Cheesegeezer 3106 Posted June 4, 2022 Author Posted June 4, 2022 2 minutes ago, CBers said: I did, then extracted it. Should I have not extracted it? No thats fine. That error come from the try catch, so it does Wanna do any work for some reason.
rbjtech 5345 Posted June 4, 2022 Posted June 4, 2022 Lets wait until you've finished ya shopping and then ping me on teams. What CBers has done is I think correct ? That log error is just a generic Catch in your code. 1
Cheesegeezer 3106 Posted June 4, 2022 Author Posted June 4, 2022 @CBers I found it! i did some code tidyup and added in some extra checks very recently and they work really well apparently hhahaha New dll up on the first post.... same rev, give it a whirl please 1
Cheesegeezer 3106 Posted June 4, 2022 Author Posted June 4, 2022 everyone missed in the logs too that the episodes and movies were exactly the same number lol
MagicDoubleM 121 Posted June 4, 2022 Posted June 4, 2022 I'm still having that issue that the plugin only does it's thing during scheduled tasks, not while importing new stuff. Where do I look for more helpful infos? Also finally nice looking previews for HDR stuff!!! Thank you so much for that addition. 1 1
CBers 7557 Posted June 4, 2022 Posted June 4, 2022 7 minutes ago, Cheesegeezer said: @CBers I found it! i did some code tidyup and added in some extra checks very recently and they work really well apparently hhahaha New dll up on the first post.... same rev, give it a whirl please Thanks Dave, running now. 6 minutes ago, Cheesegeezer said: everyone missed in the logs too that the episodes and movies were exactly the same number lol I did see that, but wasn't sure if it was a bug or not.
FrostByte 5456 Posted June 4, 2022 Posted June 4, 2022 5 minutes ago, CBers said: Thanks Dave, running now. I did see that, but wasn't sure if it was a bug or not. LOL, I saw it in your logs too and just thought it very odd that your episodes and movies were the exact number
rbjtech 5345 Posted June 4, 2022 Posted June 4, 2022 12 minutes ago, MagicDoubleM said: I'm still having that issue that the plugin only does it's thing during scheduled tasks, not while importing new stuff. Where do I look for more helpful infos? Also finally nice looking previews for HDR stuff!!! Thank you so much for that addition. It doesn't trigger on adding new items (yet) - I have just set it to trigger every hour. 1
rbjtech 5345 Posted June 4, 2022 Posted June 4, 2022 14 minutes ago, MagicDoubleM said: Also finally nice looking previews for HDR stuff!!! Thank you so much for that addition. I've had this running as an external script for a while now so thought it would be a good addition to the plugin - with Dave's wizzy coding skills it was added in a day
FrostByte 5456 Posted June 4, 2022 Posted June 4, 2022 Just now, rbjtech said: I've had this running as an external script for a while now so thought it would be a good addition to the plugin - with Dave's wizzy coding skills it was added in a day I've been using a PowerShell script myself for HDR bifs. I assume if I got this working on my NAS it will redo them all the first time
rbjtech 5345 Posted June 4, 2022 Posted June 4, 2022 3 minutes ago, FrostByte said: I've been using a PowerShell script myself for HDR bifs. I assume if I got this working on my NAS it will redo them all the first time Out the box yes, as it assumes this is a first run but does then keep a log of what it's completed so it doesn't do them again (with the option to refresh if you wanted to). You can add your ItemId's into the XML if you really don't want to re-do them and then it will just do the new ones as you add them. <HDRProcessedMovieList> <long>1355423</long> </HDRProcessedMovieList> <HDRProcessedEpisodeList> <long>1776221</long> </HDRProcessedEpisodeList> 1
Cheesegeezer 3106 Posted June 4, 2022 Author Posted June 4, 2022 Some of you may have found that some of the mkv's aren't getting edited. Well i found the cause of this and this is rectified. New DLL is up if any of you find some files don't get populated with the new audio/video track titles. Super dooper.... I'm hoping this is a fire and forget plugin 3
CBers 7557 Posted June 4, 2022 Posted June 4, 2022 (edited) The config page doesn't fully load on a mobile device. Just get the top section, but no fields. I've cleared the browser cache, but still doesn't load. Edited June 4, 2022 by CBers
Cheesegeezer 3106 Posted June 4, 2022 Author Posted June 4, 2022 (edited) 8 minutes ago, CBers said: The config page doesn't fully load on a mobile device. Just get the top section, but no fields. I've cleared the browser cache, but still doesn't load. It’s fine on my apple phone and ipad. There isn't much i can do as everything is using Emby built in controls and components. Nothing custom at all here. Edited June 4, 2022 by Cheesegeezer
rbjtech 5345 Posted June 4, 2022 Posted June 4, 2022 22 minutes ago, CBers said: The config page doesn't fully load on a mobile device. Just get the top section, but no fields. I've cleared the browser cache, but still doesn't load. Are you using Chrome for Android ? It's works ok with Edge for Android .. need to do a bit more digging ...
Cheesegeezer 3106 Posted June 4, 2022 Author Posted June 4, 2022 29 minutes ago, CBers said: The config page doesn't fully load on a mobile device. Just get the top section, but no fields. I've cleared the browser cache, but still doesn't load. Can you show me what you are experiencing please
rbjtech 5345 Posted June 4, 2022 Posted June 4, 2022 (edited) On Chrome for Android - you get nothing after this screen - you don't see any options nor can you scroll up/down/left or iright - the 'setup info' takes you to the wiki ok Edge works for fine - just about to try Firefox .. Edit - Firefox has the issue too - so only Edge is working for me on my Android 11 Phone. Edited June 4, 2022 by rbjtech 1
CBers 7557 Posted June 4, 2022 Posted June 4, 2022 (edited) 36 minutes ago, rbjtech said: Are you using Chrome for Android ? Yes. If you enable Desktop mode it works, albeit you can only scroll up/down, and continues to work if you revert. Perhaps the Audio options need to move moved under the Video options. Edited June 4, 2022 by CBers
CBers 7557 Posted June 4, 2022 Posted June 4, 2022 Not sure if @FrostByte has reported this yet, but when there's nothing to process, the message "MEDIAINFO ISN'T ENABLED IN THE CONFIG" is misleading. 2022-06-04 17:34:02.194 Info Media Info: PERFORMING MEDIAINFO EXTRACTION ON MOVIES 2022-06-04 17:34:02.194 Info Media Info: MEDIAINFO EXTRACTION ON MOVIES Completed for 575 Movies 2022-06-04 17:34:02.194 Info Media Info: TV EPISODES IS NOT ENABLED 2022-06-04 17:34:02.194 Info Media Info: MEDIAINFO ISN'T ENABLED IN THE CONFIG 2022-06-04 17:34:02.194 Debug XmlSerializer: Serializing to file C:\Users\Media\AppData\Roaming\Emby-Server\config\mediainfo.xml 2022-06-04 17:34:02.195 Debug TaskManager: Media Info Completed after 0 minute(s) and 0 seconds 1
FrostByte 5456 Posted June 4, 2022 Posted June 4, 2022 I checked again just now and I'm getting that message even when I add something
CBers 7557 Posted June 4, 2022 Posted June 4, 2022 HDR-SDR Image Generation BIF creation failing. Info-HDRConvert:: Value cannot be null. (Parameter 'source') *** Error Report *** Version: 4.8.0.0 Command line: C:\Users\Media\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows 10.0.19044 Framework: .NET 6.0.2 OS/Process: x64/x64 Runtime: C:/Users/Media/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 12 Data path: C:\Users\Media\AppData\Roaming\Emby-Server Application path: C:\Users\Media\AppData\Roaming\Emby-Server\system System.ArgumentNullException: System.ArgumentNullException: Value cannot be null. (Parameter 'source') at System.Linq.ThrowHelper.ThrowArgumentNullException(ExceptionArgument argument) at System.Linq.Enumerable.ToArray[TSource](IEnumerable`1 source) at Emby.MediaInfo.ScheduledTasks.HDRConvertScheduledTask.Execute(CancellationToken cancellationToken, IProgress`1 progress) Source: System.Linq TargetSite: Void ThrowArgumentNullException(System.Linq.ExceptionArgument) 2022-06-04 17:42:08.773 Debug TaskManager: Thumbnail Image HDR-SDR Image Generation Completed after 0 minute(s) and 0 seconds
rbjtech 5345 Posted June 4, 2022 Posted June 4, 2022 6 minutes ago, CBers said: HDR-SDR Image Generation BIF creation failing. Info-HDRConvert:: Value cannot be null. (Parameter 'source') *** Error Report *** Version: 4.8.0.0 Command line: C:\Users\Media\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows 10.0.19044 Framework: .NET 6.0.2 OS/Process: x64/x64 Runtime: C:/Users/Media/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 12 Data path: C:\Users\Media\AppData\Roaming\Emby-Server Application path: C:\Users\Media\AppData\Roaming\Emby-Server\system System.ArgumentNullException: System.ArgumentNullException: Value cannot be null. (Parameter 'source') at System.Linq.ThrowHelper.ThrowArgumentNullException(ExceptionArgument argument) at System.Linq.Enumerable.ToArray[TSource](IEnumerable`1 source) at Emby.MediaInfo.ScheduledTasks.HDRConvertScheduledTask.Execute(CancellationToken cancellationToken, IProgress`1 progress) Source: System.Linq TargetSite: Void ThrowArgumentNullException(System.Linq.ExceptionArgument) 2022-06-04 17:42:08.773 Debug TaskManager: Thumbnail Image HDR-SDR Image Generation Completed after 0 minute(s) and 0 seconds Presumably you've set movies and/or episodes to be TRUE and added the location for BIFTool ? <BIFGeneratorPath /> <EnableHDRMovies>false</EnableHDRMovies> <EnableHDREpisodes>false</EnableHDREpisodes> <EnableHDRReprocess>false</EnableHDRReprocess> Have you set the library to use BIF's with the media - re section 4.3 of the Wiki ? https://github.com/Cheesegeezer/MediaInfoWiki/wiki/Emby-HDR-to-SDR-Thumbnail-&-Chapter-Image-Generator-using-Tonemapping
Cheesegeezer 3106 Posted June 4, 2022 Author Posted June 4, 2022 Is that all thats in the log? what settings have you selected. im out no so nothing will be done until tomorrow but if you can get me as much info as possible. I will try to Cbers proof this
CBers 7557 Posted June 4, 2022 Posted June 4, 2022 I have the "Generate BIF for Movies" enabled. Can it run alongside the "Media Info" task?
CBers 7557 Posted June 4, 2022 Posted June 4, 2022 4 minutes ago, rbjtech said: Have you set the library to use BIF's with the media - re section 4.3 of the Wiki ? Yes.
