FrostByte 5456 Posted June 12, 2022 Posted June 12, 2022 The only thing I might be interested in is identifying FEL or MEL for DV7 and adding that to the title. Hardly seems worth it though. Here is a link to a toolset which already does everything else you're talking of doing. Nice menu, and videos. No gui though Dolby-Vision-Tools - Google Drive
neik 874 Posted June 12, 2022 Posted June 12, 2022 38 minutes ago, FrostByte said: FEL or MEL Noobish question incoming: What do these abbreviations mean?
Cheesegeezer 3106 Posted June 12, 2022 Author Posted June 12, 2022 12 minutes ago, neik said: Noobish question incoming: What do these abbreviations mean? I think @FrostByte was just asking to "Feel Mee" lol hahahahaa 1
Cheesegeezer 3106 Posted June 12, 2022 Author Posted June 12, 2022 Demystifying Dolby Vision - Profile Levels, Dolby Vision levels, MEL & FEL - Home Theater Lobby - AV Discourse Community Forum (SG) 1
FrostByte 5456 Posted June 12, 2022 Posted June 12, 2022 (edited) 21 minutes ago, neik said: Noobish question incoming: What do these abbreviations mean? There are basically two parts of DV profile 7. The Enhanced layer and the RPU. Full Enhanced Layer (FEL) = HDR10 10bits base layer + the extra information to make 12 bits data in EL 1080p stream + dynamic metadata RPU Minimal Enhanced Layer (MEL) = HDR10 10bits base layer + Blank EL 1080p stream for compatibility + dynamic metadata in RPU So only the FEL DV movies will get you 12bit colors if you had something which could actually play it. What you see with your Shield is only the metadata RPU part and it ignores the EL. It would need a second HEVC decoder, or something in order to play the second HEVC stream Edited June 12, 2022 by FrostByte
Cheesegeezer 3106 Posted June 12, 2022 Author Posted June 12, 2022 3 minutes ago, FrostByte said: There are basically two parts of DV profile 7. The Enhanced layer and the RPU. Full Enhanced Layer (FEL) = HDR10 10bits base layer + the extra information to make 12 bits data in EL 1080p stream + dynamic metadata RPU Minimal Enhanced Layer (MEL) = HDR10 10bits base layer + Blank EL 1080p stream for compatibility + dynamic metadata in RPU So only the FEL DV movies will get you 12bit colors if you had something which could actually play it. What you see with your Shield is only the metadata RPU part and it ignores the EL. It would need a second HEVC decoder, or something in order to play the second HEVC stream So a question... Does every DV have a dual layer or only Enhanced DV have 2 video streams in the container?
FrostByte 5456 Posted June 12, 2022 Posted June 12, 2022 1 minute ago, Cheesegeezer said: So a question... Does every DV have a dual layer or only Enhanced DV have 2 video streams in the container? Only DV7 has an enhanced layer. DV8 is basically HDR10 plus a metadata RPU with no EL. So, if you were inclined to check you would only need to check DV7.
Cheesegeezer 3106 Posted June 12, 2022 Author Posted June 12, 2022 so what i have noticed is that in media info i can see 2 video streams. if a DV7 only has 1 layer then its not got the FEL/MEL or is that not a good assumption to use
FrostByte 5456 Posted June 12, 2022 Posted June 12, 2022 The current method when creating DV7 MKV is to hide both the 2160p HEVC layer and the 1080p HEVC enhanced layer in one pid (single track dual layer). So, when using mediainfo you can only see one video track, but there are actually still two HEVC video tracks, but they are both hidden inside the one pid. What you can do is extract the HEVC from your DV7 mkv, then use dov_tool to demux the 1 HEVC back into 2 HEVC files (2160, and 1080p EL) However, when using dovi_tool you don't really need to demux the HEVC back into 2 because dovi_tool can still identify FEL or MEL from the dual layer single track DV7 HEVC file
FrostByte 5456 Posted June 12, 2022 Posted June 12, 2022 (edited) Another way to look at it. Here's the BDinfo straight from a UHD DV7 disc. As you can see it has a 2160p layer and a 1080p EL. Then when you use makemkv to create your file it hides those two video layers into one track while allowing you to reverse the process if needed later. DISC INFO: Disc Title: Morbius 2022 Disc Size: 57,347,969,383 bytes Protection: AACS2 Extras: Ultra HD, BD-Java BDInfo: 0.7.5.9 (compatible layout created by DVDFab 12.0.7.3) PLAYLIST REPORT: Name: 00001.MPLS Length: 1:44:11.244 (h:m:s.ms) Size: 56,216,807,424 bytes Total Bitrate: 71.94 Mbps (*) Indicates included stream hidden by this playlist. VIDEO: Codec Bitrate Description ----- ------- ----------- MPEG-H HEVC Video 51812 kbps 2160p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 4000nits / HDR10 / BT.2020 * MPEG-H HEVC Video 2105 kbps (3.90%) 1080p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 4000nits / Dolby Vision FEL / BT.2020 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- Dolby TrueHD/Atmos Audio English 5336 kbps 7.1+11 objects / 48 kHz / 4696 kbps / 24-bit (AC3 Core: 5.1 / 48 kHz / 640 kbps) Dolby Digital Audio English 640 kbps 5.1 / 48 kHz / 640 kbps Dolby Digital Audio Czech 640 kbps 5.1 / 48 kHz / 640 kbps Dolby Digital Audio Hungarian 640 kbps 5.1 / 48 kHz / 640 kbps DTS-HD Master Audio Italian 2352 kbps 5.1 / 48 kHz / 2352 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit) Dolby Digital Audio Polish 640 kbps 5.1 / 48 kHz / 640 kbps DTS-HD Master Audio Spanish 2395 kbps 5.1 / 48 kHz / 2395 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit) Edited June 12, 2022 by FrostByte 1
rbjtech 5345 Posted June 13, 2022 Posted June 13, 2022 15 hours ago, FrostByte said: The only thing I might be interested in is identifying FEL or MEL for DV7 and adding that to the title. Hardly seems worth it though. Here is a link to a toolset which already does everything else you're talking of doing. Nice menu, and videos. No gui though Dolby-Vision-Tools - Google Drive I think for the audience that this plugin is targeting (AV enthusiasts that simply want to see if a title is DV or not) then I personally think adding further DV 'for info but unnecessary' details is gonna confuse further rather than add value. As you've said, other than dedicated hardware that decodes the dual tracks - then it's irrelevant as nothing which runs 'Emby' can do so. 1
FrostByte 5456 Posted June 13, 2022 Posted June 13, 2022 52 minutes ago, rbjtech said: I think for the audience that this plugin is targeting (AV enthusiasts that simply want to see if a title is DV or not) then I personally think adding further DV 'for info but unnecessary' details is gonna confuse further rather than add value. As you've said, other than dedicated hardware that decodes the dual tracks - then it's irrelevant as nothing which runs 'Emby' can do so. Absolutely. Right now for me the mediainfo plugin does everything needed when used with Emby which is why I said it wasn't really necessary yet. The reason I brought it up is because you're already talking about adding stuff that goes way beyond the original intent of the plug for which there are tools for already. The list is getting bigger and bigger. All the other stuff I think should be in another plugin as it has nothing to do with mediainfo and will also confuse things. They could easily be added to a media conversion plugin. 1
rbjtech 5345 Posted June 13, 2022 Posted June 13, 2022 16 minutes ago, FrostByte said: Absolutely. Right now for me the mediainfo plugin does everything needed when used with Emby which is why I said it wasn't really necessary yet. The reason I brought it up is because you're already talking about adding stuff that goes way beyond the original intent of the plug for which there are tools for already. The list is getting bigger and bigger. All the other stuff I think should be in another plugin as it has nothing to do with mediainfo and will also confuse things. They could easily be added to a media conversion plugin. The basic MKV container conversion is a good thing to have in the toolbox - as it's basically an enabler for the main MediaInfo function that only works on MKV's But for other more complex DV conversions, then we would be going down a rabbit hole that we really don't wanna contemplate entering .. !! I'd like to see the DTS to 'Add Dolby track' added - but that is very simple process. btw - we are just testing the new formatting of the Plugin - each function now has it's own tab (like Introskip did) - it looks very wizzy now - Dave has done an amazing job of making it all look as nice as it functions He is also adding an event listener to run the task on demand - ie as you add new items. Once final testing is done - then it can go into the catalog. @Cheesegeezer 2
Cheesegeezer 3106 Posted June 13, 2022 Author Posted June 13, 2022 Almost there everyone just need to tidy up the bif generator Real Time monitor. MediaInfo RTM is working great. be tomorrow unfortunately I’m engaged in whisky drinking now for ma pals’s birthday lol 3
Cheesegeezer 3106 Posted June 13, 2022 Author Posted June 13, 2022 (edited) Also the config xml has moved, but i have put in “clinically proven iCheese Technology” to migrate old settings to new settings so you shouldn’t FEL (haha) a thing. Check log after reboot to ensure you see the “we found it” statement. Edited June 13, 2022 by Cheesegeezer 3
FrostByte 5456 Posted June 16, 2022 Posted June 16, 2022 On 6/13/2022 at 1:06 PM, Cheesegeezer said: Almost there everyone just need to tidy up the bif generator Real Time monitor. MediaInfo RTM is working great. be tomorrow unfortunately I’m engaged in whisky drinking now for ma pals’s birthday lol Have you got a new version with RTM? 1
Cheesegeezer 3106 Posted June 17, 2022 Author Posted June 17, 2022 Ok peeps so as you are aware MKV Convert is removed. I am posting up MediaInfo version 0.0.5.0. Quite a few non-obvious bug fixes Real Time Monitoring implementation New Tabbed view removal of MKV Converter (not that it ever made the released plugin here) RTM will wait 3mins before doing anything once Emby detects the new item.... This is to give emby the chance to do its thing first. ---- Can you check this in the debug logs. new tabbed view Darn.... just noticed the Plugin title and also the SETUP Info Button missing.... grrrrrrr 3 1
rbjtech 5345 Posted June 17, 2022 Posted June 17, 2022 (edited) One of the bugs which is now trapped is the inclusion of STRM (stream/link) files types - that carry no video information, thus the plugin was stalling when it hit one. Nice work from Dave as always to track that one down Edited June 17, 2022 by rbjtech 1
FrostByte 5456 Posted June 17, 2022 Posted June 17, 2022 2 hours ago, Cheesegeezer said: Ok peeps so as you are aware MKV Convert is removed. I am posting up MediaInfo version 0.0.5.0. Quite a few non-obvious bug fixes Real Time Monitoring implementation New Tabbed view removal of MKV Converter (not that it ever made the released plugin here) RTM will wait 3mins before doing anything once Emby detects the new item.... This is to give emby the chance to do its thing first. ---- Can you check this in the debug logs. new tabbed view Darn.... just noticed the Plugin title and also the SETUP Info Button missing.... grrrrrrr I noticed that if you paste the paths in it doesn't save , you have to actually navigate and select them from the select directory button. In other places you can just paste the path, such as when adding a library.
FrostByte 5456 Posted June 17, 2022 Posted June 17, 2022 Of course, the instructions do say to "Select the file path", but...it would be nice
FrostByte 5456 Posted June 17, 2022 Posted June 17, 2022 another wish Add the id next to the title of exempt items in the log. I had to look them all up again when the settings got wiped in the upgrade.
MagicDoubleM 121 Posted June 17, 2022 Posted June 17, 2022 0.0.5.0 works fine here, no hiccups. Great work, and very nice to have real time monitoring now.
Cheesegeezer 3106 Posted June 17, 2022 Author Posted June 17, 2022 42 minutes ago, FrostByte said: I noticed that if you paste the paths in it doesn't save , you have to actually navigate and select them from the select directory button. In other places you can just paste the path, such as when adding a library. Yeah sorry, really designed for first time users, ye olde veterans. However its an improvement 36 minutes ago, FrostByte said: Of course, the instructions do say to "Select the file path", but...it would be nice Gotchya 32 minutes ago, FrostByte said: another wish Add the id next to the title of exempt items in the log. I had to look them all up again when the settings got wiped in the upgrade. Sure i can do that nae bother, can you gimme an example where in your log please 3 minutes ago, MagicDoubleM said: 0.0.5.0 works fine here, no hiccups. Great work, and very nice to have real time monitoring now. Love it 1
