Cheesegeezer 3106 Posted May 29, 2022 Author Posted May 29, 2022 So i think i can release this tomorrow. @FrostByte i will add in some more logging but at info level, not debug. So its easy to see comparisons. thanks everyone for your feedback it’s really appreciated, believe me. if you have anything else to add now is the time!! 1
FrostByte 5456 Posted May 29, 2022 Posted May 29, 2022 Will this also display HLG like used in BBC? I think it mentions DTS:X, Atmos, DV, and HDR10+
FrostByte 5456 Posted May 29, 2022 Posted May 29, 2022 Mediainfo for His Dark Materials Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@Main Codec ID : V_MPEGH/ISO/HEVC Duration : 53 min 14 s Bit rate : 18.7 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 25.000 FPS Standard : Component Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Bits/(Pixel*Frame) : 0.090 Stream size : 6.95 GiB (94%) Title : 4K HLG Default : Yes Forced : No Color range : Limited Color primaries : BT.2020 Transfer characteristics : HLG transfer_characteristics_Original : HLG / BT.2020 (10-bit) Matrix coefficients : BT.2020 non-constant
Cheesegeezer 3106 Posted May 29, 2022 Author Posted May 29, 2022 17 minutes ago, FrostByte said: Mediainfo for His Dark Materials Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@Main Codec ID : V_MPEGH/ISO/HEVC Duration : 53 min 14 s Bit rate : 18.7 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 25.000 FPS Standard : Component Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Bits/(Pixel*Frame) : 0.090 Stream size : 6.95 GiB (94%) Title : 4K HLG Default : Yes Forced : No Color range : Limited Color primaries : BT.2020 Transfer characteristics : HLG transfer_characteristics_Original : HLG / BT.2020 (10-bit) Matrix coefficients : BT.2020 non-constant I’ll need to get info on this, would this replace hdr?
FrostByte 5456 Posted May 29, 2022 Posted May 29, 2022 (edited) It's a type of HDR, but it isn't HDR10. I think it should replace it, maybe rbjtech has an opinion These are the HDR formats I'm aware of DV5,7,8, etc (DV7 and DV8 have a DV and HDR10 layer) HDR10/HDR10+ HLG Hybrid Log Gamma: everything you need to know about HLG HDR | TechRadar Edited May 29, 2022 by FrostByte 1 1
MagicDoubleM 121 Posted May 30, 2022 Posted May 30, 2022 (edited) 14 hours ago, Cheesegeezer said: I can look at this for sure Bitrate is doable too, the lang is actually forced by emby not the plugin I didn’t even think of that. But is that not date modified that changes and not date created, because all my recently added file in the client havent changed. this would only be available if the information has been stored in the file container, unfortunately it isn't. it does on both the plugin settings and the wiki in big bold letters. Ill change the color to RED. Thanks for all the feedback, really appreciated Edited May 30, 2022 by MagicDoubleM double post, can't delete
MagicDoubleM 121 Posted May 30, 2022 Posted May 30, 2022 (edited) 14 hours ago, Cheesegeezer said: I can look at this for sure Bitrate is doable too, the lang is actually forced by emby not the plugin I didn’t even think of that. But is that not date modified that changes and not date created, because all my recently added file in the client havent changed. this would only be available if the information has been stored in the file container, unfortunately it isn't. it does on both the plugin settings and the wiki in big bold letters. Ill change the color to RED. Thanks for all the feedback, really appreciated Edited May 30, 2022 by MagicDoubleM triple post, can't delete, my internet sucks today
MagicDoubleM 121 Posted May 30, 2022 Posted May 30, 2022 14 hours ago, Cheesegeezer said: I can look at this for sure Bitrate is doable too, the lang is actually forced by emby not the plugin I didn’t even think of that. But is that not date modified that changes and not date created, because all my recently added file in the client havent changed. this would only be available if the information has been stored in the file container, unfortunately it isn't. it does on both the plugin settings and the wiki in big bold letters. Ill change the color to RED. Thanks for all the feedback, really appreciated The DV files I mentioned, which aren't yet tagged with DV info, are identified with "Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU" through mediainfo. So far they are only recognized as UHD HEVC Audio-bitrate would be nice, how about bit-depth and khz too? Just some geeky specs would be nice there. I assumed you get the remux info from the file name, that's where I'd look for web and such source-tags. Maybe use the trash-guides for inspiration, they're probably the closest thing to a standard due to being used in radarr/sonarr. You are right it's the modified date that changed. And emby only uses the creation date optionally, so panic/red alert cancelled here. And "THIS PLUGIN WILL REPLACE EMBEDDED TRACK TITLES TO YOUR MKV FILES",. yeah, LOL, there it was, and I did read it, and I somehow managed to not immediately be warned that it actually touches the files. I'll blame midnight-testing, sorry, my fault.
FrostByte 5456 Posted May 30, 2022 Posted May 30, 2022 13 minutes ago, MagicDoubleM said: The DV files I mentioned, which aren't yet tagged with DV info, are identified with "Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU" through mediainfo. So far they are only recognized as UHD HEVC Definitely need to know if it's DV5. My Samsung can't play DV5, but can play DV7 or DV8 which have a HDR10 track for compatibility.
MagicDoubleM 121 Posted May 30, 2022 Posted May 30, 2022 5 hours ago, FrostByte said: Definitely need to know if it's DV5. My Samsung can't play DV5, but can play DV7 or DV8 which have a HDR10 track for compatibility. Yes, that's DV5, the ones with totally off colors when played on hardware that doesn't support it.
MagicDoubleM 121 Posted May 30, 2022 Posted May 30, 2022 I just recognized that mkvs with vc1-video don't get processed yet.
Cheesegeezer 3106 Posted May 30, 2022 Author Posted May 30, 2022 (edited) 9 hours ago, MagicDoubleM said: The DV files I mentioned, which aren't yet tagged with DV info, are identified with "Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU" through mediainfo. So far they are only recognized as UHD HEVC If you can out put an example in json from mediainfo gui i can get these in. 9 hours ago, MagicDoubleM said: Audio-bitrate would be nice, how about bit-depth and khz too? Just some geeky specs would be nice there. I can throw them in but it will start to look like an essay lol 9 hours ago, MagicDoubleM said: I assumed you get the remux info from the file name, that's where I'd look for web and such source-tags. this is just a cutoff , anything above these values are classed as Remux. for 4k its 37mb/s and for 1080p its 22Mb/s 8 hours ago, FrostByte said: Definitely need to know if it's DV5. My Samsung can't play DV5, but can play DV7 or DV8 which have a HDR10 track for compatibility. If you can out put an example in json from mediainfo gui for video i can get these in. thanks again fellas { "@type": "Video", "StreamOrder": "0", "ID": "1", "UniqueID": "1", "Format": "HEVC", "Format_Profile": "Main 10", "Format_Level": "5.1", "Format_Tier": "High", "HDR_Format": "Dolby Vision / SMPTE ST 2086", "HDR_Format_Version": "1.0 / ", "HDR_Format_Profile": "dvhe.07 / ", "HDR_Format_Level": "06 / ", "HDR_Format_Settings": "BL+EL+RPU / ", "HDR_Format_Compatibility": "Blu-ray / HDR10", "CodecID": "V_MPEGH/ISO/HEVC", "Duration": "224.390833333", "BitRate": "51549385", "Width": "3840", "Height": "2160", "Sampled_Width": "3840", "Sampled_Height": "2160", "PixelAspectRatio": "1.000", "DisplayAspectRatio": "1.778", "FrameRate_Mode": "CFR", "FrameRate": "23.976", "FrameCount": "5380", "ColorSpace": "YUV", "ChromaSubsampling": "4:2:0", "ChromaSubsampling_Position": "Type 2", "BitDepth": "10", "Delay": "0.000", "StreamSize": "1445895826", "Title": "UHD DV7 HDR10 Remux [51.5Mb/s]", "Language": "en", "Default": "No", "Forced": "No", "colour_description_present": "Yes", "colour_description_present_Source": "Stream", "colour_range": "Limited", "colour_range_Source": "Stream", "colour_primaries": "BT.2020", "colour_primaries_Source": "Stream", "transfer_characteristics": "PQ", "transfer_characteristics_Source": "Stream", "matrix_coefficients": "BT.2020 non-constant", "matrix_coefficients_Source": "Stream", "MasteringDisplay_ColorPrimaries": "Display P3", "MasteringDisplay_ColorPrimaries_Source": "Stream", "MasteringDisplay_Luminance": "min: 0.0050 cd/m2, max: 4000 cd/m2", "MasteringDisplay_Luminance_Source": "Stream", "MaxCLL": "1000 cd/m2", "MaxCLL_Source": "Stream", "MaxFALL": "362 cd/m2", "MaxFALL_Source": "Stream" }, Edited May 30, 2022 by Cheesegeezer 1
FrostByte 5456 Posted May 30, 2022 Posted May 30, 2022 json from Moon Knight DV5 file { "@type": "Video", "StreamOrder": "0", "ID": "1", "UniqueID": "14332962216991161246", "Format": "HEVC", "Format_Profile": "Main 10", "Format_Level": "5.2", "Format_Tier": "Main", "HDR_Format": "Dolby Vision", "HDR_Format_Version": "1.0", "HDR_Format_Profile": "dvhe.05", "HDR_Format_Level": "06", "HDR_Format_Settings": "BL+RPU", "CodecID": "V_MPEGH/ISO/HEVC", "Duration": "2838.375000000", "BitRate": "22415925", "Width": "3840", "Height": "2160", "Sampled_Width": "3840", "Sampled_Height": "2160", "PixelAspectRatio": "1.000", "DisplayAspectRatio": "1.778", "FrameRate_Mode": "CFR", "FrameRate": "24.000", "FrameCount": "68121", "ColorSpace": "YUV", "ChromaSubsampling": "4:2:0", "ChromaSubsampling_Position": "Type 0", "BitDepth": "10", "Delay": "0.000", "StreamSize": "7953100275", "Default": "No", "Forced": "No", "colour_description_present": "Yes", "colour_description_present_Source": "Stream", "colour_range": "Full", "colour_range_Source": "Stream", "colour_primaries_Source": "Stream", "transfer_characteristics_Source": "Stream", "matrix_coefficients_Source": "Stream" }, 2
FrostByte 5456 Posted May 30, 2022 Posted May 30, 2022 HLG episode in json format if you need { "@type": "Video", "StreamOrder": "0", "ID": "1", "UniqueID": "1", "Format": "HEVC", "Format_Profile": "Main 10", "Format_Level": "5.1", "Format_Tier": "Main", "CodecID": "V_MPEGH/ISO/HEVC", "Duration": "3278.800000000", "BitRate": "18636140", "Width": "3840", "Height": "2160", "Sampled_Width": "3840", "Sampled_Height": "2160", "PixelAspectRatio": "1.000", "DisplayAspectRatio": "1.778", "FrameRate_Mode": "CFR", "FrameRate": "25.000", "FrameCount": "81969", "Standard": "Component", "ColorSpace": "YUV", "ChromaSubsampling": "4:2:0", "BitDepth": "10", "Delay": "0.000", "StreamSize": "7638022382", "Title": "4K HLG", "Default": "Yes", "Forced": "No", "colour_description_present": "Yes", "colour_description_present_Source": "Container / Stream", "colour_range": "Limited", "colour_range_Source": "Container / Stream", "colour_primaries": "BT.2020", "colour_primaries_Source": "Container / Stream", "transfer_characteristics": "HLG", "transfer_characteristics_Source": "Container", "transfer_characteristics_Original": "HLG / BT.2020 (10-bit)", "transfer_characteristics_Original_Source": "Stream", "matrix_coefficients": "BT.2020 non-constant", "matrix_coefficients_Source": "Container / Stream" }, 1 1
Cheesegeezer 3106 Posted May 30, 2022 Author Posted May 30, 2022 5 minutes ago, FrostByte said: json from Moon Knight DV5 file { "@type": "Video", "StreamOrder": "0", "ID": "1", "UniqueID": "14332962216991161246", "Format": "HEVC", "Format_Profile": "Main 10", "Format_Level": "5.2", "Format_Tier": "Main", "HDR_Format": "Dolby Vision", "HDR_Format_Version": "1.0", "HDR_Format_Profile": "dvhe.05", "HDR_Format_Level": "06", "HDR_Format_Settings": "BL+RPU", "CodecID": "V_MPEGH/ISO/HEVC", "Duration": "2838.375000000", "BitRate": "22415925", "Width": "3840", "Height": "2160", "Sampled_Width": "3840", "Sampled_Height": "2160", "PixelAspectRatio": "1.000", "DisplayAspectRatio": "1.778", "FrameRate_Mode": "CFR", "FrameRate": "24.000", "FrameCount": "68121", "ColorSpace": "YUV", "ChromaSubsampling": "4:2:0", "ChromaSubsampling_Position": "Type 0", "BitDepth": "10", "Delay": "0.000", "StreamSize": "7953100275", "Default": "No", "Forced": "No", "colour_description_present": "Yes", "colour_description_present_Source": "Stream", "colour_range": "Full", "colour_range_Source": "Stream", "colour_primaries_Source": "Stream", "transfer_characteristics_Source": "Stream", "matrix_coefficients_Source": "Stream" }, So i can see here that color_primaries aren't set for DV5 which is what i've been using to see if it's DV. I can get a fix out shortly for this. the same with HLG. Standby...... 1
FrostByte 5456 Posted May 30, 2022 Posted May 30, 2022 If you start to add more information, it may be too much for me if it's not an option. Some clients like ATV have a lot less room than others and then just start chopping things off. I'll look at mediainfo if I need more.
Cheesegeezer 3106 Posted May 30, 2022 Author Posted May 30, 2022 3 minutes ago, FrostByte said: If you start to add more information, it may be too much for me if it's not an option. Some clients like ATV have a lot less room than others and then just start chopping things off. I'll look at mediainfo if I need more. i understand this, which is why i have allow for options. The Abbreviations for Audio have come from @rbjtech which he uses on ATV, so i know these will look fine. 1
Cheesegeezer 3106 Posted May 30, 2022 Author Posted May 30, 2022 8 minutes ago, Cheesegeezer said: i understand this, which is why i have allow for options. The Abbreviations for Audio have come from @rbjtech which he uses on ATV, so i know these will look fine. you free for quick test on HLG and DV5?
FrostByte 5456 Posted May 30, 2022 Posted May 30, 2022 5 minutes ago, Cheesegeezer said: you free for quick test on HLG and DV5? I'm here
Cheesegeezer 3106 Posted May 30, 2022 Author Posted May 30, 2022 22 minutes ago, FrostByte said: I'm here Can you try this Emby.MediaInfo.dll 1
Cheesegeezer 3106 Posted May 30, 2022 Author Posted May 30, 2022 I found a bug in my code @FrostByte i'm just doing some tests, you may or may not get the episodes to work. @MagicDoubleM added some options for the geek in you 1
FrostByte 5456 Posted May 30, 2022 Posted May 30, 2022 I got the following in my log 2022-05-30 07:26:23.321 Info Media Info: PERFORMING MEDIAINFO EXTRACTION ON MOVIES 2022-05-30 07:26:23.323 Info Media Info: MEDIAINFO EXTRACTION ON MOVIES Completed for 1276 Movies 2022-05-30 07:26:23.323 Info Media Info: PERFORMING MEDIAINFO EXTRACTION ON TV EPISODES 2022-05-30 07:26:23.324 Error Media Info: Object reference not set to an instance of an object. *** Error Report *** Version: 4.8.0.0 Command line: /volume1/@appstore/EmbyServer/system/EmbyServer.dll -programdata /var/packages/EmbyServer/var -ffdetect /var/packages/EmbyServer/target/bin/ffdetect -ffmpeg /var/packages/EmbyServer/target/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/bin/ffprobe -nolocalportconfig -ignore_vaapi_enabled_flag -pidfile /var/packages/EmbyServer/var/EmbyServer.pid -defaultdirectory /volume1/Public -updatepackage emby-server-synology7_{version}_x86_64.spk Operating system: Linux version 4.4.180+ (root@build17) (gcc version 8.5.0 (GCC) ) #42661 SMP Fri Apr 1 15:31:10 CST 2022 Framework: .NET 6.0.2 OS/Process: x64/x64 Runtime: volume1/@appstore/EmbyServer/system/System.Private.CoreLib.dll Processor count: 8 Data path: /var/packages/EmbyServer/var Application path: /volume1/@appstore/EmbyServer/system System.NullReferenceException: System.NullReferenceException: Object reference not set to an instance of an object. at Emby.MediaInfo.ScheduledTasks.MediaInfoScheduledTask.Execute(CancellationToken cancellationToken, IProgress`1 progress) Source: Emby.MediaInfo TargetSite: Void MoveNext()
Cheesegeezer 3106 Posted May 30, 2022 Author Posted May 30, 2022 4 minutes ago, FrostByte said: I got the following in my log 2022-05-30 07:26:23.321 Info Media Info: PERFORMING MEDIAINFO EXTRACTION ON MOVIES 2022-05-30 07:26:23.323 Info Media Info: MEDIAINFO EXTRACTION ON MOVIES Completed for 1276 Movies 2022-05-30 07:26:23.323 Info Media Info: PERFORMING MEDIAINFO EXTRACTION ON TV EPISODES 2022-05-30 07:26:23.324 Error Media Info: Object reference not set to an instance of an object. *** Error Report *** Version: 4.8.0.0 Command line: /volume1/@appstore/EmbyServer/system/EmbyServer.dll -programdata /var/packages/EmbyServer/var -ffdetect /var/packages/EmbyServer/target/bin/ffdetect -ffmpeg /var/packages/EmbyServer/target/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/bin/ffprobe -nolocalportconfig -ignore_vaapi_enabled_flag -pidfile /var/packages/EmbyServer/var/EmbyServer.pid -defaultdirectory /volume1/Public -updatepackage emby-server-synology7_{version}_x86_64.spk Operating system: Linux version 4.4.180+ (root@build17) (gcc version 8.5.0 (GCC) ) #42661 SMP Fri Apr 1 15:31:10 CST 2022 Framework: .NET 6.0.2 OS/Process: x64/x64 Runtime: volume1/@appstore/EmbyServer/system/System.Private.CoreLib.dll Processor count: 8 Data path: /var/packages/EmbyServer/var Application path: /volume1/@appstore/EmbyServer/system System.NullReferenceException: System.NullReferenceException: Object reference not set to an instance of an object. at Emby.MediaInfo.ScheduledTasks.MediaInfoScheduledTask.Execute(CancellationToken cancellationToken, IProgress`1 progress) Source: Emby.MediaInfo TargetSite: Void MoveNext() I thought so, as i said i found it while i was refactoring and improving the progress bar accuracy. 2 secs and i'll get another dll up.
