CBers 7557 Posted June 4, 2022 Posted June 4, 2022 4 minutes ago, Cheesegeezer said: Is that all thats in the log? what settings have you selected. im out no so nothing will be done until tomorrow but if you can get me as much info as possible. I will try to Cbers proof this I bet you're glad I started testing for you No worries, enjoy your evening
neik 874 Posted June 4, 2022 Posted June 4, 2022 10 minutes ago, rbjtech said: Have you set the library to use BIF's with the media - re section 4.3 of the Wiki ? Is it planned to expand the functionality to BIF's that are not saved alongside the media files?
rbjtech 5345 Posted June 4, 2022 Posted June 4, 2022 (edited) 18 minutes ago, neik said: Is it planned to expand the functionality to BIF's that are not saved alongside the media files? Possibly, we tried for a while to find where these are held in the dB but failed. Is there any reason you don't save the BIF file with the media ? I guess if you have never done this, then it will mean recreating all your BIF's (for both HDR - via the plugin and non-HDR items - via core emby) which is not ideal I agree. @ebr @Luke Can you kindly let us know how we find the location of the BIF file if it is not held alongside the media ? Thanks. Edited June 4, 2022 by rbjtech
Cheesegeezer 3106 Posted June 4, 2022 Author Posted June 4, 2022 22 minutes ago, CBers said: I have the "Generate BIF for Movies" enabled. Can it run alongside the "Media Info" task? Sure no problems, it was my first test! My cpu happily bounces around 75% 1
neik 874 Posted June 4, 2022 Posted June 4, 2022 55 minutes ago, rbjtech said: Is there any reason you don't save the BIF file with the media ? In my case no specific one just started with the default Emby location and never changed it ever since. But for those using cloud storage they might hit some limits / delays, I guess. 57 minutes ago, rbjtech said: Can you kindly let us know how we find the location of the BIF file if it is not held alongside the media ? Thanks. I assume you guys already had a look at the API, right?
Cheesegeezer 3106 Posted June 4, 2022 Author Posted June 4, 2022 (edited) 54 minutes ago, neik said: In my case no specific one just started with the default Emby location and never changed it ever since. But for those using cloud storage they might hit some limits / delays, I guess. I assume you guys already had a look at the API, right? Can’t access them, i spent a day finding them and couldn’t update or overwrite them. I could spend more time, but at the moment thats a choice the user will have to make. And a movie is only about 10Mb of data. and to be fair if they are using the cloud they will have plenty of storage Edited June 4, 2022 by Cheesegeezer
MagicDoubleM 121 Posted June 4, 2022 Posted June 4, 2022 4 hours ago, Cheesegeezer said: Is that all thats in the log? what settings have you selected. im out no so nothing will be done until tomorrow but if you can get me as much info as possible. I will try to Cbers proof this I'm having the same issue. Have all 4 options enablend, have the libs configured to have the bif-files alongside the media-files and when i start the task i get the same error, not much more errors to post here.
Cheesegeezer 3106 Posted June 5, 2022 Author Posted June 5, 2022 (edited) Do we need to start posting the topic in our signatures again…. How to report a problem. if was to tell you on email, my phone isn’t working correctly and then leave you with that. There would be flurry of of questions from you you to try and understand how the problem is repeating itself. drop a car off at the garage… sure… you say, i got a light on the dashboard… but they plug in a diagnostic tool that helps them and then they charge you for the priveledge of using their tool. please help me here… i cant diagnose if you can’t supply info and scenarios Edited June 5, 2022 by Cheesegeezer
MagicDoubleM 121 Posted June 5, 2022 Posted June 5, 2022 1 hour ago, Cheesegeezer said: Do we need to start posting the topic in our signatures again…. How to report a problem. if was to tell you on email, my phone isn’t working correctly and then leave you with that. There would be flurry of of questions from you you to try and understand how the problem is repeating itself. drop a car off at the garage… sure… you say, i got a light on the dashboard… but they plug in a diagnostic tool that helps them and then they charge you for the priveledge of using their tool. please help me here… i cant diagnose if you can’t supply info and scenarios 2022-06-05 05:47:16.846 Debug TaskManager: Executing Thumbnail Image HDR-SDR Image Generation 2022-06-05 05:47:16.846 Info Media Info-HDRConvert:: HDR Conversion TASK IS STARTING 2022-06-05 05:47:16.846 Info Media Info-HDRConvert:: HDR Reprocess Items is ON - Resetting Lists... 2022-06-05 05:47:16.846 Info Media Info-HDRConvert:: Resetting HDR Lists for Movies & TV Episodes... 2022-06-05 05:47:16.846 Info Media Info-HDRConvert:: Lists for HDR Movies & TV Episodes successfully Reset 2022-06-05 05:47:16.846 Info Media Info-HDRConvert:: Getting All Movies in Library 2022-06-05 05:47:16.850 Debug Server: http/1.1 GET http://192.168.0.10:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzc3LjAuMzg2NS45MCBTYWZhcmkvNTM3LjM2fDE1NzA0NDkwOTQwMjQ1&X-Emby-Client-Version=4.8.0.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/102.0.5005.63 Safari/537.36 2022-06-05 05:47:16.851 Debug Server: http/1.1 Response 200 to 192.168.0.10. Time: 1ms. http://192.168.0.10:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzc3LjAuMzg2NS45MCBTYWZhcmkvNTM3LjM2fDE1NzA0NDkwOTQwMjQ1&X-Emby-Client-Version=4.8.0.0 2022-06-05 05:47:16.866 Info Media Info-HDRConvert:: Filtering HDR Movies 2022-06-05 05:47:16.906 Info Media Info-HDRConvert:: Total Movies in Library = 403 2022-06-05 05:47:16.906 Error Media Info-HDRConvert:: Value cannot be null. (Parameter 'source') *** Error Report *** Version: 4.8.0.0 Command line: C:\Users\User\AppData\Roaming\Emby-Server\system\EmbyServer.dll -service Operating system: Microsoft Windows 10.0.22000 Framework: .NET 6.0.2 OS/Process: x64/x64 Runtime: C:/Users/User/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 16 Data path: C:\Users\User\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\User\AppData\Roaming\Emby-Server\system System.ArgumentNullException: System.ArgumentNullException: Value cannot be null. (Parameter 'source') at System.Linq.ThrowHelper.ThrowArgumentNullException(ExceptionArgument argument) at System.Linq.Enumerable.ToArray[TSource](IEnumerable`1 source) at Emby.MediaInfo.ScheduledTasks.HDRConvertScheduledTask.Execute(CancellationToken cancellationToken, IProgress`1 progress) Source: System.Linq TargetSite: Void ThrowArgumentNullException(System.Linq.ExceptionArgument) 2022-06-05 05:47:16.906 Debug TaskManager: Thumbnail Image HDR-SDR Image Generation Completed after 0 minute(s) and 0 seconds This is all I get, when I initiate the task. 1
rbjtech 5345 Posted June 5, 2022 Posted June 5, 2022 4 hours ago, MagicDoubleM said: This is all I get, when I initiate the task. The error is suggesting you have no HDR movies and it's returning a NULL reference (ArgumentNullException which we need to trap) but I presume there are HDR movies to convert - thus you running it ? If you picked one manually, does it have colour primaries as bt2020 in it's media info ? 1
MagicDoubleM 121 Posted June 5, 2022 Posted June 5, 2022 56 minutes ago, rbjtech said: The error is suggesting you have no HDR movies and it's returning a NULL reference (ArgumentNullException which we need to trap) but I presume there are HDR movies to convert - thus you running it ? If you picked one manually, does it have colour primaries as bt2020 in it's media info ? Yes and yes. Only those HD and UHD-DV5 files don't have those infos at all, lots of others UHD HDR ones look exactly like yours. I haven't checked all. 2
FrostByte 5456 Posted June 5, 2022 Posted June 5, 2022 It appears that when you have (Default) on and there is only on audio track that it's removing the (Default) and the video information. For all episodes I have the video information is missing even though the log says it was written. It wasn't doing this before though because older episodes have the video info. Log in link. I can rerun with debugging on and reset 2022-06-05 06:59:57.174 Info Media Info: Getting Episodes in Library2022-06-05 - Pastebin.com JSON for Obi-Wan, others are the same { "@type": "Video", "StreamOrder": "0", "ID": "1", "UniqueID": "9662855407556330958", "Format": "HEVC", "Format_Profile": "Main 10", "Format_Level": "5", "Format_Tier": "High", "HDR_Format": "SMPTE ST 2086", "HDR_Format_Compatibility": "HDR10", "CodecID": "V_MPEGH/ISO/HEVC", "Duration": "2674.709000000", "BitRate": "15359976", "Width": "3840", "Height": "2160", "Sampled_Width": "3840", "Sampled_Height": "2160", "PixelAspectRatio": "1.000", "DisplayAspectRatio": "1.778", "FrameRate_Mode": "CFR", "FrameRate": "24.000", "FrameCount": "64193", "ColorSpace": "YUV", "ChromaSubsampling": "4:2:0", "BitDepth": "10", "Delay": "0.000", "StreamSize": "5135433505", "Default": "Yes", "Forced": "No", "colour_description_present": "Yes", "colour_description_present_Source": "Stream", "colour_range": "Limited", "colour_range_Source": "Stream", "colour_primaries": "BT.2020", "colour_primaries_Source": "Stream", "transfer_characteristics": "PQ", "transfer_characteristics_Source": "Stream", "matrix_coefficients": "BT.2020 non-constant", "matrix_coefficients_Source": "Stream", "MasteringDisplay_ColorPrimaries": "BT.2020", "MasteringDisplay_ColorPrimaries_Source": "Stream", "MasteringDisplay_Luminance": "min: 0.0000 cd/m2, max: 1000 cd/m2", "MasteringDisplay_Luminance_Source": "Stream" }, { "@type": "Audio", "StreamOrder": "1", "ID": "2", "UniqueID": "17813015296226792782", "Format": "E-AC-3", "Format_Commercial_IfAny": "Dolby Digital Plus with Dolby Atmos", "Format_Settings_Endianness": "Big", "Format_AdditionalFeatures": "JOC", "CodecID": "A_EAC3", "Duration": "2674.720000000", "BitRate_Mode": "CBR", "BitRate": "768000", "Channels": "6", "ChannelPositions": "Front: L C R, Side: L R, LFE", "ChannelLayout": "L R C LFE Ls Rs", "SamplesPerFrame": "1536", "SamplingRate": "48000", "SamplingCount": "128386560", "FrameRate": "31.250", "FrameCount": "83585", "Compression_Mode": "Lossy", "Delay": "0.000", "Delay_Source": "Container", "StreamSize": "256773120", "StreamSize_Proportion": "0.04761", "Title": "Dolby Digital Plus Atmos 5.1 ", "Language": "en", "ServiceKind": "CM", "Default": "Yes", "Forced": "No", "extra": { "ComplexityIndex": "16", "NumberOfDynamicObjects": "15", "BedChannelCount": "1", "BedChannelConfiguration": "LFE", "bsid": "16", "dialnorm": "-27", "compr": "-0.28", "acmod": "7", "lfeon": "1", "dialnorm_Average": "-27", "dialnorm_Minimum": "-27", "compr_Average": "-0.11", "compr_Minimum": "-0.86", "compr_Maximum": "1.94", "compr_Count": "112" }
Cheesegeezer 3106 Posted June 5, 2022 Author Posted June 5, 2022 On 01/06/2022 at 00:37, FrostByte said: If not too late, is it possible to only write (Default) if there are more than one audio track? Doesn't really make sense to have (Default) when there is only one. @FrostByte
FrostByte 5456 Posted June 5, 2022 Posted June 5, 2022 Okay, well it has nothing to do with the Default I don't think. Because some have the video title and some don't After the refresh it's all the same episodes without video track info even though the log says it was written 2022-06-05 07:29:12.782 Info Media Info: PROCESSING OF Part III HAS STARTED202 - Pastebin.com
Cheesegeezer 3106 Posted June 5, 2022 Author Posted June 5, 2022 26 minutes ago, FrostByte said: It appears that when you have (Default) on and there is only on audio track that it's removing the (Default) and the video information. For all episodes I have the video information is missing even though the log says it was written. It wasn't doing this before though because older episodes have the video info. Log in link. I can rerun with debugging on and reset 2022-06-05 06:59:57.174 Info Media Info: Getting Episodes in Library2022-06-05 - Pastebin.com JSON for Obi-Wan, others are the same { "@type": "Video", "StreamOrder": "0", "ID": "1", "UniqueID": "9662855407556330958", "Format": "HEVC", "Format_Profile": "Main 10", "Format_Level": "5", "Format_Tier": "High", "HDR_Format": "SMPTE ST 2086", "HDR_Format_Compatibility": "HDR10", "CodecID": "V_MPEGH/ISO/HEVC", "Duration": "2674.709000000", "BitRate": "15359976", "Width": "3840", "Height": "2160", "Sampled_Width": "3840", "Sampled_Height": "2160", "PixelAspectRatio": "1.000", "DisplayAspectRatio": "1.778", "FrameRate_Mode": "CFR", "FrameRate": "24.000", "FrameCount": "64193", "ColorSpace": "YUV", "ChromaSubsampling": "4:2:0", "BitDepth": "10", "Delay": "0.000", "StreamSize": "5135433505", "Default": "Yes", "Forced": "No", "colour_description_present": "Yes", "colour_description_present_Source": "Stream", "colour_range": "Limited", "colour_range_Source": "Stream", "colour_primaries": "BT.2020", "colour_primaries_Source": "Stream", "transfer_characteristics": "PQ", "transfer_characteristics_Source": "Stream", "matrix_coefficients": "BT.2020 non-constant", "matrix_coefficients_Source": "Stream", "MasteringDisplay_ColorPrimaries": "BT.2020", "MasteringDisplay_ColorPrimaries_Source": "Stream", "MasteringDisplay_Luminance": "min: 0.0000 cd/m2, max: 1000 cd/m2", "MasteringDisplay_Luminance_Source": "Stream" }, { "@type": "Audio", "StreamOrder": "1", "ID": "2", "UniqueID": "17813015296226792782", "Format": "E-AC-3", "Format_Commercial_IfAny": "Dolby Digital Plus with Dolby Atmos", "Format_Settings_Endianness": "Big", "Format_AdditionalFeatures": "JOC", "CodecID": "A_EAC3", "Duration": "2674.720000000", "BitRate_Mode": "CBR", "BitRate": "768000", "Channels": "6", "ChannelPositions": "Front: L C R, Side: L R, LFE", "ChannelLayout": "L R C LFE Ls Rs", "SamplesPerFrame": "1536", "SamplingRate": "48000", "SamplingCount": "128386560", "FrameRate": "31.250", "FrameCount": "83585", "Compression_Mode": "Lossy", "Delay": "0.000", "Delay_Source": "Container", "StreamSize": "256773120", "StreamSize_Proportion": "0.04761", "Title": "Dolby Digital Plus Atmos 5.1 ", "Language": "en", "ServiceKind": "CM", "Default": "Yes", "Forced": "No", "extra": { "ComplexityIndex": "16", "NumberOfDynamicObjects": "15", "BedChannelCount": "1", "BedChannelConfiguration": "LFE", "bsid": "16", "dialnorm": "-27", "compr": "-0.28", "acmod": "7", "lfeon": "1", "dialnorm_Average": "-27", "dialnorm_Minimum": "-27", "compr_Average": "-0.11", "compr_Minimum": "-0.86", "compr_Maximum": "1.94", "compr_Count": "112" } sorry i miread you're saying if only one audio track the Video Title is being removed?
FrostByte 5456 Posted June 5, 2022 Posted June 5, 2022 1 minute ago, Cheesegeezer said: @FrostByte Roger, that's not the problem. The problem is I have several episodes with no video information even though the log says it was written
FrostByte 5456 Posted June 5, 2022 Posted June 5, 2022 Just now, Cheesegeezer said: sorry i miread you're saying if only one audio track the Video Title is being removed? Well, that's what I thought at first. But it doesn't appear so because I have some episodes with 1 audio track and the video info was written. However, even after refresh these same episodes don't have any video info.
Cheesegeezer 3106 Posted June 5, 2022 Author Posted June 5, 2022 2 minutes ago, FrostByte said: Okay, well it has nothing to do with the Default I don't think. Because some have the video title and some don't After the refresh it's all the same episodes without video track info even though the log says it was written 2022-06-05 07:29:12.782 Info Media Info: PROCESSING OF Part III HAS STARTED202 - Pastebin.com hahaha, ok that's completely my fault. I was doing some testing for the "locked" file issues, and put those in for my testing. so i could figure out how to fix and oooops i forgot to remove them (which is why it's not writing a title. give me a few mins. I wanna try and get the Bif issues sorted too. 2
rbjtech 5345 Posted June 5, 2022 Posted June 5, 2022 (edited) 2022-06-05 07:29:13.042 Debug Media Info: No Video Track Title found - probably need to add the field to the TrackInfo is it possible those Video Tracks on the effected items are not Track 1 ? ie are they duel video track items maybe ? edit - ah forget that - Dave has identified above ... Edited June 5, 2022 by rbjtech
rbjtech 5345 Posted June 5, 2022 Posted June 5, 2022 @Cheesegeezer - Can you also please increment the release numbers .. as I'm not seeing any of these issues as I'm still on the last release before you added to the catalog .. 1
rbjtech 5345 Posted June 5, 2022 Posted June 5, 2022 We are looking at this with some head scratching going on - it worked perfectly fine and then we had to go and improve it ... brb..
neik 874 Posted June 5, 2022 Posted June 5, 2022 (edited) The issue with the titles not being edtied on Linux seems solved with the latest version in post #1. Well, at least for the audio tracks, video is still not being edited, dunno why, can't see anything in the logs either. So, step by step we are getting there.. Edited June 5, 2022 by neik
Cheesegeezer 3106 Posted June 5, 2022 Author Posted June 5, 2022 1 hour ago, rbjtech said: We are looking at this with some head scratching going on - it worked perfectly fine and then we had to go and improve it ... brb.. Yeah this one has got me good and proper!! 1 hour ago, neik said: The issue with the titles not being edtied on Linux seems solved with the latest version in post #1. Well, at least for the audio tracks, video is still not being edited, dunno why, can't see anything in the logs either. So, step by step we are getting there.. sure are…. Ill get something up later for you guys to try 3 hours ago, rbjtech said: @Cheesegeezer - Can you also please increment the release numbers .. as I'm not seeing any of these issues as I'm still on the last release before you added to the catalog .. I will start next batch of releases, starting at 0.0.1.2 3
Spaceboy 2573 Posted June 5, 2022 Posted June 5, 2022 so... the scheduled task ran for 20hours and a library scan followed but no evidence of any changes in emby nor, as far as i can see, in the files themselves
Cheesegeezer 3106 Posted June 6, 2022 Author Posted June 6, 2022 2 hours ago, Spaceboy said: so... the scheduled task ran for 20hours and a library scan followed but no evidence of any changes in emby nor, as far as i can see, in the files themselves Cool… and… 1. which library task 2. Log with debug enabled 3. Settings 4. would really appreciate that Stuff
