Trevor68 70 Posted October 14, 2022 Posted October 14, 2022 I think I have it now, looks like it ran and built a (zero) list when the paths were incorrect, I just had to use the refresh setting after correcting the paths. 1
lorac 120 Posted October 21, 2022 Posted October 21, 2022 I like this plugin but it has an annoying tendency to reset itself from time to time which is what I believe leaves to the media titles with the HD 1080P AVC... I know I reconfigured it not just two days ago and today it's been reset.
Cheesegeezer 3106 Posted October 21, 2022 Author Posted October 21, 2022 3 minutes ago, lorac said: I like this plugin but it has an annoying tendency to reset itself from time to time which is what I believe leaves to the media titles with the HD 1080P AVC... I know I reconfigured it not just two days ago and today it's been reset. Hi there i'm not sure i understand. Are you saying the "use embedded title" setting is reverted to use display titles. When the plugin runs it actually sets this setting to use "Embedded Titles" so i can't see why this would happen. Also this only works with MKV containers. 1
rbjtech 5345 Posted October 21, 2022 Posted October 21, 2022 Also to add, this plugin changes the actual MKV headers (track titles) - so worth looking at it via mediaInfo itself to see if it's track titles have been changed - if they haven't, then the problem is squarely with emby somewhere .. if they have, then perhaps they have been overwritten/re-acquired. Because the plugin keeps track of what it has changed (by Itemid), it won't attempt that item again - so you need to force it using the 're-process' option within the plugin. 1
Trevor68 70 Posted October 21, 2022 Posted October 21, 2022 Just a note that the plugin never changed that setting here, I did it manually.
lorac 120 Posted October 21, 2022 Posted October 21, 2022 No i mean that the plugin configuration (essentially the xml file) gets reset. The paths to all the exe files revert to blank as well as any settings. Basically what you'd see when you first launch it. I believe the processed list remains intact as the file had over 20K entries. new 6.txt
MrLinford 62 Posted October 23, 2022 Posted October 23, 2022 I got this working on Docker version of emby server !
mbguy 40 Posted October 25, 2022 Posted October 25, 2022 (edited) Hi, I am on latest release version 1.0.1.10 and having an issue of the "Advanced media Information" progress bar in "Scheduled Tasks" stuck at 0% It's strange because the first it ran, it went all the way to 67.9% and got stuck there. I tried stopping and starting it manually but it just wouldn't move past 67.9%. So I restarted Emby Server and windows hoping to solve the issue, but now it won't even move past 0.0%. If I stopped it manually, the status would just be stuck in "Stopping" forever. I know it can't be the paths because many of my titles are showing the new advanced media info as I configured, but many titles are still left unchanged. I did a "Scan media library" and it went to 100% without issues so I don't think it's a library issue. Anything else I can try to fix this? What are the recommended next steps? Thanks. Edited October 25, 2022 by mbguy
Cheesegeezer 3106 Posted October 25, 2022 Author Posted October 25, 2022 2 hours ago, mbguy said: Hi, I am on latest release version 1.0.1.10 and having an issue of the "Advanced media Information" progress bar in "Scheduled Tasks" stuck at 0% It's strange because the first it ran, it went all the way to 67.9% and got stuck there. I tried stopping and starting it manually but it just wouldn't move past 67.9%. So I restarted Emby Server and windows hoping to solve the issue, but now it won't even move past 0.0%. If I stopped it manually, the status would just be stuck in "Stopping" forever. I know it can't be the paths because many of my titles are showing the new advanced media info as I configured, but many titles are still left unchanged. I did a "Scan media library" and it went to 100% without issues so I don't think it's a library issue. Anything else I can try to fix this? What are the recommended next steps? Thanks. Can you please provide a debug log. PM me if you want to keep it private. Thanks
bill_w 1 Posted October 28, 2022 Posted October 28, 2022 I just installed 1.0.1.10 and gave it a try. It seems to be unable to find the executables, although I have given it the full paths (both are in the default location in /usr/bin) to each. This is on Ubuntu 22.04. Any suggestions? 2022-10-28 02:01:56.035 Info Media Info: PERFORMING MEDIAINFO EXTRACTION ON MOVIES 2022-10-28 02:01:56.035 Info Media Info: PROCESSING OF The Quatermass Experiment HAS STARTED 2022-10-28 02:01:56.035 Info Media Info: Item FilePath = /data/Media/Videos/Movies/The Quatermass Experiment (1953)/The Quatermass Experiment (1953) - 576i.mkv 2022-10-28 02:01:56.036 Warn Media Info: FileName for MEDIAINFOCLI must me CORRECT 2022-10-28 02:01:56.036 Warn Media Info: MEDIA INFO CANNOT CONTINUE
Cheesegeezer 3106 Posted October 28, 2022 Author Posted October 28, 2022 8 minutes ago, bill_w said: I just installed 1.0.1.10 and gave it a try. It seems to be unable to find the executables, although I have given it the full paths (both are in the default location in /usr/bin) to each. This is on Ubuntu 22.04. Any suggestions? 2022-10-28 02:01:56.035 Info Media Info: PERFORMING MEDIAINFO EXTRACTION ON MOVIES 2022-10-28 02:01:56.035 Info Media Info: PROCESSING OF The Quatermass Experiment HAS STARTED 2022-10-28 02:01:56.035 Info Media Info: Item FilePath = /data/Media/Videos/Movies/The Quatermass Experiment (1953)/The Quatermass Experiment (1953) - 576i.mkv 2022-10-28 02:01:56.036 Warn Media Info: FileName for MEDIAINFOCLI must me CORRECT 2022-10-28 02:01:56.036 Warn Media Info: MEDIA INFO CANNOT CONTINUE So, @softworkz really helped me out with the linux integration for this plugin, but it seems like all the recent issues are from Linux Based users. I don't know if something has changed here. Let me update the catalogue to 1.0.1.14 which hopefully will fix issues. Can you get back to me and let me know if this fixes your issues. Cheers buddy
rbjtech 5345 Posted October 28, 2022 Posted October 28, 2022 Agreed - think we may need to update the Wiki ? https://github.com/Cheesegeezer/MediaInfoWiki/wiki Specifically - https://github.com/Cheesegeezer/MediaInfoWiki/wiki/Various-OS-Installation-Help#4-linux Let us know if that helps - if not, we can reach out for more Linux assistance - as it's a 'Linux OS/Permissions' issue rather a plugin issue.
Cheesegeezer 3106 Posted October 28, 2022 Author Posted October 28, 2022 updated the catalogue V1.0.1.14 - introduces some fixes and features Hopefully fix Linux file issues introduce mediaInfo for difference versions of the same media(multiversion support) random bug fixes and improved debug logging 1
bill_w 1 Posted October 28, 2022 Posted October 28, 2022 43 minutes ago, Cheesegeezer said: Let me update the catalogue to 1.0.1.14 which hopefully will fix issues. Can you get back to me and let me know if this fixes your issues. It looks like that did the trick. I haven't looked at the results yet, but at least it is running now. 1
Andy2k 77 Posted October 28, 2022 Posted October 28, 2022 (edited) Hi, not sure what you changed, but this version is now completely broken under linux (Ubuntu 22.04, Server Version 4.8.0.15 beta). This version process the files, but do nothing. There are some errors in the log: 2022-10-28 21:37:08.594 Debug Media Info: MEDIAINFO TASK IS STARTING 2022-10-28 21:37:08.594 Debug Media Info: isEnabled = True 2022-10-28 21:37:08.598 Info Media Info: 597799 ITEM ID has been removed from processed list and new MediaInfo Titles will be generated 2022-10-28 21:37:08.598 Info Media Info: MediaInfo Individual ID list has been cleared 2022-10-28 21:37:08.598 Info Media Info: Getting Episodes in Library 2022-10-28 21:37:12.515 Info Media Info: Total Episodes in Library = 12027 2022-10-28 21:37:12.515 Info Media Info: Filtering MKV Episodes 2022-10-28 21:37:12.806 Error Media Info: System.NullReferenceException: Object reference not set to an instance of an object. at Emby.MediaInfo.ScheduledTasks.MediaInfoScheduledTask.Execute(CancellationToken cancellationToken, IProgress`1 progress) 2022-10-28 21:37:12.806 Info Media Info: NO MKV EPISODES FOUND 2022-10-28 21:37:14.507 Info Media Info: Total Movies in Library = 3586 2022-10-28 21:37:14.507 Info Media Info: Filtering MKV Movies 2022-10-28 21:37:14.531 Info Media Info: Actual Movies to process = 1 2022-10-28 21:37:14.532 Debug Media Info: Ep items = 0 2022-10-28 21:37:14.532 Debug Media Info: mov items = 1 2022-10-28 21:37:14.532 Info Media Info: Total items to process = 1 2022-10-28 21:37:14.532 Info Media Info: PERFORMING MEDIAINFO EXTRACTION ON MOVIES 2022-10-28 21:37:14.534 Info Media Info: PROCESSING OF Bekenntnisse des Hochstaplers Felix Krull HAS STARTED 2022-10-28 21:37:14.534 Info Media Info: Item FilePath = \\192.168.0.40\video\Filme\Web-DL HD & UHD\Bekenntnisse des Hochstaplers Felix Krull (1957)\Bekenntnisse des Hochstaplers Felix Krull (1957) 1080p DTS Blu-ray.mkv 2022-10-28 21:37:14.534 Debug Media Info: Starting MediaInfo.exe process 2022-10-28 21:37:14.560 Debug Media Info: Reset Embedded Titles = False 2022-10-28 21:37:14.561 Debug Media Info: Object reference not set to an instance of an object. 2022-10-28 21:37:14.561 Info Media Info: PROCESSING OF 1080p DTS Blu-ray HAS COMPLETED 2022-10-28 21:37:14.563 Debug Media Info: MediaInfo processing for 1080p DTS Blu-ray and took 28 milliseconds 2022-10-28 21:37:14.563 Debug XmlSerializer: Serializing to file /var/lib/emby/plugins/configurations/Emby.MediaInfo.xml 2022-10-28 21:37:14.584 Info Media Info: MEDIAINFO EXTRACTION ON MOVIES Completed for 3586 Movies 2022-10-28 21:37:14.584 Debug XmlSerializer: Serializing to file /var/lib/emby/plugins/configurations/Emby.MediaInfo.xml 2022-10-28 21:37:14.605 Info Media Info: Media Info has triggered Run Metadata Refresh In addition, i saw only a metadata refresh, no library scan after proccesing, compared to the version before. A (short) downgrade to version 1.0.1.10 worked like before, so its not the new beta server from today. Also i think i discovered another bug: I got some movies with a default languages on the video-track, show below: These files was playable with emby, vlc,...before processing. Processing these files with the plugin resulted in an really really destroyed mkv, not playable anymore and mkvtoolnix does not show a video track anymore. Changing the video-track language to "undefined" (clearing it) and remuxing it was the "solution" for me, after this the plugin did his job as intended. Andy Edited October 28, 2022 by Andy2k
bill_w 1 Posted October 28, 2022 Posted October 28, 2022 The job completed successfully and tagged about 95% of my content. The results look great and I am really happy with them. There were about 5% that couldn't be processed. This is an example: 2022-10-28 11:42:42.633 Info Media Info: PROCESSING OF Alexander HAS STARTED 2022-10-28 11:42:42.633 Info Media Info: Item FilePath = /Movies/Alexander (2004)/Alexander (2004) - 1080p.mkv 2022-10-28 11:42:42.902 Info Media Info: Video Track successfully Written & Exited with Code 2 2022-10-28 11:42:42.902 Info Media Info: Video Track Title Set to HD 1080p VC-1 [16.9Mb/s] 2022-10-28 11:42:42.911 Warn Media Info: Replace Audio Track Failed to update Track Title & Exited with Code 2 2022-10-28 11:42:42.916 Warn Media Info: Replace Audio Track Failed to update Track Title & Exited with Code 2 2022-10-28 11:42:42.917 Warn Media Info: Replace Audio Track Failed to update Track Title & Exited with Code 2 2022-10-28 11:42:42.918 Info Media Info: Item Tags found = 2022-10-28 11:42:42.918 Info Media Info: PROCESSING OF 1080p HAS COMPLETED There is nothing different about the permissions on this file from all the rest and all were ripped with makemkv with the same settings.
Andy2k 77 Posted October 29, 2022 Posted October 29, 2022 @bill_w In the time i started with the Media Info Plugin i got myself a handfull files with Code 2. I retested these with VLC and MKVToolnix and found out these files was corrupted in different ways. Some are not even playable, others was playable, but chapter skipping or fast forward / fast rewind does not worked on these files. It seems something went wrong during muxing in my case. Andy 1
Cheesegeezer 3106 Posted October 29, 2022 Author Posted October 29, 2022 18 hours ago, bill_w said: The job completed successfully and tagged about 95% of my content. The results look great and I am really happy with them. There were about 5% that couldn't be processed. This is an example: 2022-10-28 11:42:42.633 Info Media Info: PROCESSING OF Alexander HAS STARTED 2022-10-28 11:42:42.633 Info Media Info: Item FilePath = /Movies/Alexander (2004)/Alexander (2004) - 1080p.mkv 2022-10-28 11:42:42.902 Info Media Info: Video Track successfully Written & Exited with Code 2 2022-10-28 11:42:42.902 Info Media Info: Video Track Title Set to HD 1080p VC-1 [16.9Mb/s] 2022-10-28 11:42:42.911 Warn Media Info: Replace Audio Track Failed to update Track Title & Exited with Code 2 2022-10-28 11:42:42.916 Warn Media Info: Replace Audio Track Failed to update Track Title & Exited with Code 2 2022-10-28 11:42:42.917 Warn Media Info: Replace Audio Track Failed to update Track Title & Exited with Code 2 2022-10-28 11:42:42.918 Info Media Info: Item Tags found = 2022-10-28 11:42:42.918 Info Media Info: PROCESSING OF 1080p HAS COMPLETED There is nothing different about the permissions on this file from all the rest and all were ripped with makemkv with the same settings. What's strange is the Processing of 1080p Has completed. That should show the name of the movie, not the end bit.
sh0rty 728 Posted October 29, 2022 Posted October 29, 2022 Win 10 x64, Latest Emby Beta 4.8.0.14, Tool Version 1.0.1.14 (updated today after server start) Since the .14 Update, the tool simply does nothing with my files. Did not change any configuration, yesterday the 1.0.1.10 version did the job flawlessly like the weeks before. But after the update today, nothing. Track infos did not change inside the files. serverlog.txt 1
bill_w 1 Posted October 29, 2022 Posted October 29, 2022 @Andy2k That was a useful clue. I forgot that, at least in this example, this was a two part movie that I joined with mkvmerge. You can see that under Writing application. And it appears to me that it didn't fix the chapters when it merged them - it just added one set after the other. I rarely use chapters, so I've never noticed. The movie otherwise plays just fine. I can rename the streams with mkvtoonix without any complaints. So, I'm curious why this breaks tagging the streams. Is there something in here that reveals the problem? General Unique ID : 160119021817506163083374888403976412869 (0x7875CD47E7AC59C2FC5F502E4CB95EC5) Complete name : Alexander (2004) - 1080p.mkv Format : Matroska Format version : Version 4 File size : 26.8 GiB Duration : 3 h 33 min Overall bit rate : 17.9 Mb/s Encoded date : UTC 2020-10-14 01:17:52 Writing application : mkvmerge v65.0.0 ('Too Much') 64-bit Writing library : libebml v1.4.2 + libmatroska v1.6.3 Video ID : 1 Format : VC-1 Format profile : Advanced@L3 Codec ID : V_MS/VFW/FOURCC / WVC1 Codec ID/Hint : Microsoft Duration : 3 h 33 min Bit rate : 16.9 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Compression mode : Lossy Bits/(Pixel*Frame) : 0.339 Stream size : 25.2 GiB (94%) Language : English Default : No Forced : No Audio #1 ID : 2 Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : A_AC3 Duration : 3 h 33 min Bit rate mode : Constant Bit rate : 640 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 978 MiB (4%) Title : Surround 5.1 Language : English Service kind : Complete Main Default : Yes Forced : No Audio #2 ID : 3 Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Format settings : Dolby Surround Codec ID : A_AC3 Duration : 3 h 33 min Bit rate mode : Constant Bit rate : 192 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 293 MiB (1%) Title : Stereo Language : English Service kind : Complete Main Default : No Forced : No Audio #3 ID : 4 Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Format settings : Dolby Surround Codec ID : A_AC3 Duration : 3 h 33 min Bit rate mode : Constant Bit rate : 192 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 293 MiB (1%) Title : Stereo Language : English Service kind : Complete Main Default : No Forced : No Text #1 ID : 5 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 3 h 30 min Bit rate : 28.1 kb/s Count of elements : 4118 Stream size : 42.2 MiB (0%) Language : English Default : No Forced : No Text #2 ID : 6 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 3 h 30 min Bit rate : 30.6 kb/s Count of elements : 4554 Stream size : 46.2 MiB (0%) Language : English Default : No Forced : No Text #3 ID : 7 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 3 h 31 min Bit rate : 29.3 kb/s Count of elements : 4193 Stream size : 44.3 MiB (0%) Language : French Default : No Forced : No Text #4 ID : 8 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 3 h 31 min Bit rate : 28.9 kb/s Count of elements : 4254 Stream size : 43.8 MiB (0%) Language : Spanish Default : No Forced : No Menu 00:00:00.000 : en:Chapter 01 00:04:07.247 : en:Chapter 02 00:07:51.429 : en:Chapter 03 00:12:37.506 : en:Chapter 04 00:16:08.968 : en:Chapter 05 00:24:01.606 : en:Chapter 06 00:29:55.794 : en:Chapter 07 00:35:51.149 : en:Chapter 08 00:38:07.159 : en:Chapter 09 00:42:15.533 : en:Chapter 10 00:49:15.243 : en:Chapter 11 00:54:46.700 : en:Chapter 12 01:00:43.931 : en:Chapter 13 01:05:00.855 : en:Chapter 14 01:08:14.006 : en:Chapter 15 01:10:46.367 : en:Chapter 16 01:13:01.710 : en:Chapter 17 01:18:29.705 : en:Chapter 18 01:20:42.379 : en:Chapter 19 01:27:28.493 : en:Chapter 20 01:32:45.017 : en:Chapter 21 01:36:43.088 : en:Chapter 22 01:41:57.111 : en:Chapter 23 01:48:50.232 : en:Chapter 24 01:55:07.901 : en:Chapter 25 02:00:33.100 : en:Chapter 26 02:04:52.443 : en:Chapter 27 02:06:21.632 : en:Chapter 01 02:12:16.027 : en:Chapter 02 02:16:04.297 : en:Chapter 03 02:22:05.950 : en:Chapter 04 02:25:06.630 : en:Chapter 05 02:29:12.501 : en:Chapter 06 02:32:48.133 : en:Chapter 07 02:39:16.062 : en:Chapter 08 02:40:40.105 : en:Chapter 09 02:46:08.016 : en:Chapter 10 02:51:52.193 : en:Chapter 11 02:57:12.221 : en:Chapter 12 03:02:28.704 : en:Chapter 13 03:06:33.198 : en:Chapter 14 03:07:53.236 : en:Chapter 15 03:09:37.966 : en:Chapter 16 03:13:39.415 : en:Chapter 17 03:16:13.361 : en:Chapter 18 03:22:16.932 : en:Chapter 19 03:25:23.619 : en:Chapter 20
bill_w 1 Posted October 29, 2022 Posted October 29, 2022 For what it's worth, I fixed the chapters in mkvtoolnix and that didn't change the result.
Andy2k 77 Posted October 29, 2022 Posted October 29, 2022 In addition to my post, and at least abit funny... With the last version movies in 1080p dont get processed, but serie episodes in 720p....
mbguy 40 Posted October 30, 2022 Posted October 30, 2022 (edited) oh no, after running Mediainfo v1.0.14 on Windows today, many of my mkv files produce "Cannot render file" error when opening with MPC-HC. VLC can open the files but video is gone, only album arts shows during the entire video while the sound plays. Something is seriously wrong, and it seems hundreds of my files are "destroyed" like this. I haven't had time to dig into the log files yet, but is this a common thing and is there a quick fix? Edited October 30, 2022 by mbguy
Cheesegeezer 3106 Posted October 30, 2022 Author Posted October 30, 2022 4 hours ago, mbguy said: oh no, after running Mediainfo v1.0.14 on Windows today, many of my mkv files produce "Cannot render file" error when opening with MPC-HC. VLC can open the files but video is gone, only album arts shows during the entire video while the sound plays. Something is seriously wrong, and it seems hundreds of my files are "destroyed" like this. I haven't had time to dig into the log files yet, but is this a common thing and is there a quick fix? The plugin doesn’t touch or remux any video or audio streams it simply writes a header to the the title field. can you share a mediaInfo json output for an example and also debug log when you run the task. revert back to previous version in catalog if you want. This version simply added multiversion support and it was tested on about 30K episodes and movies with multiversions. ill pull 1.0.14 from the catalog
mbguy 40 Posted October 30, 2022 Posted October 30, 2022 2 hours ago, Cheesegeezer said: The plugin doesn’t touch or remux any video or audio streams it simply writes a header to the the title field. can you share a mediaInfo json output for an example and also debug log when you run the task. I only had limited time tonight but I noticed in today's log there are 362 entries with *** Error Reports *** These 362 error reports point directly to 362 videos that now have "cannot render file" status after running MediaInfo 1.0.14 Not sure if these files are permanently damaged, I sincerely hope they can be "rescued". This is an example of the section that repeats 362 times for each of the "killed" files: 2022-10-29 09:49:45.343 Debug App: Refreshing \\My Computer\TV Shows\Parks and Recreation\Season 3\Parks.And.Recreation.S03E16.720p.HDTV.x264.mkv due to date modified change 1666599723 - 1667058145. 2022-10-29 09:49:45.343 Debug App: FFProbeProvider reports change to 457868 - \\My Computer\TV Shows\Parks and Recreation\Season 3\Parks.And.Recreation.S03E16.720p.HDTV.x264.mkv 2022-10-29 09:49:45.343 Debug App: Running FFProbeProvider for \\My Computer\TV Shows\Parks and Recreation\Season 3\Parks.And.Recreation.S03E16.720p.HDTV.x264.mkv 2022-10-29 09:49:45.343 Info MediaProbeManager: ProcessRun 'ffprobe' Execute: C:\Users\admin\AppData\Roaming\Emby-Server\system\ffprobe.exe -i file:"\\My Computer\TV Shows\Parks and Recreation\Season 3\Parks.And.Recreation.S03E16.720p.HDTV.x264.mkv" -threads 0 -v info -print_format json -show_streams -show_chapters -show_format -show_data 2022-10-29 09:49:45.346 Debug MediaProbeManager: ProcessRun 'ffprobe' Started. 2022-10-29 09:49:45.418 Info MediaProbeManager: ProcessRun 'ffprobe' Process exited with code 1 - Failed 2022-10-29 09:49:45.418 Error App: Error in ffprobe *** Error Report *** Version: 4.7.8.0 Command line: C:\Users\admin\AppData\Roaming\Emby-Server\system\EmbyServer.dll Operating system: Microsoft Windows 10.0.22621 Framework: .NET 6.0.9 OS/Process: x64/x64 Runtime: C:/Users/admin/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 24 Data path: C:\Users\admin\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\admin\AppData\Roaming\Emby-Server\system System.Exception: System.Exception: ffprobe failed for file:"\\My Computer\TV Shows\Parks and Recreation\Season 3\Parks.And.Recreation.S03E16.720p.HDTV.x264.mkv" - streams and format are both null: { } ffprobe version 5.0.0-emby_2022_05_27-u1 Copyright (c) 2007-2022 the FFmpeg developers and softworkz for Emby LLC built with gcc 10.3.0 (Rev5, Built by MSYS2 project) [matroska,webm @ 000002636b3c0340] 0x00 at pos 165 (0xa5) invalid as first byte of an EBML number [matroska,webm @ 000002636b3c0340] Element at 0x35 ending at 0x34df5 exceeds containing master element ending at 0x13e1 [matroska,webm @ 000002636b3c0340] Duplicate element [matroska,webm @ 000002636b3c0340] Element at 0x44 ending at 0xa54e04 exceeds containing master element ending at 0x13f0 [matroska,webm @ 000002636b3c0340] Element at 0x53 ending at 0x2ecb1 exceeds containing master element ending at 0x13ff [matroska,webm @ 000002636b3c0340] Element at 0x64 ending at 0x2ecab exceeds containing master element ending at 0x1410 [matroska,webm @ 000002636b3c0340] 0x00 at pos 165 (0xa5) invalid as first byte of an EBML number [matroska,webm @ 000002636b3c0340] Duplicate element [h264 @ 000002636b3d3240] missing picture in access unit with size 1873 [extract_extradata @ 000002636b393dc0] No start code is found. file:\\My Computer\TV Shows\Parks and Recreation\Season 3\Parks.And.Recreation.S03E16.720p.HDTV.x264.mkv: Invalid data found when processing input at Emby.Server.MediaEncoding.Probing.MediaProbeManager.GetMediaInfoInternal(String inputPath, String primaryPath, MediaProtocol protocol, String userAgent, Boolean extractChapters, String probeSizeArgument, Boolean isAudio, Boolean forceEnableLogging, CancellationToken cancellationToken) at Emby.Providers.MediaInfo.FFProbeVideoInfo.ProbeVideo[T](MetadataResult`1 metadataResult, MetadataRefreshOptions options, LibraryOptions libraryOptions, CancellationToken cancellationToken) at Emby.Providers.Manager.MetadataService`2.RunCustomProvider(ICustomMetadataProvider`1 provider, MetadataResult`1 itemResult, String logName, MetadataRefreshOptions options, LibraryOptions libraryOptions, RefreshResult refreshResult, CancellationToken cancellationToken) Source: Emby.Server.MediaEncoding TargetSite: Void MoveNext() 2022-10-29 09:49:45.418 Debug App: Running EpisodeNfoProvider for \\My Computer\TV Shows\Parks and Recreation\Season 3\Parks.And.Recreation.S03E16.720p.HDTV.x264.mkv 2022-10-29 09:49:45.418 Debug App: EpisodeNfoProvider returned no metadata for \\My Computer\TV Shows\Parks and Recreation\Season 3\Parks.And.Recreation.S03E16.720p.HDTV.x264.mkv 2022-10-29 09:49:45.418 Debug App: Running EpisodeXmlProvider for \\My Computer\TV Shows\Parks and Recreation\Season 3\Parks.And.Recreation.S03E16.720p.HDTV.x264.mkv 2022-10-29 09:49:45.418 Debug App: EpisodeXmlProvider will fetch xml from \\My Computer\TV Shows\Parks and Recreation\Season 3\metadata\Parks.And.Recreation.S03E16.720p.HDTV.x264.xml
