Mookdog 90 Posted June 10, 2022 Posted June 10, 2022 On 6/7/2022 at 3:21 PM, Cheesegeezer said: I’m gonna put this out there but is anyone interested in this feature Ok so say for instance I got 3000 movies and 1000 tv shows this would probably take forever lol Mook
gihayes 47 Posted June 10, 2022 Posted June 10, 2022 1 minute ago, Mookdog said: Ok so say for instance I got 3000 movies and 1000 tv shows this would probably take forever lol Mook But what you'd have after it finished would be great!
Mookdog 90 Posted June 10, 2022 Posted June 10, 2022 12 minutes ago, gihayes said: But what you'd have after it finished would be great! Actually I converted a file just now it look like 6 seconds not bad at all. Does the beta delete the source file ? I hope it does that way I dont have to go through every single folder lol Mook
gihayes 47 Posted June 10, 2022 Posted June 10, 2022 Just now, Mookdog said: Does the beta delete the source file ? I hope it does that way I dont have to go through every single folder lol What Cheese showed earlier gave you that option
Mookdog 90 Posted June 10, 2022 Posted June 10, 2022 14 minutes ago, gihayes said: What Cheese showed earlier gave you that option I could definitely use that function to convert. The dll with that function hasnt been posted yet ? Mook
gihayes 47 Posted June 10, 2022 Posted June 10, 2022 2 minutes ago, Mookdog said: I could definitely use that function to convert. The dll with that function hasnt been posted yet ? Mook I don't think so. He is still workin' on it. Great stuff!
rbjtech 5345 Posted June 10, 2022 Posted June 10, 2022 (edited) 6 hours ago, MagicDoubleM said: Re Tags... I noticed that movies with a radarr tag again lost their mediainfo tags. So here's the only explanation I have currently, emby seems to reset tags when it reads metadata from an nfo file and doesn't ever write tags through the metadata saver plugin, hence tags get lost as soon as there's one in the nfo and a metadata refresh is happening. I'll have to test this, but that's basically what was going on. Hi - Yep, I think you have uncovered the issue - it's the nfo files. While my items retain the MediaInfo tag's - they are not in the NFO. I had a manually added a tag before MediaInfo added more - and that was in the NFO. They are only written to the NFO if I go into the metadata and hit 'Save' - then All the Tag's are written. If I manually add another one - then ALL the tags, incl the MediaInfo ones get written. Before writing them to the NFO, they are however, not lost if I refresh the metadata, as they are locked items according to the Metadata editor. So I think all we are missing is 're-saving' the metadata once the tags have been added by MediaInfo - in the API this is the 'ItemUpdateService' @Cheesegeezer - Any thoughts ? Edited June 10, 2022 by rbjtech 1
neik 874 Posted June 10, 2022 Posted June 10, 2022 I feel like the processed list is not being filled correctly. Today morning I ran the task again for a bit where it processed a couple of files and then I canceled it within the Emby dashboard. It seemed to have stopped gracefully but the files that were processed have already been processed previously and when I have a look at the XML it only lists two processed IDs which is definitely a bit low. Anyone else seeing this? This is on 0.0.2.1
rbjtech 5345 Posted June 10, 2022 Posted June 10, 2022 6 minutes ago, neik said: I feel like the processed list is not being filled correctly. Today morning I ran the task again for a bit where it processed a couple of files and then I canceled it within the Emby dashboard. It seemed to have stopped gracefully but the files that were processed have already been processed previously and when I have a look at the XML it only lists two processed IDs which is definitely a bit low. Anyone else seeing this? This is on 0.0.2.1 I can try and reproduce - but my XML is over 700K lol, so lots of stuff is being written .. I'll delete some 'processed' items and see if it re-picks them up and then re-adds them ..
Cheesegeezer 3106 Posted June 10, 2022 Author Posted June 10, 2022 (edited) 2 hours ago, neik said: I feel like the processed list is not being filled correctly. Today morning I ran the task again for a bit where it processed a couple of files and then I canceled it within the Emby dashboard. It seemed to have stopped gracefully but the files that were processed have already been processed previously and when I have a look at the XML it only lists two processed IDs which is definitely a bit low. Anyone else seeing this? This is on 0.0.2.1 Did you have refresh on? Because this will delete the processed list. rich is doing some tests now Edited June 10, 2022 by Cheesegeezer
neik 874 Posted June 10, 2022 Posted June 10, 2022 20 minutes ago, Cheesegeezer said: Did you have refresh on? Because this will delete the processed list. rich is doing some tests now I'm quite sure it was off but I will also double check on my side and do some retests once I get to it. @rbjtech, let me please know how your tests go on. Thanks!
Cheesegeezer 3106 Posted June 10, 2022 Author Posted June 10, 2022 (edited) mkvConvert.webm Here is a wee video show casing the MKV Convert feature. It allows you to preserver Dolby Vision inside of MP4 video. it will rename your old file to "orig-" + original extension You can keep the old file for upto 12 weeks or set to 0 for immediate deletion If you wish to revert the conversion back to their original format this can also be done. mkvConvert.webm Edited June 10, 2022 by Cheesegeezer 1
rbjtech 5345 Posted June 10, 2022 Posted June 10, 2022 (edited) 6 hours ago, rbjtech said: Hi - Yep, I think you have uncovered the issue - it's the nfo files. While my items retain the MediaInfo tag's - they are not in the NFO. I had a manually added a tag before MediaInfo added more - and that was in the NFO. They are only written to the NFO if I go into the metadata and hit 'Save' - then All the Tag's are written. If I manually add another one - then ALL the tags, incl the MediaInfo ones get written. Before writing them to the NFO, they are however, not lost if I refresh the metadata, as they are locked items according to the Metadata editor. So I think all we are missing is 're-saving' the metadata once the tags have been added by MediaInfo - in the API this is the 'ItemUpdateService' @Cheesegeezer - Any thoughts ? @MagicDoubleM This has been fixed - we are testing it now. In summary, the NFO data is not written as part of the usual metadata update (for some reason), it's written by a separate 'Library' function - this is why it was understandably missed. Once it's tested, Cheese will update the DLL and then the NFO for each Item will be immediately updated, allowing any further NFO processing to include the Tag updates from MediaInfo. Edited June 10, 2022 by rbjtech 1
Cheesegeezer 3106 Posted June 10, 2022 Author Posted June 10, 2022 26 minutes ago, rbjtech said: Once it's tested, Cheese will update the DLL and then the NFO for each Item will be immediately updated, allowing any further NFO processing to include the Tag updates from MediaInfo. Actually the librarys will need to be refreshed in the plugin. So Tick refresh and run again. 1 1
Mookdog 90 Posted June 10, 2022 Posted June 10, 2022 3 hours ago, Cheesegeezer said: mkvConvert.webm 15.73 MB · 0 downloads Here is a wee video show casing the MKV Convert feature. It allows you to preserver Dolby Vision inside of MP4 video. it will rename your old file to "orig-" + original extension You can keep the old file for upto 12 weeks or set to 0 for immediate deletion If you wish to revert the conversion back to their original format this can also be done. mkvConvert.webm 15.73 MB · 0 downloads Looks amazing @CheesegeezerI am chomping at the bit just waiting for it so I can get started converting my library lol Mook
Cheesegeezer 3106 Posted June 10, 2022 Author Posted June 10, 2022 2 minutes ago, Mookdog said: Looks amazing @CheesegeezerI am chomping at the bit just waiting for it so I can get started converting my library lol Mook @MagicDoubleM @neik @Mookdog Version 3.0 is up on first post... I haven't had chance to create a wiki for the Convert to MKV, but the video above will help you out massively. NOTHING WILL BE DELETED UNITL WE ARE HAPPY WITH THE CONVERSION. So please check your logs in DEBUG mode to keep an eye on this. If you have any doubts about running the convert to mkv feature, just leave it alone. Following fixes NFO tag writting and removal should be fixed Items remaining in cache should be fixed. 1
Mookdog 90 Posted June 10, 2022 Posted June 10, 2022 22 minutes ago, Cheesegeezer said: @MagicDoubleM @neik @Mookdog Version 3.0 is up on first post... I haven't had chance to create a wiki for the Convert to MKV, but the video above will help you out massively. NOTHING WILL BE DELETED UNITL WE ARE HAPPY WITH THE CONVERSION. So please check your logs in DEBUG mode to keep an eye on this. If you have any doubts about running the convert to mkv feature, just leave it alone. Following fixes NFO tag writting and removal should be fixed Items remaining in cache should be fixed. Anyway to turn on deletion ? I have over 3000 movies and it would take forever to delete each movie lol Mook
Cheesegeezer 3106 Posted June 10, 2022 Author Posted June 10, 2022 (edited) 4 minutes ago, Mookdog said: Anyway to turn on deletion ? I have over 3000 movies and it would take forever to delete each movie lol Mook Nope not yet… the idea of allowing that is to stop you losing your entire library should anything go wrong during testing. once we can confirm it worked on your 3000 movies, i can enable the file deletion and you can set your time and they will be deleted Edited June 10, 2022 by Cheesegeezer
Mookdog 90 Posted June 10, 2022 Posted June 10, 2022 2 hours ago, Cheesegeezer said: @MagicDoubleM @neik @Mookdog Version 3.0 is up on first post... I haven't had chance to create a wiki for the Convert to MKV, but the video above will help you out massively. NOTHING WILL BE DELETED UNITL WE ARE HAPPY WITH THE CONVERSION. So please check your logs in DEBUG mode to keep an eye on this. If you have any doubts about running the convert to mkv feature, just leave it alone. Following fixes NFO tag writting and removal should be fixed Items remaining in cache should be fixed. @CheesegeezerSo nothing will be deleted if I set the days to keep original file to 0 ? Reason I ask is I am pretty limited on space right now and I wouldnt be able to have duplicate in mp4 format bc of that situation. I know all my movies arent mp4 but a good bulk is. Thanks for all your hard work Mook
Cheesegeezer 3106 Posted June 10, 2022 Author Posted June 10, 2022 26 minutes ago, Mookdog said: @CheesegeezerSo nothing will be deleted if I set the days to keep original file to 0 ? Reason I ask is I am pretty limited on space right now and I wouldnt be able to have duplicate in mp4 format bc of that situation. I know all my movies arent mp4 but a good bulk is. Thanks for all your hard work Mook Can you setup a seperate server with -about 20 movies in to test. im pretty confident it will work but if i delete all your originals and you have nothing to play because of damaged files, believe me you would be raging with me! i need it testing first, to appease my good nature and we can go from there. hope that makes real good sense to you. Cheers
Mookdog 90 Posted June 10, 2022 Posted June 10, 2022 35 minutes ago, Cheesegeezer said: Can you setup a seperate server with -about 20 movies in to test. im pretty confident it will work but if i delete all your originals and you have nothing to play because of damaged files, believe me you would be raging with me! i need it testing first, to appease my good nature and we can go from there. hope that makes real good sense to you. Cheers I understand brother I will test on my laptop later today Mook
Mookdog 90 Posted June 10, 2022 Posted June 10, 2022 52 minutes ago, Cheesegeezer said: Can you setup a seperate server with -about 20 movies in to test. im pretty confident it will work but if i delete all your originals and you have nothing to play because of damaged files, believe me you would be raging with me! i need it testing first, to appease my good nature and we can go from there. hope that makes real good sense to you. Cheers @Cheesegeezermost of my files are 1080p I will test them in a bit. Do u need a debug log when I am finished ? Mook
neik 874 Posted June 10, 2022 Posted June 10, 2022 8 hours ago, neik said: I'm quite sure it was off but I will also double check on my side and do some retests once I get to it. Just tested with the updated version of today, same issue unfortunately. Do I need to delete the XML when updating plugin versions?
rbjtech 5345 Posted June 10, 2022 Posted June 10, 2022 11 minutes ago, neik said: Just tested with the updated version of today, same issue unfortunately. Do I need to delete the XML when updating plugin versions? Can you provide the MediaInfo JSON of one of the files - I'm seeing some issues myself where the order of the tracks is Audio then Video, rather than the usual Video then Audio - I'm wondering if this is related to your issue. In these cases, the item is not written as 'processed' and thus gets repeated over and over again.
neik 874 Posted June 10, 2022 Posted June 10, 2022 2 minutes ago, rbjtech said: Can you provide the MediaInfo JSON of one of the files - I'm seeing some issues myself where the order of the tracks is Audio then Video, rather than the usual Video then Audio - I'm wondering if this is related to your issue. In these cases, the item is not written as 'processed' and thus gets repeated over and over again. I've seen such files as well but in this case the affected ones are do seem to have a "regular" order. Example 1: Format : Matroska Format version : Version 4 File size : 2.23 GiB Duration : 1 h 39 min Overall bit rate : 3 210 kb/s Encoded date : UTC 2020-08-29 10:25:44 Writing application : mkvmerge v19.0.0 ('Brave Captain') 64-bit Writing library : libebml v1.3.5 + libmatroska v1.4.8 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L3.1 Format settings : CABAC / 4 Ref Frames Format settings, CABAC : Yes Format settings, Reference frames : 4 frames Format settings, GOP : M=1, N=50 Codec ID : V_MPEG4/ISO/AVC Duration : 1 h 39 min Bit rate mode : Constant Bit rate : 3 199 kb/s Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 25.000 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.139 Stream size : 2.16 GiB (97%) Title : 720p AVC Language : German Default : Yes Forced : No Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Audio ID : 2 Format : AAC LC Format/Info : Advanced Audio Codec Low Complexity Codec ID : A_AAC-2 Duration : 1 h 39 min Bit rate : 96.0 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 44.1 kHz Frame rate : 43.066 FPS (1024 SPF) Compression mode : Lossy Stream size : 68.3 MiB (3%) Title : AAC LC 2.0 Language : German Default : Yes Forced : No Example 2: Format : Matroska Format version : Version 4 File size : 911 MiB Duration : 50 min 21 s Overall bit rate : 2 530 kb/s Encoded date : UTC 2020-08-25 08:43:12 Writing application : mkvmerge v47.0.0 ('Black Flag') 64-bit Writing library : libebml v1.3.10 + libmatroska v1.5.2 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L3.1 Format settings : CABAC / 3 Ref Frames Format settings, CABAC : Yes Format settings, Reference frames : 3 frames Codec ID : V_MPEG4/ISO/AVC Duration : 50 min 21 s Bit rate : 2 402 kb/s Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 25.000 FPS Standard : PAL Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.104 Stream size : 865 MiB (95%) Title : 720p AVC Default : Yes Forced : No Color range : Limited Audio ID : 2 Format : AAC LC Format/Info : Advanced Audio Codec Low Complexity Codec ID : A_AAC-2 Duration : 50 min 21 s Bit rate : 125 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 46.875 FPS (1024 SPF) Compression mode : Lossy Delay relative to video : -80 ms Stream size : 45.2 MiB (5%) Title : AAC LC 2.0 Language : German Default : Yes Forced : No
