neik 874 Posted June 29, 2022 Posted June 29, 2022 45 minutes ago, neik said: In the meantime I'll check the latest server beta to see if the library changed there - maybe it has already been updated. rbjtech/Cheese, the latest beta does already have the updated library and the plugin is working fine again. Thank you guys! 1
Dedone 17 Posted June 29, 2022 Posted June 29, 2022 45 minutes ago, rbjtech said: Hi - yes, details are the the Wiki https://github.com/Cheesegeezer/MediaInfoWiki/wiki/Various-OS-Installation-Help Thanks!!!!
neik 874 Posted June 29, 2022 Posted June 29, 2022 I think I found a bug: Just started processing all items thus activated "Refresh all items" to reprocess the files which I used to test the plugin. I let it run for a bit and then stopped the task but: - the processed list in "Emby.Mediainfo.xml" didn't get refreshed and -Â Â <ResetProcessedList>true</ResetProcessedList> didn't get changed back to false. This means whenever I restart the task it will start from the beginning again.
Dedone 17 Posted June 29, 2022 Posted June 29, 2022 @FrostByte I've some problems on Sinology running last DSM. As i read in you post, the process is very quick and it don't apply any modification. I had try to follow all the instructions, but i'm not able to make it run. Hope in your help Thanks!
rbjtech 5345 Posted June 29, 2022 Posted June 29, 2022 13 minutes ago, neik said: I think I found a bug: Just started processing all items thus activated "Refresh all items" to reprocess the files which I used to test the plugin. I let it run for a bit and then stopped the task but: - the processed list in "Emby.Mediainfo.xml" didn't get refreshed and -  <ResetProcessedList>true</ResetProcessedList> didn't get changed back to false. This means whenever I restart the task it will start from the beginning again. Refresh all items does exactly what it says on the tin  If you selected it, then it removes all the items from the list and refreshes them - if you stop it part of the way through, then it's going to continue the task until it completes, THEN unset the task. You need to re-run it to rebuild the processed list - it shouldn't take that long and will just overwrite the existing values with the same or changed values. 1 1 1
Dedone 17 Posted June 29, 2022 Posted June 29, 2022 14 minutes ago, rbjtech said: Refresh all items does exactly what it says on the tin  If you selected it, then it removes all the items from the list and refreshes them - if you stop it part of the way through, then it's going to continue the task until it completes, THEN unset the task. You need to re-run it to rebuild the processed list - it shouldn't take that long and will just overwrite the existing values with the same or changed values. This solve my problem!!!! I've checked Refresh all items, and now the process is working...let's see at the end if every will work. Thanks 1
neik 874 Posted June 29, 2022 Posted June 29, 2022 (edited) 56 minutes ago, rbjtech said: if you stop it part of the way through, then it's going to continue the task until it completes, THEN unset the task. The thing is, for me it is not picking up where I stopped it, it starts from the beginning again and according to the logs it seems to be reprocessing the same files from before. I will try to prepare a log for you to analyze. Edit: Sent it to you and Cheese via PM. Edited June 29, 2022 by neik 1
Cheesegeezer 3106 Posted June 29, 2022 Author Posted June 29, 2022 (edited) New version up   Edited June 29, 2022 by Cheesegeezer 2 1
FrostByte 5456 Posted June 29, 2022 Posted June 29, 2022 Anyone got the biftool working on their NAS? I got error code 1 on every episode. I'm thinking biftool needs recompiling, but I'm not sure.  biftool.txt
MagicDoubleM 121 Posted June 29, 2022 Posted June 29, 2022 I'm still having random problems with real-time-monitoring and even the scheduled task (set to 15min) catching up on all additions. Sometimes they show up after I restart emby, sometimes they pop up hours later, sometimes there are gaps and some stuff doesn't get processed, while newer does get it. Not sure, where to look, or how to start debugging here.
Dedone 17 Posted June 30, 2022 Posted June 30, 2022 Same here. Randomly the informations appear and after some minutes, the same disappear. I try to launch the task but without results (on Nas DS218+ with latest beta 4.8.0.3)
rbjtech 5345 Posted June 30, 2022 Posted June 30, 2022 14 hours ago, MagicDoubleM said: I'm still having random problems with real-time-monitoring and even the scheduled task (set to 15min) catching up on all additions. Sometimes they show up after I restart emby, sometimes they pop up hours later, sometimes there are gaps and some stuff doesn't get processed, while newer does get it. Not sure, where to look, or how to start debugging here. Â 2 hours ago, Dedone said: Same here. Randomly the informations appear and after some minutes, the same disappear. I try to launch the task but without results (on Nas DS218+ with latest beta 4.8.0.3) Are you guys waiting for the library scan to finish and for emby to do its thang ? Results won;t be instant - they take a little while to 'come though' even after a library scan - this is normal. I don't use the real time monitor - but I have zero issues with this plugin on a schedule (every 2 hrs). 1
Dedone 17 Posted June 30, 2022 Posted June 30, 2022 28 minutes ago, rbjtech said: Â Are you guys waiting for the library scan to finish and for emby to do its thang ? Results won;t be instant - they take a little while to 'come though' even after a library scan - this is normal. I don't use the real time monitor - but I have zero issues with this plugin on a schedule (every 2 hrs). The problem is that i shut down the nas during the night, and when it start in the mornig, the results are not present. I must run the scan and then they appear. 1
MagicDoubleM 121 Posted June 30, 2022 Posted June 30, 2022 9 hours ago, rbjtech said: Â Are you guys waiting for the library scan to finish and for emby to do its thang ? Results won;t be instant - they take a little while to 'come though' even after a library scan - this is normal. I don't use the real time monitor - but I have zero issues with this plugin on a schedule (every 2 hrs). Must be the heat, yeah, the "scan media library" scheduled task should be set to more or less match the media-info task, and not to 24h like I had it before...Â
FrostByte 5456 Posted July 4, 2022 Posted July 4, 2022 (edited) I may have found another bug. It looks like it's adding Atmos to all TrueHD tracks even though it may not have Atmos. v1.0.0.2 2022-07-04 09:54:54.984 Info Media Info: PROCESSING OF The Madagascar Penguins in a Christmas Caper HAS STARTED 2022-07-04 09:54:54.984 Info Media Info: Item FilePath = /volume1/MyEmbyMedia/Movies/The Madagascar Penguins in a Christmas Caper (2012)/The.Madagascar.Penguins.in.a.Christmas.Caper.2012.1080p.BluRay.REMUX.AVC.TrueHD.5.1-TRiToN.mkv 2022-07-04 09:54:55.067 Info Media Info: Video Track successfully Written & Exited with Code 0 2022-07-04 09:54:55.067 Info Media Info: Video Track Title Set to 1080p 2022-07-04 09:54:55.501 Info Media Info: Audio Track successfully Written & Exited with Code 0 2022-07-04 09:54:55.501 Info Media Info: Audio Stream #1 Updated to: Dolby TrueHD Atmos 5.1 (Default) 2022-07-04 09:54:55.593 Info Media Info: Audio Track successfully Written & Exited with Code 0 2022-07-04 09:54:55.593 Info Media Info: Audio Stream #2 Updated to: Dolby Digital Plus 5.1 2022-07-04 09:54:55.595 Info Media Info: Item Tags found = 2022-07-04 09:54:55.595 Info Media Info: PROCESSING OF The Madagascar Penguins in a Christmas Caper HAS COMPLETED { "@type": "Audio", "@typeorder": "1", "StreamOrder": "1", "ID": "2", "UniqueID": "17064740059483774338", "Format": "MLP FBA", "Format_Commercial_IfAny": "Dolby TrueHD", "CodecID": "A_TRUEHD", "Duration": "622.831000000", "BitRate_Mode": "VBR", "BitRate": "3463749", "BitRate_Maximum": "4740000", "Channels": "6", "ChannelPositions": "Front: L C R, Side: L R, LFE", "ChannelLayout": "L R C LFE Ls Rs", "SamplesPerFrame": "40", "SamplingRate": "48000", "SamplingCount": "29895888", "FrameRate": "1200.000", "FrameCount": "747397", "Compression_Mode": "Lossless", "Delay": "0.000", "Delay_Source": "Container", "StreamSize": "269666328", "StreamSize_Proportion": "0.08922", "Title": "Dolby TrueHD Atmos 5.1 (Default)", "Language": "en", "Default": "Yes", "Forced": "No" },  Edited July 4, 2022 by FrostByte
Cheesegeezer 3106 Posted July 4, 2022 Author Posted July 4, 2022 3 minutes ago, FrostByte said: I may have found another bug. It looks like it's adding Atmos to all TrueHD tracks even though it may not have Atmos. v1.0.0.2 2022-07-04 09:54:54.984 Info Media Info: PROCESSING OF The Madagascar Penguins in a Christmas Caper HAS STARTED 2022-07-04 09:54:54.984 Info Media Info: Item FilePath = /volume1/MyEmbyMedia/Movies/The Madagascar Penguins in a Christmas Caper (2012)/The.Madagascar.Penguins.in.a.Christmas.Caper.2012.1080p.BluRay.REMUX.AVC.TrueHD.5.1-TRiToN.mkv 2022-07-04 09:54:55.067 Info Media Info: Video Track successfully Written & Exited with Code 0 2022-07-04 09:54:55.067 Info Media Info: Video Track Title Set to 1080p 2022-07-04 09:54:55.501 Info Media Info: Audio Track successfully Written & Exited with Code 0 2022-07-04 09:54:55.501 Info Media Info: Audio Stream #1 Updated to: Dolby TrueHD Atmos 5.1 (Default) 2022-07-04 09:54:55.593 Info Media Info: Audio Track successfully Written & Exited with Code 0 2022-07-04 09:54:55.593 Info Media Info: Audio Stream #2 Updated to: Dolby Digital Plus 5.1 2022-07-04 09:54:55.595 Info Media Info: Item Tags found = 2022-07-04 09:54:55.595 Info Media Info: PROCESSING OF The Madagascar Penguins in a Christmas Caper HAS COMPLETED { "@type": "Audio", "@typeorder": "1", "StreamOrder": "1", "ID": "2", "UniqueID": "17064740059483774338", "Format": "MLP FBA", "Format_Commercial_IfAny": "Dolby TrueHD", "CodecID": "A_TRUEHD", "Duration": "622.831000000", "BitRate_Mode": "VBR", "BitRate": "3463749", "BitRate_Maximum": "4740000", "Channels": "6", "ChannelPositions": "Front: L C R, Side: L R, LFE", "ChannelLayout": "L R C LFE Ls Rs", "SamplesPerFrame": "40", "SamplingRate": "48000", "SamplingCount": "29895888", "FrameRate": "1200.000", "FrameCount": "747397", "Compression_Mode": "Lossless", "Delay": "0.000", "Delay_Source": "Container", "StreamSize": "269666328", "StreamSize_Proportion": "0.08922", "Title": "Dolby TrueHD Atmos 5.1 (Default)", "Language": "en", "Default": "Yes", "Forced": "No" },  interesting, i have the code open now, so i'll take a wee look see Â
Cheesegeezer 3106 Posted July 4, 2022 Author Posted July 4, 2022 (edited) 13 minutes ago, FrostByte said: I may have found another bug. It looks like it's adding Atmos to all TrueHD tracks even though it may not have Atmos. v1.0.0.2 2022-07-04 09:54:54.984 Info Media Info: PROCESSING OF The Madagascar Penguins in a Christmas Caper HAS STARTED 2022-07-04 09:54:54.984 Info Media Info: Item FilePath = /volume1/MyEmbyMedia/Movies/The Madagascar Penguins in a Christmas Caper (2012)/The.Madagascar.Penguins.in.a.Christmas.Caper.2012.1080p.BluRay.REMUX.AVC.TrueHD.5.1-TRiToN.mkv 2022-07-04 09:54:55.067 Info Media Info: Video Track successfully Written & Exited with Code 0 2022-07-04 09:54:55.067 Info Media Info: Video Track Title Set to 1080p 2022-07-04 09:54:55.501 Info Media Info: Audio Track successfully Written & Exited with Code 0 2022-07-04 09:54:55.501 Info Media Info: Audio Stream #1 Updated to: Dolby TrueHD Atmos 5.1 (Default) 2022-07-04 09:54:55.593 Info Media Info: Audio Track successfully Written & Exited with Code 0 2022-07-04 09:54:55.593 Info Media Info: Audio Stream #2 Updated to: Dolby Digital Plus 5.1 2022-07-04 09:54:55.595 Info Media Info: Item Tags found = 2022-07-04 09:54:55.595 Info Media Info: PROCESSING OF The Madagascar Penguins in a Christmas Caper HAS COMPLETED { "@type": "Audio", "@typeorder": "1", "StreamOrder": "1", "ID": "2", "UniqueID": "17064740059483774338", "Format": "MLP FBA", "Format_Commercial_IfAny": "Dolby TrueHD", "CodecID": "A_TRUEHD", "Duration": "622.831000000", "BitRate_Mode": "VBR", "BitRate": "3463749", "BitRate_Maximum": "4740000", "Channels": "6", "ChannelPositions": "Front: L C R, Side: L R, LFE", "ChannelLayout": "L R C LFE Ls Rs", "SamplesPerFrame": "40", "SamplingRate": "48000", "SamplingCount": "29895888", "FrameRate": "1200.000", "FrameCount": "747397", "Compression_Mode": "Lossless", "Delay": "0.000", "Delay_Source": "Container", "StreamSize": "269666328", "StreamSize_Proportion": "0.08922", "Title": "Dolby TrueHD Atmos 5.1 (Default)", "Language": "en", "Default": "Yes", "Forced": "No" },  nope i just checked the standards and MLP FBA is with ATMOS. But that has 16Ch i think so we may need to add this to the mix.   Edited July 4, 2022 by Cheesegeezer
Cheesegeezer 3106 Posted July 4, 2022 Author Posted July 4, 2022 13 minutes ago, FrostByte said: I may have found another bug. It looks like it's adding Atmos to all TrueHD tracks even though it may not have Atmos. v1.0.0.2 Ok so i think i need to add in an additional feature for Atmos. Your example has no Format Additional features, but atmos has it for 16-ch. Nice wee cheeky find  1
Cheesegeezer 3106 Posted July 4, 2022 Author Posted July 4, 2022 frosty what does the JSON look like please not the sheet Thanks
FrostByte 5456 Posted July 4, 2022 Posted July 4, 2022 { "@type": "General", "UniqueID": "186810533500250407656291911095836829592", "VideoCount": "1", "AudioCount": "2", "TextCount": "2", "MenuCount": "1", "FileExtension": "mkv", "Format": "Matroska", "Format_Version": "4", "FileSize": "3022337864", "Duration": "622.832", "OverallBitRate_Mode": "VBR", "OverallBitRate": "38820586", "FrameRate": "23.976", "FrameCount": "14933", "IsStreamable": "Yes", "Encoded_Date": "UTC 2022-07-04 03:08:30", "File_Created_Date": "UTC 2022-07-04 03:15:55.190", "File_Created_Date_Local": "2022-07-03 23:15:55.190", "File_Modified_Date": "UTC 2022-07-04 14:04:50.327", "File_Modified_Date_Local": "2022-07-04 10:04:50.327", "Encoded_Application": "mkvmerge v68.0.0 ('The Curtain') 64-bit", "Encoded_Library": "libebml v1.4.2 + libmatroska v1.6.4", "extra": { "IMDB": "tt6979738", "TMDB": "movie/286488" } }, { "@type": "Video", "StreamOrder": "0", "ID": "1", "UniqueID": "15390643179230988011", "Format": "AVC", "Format_Profile": "High", "Format_Level": "4.1", "Format_Settings_CABAC": "Yes", "Format_Settings_RefFrames": "4", "CodecID": "V_MPEG4/ISO/AVC", "Duration": "622.831000000", "BitRate_Mode": "VBR", "BitRate": "33715273", "BitRate_Maximum": "36999936", "Width": "1920", "Height": "1080", "Stored_Height": "1088", "Sampled_Width": "1920", "Sampled_Height": "1080", "PixelAspectRatio": "1.000", "DisplayAspectRatio": "1.778", "FrameRate_Mode": "CFR", "FrameRate": "23.976", "FrameCount": "14933", "ColorSpace": "YUV", "ChromaSubsampling": "4:2:0", "BitDepth": "8", "ScanType": "Progressive", "Delay": "0.000", "StreamSize": "2624864712", "Title": "1080p ", "Default": "Yes", "Forced": "No", "BufferSize": "30000000 / 30000000" }, { "@type": "Audio", "@typeorder": "1", "StreamOrder": "1", "ID": "2", "UniqueID": "17064740059483774338", "Format": "MLP FBA", "Format_Commercial_IfAny": "Dolby TrueHD", "CodecID": "A_TRUEHD", "Duration": "622.831000000", "BitRate_Mode": "VBR", "BitRate": "3463749", "BitRate_Maximum": "4740000", "Channels": "6", "ChannelPositions": "Front: L C R, Side: L R, LFE", "ChannelLayout": "L R C LFE Ls Rs", "SamplesPerFrame": "40", "SamplingRate": "48000", "SamplingCount": "29895888", "FrameRate": "1200.000", "FrameCount": "747397", "Compression_Mode": "Lossless", "Delay": "0.000", "Delay_Source": "Container", "StreamSize": "269666328", "StreamSize_Proportion": "0.08922", "Title": "Dolby TrueHD Atmos 5.1 (Default)", "Language": "en", "Default": "Yes", "Forced": "No" }, { "@type": "Audio", "@typeorder": "2", "StreamOrder": "2", "ID": "3", "UniqueID": "4835666226456387469", "Format": "E-AC-3", "Format_Commercial_IfAny": "Dolby Digital Plus", "Format_Settings_Endianness": "Big", "CodecID": "A_EAC3", "Duration": "622.832000000", "BitRate_Mode": "CBR", "BitRate": "1536000", "Channels": "6", "ChannelPositions": "Front: L C R, Side: L R, LFE", "ChannelLayout": "L R C LFE Ls Rs", "SamplesPerFrame": "768", "SamplingRate": "48000", "SamplingCount": "29895936", "FrameRate": "62.500", "FrameCount": "38927", "Compression_Mode": "Lossy", "Delay": "0.000", "Delay_Source": "Container", "StreamSize": "119583744", "StreamSize_Proportion": "0.03957", "Title": "Dolby Digital Plus 5.1", "Language": "en", "ServiceKind": "CM", "Default": "No", "Forced": "No", "extra": { "bsid": "16", "dialnorm": "-31", "acmod": "7", "lfeon": "1", "dialnorm_Average": "-31", "dialnorm_Minimum": "-31" } }, { "@type": "Text", "@typeorder": "1", "StreamOrder": "3", "ID": "4", "UniqueID": "15066381947696455122", "Format": "PGS", "MuxingMode": "zlib", "CodecID": "S_HDMV/PGS", "Duration": "557.473000000", "BitRate": "59773", "FrameRate": "0.502", "FrameCount": "280", "ElementCount": "280", "StreamSize": "4165242", "Title": "(Default PGS)", "Language": "en", "Default": "Yes", "Forced": "No" }, { "@type": "Text", "@typeorder": "2", "StreamOrder": "4", "ID": "5", "UniqueID": "12775586581117609331", "Format": "PGS", "MuxingMode": "zlib", "CodecID": "S_HDMV/PGS", "Duration": "614.114000000", "BitRate": "62076", "FrameRate": "0.518", "FrameCount": "318", "ElementCount": "318", "StreamSize": "4765276", "Title": "SDH (PGS)", "Language": "en", "Default": "No", "Forced": "No" }, { "@type": "Menu", "extra": { "_00_00_00_000": "en:Chapter 01", "_00_10_22_831": "en:Chapter 02" Â
Cheesegeezer 3106 Posted July 4, 2022 Author Posted July 4, 2022 2 minutes ago, FrostByte said: { "@type": "General", "UniqueID": "186810533500250407656291911095836829592", "VideoCount": "1", "AudioCount": "2", "TextCount": "2", "MenuCount": "1", "FileExtension": "mkv", "Format": "Matroska", "Format_Version": "4", "FileSize": "3022337864", "Duration": "622.832", "OverallBitRate_Mode": "VBR", "OverallBitRate": "38820586", "FrameRate": "23.976", "FrameCount": "14933", "IsStreamable": "Yes", "Encoded_Date": "UTC 2022-07-04 03:08:30", "File_Created_Date": "UTC 2022-07-04 03:15:55.190", "File_Created_Date_Local": "2022-07-03 23:15:55.190", "File_Modified_Date": "UTC 2022-07-04 14:04:50.327", "File_Modified_Date_Local": "2022-07-04 10:04:50.327", "Encoded_Application": "mkvmerge v68.0.0 ('The Curtain') 64-bit", "Encoded_Library": "libebml v1.4.2 + libmatroska v1.6.4", "extra": { "IMDB": "tt6979738", "TMDB": "movie/286488" } }, { "@type": "Video", "StreamOrder": "0", "ID": "1", "UniqueID": "15390643179230988011", "Format": "AVC", "Format_Profile": "High", "Format_Level": "4.1", "Format_Settings_CABAC": "Yes", "Format_Settings_RefFrames": "4", "CodecID": "V_MPEG4/ISO/AVC", "Duration": "622.831000000", "BitRate_Mode": "VBR", "BitRate": "33715273", "BitRate_Maximum": "36999936", "Width": "1920", "Height": "1080", "Stored_Height": "1088", "Sampled_Width": "1920", "Sampled_Height": "1080", "PixelAspectRatio": "1.000", "DisplayAspectRatio": "1.778", "FrameRate_Mode": "CFR", "FrameRate": "23.976", "FrameCount": "14933", "ColorSpace": "YUV", "ChromaSubsampling": "4:2:0", "BitDepth": "8", "ScanType": "Progressive", "Delay": "0.000", "StreamSize": "2624864712", "Title": "1080p ", "Default": "Yes", "Forced": "No", "BufferSize": "30000000 / 30000000" }, { "@type": "Audio", "@typeorder": "1", "StreamOrder": "1", "ID": "2", "UniqueID": "17064740059483774338", "Format": "MLP FBA", "Format_Commercial_IfAny": "Dolby TrueHD", "CodecID": "A_TRUEHD", "Duration": "622.831000000", "BitRate_Mode": "VBR", "BitRate": "3463749", "BitRate_Maximum": "4740000", "Channels": "6", "ChannelPositions": "Front: L C R, Side: L R, LFE", "ChannelLayout": "L R C LFE Ls Rs", "SamplesPerFrame": "40", "SamplingRate": "48000", "SamplingCount": "29895888", "FrameRate": "1200.000", "FrameCount": "747397", "Compression_Mode": "Lossless", "Delay": "0.000", "Delay_Source": "Container", "StreamSize": "269666328", "StreamSize_Proportion": "0.08922", "Title": "Dolby TrueHD Atmos 5.1 (Default)", "Language": "en", "Default": "Yes", "Forced": "No" }, { "@type": "Audio", "@typeorder": "2", "StreamOrder": "2", "ID": "3", "UniqueID": "4835666226456387469", "Format": "E-AC-3", "Format_Commercial_IfAny": "Dolby Digital Plus", "Format_Settings_Endianness": "Big", "CodecID": "A_EAC3", "Duration": "622.832000000", "BitRate_Mode": "CBR", "BitRate": "1536000", "Channels": "6", "ChannelPositions": "Front: L C R, Side: L R, LFE", "ChannelLayout": "L R C LFE Ls Rs", "SamplesPerFrame": "768", "SamplingRate": "48000", "SamplingCount": "29895936", "FrameRate": "62.500", "FrameCount": "38927", "Compression_Mode": "Lossy", "Delay": "0.000", "Delay_Source": "Container", "StreamSize": "119583744", "StreamSize_Proportion": "0.03957", "Title": "Dolby Digital Plus 5.1", "Language": "en", "ServiceKind": "CM", "Default": "No", "Forced": "No", "extra": { "bsid": "16", "dialnorm": "-31", "acmod": "7", "lfeon": "1", "dialnorm_Average": "-31", "dialnorm_Minimum": "-31" } }, { "@type": "Text", "@typeorder": "1", "StreamOrder": "3", "ID": "4", "UniqueID": "15066381947696455122", "Format": "PGS", "MuxingMode": "zlib", "CodecID": "S_HDMV/PGS", "Duration": "557.473000000", "BitRate": "59773", "FrameRate": "0.502", "FrameCount": "280", "ElementCount": "280", "StreamSize": "4165242", "Title": "(Default PGS)", "Language": "en", "Default": "Yes", "Forced": "No" }, { "@type": "Text", "@typeorder": "2", "StreamOrder": "4", "ID": "5", "UniqueID": "12775586581117609331", "Format": "PGS", "MuxingMode": "zlib", "CodecID": "S_HDMV/PGS", "Duration": "614.114000000", "BitRate": "62076", "FrameRate": "0.518", "FrameCount": "318", "ElementCount": "318", "StreamSize": "4765276", "Title": "SDH (PGS)", "Language": "en", "Default": "No", "Forced": "No" }, { "@type": "Menu", "extra": { "_00_00_00_000": "en:Chapter 01", "_00_10_22_831": "en:Chapter 02"  Perfecto just as i thought… no 16-ch in additional featuresÂ
FrostByte 5456 Posted July 4, 2022 Posted July 4, 2022 I checked several movies with just TrueHD 5.1 (no Atmos) and they all got identified as having Atmos Here's the json for the movie Automata { "@type": "Audio", "@typeorder": "1", "StreamOrder": "1", "ID": "2", "UniqueID": "2", "Format": "MLP FBA", "Format_Commercial_IfAny": "Dolby TrueHD", "CodecID": "A_TRUEHD", "Duration": "6594.130000000", "BitRate_Mode": "VBR", "BitRate": "3197568", "BitRate_Maximum": "4500000", "Channels": "6", "ChannelPositions": "Front: L C R, Side: L R, LFE", "ChannelLayout": "L R C LFE Ls Rs", "SamplesPerFrame": "40", "SamplingRate": "48000", "SamplingCount": "316518240", "FrameRate": "1200.000", "FrameCount": "7912956", "BitDepth": "24", "Compression_Mode": "Lossless", "Delay": "0.000", "Delay_Source": "Container", "StreamSize": "2635647466", "StreamSize_Proportion": "0.14020", "Title": "Dolby TrueHD Atmos 5.1 (Default)", "Language": "en", "Default": "Yes", "Forced": "No" }, Â 1
FrostByte 5456 Posted July 4, 2022 Posted July 4, 2022 I have never seen TrueHD 5.1 with Atmos, but I haven't seen anything saying you can't have it either. Â
rbjtech 5345 Posted July 4, 2022 Posted July 4, 2022 Nice catch ! I never caught that in my original script either. So MLP FBA + 16 Channels = TrueHD + Atmos MLP FBA Only = TrueHD 1 1 1
Cheesegeezer 3106 Posted July 4, 2022 Author Posted July 4, 2022 36 minutes ago, rbjtech said: So MLP FBA + 16 Channels = TrueHD + Atmos  Actually no its Dolby TrueHD 7.1 [Atmos]  1 1
