kofzhanganguo 39 Posted May 26, 2022 Posted May 26, 2022 (edited) 季节过多时,操作选择繁琐,需要点击左右箭头滑动到自己选择的季节,然后点击收看剧集。 能不能加入这种风格的视图显示选择,可以快速定位季节或剧集,否则来回滚动选择季节和剧集非常麻烦。 风格视频.mp4 Edited May 26, 2022 by kofzhanganguo
kofzhanganguo 39 Posted May 26, 2022 Author Posted May 26, 2022 Hello, mine are all formal names. The question I raised is a suggestion. When users customize the number of seasons, the operation logic of EMBY is very cumbersome.
kofzhanganguo 39 Posted May 26, 2022 Author Posted May 26, 2022 When the number of seasons or episodes is small, the EMBY original view display is no problem, but when the number of seasons and episodes is large, the EMBY view style is very troublesome to choose.
ebr 16337 Posted May 26, 2022 Posted May 26, 2022 Its not a bad idea but I'd want it to be intelligent and only collapse to that type of display if the number of seasons were, say, greater than 15 or 20.
Happy2Play 9812 Posted May 26, 2022 Posted May 26, 2022 Yep 40 + seasons of looney toons. But yes virtual scroll can be problematic with lots of items like this.
kofzhanganguo 39 Posted May 26, 2022 Author Posted May 26, 2022 Wish there was a view option that showed seasons and episodes as little icons without covers
Mistwalker 1 Posted February 18, 2025 Posted February 18, 2025 So, it's been nearly 3 years now, can we get an update for those of use with shows that have seasons in the double digits? The current scrolling method is really looking dated and is very cumbersome for anything over a few seasons. I've tried changing it in CSS, but that doesn't work and wouldn't help with TV apps.
Luke 42244 Posted February 18, 2025 Posted February 18, 2025 4 hours ago, Mistwalker said: So, it's been nearly 3 years now, can we get an update for those of use with shows that have seasons in the double digits? The current scrolling method is really looking dated and is very cumbersome for anything over a few seasons. I've tried changing it in CSS, but that doesn't work and wouldn't help with TV apps. hi there, what exactly are you asking for?
DarkStar1977 120 Posted February 19, 2025 Posted February 19, 2025 19 hours ago, Luke said: hi there, what exactly are you asking for? The same he asked at the begining in 2022, having multi-row as a view option for seasons, or/and smaller icons for long seasons show, can u imagine scrolling on a 60 Seasons show to arrive to the latest one ? I Can:
