-10 00:34:34.494 Debug XmlSerializer: Serializing to file C:\Users\blingbling\AppData\Roaming\Emby-Server\programdata\plugins\configurations\Emby.MediaInfo.xml 2022-12-10 00:34:34.669 Info Media Info: MEDIAINFO TITLES Completed for 695 Videos 2022-12-10 00:34:34.669 Debug XmlSerializer: Serializing to file C:\Users\blingbling\AppData\Roaming\Emby-Server\programdata\plugins\configurations\Emby.MediaInfo.xml 2022-12-10 00:34:34.671 Debug TaskManager: Advanced Media Information Completed after 0 minute(s) and 2 seconds Same here on Windows I guess. Edited December 10, 2022 by shorty1483
Regista 7 Posted December 10, 2022 Posted December 10, 2022 Hello i've seen that the mediainfo plugin has been updated. Its Version 1.0.1.19. Bevor the update the mediainfo plugin was working great all all new files has detected fine so that the informations about DV, HDR, DTSX has been shown at the Top of the movie. Currently its not working. I started the task manually but no luck. Is it a problem with the current emby Version 4.7.10.0 or the plugin which is scanning the files? Has anyone else this problem?
Regista 7 Posted December 10, 2022 Posted December 10, 2022 2022-12-10 08:26:26.693 Info Media Info: MKVPropEdit Process Version Check Completed with Exit Code: 0 2022-12-10 08:26:26.693 Info Media Info: MKVPROPEDIT VERSION IS 22 - CONGRATS..... THIS VERSION IS SUPPORTED!! 2022-12-10 08:26:26.693 Info Media Info: No. of Libraries selected is 3 2022-12-10 08:26:26.693 Info Media Info: Getting Folder(s) Items 2022-12-10 08:26:26.803 Info Media Info: Total No. of items in Library 1078 2022-12-10 08:26:26.806 Info Media Info: Actual Items to process = 4 2022-12-10 08:26:26.806 Info Media Info: PERFORMING MEDIAINFO EXTRACTION 2022-12-10 08:26:26.807 Info Media Info: PROCESSING OF Emancipation HAS STARTED 2022-12-10 08:26:26.807 Info Media Info: Item FilePath = /volume1/Data 1/Movies1/Emancipation.2022.GERMAN.DL.DV.2160P.WEB.H265-WAYNE/Emancipation.2022.GERMAN.DL.DV.2160P.WEB.H265-WAYNE.mkv 2022-12-10 08:26:34.227 Error Media Info: UNABLE TO PROCESS MEDIA INFO 2022-12-10 08:26:34.227 Info Media Info: PROCESSING OF Emancipation HAS COMPLETED This happens at all files currently
Cheesegeezer 3106 Posted December 10, 2022 Author Posted December 10, 2022 Hi all, it appears that linux bases servers have an earlier version of System.Text.Json in the Emby-Server program folder. can someone let me know version they have so i can downgrade is module to a prev version. thanks
neik 874 Posted December 10, 2022 Posted December 10, 2022 Here a screenshot with the information of the file in my Linux setup: Doesn't seem to be a Linux related issue though as shorty experienced the same on Windows. 1 1
sh0rty 728 Posted December 10, 2022 Posted December 10, 2022 17 minutes ago, Cheesegeezer said: Hi all, it appears that linux bases servers have an earlier version of System.Text.Json in the Emby-Server program folder. can someone let me know version they have so i can downgrade is module to a prev version. thanks I have this error on Windows as you can see in my previous post.
Cheesegeezer 3106 Posted December 10, 2022 Author Posted December 10, 2022 8 minutes ago, shorty1483 said: I have this error on Windows as you can see in my previous post. And your error is also due to the json error
neik 874 Posted December 10, 2022 Posted December 10, 2022 FWIW... Reverting back to .18 solves the issue. Probably expected as you already know what the issue is though.
neik 874 Posted December 11, 2022 Posted December 11, 2022 Cheese, just updated to .20 and it solved the issue that came up with .19 Thank you for the quick fix! 1
Regista 7 Posted December 11, 2022 Posted December 11, 2022 Thanks for the Update. Its working fine again. Thank you 1 1
Andy2k 77 Posted December 16, 2022 Posted December 16, 2022 (edited) @Cheesegeezer Just a question about mkvpropedit v72.0....is it in the latest version on the whitelist or still blocked? Edit: Another batch (around 80 files) of movies and tv-show episodes processed with V72.0, still no defective file. Edited December 18, 2022 by Andy2k
purger500 13 Posted January 6, 2023 Posted January 6, 2023 Plugin has stopped working on Synology, server version 4.7.11.0 2023-01-06 11:15:44.761 Info Media Info: Current OS = LINUX 2023-01-06 11:15:44.761 Info Media Info: MEDIAINFO TASK IS STARTING 2023-01-06 11:15:44.761 Info Media Info: Performing MKV Version Checks......... 2023-01-06 11:15:44.933 Info Media Info: MKVPropEdit Process Version: mkvpropedit v22.0.0 ('At The End Of The World') 64-bit 2023-01-06 11:15:44.939 Info Media Info: MKVPropEdit Process Version Check Completed with Exit Code: 0 2023-01-06 11:15:44.939 Info Media Info: MKVPROPEDIT VERSION IS 22 - CONGRATS..... THIS VERSION IS SUPPORTED!! 2023-01-06 11:15:44.946 Info Media Info: No. of Libraries selected is 3 2023-01-06 11:15:44.946 Info Media Info: Getting Folder(s) Items 2023-01-06 11:15:45.868 Info Media Info: Total No. of items in Library 3719 2023-01-06 11:15:45.876 Info Media Info: Actual Items to process = 1 2023-01-06 11:15:45.876 Info Media Info: PERFORMING MEDIAINFO EXTRACTION 2023-01-06 11:15:45.877 Info Media Info: PROCESSING OF The Outfit HAS STARTED 2023-01-06 11:15:45.877 Info Media Info: Item FilePath = /volume1/FILMOVI/FILMOVI/KRIMINALISTIČKI/The.Outfit.2022.1080p.BluRay.REMUX.AVC.DTS-HD.MA.TrueHD.7.1.Atmos-FGT/The Outfit (2022) - 1080p.BluRay.REMUX.AVC.DTS-HD.MA.TrueHD.7.1.Atmos-FGT.mkv 2023-01-06 11:15:46.039 Error Media Info: UNABLE TO PROCESS MEDIA INFO 2023-01-06 11:15:46.039 Info Media Info: PROCESSING OF The Outfit HAS COMPLETED
