RetroZelda 6 Posted May 26, 2022 Posted May 26, 2022 So i have an issue where everything runs fine after restarting the server, but then randomly all WAN access will result in "Connection Failure". LAN access continues to work fine. Any assistance would be appreciated.
RetroZelda 6 Posted May 26, 2022 Author Posted May 26, 2022 im not exactly sure. longer than 10 minutes but within an hour
Luke 42246 Posted May 26, 2022 Posted May 26, 2022 OK I just pushed a 1.1.3 update to the port mapper plugin. Please let us know if that helps. Thanks.
RetroZelda 6 Posted May 26, 2022 Author Posted May 26, 2022 just updated it and restarted the server. I will let you know in an hour or so, and then sometime tomorrow 1
RetroZelda 6 Posted May 26, 2022 Author Posted May 26, 2022 seems to still occur. I have my logs attached(with debug enabled) embyserver (1).txt
Luke 42246 Posted May 27, 2022 Posted May 27, 2022 How long did it take after starting the server for there to be a problem?
