Cheesegeezer 3106 Posted June 6, 2022 Author Posted June 6, 2022 6 minutes ago, neik said: Just tested the latest version but unfortunately the naming of video tracks still seems to be an issue. 7 minutes ago, FrostByte said: It's still not updating the video portion of lots of new stuff I add even though the log says it is updating. For instance, the 3rd episode of Obi-Wan. Even though the first 2 episodes update with no problem. There are several episodes and movies which won't update, but it's always the same ones. obi2.txt 5.16 MB · 0 downloads "@type": "Video", "StreamOrder": "0", "ID": "1", "UniqueID": "9662855407556330958", "Format": "HEVC", "Format_Profile": "Main 10", "Format_Level": "5", "Format_Tier": "High", "HDR_Format": "SMPTE ST 2086", "HDR_Format_Compatibility": "HDR10", "CodecID": "V_MPEGH/ISO/HEVC", "Duration": "2674.709000000", "BitRate": "15359976", "Width": "3840", "Height": "2160", "Sampled_Width": "3840", "Sampled_Height": "2160", "PixelAspectRatio": "1.000", "DisplayAspectRatio": "1.778", "FrameRate_Mode": "CFR", "FrameRate": "24.000", "FrameCount": "64193", "ColorSpace": "YUV", "ChromaSubsampling": "4:2:0", "BitDepth": "10", "Delay": "0.000", "StreamSize": "5135433505", "Default": "Yes", "Forced": "No", "colour_description_present": "Yes", "colour_description_present_Source": "Stream", "colour_range": "Limited", "colour_range_Source": "Stream", "colour_primaries": "BT.2020", "colour_primaries_Source": "Stream", "transfer_characteristics": "PQ", "transfer_characteristics_Source": "Stream", "matrix_coefficients": "BT.2020 non-constant", "matrix_coefficients_Source": "Stream", "MasteringDisplay_ColorPrimaries": "BT.2020", "MasteringDisplay_ColorPrimaries_Source": "Stream", "MasteringDisplay_Luminance": "min: 0.0000 cd/m2, max: 1000 cd/m2", "MasteringDisplay_Luminance_Source": "Stream" Working on this now, me and rich picked it up also. Trying to reset them doesn't reset them either. Standby we are nearly there 2
Cheesegeezer 3106 Posted June 6, 2022 Author Posted June 6, 2022 tracked down the problem.... the issue was the bit inbetween the chair and the laptop. Just testing the fix now.... be about 10mins 1 1
Cheesegeezer 3106 Posted June 6, 2022 Author Posted June 6, 2022 Ok fellas Version 0.0.1.6 up on the first post Good luck.... i really just wanna hear great things now..... (i'm a broken man lol ) Cheers 1 1
rbjtech 5345 Posted June 6, 2022 Posted June 6, 2022 10 minutes ago, Cheesegeezer said: Ok fellas Version 0.0.1.6 up on the first post Good luck.... i really just wanna hear great things now..... (i'm a broken man lol ) Cheers Looking good ... now... if we can just stop that Frosty fella from making up these weird and wonderful codec combinations .. then we might be onto a winner ... 1 1
CBers 7557 Posted June 6, 2022 Posted June 6, 2022 22 minutes ago, Cheesegeezer said: the issue was the bit inbetween the chair and the laptop. An id10t code then 1
FrostByte 5456 Posted June 6, 2022 Posted June 6, 2022 30 minutes ago, Cheesegeezer said: tracked down the problem.... the issue was the bit inbetween the chair and the laptop. Just testing the fix now.... be about 10mins Hit the "loose nut" between the laptop and chair with one of these a couple times. Just fix it right up 3
FrostByte 5456 Posted June 6, 2022 Posted June 6, 2022 26 minutes ago, Cheesegeezer said: Ok fellas Version 0.0.1.6 up on the first post Good luck.... i really just wanna hear great things now..... (i'm a broken man lol ) Cheers Winner, winner, chicken dinner! Everything reset and updated. Including the 5 or 6 Imax DTS:X movies I manually changed an hour ago 1 1 1
Cheesegeezer 3106 Posted June 6, 2022 Author Posted June 6, 2022 3 minutes ago, FrostByte said: Everything reset and updated. Including the 5 or 6 Imax DTS:X movies I manually changed an hour ago My pleasure lol 1
MagicDoubleM 121 Posted June 6, 2022 Posted June 6, 2022 Discovered another idiotic off-resolution that doesn't get catched so far: 3828*1592.
rbjtech 5345 Posted June 6, 2022 Posted June 6, 2022 5 minutes ago, MagicDoubleM said: Discovered another idiotic off-resolution that doesn't get catched so far: 3828*1592. This should have been captured as the width falls within this range - it should be titled as 4K or UHD ? if (Convert.ToInt32(typeInfo.Width) >= 1921 && Convert.ToInt32(typeInfo.Width) <= 3840 ) { resolution = config.ShowAsUHD ? "UHD".Trim() : "4K".Trim(); 1
MagicDoubleM 121 Posted June 6, 2022 Posted June 6, 2022 50 minutes ago, rbjtech said: This should have been captured as the width falls within this range - it should be titled as 4K or UHD ? if (Convert.ToInt32(typeInfo.Width) >= 1921 && Convert.ToInt32(typeInfo.Width) <= 3840 ) { resolution = config.ShowAsUHD ? "UHD".Trim() : "4K".Trim(); Hmm, yeah, the problem might be different. I noticed that a few of my latest additions only got the audiotrack updated, not video. I'll do some testing with today's build when I'm back home later. 1
Cheesegeezer 3106 Posted June 6, 2022 Author Posted June 6, 2022 31 minutes ago, MagicDoubleM said: Hmm, yeah, the problem might be different. I noticed that a few of my latest additions only got the audiotrack updated, not video. I'll do some testing with today's build when I'm back home later. are you using the latest version from the first post. All these issues have been resolved you should be running version 0.0.1.6 not 1.0.0.2
Cheesegeezer 3106 Posted June 6, 2022 Author Posted June 6, 2022 (edited) @FrostByte I'm just testing out this with Rich Edited June 6, 2022 by Cheesegeezer 1
Cheesegeezer 3106 Posted June 6, 2022 Author Posted June 6, 2022 @FrostByte Also you should find this in the logs, I had 7 movies before the exclude no i only have 5 1
FrostByte 5456 Posted June 6, 2022 Posted June 6, 2022 3 minutes ago, Cheesegeezer said: @FrostByte I'm just testing out this with Rich Cool. I went through that Imax enhanced website and noticed not all titles have the issue, but all the titles I have which have the issue are on that list. So, definitely something they are doing on some titles that is different and isn't being caught by the way the mediainfo developer reverse engineered the track info
Cheesegeezer 3106 Posted June 6, 2022 Author Posted June 6, 2022 (edited) @FrostByte 0.0.2.0 is on first post. It's pretty bomb proof. even if you add special characters, letters to the Emby Item Ids it will ignore them, even adding a comma at the end is caught. We have given it a good test so go for it lol You'll need to clear browser cache to get the new option to show Edited June 6, 2022 by Cheesegeezer 1
Cheesegeezer 3106 Posted June 6, 2022 Author Posted June 6, 2022 i'm popping out for a couple of hours, but will check back when i return. Good luck everyone 1
FrostByte 5456 Posted June 6, 2022 Posted June 6, 2022 2 minutes ago, Cheesegeezer said: @FrostByte 0.0.2.0 is on first post. It's pretty bomb proof. even if you add special characters, letters to the Emby Item Ids it will ignore them, even adding a comma at the end is caught. We have given it a good test so go for it lol You'll need to clear browser cache to get the new option to show Testing now. Will this exempt the listed movies from both updating and refreshing?
Cheesegeezer 3106 Posted June 6, 2022 Author Posted June 6, 2022 (edited) 1 minute ago, FrostByte said: Testing now. Will this exempt the listed movies from both updating and refreshing? Yes and resetting Edited June 6, 2022 by Cheesegeezer 1
FrostByte 5456 Posted June 6, 2022 Posted June 6, 2022 Just now, Cheesegeezer said: i'm popping out for a couple of hours, but will check back when i return. Good luck everyone Okay. Thanks. I'll post my findings in a bit 1
neik 874 Posted June 6, 2022 Posted June 6, 2022 Cheese, you might wanna remove the versioning in the setup page as it is outdated and probably doesn't provide much information but a bit of effort on your side to keep it updated: Btw., video track naming does seem to work now. Thank you, Cheese!
Cheesegeezer 3106 Posted June 6, 2022 Author Posted June 6, 2022 14 minutes ago, neik said: Cheese, you might wanna remove the versioning in the setup page as it is outdated and probably doesn't provide much information but a bit of effort on your side to keep it updated: Btw., video track naming does seem to work now. Thank you, Cheese! Feeky Chucker!! when its released to the plugin store it will be version 1.0.0.0. So you’ll just have to live with it until then! 1
neik 874 Posted June 6, 2022 Posted June 6, 2022 4 minutes ago, Cheesegeezer said: when its released to the plugin store it will be version 1.0.0.0. So you’ll just have to live with it until then! Sure thing! Not quite sure this is a bug but I have a file which has a strange video track naming: 2022-06-06 18:56:31.544 Debug Media Info: Starting MediaInfo.exe process 2022-06-06 18:56:32.141 Debug Media Info: ************** Reset Embedded Titles = False 2022-06-06 18:56:32.191 Debug Media Info: Ref Item = (...)/4K/movies/Die Legende Von Aang (2010)/Die Legende Von Aang (2010).mkv 2022-06-06 18:56:32.191 Debug Media Info: GENERAL INFO 2022-06-06 18:56:32.191 Debug Media Info: Video Tracks = 1 2022-06-06 18:56:32.191 Debug Media Info: Audio Tracks = 2 2022-06-06 18:56:32.191 Debug Media Info: Subtitle Tracks = 2022-06-06 18:56:32.191 Debug Media Info: Overall Bitrate = 15845263 2022-06-06 18:56:32.191 Debug Media Info: ********************* 2022-06-06 18:56:32.191 Debug Media Info: VIDEO INFO 2022-06-06 18:56:32.191 Debug Media Info: Track Format = HEVC 2022-06-06 18:56:32.191 Debug Media Info: BitRate = 15013158 2022-06-06 18:56:32.191 Debug Media Info: Height =2160 2022-06-06 18:56:32.191 Debug Media Info: Width =3840 2022-06-06 18:56:32.191 Debug Media Info: Aspect Ration =1.778 2022-06-06 18:56:32.191 Debug Media Info: HDR Format =SMPTE ST 2086 2022-06-06 18:56:32.191 Debug Media Info: HDR Format Profile = 2022-06-06 18:56:32.191 Debug Media Info: HDR Compatibility =HDR10 2022-06-06 18:56:32.191 Debug Media Info: ********************* 2022-06-06 18:56:32.240 Info Media Info: Video Stream Updated to: 4K 2022-06-06 18:56:32.240 Info Media Info: Video Track Title Set to 4K 2022-06-06 18:56:32.240 Debug Media Info: AUDIO INFO 2022-06-06 18:56:32.240 Debug Media Info: Track Format = AC-3 2022-06-06 18:56:32.240 Debug Media Info: No of Channels = 6 2022-06-06 18:56:32.240 Debug Media Info: Track Index = 1 2022-06-06 18:56:32.240 Debug Media Info: Track Additional Features = 2022-06-06 18:56:32.240 Debug Media Info: ********************* 2022-06-06 18:56:32.243 Debug Media Info: ************** Reset Embedded Titles = False 2022-06-06 18:56:32.268 Info Media Info: Audio Stream #1 Updated to: Dolby Digital 5.1 2022-06-06 18:56:32.268 Debug Media Info: AUDIO INFO 2022-06-06 18:56:32.268 Debug Media Info: Track Format = AAC 2022-06-06 18:56:32.268 Debug Media Info: No of Channels = 6 2022-06-06 18:56:32.268 Debug Media Info: Track Index = 2 2022-06-06 18:56:32.268 Debug Media Info: Track Additional Features = LC 2022-06-06 18:56:32.268 Debug Media Info: ********************* 2022-06-06 18:56:32.268 Debug Media Info: ************** Reset Embedded Titles = False 2022-06-06 18:56:32.292 Info Media Info: Audio Stream #2 Updated to: AAC LC 5.1 2022-06-06 18:56:32.292 Info Media Info: Item Tags found = 2022-06-06 18:56:32.292 Info Media Info: PROCESSING OF Die Legende von Aang HAS COMPLETED 2022-06-06 18:56:32.294 Debug Media Info: MediaInfo processing for Die Legende von Aang and took 751 milliseconds I would have expected a "4K HDR10". Might also be a damaged file as the thumbnails look all a bit greenish.
Cheesegeezer 3106 Posted June 6, 2022 Author Posted June 6, 2022 @FrostByte @rbjtech @neik @MagicDoubleM @CBers @Spaceboy are we ready for a catalogue release. cheers
