Emxynet 0 Posted September 15, 2022 Posted September 15, 2022 Totally lost here. I installed the package on my Synology. Now what? I've read and re-read the Wiki and it talks about a settings page I can't find because although my Synology says the plugins are installed, Emby doesn't show me the plugins.
FrostByte 5456 Posted September 15, 2022 Posted September 15, 2022 1 hour ago, Emxynet said: Totally lost here. I installed the package on my Synology. Now what? I've read and re-read the Wiki and it talks about a settings page I can't find because although my Synology says the plugins are installed, Emby doesn't show me the plugins. If you already installed both the mediainfo and mkvtoolnix apps from Synocommunity and Media Toolbox from the Emby plugin catalog, then you might need to restart Emby server to see the plugin.
Emxynet 0 Posted September 15, 2022 Posted September 15, 2022 (edited) 1 hour ago, FrostByte said: If you already installed both the mediainfo and mkvtoolnix apps from Synocommunity and Media Toolbox from the Emby plugin catalog, then you might need to restart Emby server to see the plugin. I did that. Twice! No dice! Do I need to be on Premier? Edit: Wait, Media Toolbox? There is no Media toolbox in my Emby catalog or in Community. Edited September 15, 2022 by Emxynet
FrostByte 5456 Posted September 15, 2022 Posted September 15, 2022 I think it is going through a name change. The name in the catalogue may be the old name. It's Media Toolbox when you use it though
Emxynet 0 Posted September 15, 2022 Posted September 15, 2022 Not showing up anywhere on my Emby server. Not under plugins. Not on the menu like yours. Nothing! But both Info and ToolNix are installed and running on the NAS. I have a DS418 and I already can't upgrade to the latest Emby version so this is getting pretty annoying. Don't get me started on trying to install Emby on my Shield Pro lol.
FrostByte 5456 Posted September 15, 2022 Posted September 15, 2022 16 minutes ago, Emxynet said: Not showing up anywhere on my Emby server. Not under plugins. Not on the menu like yours. Nothing! But both Info and ToolNix are installed and running on the NAS. I have a DS418 and I already can't upgrade to the latest Emby version so this is getting pretty annoying. Don't get me started on trying to install Emby on my Shield Pro lol. The plugin may require a certain version of server. @Cheesegeezer would need to say Are you trying to sideload one of the two Android apps?
Emxynet 0 Posted September 15, 2022 Posted September 15, 2022 1 minute ago, FrostByte said: The plugin may require a certain version of server. @Cheesegeezer would need to say Are you trying to sideload one of the two Android apps? I think that might be the issue with my Synology NAS but since none of your binaries work with DSM7.1 on the DS418 NAS I'm stuck. As for the Shield, the server app installs but then I can't connect to the webpage. I know there is no firewall or other connectivity issue because I have another web based server running which I can access from anywhere on my LAN.
neik 874 Posted September 15, 2022 Posted September 15, 2022 Frosty, where did you get your version from? I am on the latest I can find and that is 1.0.0.2, while you are on 1.0.1.4...
FrostByte 5456 Posted September 15, 2022 Posted September 15, 2022 14 minutes ago, neik said: Frosty, where did you get your version from? I am on the latest I can find and that is 1.0.0.2, while you are on 1.0.1.4... Cheese has a beta version he's working on. Contact him. He's adding a tab for deleting unwanted subs. 1
lorac 120 Posted September 16, 2022 Posted September 16, 2022 Using version 1.0.0.2 and i've seen a few movies where the title track gets overwritten by the bitrate. So instead of MOVIE NAME it will be HD 1080p 5mb/s I have not read through this entire thread so not sure if someone else has reported this.
neik 874 Posted September 16, 2022 Posted September 16, 2022 8 hours ago, FrostByte said: Cheese has a beta version he's working on. Contact him. He's adding a tab for deleting unwanted subs. Thank you! @Cheesegeezer, any chance you could put me in the beta group as well? Thanks! 5 hours ago, lorac said: Using version 1.0.0.2 and i've seen a few movies where the title track gets overwritten by the bitrate. So instead of MOVIE NAME it will be HD 1080p 5mb/s I have not read through this entire thread so not sure if someone else has reported this. There are options to control that, check them out.
Dizzy49 99 Posted September 16, 2022 Posted September 16, 2022 I got the BIF files working. Figures that was the thing I didn't care as much about. I'm having a crap of a time trying to get MediaInfo working. I restarted the server, and checked the option to Refresh All Items. I figured I'd let it run after I had updated all the BIFs. I started the task and it's just sitting there are 0%... Again... Been like that for 14 hours now.
rbjtech 5345 Posted September 16, 2022 Posted September 16, 2022 1 hour ago, Dizzy49 said: I got the BIF files working. Figures that was the thing I didn't care as much about. I'm having a crap of a time trying to get MediaInfo working. I restarted the server, and checked the option to Refresh All Items. I figured I'd let it run after I had updated all the BIFs. I started the task and it's just sitting there are 0%... Again... Been like that for 14 hours now. The MediaInfo part only takes a few minutes for a large library - so something is not right. Ensure you have used the mediainfo CLI executable in the path and not the normal mediainfo. Turn on debug logging as it has comprehensive logging and will tell you exactly what it is attempting to do. Share if you like and we can try and help. (PM or post here ..)
lorac 120 Posted September 16, 2022 Posted September 16, 2022 11 hours ago, neik said: Thank you! @Cheesegeezer, any chance you could put me in the beta group as well? Thanks! There are options to control that, check them out. It only happens with a few movies. I don't see how I'm going to contol that. I'll just have to monitor for changes.
Emxynet 0 Posted September 19, 2022 Posted September 19, 2022 (edited) OK so now that I have the correct OS binary (I still don't understand why admittedly dumb mistake wasn't corrected by the mods) this does work very nicely and I may have discovered one file with the wrong audio codec because of it. Edited September 19, 2022 by Emxynet
Emxynet 0 Posted September 19, 2022 Posted September 19, 2022 So is there a way to fix the audio description here?
Cheesegeezer 3106 Posted September 19, 2022 Author Posted September 19, 2022 4 hours ago, Emxynet said: So is there a way to fix the audio description here? is it a PCM stream? this has been fixed internally
Cheesegeezer 3106 Posted September 19, 2022 Author Posted September 19, 2022 @softworkz i re-added you to the repo for your help with the linux side you suggested. I still don't know how you were removed. Very confused. Cheers fella
Emxynet 0 Posted September 19, 2022 Posted September 19, 2022 46 minutes ago, Cheesegeezer said: is it a PCM stream? this has been fixed internally No it's 5.1 True HD.
Cheesegeezer 3106 Posted September 19, 2022 Author Posted September 19, 2022 42 minutes ago, Emxynet said: No it's 5.1 True HD. Can you share the mediaInfo json file please
Emxynet 0 Posted September 19, 2022 Posted September 19, 2022 (edited) 27 minutes ago, Cheesegeezer said: Can you share the mediaInfo json file please I had no idea how to do this lol but I got there in the end The output is horrible and double spaced so I also added a text file attachment just in case. mijson.rtf { "creatingLibrary": { "name": "MediaInfoLib", "version": "21.09", "url": "https://mediaarea.net/MediaInfo" }, "media": { "@ref": "/volume3/DV/MISSION IMPOSSIBLE/Mission Impossible.mkv", "track": [ { "@type": "General", "UniqueID": "297618337769135471623225461770217187882", "VideoCount": "1", "AudioCount": "1", "TextCount": "4", "MenuCount": "1", "FileExtension": "mkv", "Format": "Matroska", "Format_Version": "2", "FileSize": "54809212704", "Duration": "6612.939", "OverallBitRate_Mode": "VBR", "OverallBitRate": "66305421", "FrameRate": "23.976", "FrameCount": "158552", "StreamSize": "10337216", "IsStreamable": "Yes", "Title": "Mission: Impossible", "Movie": "Mission: Impossible", "Encoded_Date": "UTC 2021-07-14 15:27:46", "File_Modified_Date": "UTC 2022-09-19 11:41:40", "File_Modified_Date_Local": "2022-09-19 12:41:40", "Encoded_Application": "MakeMKV v1.16.4 win(x64-release)", "Encoded_Library": "libmakemkv v1.16.4 (1.3.10/1.5.2) win(x64-release)", "Cover": "Yes", "extra": { "Attachments": "cover.jpg" } }, { "@type": "Video", "StreamOrder": "0", "ID": "1", "OriginalSourceMedium_ID": "4113", "UniqueID": "1", "Format": "HEVC", "Format_Profile": "Main 10", "Format_Level": "5.1", "Format_Tier": "High", "HDR_Format": "Dolby Vision / SMPTE ST 2086", "HDR_Format_Version": "1.0 / ", "HDR_Format_Profile": "dvhe.07 / ", "HDR_Format_Level": "06 / ", "HDR_Format_Settings": "BL+EL+RPU / ", "HDR_Format_Compatibility": "Blu-ray / HDR10", "CodecID": "V_MPEGH/ISO/HEVC", "Duration": "6612.939666666", "BitRate": "62882159", "Width": "3840", "Height": "2160", "Sampled_Width": "3840", "Sampled_Height": "2160", "PixelAspectRatio": "1.000", "DisplayAspectRatio": "1.778", "FrameRate_Mode": "CFR", "FrameRate": "23.976", "FrameCount": "158552", "ColorSpace": "YUV", "ChromaSubsampling": "4:2:0", "ChromaSubsampling_Position": "Type 2", "BitDepth": "10", "Delay": "0.000", "StreamSize": "51979485684", "Title": "4K DV7 HDR10", "Language": "en", "Default": "No", "Forced": "No", "colour_description_present": "Yes", "colour_description_present_Source": "Stream", "colour_range": "Limited", "colour_range_Source": "Stream", "colour_primaries": "BT.2020", "colour_primaries_Source": "Stream", "transfer_characteristics": "PQ", "transfer_characteristics_Source": "Stream", "matrix_coefficients": "BT.2020 non-constant", "matrix_coefficients_Source": "Stream", "MasteringDisplay_ColorPrimaries": "Display P3", "MasteringDisplay_ColorPrimaries_Source": "Stream", "MasteringDisplay_Luminance": "min: 0.0001 cd/m2, max: 1000 cd/m2", "MasteringDisplay_Luminance_Source": "Stream", "extra": { "OriginalSourceMedium": "Blu-ray" } }, { "@type": "Audio", "StreamOrder": "1", "ID": "2", "OriginalSourceMedium_ID": "4352", "UniqueID": "2", "Format": "MLP FBA", "Format_Commercial_IfAny": "Dolby TrueHD", "CodecID": "A_TRUEHD", "Duration": "6612.940833333", "BitRate_Mode": "VBR", "BitRate": "3365310", "BitRate_Maximum": "4890000", "Channels": "6", "ChannelPositions": "Front: L C R, Side: L R, LFE", "ChannelLayout": "L R C LFE Ls Rs", "SamplesPerFrame": "40", "SamplingRate": "48000", "SamplingCount": "317421160", "FrameRate": "1200.000", "FrameCount": "7935529", "BitDepth": "24", "Compression_Mode": "Lossless", "Delay": "0.000", "Delay_Source": "Container", "StreamSize": "2781824676", "StreamSize_Proportion": "0.05075", "Title": " (48Khz) [24-Bit] ", "Language": "en", "Default": "Yes", "Forced": "No", "extra": { "OriginalSourceMedium": "Blu-ray" } }, { "@type": "Text", "@typeorder": "1", "StreamOrder": "2", "ID": "3", "OriginalSourceMedium_ID": "4768", "UniqueID": "3", "Format": "PGS", "CodecID": "S_HDMV/PGS", "Duration": "6327.300145833", "BitRate": "24508", "FrameRate": "0.301", "FrameCount": "1904", "ElementCount": "1904", "StreamSize": "19383984", "Language": "en", "Default": "No", "Forced": "No", "extra": { "OriginalSourceMedium": "Blu-ray" } }, { "@type": "Text", "@typeorder": "2", "StreamOrder": "3", "ID": "4", "OriginalSourceMedium_ID": "4768", "UniqueID": "4", "Format": "PGS", "CodecID": "S_HDMV/PGS", "Duration": "90.361104166", "BitRate": "19243", "FrameRate": "0.443", "FrameCount": "40", "ElementCount": "40", "StreamSize": "217360", "Language": "en", "Default": "Yes", "Forced": "No", "extra": { "OriginalSourceMedium": "Blu-ray" } }, { "@type": "Text", "@typeorder": "3", "StreamOrder": "4", "ID": "5", "OriginalSourceMedium_ID": "4773", "UniqueID": "5", "Format": "PGS", "CodecID": "S_HDMV/PGS", "Duration": "6327.633812500", "BitRate": "22285", "FrameRate": "0.289", "FrameCount": "1826", "ElementCount": "1826", "StreamSize": "17627154", "Language": "es", "Default": "No", "Forced": "No", "extra": { "OriginalSourceMedium": "Blu-ray" } }, { "@type": "Text", "@typeorder": "4", "StreamOrder": "5", "ID": "6", "OriginalSourceMedium_ID": "4773", "UniqueID": "6", "Format": "PGS", "CodecID": "S_HDMV/PGS", "Duration": "5465.147187500", "BitRate": "492", "FrameRate": "0.009", "FrameCount": "50", "ElementCount": "50", "StreamSize": "336630", "Language": "es", "Default": "No", "Forced": "No", "extra": { "OriginalSourceMedium": "Blu-ray" } }, { "@type": "Menu", "extra": { "_00_00_00_000": "en:Chapter 01", "_00_03_01_139": "en:Chapter 02", "_00_10_44_894": "en:Chapter 03", "_00_26_43_977": "en:Chapter 04", "_00_32_21_147": "en:Chapter 05", "_00_39_50_513": "en:Chapter 06", "_00_49_39_309": "en:Chapter 07", "_00_55_45_800": "en:Chapter 08", "_01_12_25_883": "en:Chapter 09", "_01_18_34_543": "en:Chapter 10", "_01_28_14_664": "en:Chapter 11", "_01_38_06_630": "en:Chapter 12", "_01_44_02_945": "en:Chapter 13" } } ] } } Edited September 19, 2022 by Emxynet
Cheesegeezer 3106 Posted September 19, 2022 Author Posted September 19, 2022 (edited) 45 minutes ago, Emxynet said: I had no idea how to do this lol but I got there in the end The output is horrible and double spaced so I also added a text file attachment just in case. Thanks for that, not sure why it hasn’t picked it up… that format is definitely in the processing i will double check tomorrow Edited September 19, 2022 by Cheesegeezer
Emxynet 0 Posted September 19, 2022 Posted September 19, 2022 1 hour ago, Cheesegeezer said: Thanks for that, not sure why it hasn’t picked it up… that format is definitely in the processing i will double check tomorrow I did notice that the format looked correct too. Hopefully you will see something tomorrow. Thanks
Cheesegeezer 3106 Posted September 20, 2022 Author Posted September 20, 2022 New Version uploaded to the catalogue. Please clear your browser cache after installing Cheers 3
Cheesegeezer 3106 Posted September 20, 2022 Author Posted September 20, 2022 @softworkz Neik did post this in the beta thread regarding the linux library issues Quote Just got to it and it seems like I have good news regarding the library issue on Linux. I reverted the change I made to Emby's lib by replacing the file with the original file I backed up before and it just works. I'll keep an eye on it.
