FrostByte 5428 Posted November 4, 2022 Posted November 4, 2022 (edited) How did you install the tools? Did you install them from SynoCommunity? Here are the paths. They are in appstore, not appdata /volume1/@appstore/mediainfo/bin/mediainfo /volume1/@appstore/mkvtoolnix/bin/mkvpropedit Edited November 4, 2022 by FrostByte
Regista 7 Posted November 4, 2022 Posted November 4, 2022 (edited) Found it Edited November 4, 2022 by Regista 1
Regista 7 Posted November 4, 2022 Posted November 4, 2022 For your information: I've installed one HDD (1x16TB Seagate) on my synology System. This is volume1. Maybe thats important.
Regista 7 Posted November 4, 2022 Posted November 4, 2022 (edited) Ok its working fine for that movie But for the other movies, its not working Do i have to configure something else? I did a new Scan of the complete libary and startet the task mediatoolbox manually but no luck thank you Edited November 4, 2022 by Regista
Regista 7 Posted November 4, 2022 Posted November 4, 2022 (edited) Ok i think i found the issue. If i remove the movies, step by step from the database, do a rescan, and add the removed movies to the database again, the mediainfo plugin is working Edited November 4, 2022 by Regista
mbguy 40 Posted November 5, 2022 Posted November 5, 2022 17 hours ago, Regista said: This is interesting, I have seen this kind of weird text in the "Video:" section before. Mediainfo would fail to scan these files. I solved it by completely removing all metadata saved within the folder, using TinyMediaManager to create new metadata, scanning the Emby library one more time and finally running Mediainfo again.
Cheesegeezer 3104 Posted November 5, 2022 Author Posted November 5, 2022 2 hours ago, mbguy said: This is interesting, I have seen this kind of weird text in the "Video:" section before. Mediainfo would fail to scan these files. I solved it by completely removing all metadata saved within the folder, using TinyMediaManager to create new metadata, scanning the Emby library one more time and finally running Mediainfo again. can you share the MediaInfo Json for the file please.
mbguy 40 Posted November 5, 2022 Posted November 5, 2022 17 hours ago, Cheesegeezer said: can you share the MediaInfo Json for the file please. Sorry, didn't keep track of which files. I just remember removing all saved metadata and did a re-scan which solved the issue. I will pay attention from now on, if I come across one again, will share right away!
Cheesegeezer 3104 Posted November 5, 2022 Author Posted November 5, 2022 1 minute ago, mbguy said: Sorry, didn't keep track of which files. I just remember removing all saved metadata and did a re-scan which solved the issue. I will pay attention from now on, if I come across one again, will share right away! That’s great and appreciate it. It’s a constant learning and tweaking road with the mediaInfo side. But we should get there glad you are all sorted fella 1
TheGru 149 Posted November 8, 2022 Posted November 8, 2022 On 10/23/2022 at 5:04 PM, MrLinford said: I got this working on Docker version of emby server ! Care to provide instructions? Thanks!
rbjtech 5332 Posted November 8, 2022 Posted November 8, 2022 16 minutes ago, TheGru said: Care to provide instructions? Thanks! @MrLinford Yes please do provide this info if you can - I can then add to the Wiki as currently it states Docker is not supported .. Thanks. https://github.com/Cheesegeezer/MediaInfoWiki/wiki/Various-OS-Installation-Help 1
MrLinford 62 Posted November 9, 2022 Posted November 9, 2022 21 hours ago, TheGru said: Care to provide instructions? Thanks! I'll work on one sure 2
MrLinford 62 Posted November 9, 2022 Posted November 9, 2022 (edited) On 08/11/2022 at 12:35, rbjtech said: @MrLinford Yes please do provide this info if you can - I can then add to the Wiki as currently it states Docker is not supported .. Thanks. https://github.com/Cheesegeezer/MediaInfoWiki/wiki/Various-OS-Installation-Help I have now created a shell script to run with "emby" docker container, you can find it here: https://github.com/MrLinford/Docker-MediaInfo-PreReq Here is my quick guide on how to install the dependencies for Media Toolbox when running EMBY in a Docker Container. A few notes: You must be running the https://github.com/linuxserver/docker-emby container You will have to reinstall the dependencies when a new docker image is used. # **MediaInfo For Emby running in Docker** **A few notes:** You must be running the https://github.com/linuxserver/docker-emby container You will have to reinstall the dependencies when a new docker image is used. --- **First you need to connect to the emby container:** `docker exec -it <container> bash` --- **Install mediainfo (https://mediaarea.net/en/MediaInfo/Download/Ubuntu):** `apt update` `apt-get install mediainfo` --- **Install mkvtoolnix (https://mkvtoolnix.download/downloads.html#ubuntu):** `curl -o /usr/share/keyrings/gpg-pub-moritzbunkus.gpg https://mkvtoolnix.download/gpg-pub-moritzbunkus.gpg` `cd /etc/apt/sources.list.d` `touch mkvtoolnix.download.list` `cat > mkvtoolnix.download.list << EOF deb [signed-by=/usr/share/keyrings/gpg-pub-moritzbunkus.gpg] https://mkvtoolnix.download/ubuntu/ jammy main deb-src [signed-by=/usr/share/keyrings/gpg-pub-moritzbunkus.gpg] https://mkvtoolnix.download/ubuntu/ jammy main EOF` Now run `apt update` followed by `apt install mkvtoolnix=70.0.0-0~ubuntu2204bunkus01 mkvtoolnix-gui=70.0.0-0~ubuntu2204bunkus01` --- **Download BifTool Executables:** `curl -Lo /tmp/biftool_linux.zip https://github.com/rokudev/samples/raw/master/utilities/bif%20tool/biftool_linux.zip` **Installed unzip:** `apt-get install unzip` **Extract BifTool zip file to /bin/:** `unzip /tmp/biftool_linux.zip -d /bin` --- Configure the Media Toolbox plugin, applications installed will be located in `/bin/` Edited May 7, 2023 by MrLinford Updated Guide 13/12/2022 3
rbjtech 5332 Posted November 9, 2022 Posted November 9, 2022 (edited) 1 hour ago, MrLinford said: Here is my quick guide on how to install the dependencies for Media Toolbox when running EMBY in a Docker Container. A few notes: I run the https://github.com/linuxserver/docker-emby container You will have to reinstall the dependencies when a new docker image is used. # **MediaInfo For Emby running in Docker** **First you need to connect to the emby containter:** `docker exec -it <container> bash` --- **Install mediainfo (https://mediaarea.net/en/MediaInfo/Download/Ubuntu):** `apt-get install mediainfo` --- **Install mkvtoolnix (https://mkvtoolnix.download/downloads.html#ubuntu):** `curl -o /usr/share/keyrings/gpg-pub-moritzbunkus.gpg https://mkvtoolnix.download/gpg-pub-moritzbunkus.gpg` `cd /etc/apt/sources.list.d` `touch mkvtoolnix.download.list` `cat > mkvtoolnix.download.list` **Paste the below the Crtl+D to exit:** deb [signed-by=/usr/share/keyrings/gpg-pub-moritzbunkus.gpg] https://mkvtoolnix.download/ubuntu/ jammy main deb-src [signed-by=/usr/share/keyrings/gpg-pub-moritzbunkus.gpg] https://mkvtoolnix.download/ubuntu/ jammy main Now simply run `apt update` followed by `apt install mkvtoolnix mkvtoolnix-gui` --- **Download BifTool Executables:** `curl -Lo /tmp/biftool_linux.zip https://github.com/rokudev/samples/raw/master/utilities/bif%20tool/biftool_linux.zip` **Installed unzip:** `apt-get install unzip` **Extract BifTool zip file to /bin/:** `unzip /tmp/biftool_linux.zip -d /bin` --- Configure the Media Toolbox plugin, applications installed will be located in `/bin/` Fantastic - thankyou. I have added into the Wiki via a link to your post and also copied verbatim into Wiki itself - I trust this is ok. Various OS Installation Help · Cheesegeezer/MediaInfoWiki Wiki (github.com) Edited November 9, 2022 by rbjtech 1 1
MrLinford 62 Posted November 9, 2022 Posted November 9, 2022 7 minutes ago, rbjtech said: Fantastic - thankyou. I have added into the Wiki via a link to your post and also copied verbatim into Wiki itself - I trust this is ok. Various OS Installation Help · Cheesegeezer/MediaInfoWiki Wiki (github.com) Of course, i even added an issue on git for it https://github.com/Cheesegeezer/MediaInfoWiki/issues/1 1
rbjtech 5332 Posted November 9, 2022 Posted November 9, 2022 5 minutes ago, MrLinford said: You may also want to update this: I missed that - fixed - thanks !
MrLinford 62 Posted November 9, 2022 Posted November 9, 2022 Updated Docker instructions as new version of mkvtoolnix is out 71, but not support by you yet. So change `apt install mkvtoolnix mkvtoolnix-gui` to `apt install mkvtoolnix=70.0.0-0~ubuntu2204bunkus01 mkvtoolnix-gui=70.0.0-0~ubuntu2204bunkus01` 2 1
Cheesegeezer 3104 Posted November 9, 2022 Author Posted November 9, 2022 3 minutes ago, MrLinford said: Updated Docker instructions as new version of mkvtoolnix is out 71, but not support by you yet. So change `apt install mkvtoolnix mkvtoolnix-gui` to `apt install mkvtoolnix=70.0.0-0~ubuntu2204bunkus01 mkvtoolnix-gui=70.0.0-0~ubuntu2204bunkus01` and it wont be because it's not been tested and there was a huge bug in that release. Really appreciate your contribution MrLindford 1
rbjtech 5332 Posted November 9, 2022 Posted November 9, 2022 5 minutes ago, MrLinford said: Updated Docker instructions as new version of mkvtoolnix is out 71, but not support by you yet. So change `apt install mkvtoolnix mkvtoolnix-gui` to `apt install mkvtoolnix=70.0.0-0~ubuntu2204bunkus01 mkvtoolnix-gui=70.0.0-0~ubuntu2204bunkus01` Updated - thanks - this is key as v71 corrupts some MKV's ...
TheGru 149 Posted November 9, 2022 Posted November 9, 2022 Bummer I am using the https://registry.hub.docker.com/r/emby/embyserver/ beta on Unraid and apparently that is not built on ubuntu and the commands are not the same. 1
sydlexius 297 Posted November 9, 2022 Posted November 9, 2022 5 hours ago, rbjtech said: Fantastic - thankyou. I have added into the Wiki via a link to your post and also copied verbatim into Wiki itself - I trust this is ok. Various OS Installation Help · Cheesegeezer/MediaInfoWiki Wiki (github.com) Just FYI, this will not work for the official Emby container...still, the LinuxServer container has a great reputation and is widely used. Thanks @MrLinford! 1
MrLinford 62 Posted November 9, 2022 Posted November 9, 2022 1 hour ago, TheGru said: Bummer I am using the https://registry.hub.docker.com/r/emby/embyserver/ beta on Unraid and apparently that is not built on ubuntu and the commands are not the same. Not sure what the official emby container is built on. But you can always switch. 1
sydlexius 297 Posted November 9, 2022 Posted November 9, 2022 2 hours ago, MrLinford said: Not sure what the official emby container is built on. But you can always switch. Given some of the headaches recently experienced by the LSIO team with missing artifacts for the beta builds (from what I understand, this is an issue with Emby itself), I'll probably wait until that gets sorted.
