Cheesegeezer 3106 Posted July 5, 2022 Author Posted July 5, 2022 @SikSlayer i saw your confused face. Its a little joke, because thats the formatting that @rbjtech likes and if you have used the plugin you will see an option for RBJTech formatting. Which displays the output like that 1 1 1
SikSlayer 254 Posted July 5, 2022 Posted July 5, 2022 (edited) 5 hours ago, Cheesegeezer said: @SikSlayer i saw your confused face. Its a little joke, because thats the formatting that @rbjtech likes and if you have used the plugin you will see an option for RBJTech formatting. Which displays the output like that Thanks for clarifying. The two posts were seemingly contradictory. Edited July 5, 2022 by SikSlayer 2
neik 874 Posted July 6, 2022 Posted July 6, 2022 cheese, is the issue described by frosty regarding the Atmos tracks an actual issue? If so, is it being looked at? Thank you!
Cheesegeezer 3106 Posted July 6, 2022 Author Posted July 6, 2022 Just now, neik said: cheese, is the issue described by frosty regarding the Atmos tracks an actual issue? Yes Just now, neik said: If so, is it being looked at? Yes Just now, neik said: Thank you! No probs 1 1
Netdhio 0 Posted July 13, 2022 Posted July 13, 2022 El 18/06/2022 a las 2:41 PM, FrostByte dijo: Soy bueno aquí. Funciona perfectamente en mi NAS. Gracias HOLA PUEDES AYUDARME, LE E DEJADO LAS RUTAS DE LOS INSTALADORES EN EL DISCO DURO DE MI NAS QNAP, Y LE DOY A TAREAS PROGRAMDAS Y ESCANEA Y NO PASA NADA AYUDAME COMO LO HCIISTE QUE ESTOY HCIENDO MAL. HOLA ME PUEDES AYUDAR, HE DEJADO LAS RUTAS DE LOS INSTALADORES EN EL DISCO DURO DE MI QNAP NAS, Y TE DOY TAREAS PROGRAMADAS Y ESCANEO Y NO PASA NADA AYÚDAME COMO TÚ LO HICISTE QUE LO ESTOY HACIENDO MAL.
FrostByte 5456 Posted July 13, 2022 Posted July 13, 2022 1 hour ago, Netdhio said: HOLA PUEDES AYUDARME, LE E DEJADO LAS RUTAS DE LOS INSTALADORES EN EL DISCO DURO DE MI NAS QNAP, Y LE DOY A TAREAS PROGRAMDAS Y ESCANEA Y NO PASA NADA AYUDAME COMO LO HCIISTE QUE ESTOY HCIENDO MAL. HOLA ME PUEDES AYUDAR, HE DEJADO LAS RUTAS DE LOS INSTALADORES EN EL DISCO DURO DE MI QNAP NAS, Y TE DOY TAREAS PROGRAMADAS Y ESCANEO Y NO PASA NADA AYÚDAME COMO TÚ LO HICISTE QUE LO ESTOY HACIENDO MAL. It looks like you're using the Windows versions of both apps. Is your Qnap running Windows? If it's running Unix then you will need a different version.
Netdhio 0 Posted July 13, 2022 Posted July 13, 2022 Hace 2 horas, FrostByte dijo: Parece que estás usando las versiones de Windows de ambas aplicaciones. ¿Su Qnap está ejecutando Windows? Si está ejecutando Unix, entonces necesitará una versión diferente. EL QNAP NO EJECUTA WINDOWS, Y ENTONCES DE DONDE SACO ESAS VERSIONES PARA UNIX O LINUX O UBUNTU POR FAVOR QNAP NO EJECUTA WINDOWS, Y LUEGO, ¿DE DÓNDE OBTENGO ESAS VERSIONES PARA UNIX O LINUX O UBUNTU, POR FAVOR?
FrostByte 5456 Posted July 13, 2022 Posted July 13, 2022 I don't know much about Qnap, but I believe both are in the community site https://www.qnapclub.eu/
sydlexius 301 Posted July 13, 2022 Posted July 13, 2022 On 6/2/2022 at 3:05 AM, Cheesegeezer said: After doing some Googling found this thread Which version of Unix is unRaid based on? - General Support - Unraid Which points to this The Slackware Linux Project: Configuration Help So you should download Slackware Linux MediaInfo MediaInfo - Download MediaInfo for Slackware (mediaarea.net) FYI, that approach is a dead-end. Also, for users of uNRAID, it's made available through the "Nerd Pack". Still, the binaries are not statically-linked, so there's no way to incorporate them into the docker images for Emby (either official, or lsio's). Sorry for the late response...I decided to take a stab at this on my own and quickly discovered that it'll be a tall task to pull off. Additionally, I don't want my MKVs modified, so this is a bit of a non-starter for me.
FrostByte 5456 Posted July 13, 2022 Posted July 13, 2022 2 minutes ago, sydlexius said: Additionally, I don't want my MKVs modified, so this is a bit of a non-starter for me. I believe softworkz is working on getting this into the core eventually. He made a comment in the original FR thread, and it sounds like he's made some progress already.
rbjtech 5345 Posted July 14, 2022 Posted July 14, 2022 10 hours ago, FrostByte said: I believe softworkz is working on getting this into the core eventually. He made a comment in the original FR thread, and it sounds like he's made some progress already. From my understanding, only from a DV profile perspective. There is still no movement from ffmpeg on Dolby Atmos or other discreet audio attributes, thus emby will still not have complete codec identification vs MediaInfo. 3
Desafino 0 Posted July 26, 2022 Posted July 26, 2022 (edited) Sorry if this sounds ridiculous...I'm a novice. I tried following the steps/instructions but I'm a bit confused/stuck on one of the steps.. I've Downloaded the software - MediaInfo CLI file + mkvtoolnix file. How do I get to the executable file paths (as per pic)...? ..emby settings somewhere? - Do I need to run/setup mkvtoolnix first with the media info file...? Thanks in advance Edited July 26, 2022 by Desafino
Cheesegeezer 3106 Posted July 26, 2022 Author Posted July 26, 2022 50 minutes ago, Desafino said: Sorry if this sounds ridiculous...I'm a novice. I tried following the steps/instructions but I'm a bit confused/stuck on one of the steps.. I've Downloaded the software - MediaInfo CLI file + mkvtoolnix file. How do I get to the executable file paths (as per pic)...? ..emby settings somewhere? - Do I need to run/setup mkvtoolnix first with the media info file...? Thanks in advance Are you running windows? cheers
Desafino 0 Posted July 26, 2022 Posted July 26, 2022 5 minutes ago, Cheesegeezer said: Are you running windows? cheers Yes...Win 11. Thx.
Cheesegeezer 3106 Posted July 26, 2022 Author Posted July 26, 2022 4 minutes ago, Desafino said: Yes...Win 11. Thx. Can you screenshot your paths please if you dont mind.
Desafino 0 Posted July 26, 2022 Posted July 26, 2022 9 minutes ago, Cheesegeezer said: Can you screenshot your paths please if you dont mind. Sorry...How do I get to the paths? Where do I go under settings to do all this..etc..under "Plugins"?
FrostByte 5456 Posted July 26, 2022 Posted July 26, 2022 The path is where you installed or copied those executables to.
FrostByte 5456 Posted July 26, 2022 Posted July 26, 2022 If you used the Windows installer for both they are probably in the paths below, but go ahead and check. C:\Program Files\MediaInfo\MediaInfo.exe C:\Program Files\MKVToolNix\mkvpropedit.exe 1
Cheesegeezer 3106 Posted July 26, 2022 Author Posted July 26, 2022 1 hour ago, Desafino said: Sorry...How do I get to the paths? Where do I go under settings to do all this..etc..under "Plugins"? Ahhh right, you need to click on the search icon and navigate to where you ectracted the zip file
Cheesegeezer 3106 Posted July 26, 2022 Author Posted July 26, 2022 58 minutes ago, FrostByte said: If you used the Windows installer for both they are probably in the paths below, but go ahead and check. C:\Program Files\MediaInfo\MediaInfo.exe C:\Program Files\MKVToolNix\mkvpropedit.exe Its cli so not an installer, just folder with required dll’s thanks frosty
Desafino 0 Posted July 26, 2022 Posted July 26, 2022 55 minutes ago, FrostByte said: If you used the Windows installer for both they are probably in the paths below, but go ahead and check. C:\Program Files\MediaInfo\MediaInfo.exe C:\Program Files\MKVToolNix\mkvpropedit.exe MediaInfo: C:\Program Files\MediaInfo MKVToolNix: Installation path: C:\Program Files\WindowsApps\53641MoritzBunkus.MKVToolNix_69.0.0.0_x64__dzwm38c22apxe\mkvtoolnix INI file location: C:\Users\rpmar\AppData\Local\bunkus.org\mkvtoolnix-gui\mkvtoolnix-gui.ini
Cheesegeezer 3106 Posted July 26, 2022 Author Posted July 26, 2022 1 minute ago, Desafino said: MediaInfo: C:\Program Files\MediaInfo MKVToolNix: Installation path: C:\Program Files\WindowsApps\53641MoritzBunkus.MKVToolNix_69.0.0.0_x64__dzwm38c22apxe\mkvtoolnix INI file location: C:\Users\rpmar\AppData\Local\bunkus.org\mkvtoolnix-gui\mkvtoolnix-gui.ini You need to download CLI versions not the GUI version. The plugin requires CLI which should be a zip folder and you just extract it. CLI is command line interface, the gui closes of these command lines ehich the plugin requires. please look at the Wiki posted on the first post, if you are still stuck then let me know and we can walk thru it.
FrostByte 5456 Posted July 26, 2022 Posted July 26, 2022 5 minutes ago, Cheesegeezer said: Its cli so not an installer, just folder with required dll’s thanks frosty The installer will install both the gui and the cli though.
Cheesegeezer 3106 Posted July 26, 2022 Author Posted July 26, 2022 (edited) 1 minute ago, FrostByte said: The installer will install both the gui and the cli though. No it doesn’t on windows the exe launches the gui and absorbs the dll file, not exposed. Thats why its highlighted in the wiki Edited July 26, 2022 by Cheesegeezer
