wesmckean 16 Posted May 25, 2022 Posted May 25, 2022 something I noticed when playing back ATSC 3.0 channels on Chrome with Google TV. it does not happen when playing back ATSC 3.0 channels on the Roku app. The sound will be fine for minutes at a time, then it will just cut out for a second then come back. I will try to see if it happens on a regular Android TV box as well. Let me know what else you need. Wes
wesmckean 16 Posted May 25, 2022 Author Posted May 25, 2022 I tried to end playback right after it popped to make it easier. I didn't see where in the Emby Player for Android TV where I could set the log files or how to retrieve them. hope this helps. Wes embyserver.txt ffmpeg-remux-bc745eda-54e8-46b2-a16d-dc52aa0d325b_1.txt
wesmckean 16 Posted May 25, 2022 Author Posted May 25, 2022 I experimented with different bit rates, and the break ups went away. funny thing is is that its sound only. not video.
ebr 16337 Posted May 25, 2022 Posted May 25, 2022 Guessing, whichever it is, it is this: 16:31:17.472 Error while decoding stream #0:2: Invalid data found when processing input
wesmckean 16 Posted May 25, 2022 Author Posted May 25, 2022 1 minute ago, ebr said: Does it make a "pop" noise or just drop-out? right. not an audible pop (my wife's description). it just drops out.
wesmckean 16 Posted May 26, 2022 Author Posted May 26, 2022 I've been watching ATSC 3.0 channel on the Emby app for Samsung for a while now, and no drops in sounds. It's possible that its the TV?!? I tried the Chromecast with Google TV on the Samsung, and I thought it was experiencing drops. I was going to test the Onn android box on the Hitachi in the kitchen to see if it is doing it as well. I'll let you know.
wesmckean 16 Posted May 26, 2022 Author Posted May 26, 2022 same issues with the Onn box on the kitchen Hitachi. Going to try it on the Samsung in the Den. More to follow: 19:11:15.105 [segment @ 0x1e2cb00] Opening '/var/lib/emby/transcoding-temp/9E5AAA/9E5AAA_48.ts.tmp' for writing 19:11:15.202 elapsed=00:02:20.64 frame= 8645 fps= 61 q=-1.0 size=N/A time=00:02:20.35 bitrate=N/A throttle=off speed=0.998x 19:11:15.715 elapsed=00:02:21.16 frame= 8663 fps= 61 q=-1.0 size=N/A time=00:02:20.87 bitrate=N/A throttle=off speed=0.998x 19:11:16.215 elapsed=00:02:21.66 frame= 8697 fps= 61 q=-1.0 size=N/A time=00:02:21.39 bitrate=N/A throttle=off speed=0.998x 19:11:16.326 [ac4 @ 0x1e2b600] substream audio data overread: 6 19:11:16.326 Error while decoding stream #0:2: Invalid data found when processing input
wesmckean 16 Posted May 26, 2022 Author Posted May 26, 2022 different error on the Samsung, but same blank spot in the sound. This with Android TV on the Onn device connected to a Samsung TV: 19:28:11.032 SegmentComplete=video:0 Index=50 Start=150.150000 End=152.969478 Duration=2.819478 offset_pts=0 start_pts=150150000 Frames=169 filename=hls/E9D326/E9D326_50.ts 19:28:11.032 [segment @ 0x26c3b00] Opening '/var/lib/emby/transcoding-temp/E9D326/E9D326_51.ts.tmp' for writing 19:28:11.231 elapsed=00:02:29.70 frame= 9175 fps= 61 q=-1.0 size=N/A time=00:02:33.24 bitrate=N/A throttle=off speed=1.02x 19:28:11.732 elapsed=00:02:30.20 frame= 9216 fps= 61 q=-1.0 size=N/A time=00:02:33.77 bitrate=N/A throttle=off speed=1.02x 19:28:12.031 [ac4 @ 0x26c2600] unexpected sequence counter: 167 vs 161 19:28:12.032 Error while decoding stream #0:2: Invalid data found when processing input
Luke 42245 Posted June 16, 2022 Posted June 16, 2022 Hi, if you play from the Emby web app, how does that compare?
wesmckean 16 Posted June 16, 2022 Author Posted June 16, 2022 4 minutes ago, Luke said: Hi, if you play from the Emby web app, how does that compare? it seems to only happen with Android/Google TV. I've kind of given up on it and gone back to strictly Roku. That's a bummer, because my Roku TV in the kitchen drops the network, and the router is like 5 feet away. Wes
Luke 42245 Posted July 2, 2022 Posted July 2, 2022 Hi @wesmckean are you still having an issue with this?
wesmckean 16 Posted July 2, 2022 Author Posted July 2, 2022 Right now. None of my ATSC 3.0 channels are playing due to another issue I posted about 1
troyhough 61 Posted July 26, 2022 Posted July 26, 2022 On 7/2/2022 at 3:40 PM, wesmckean said: Right now. None of my ATSC 3.0 channels are playing due to another issue I posted about Same here.
wesmckean 16 Posted August 25, 2022 Author Posted August 25, 2022 9 hours ago, Luke said: Are you still having an issue with this? I'm still on server 4.8.0.2. that's the last server I have that will play ATSC 3.0 channels here in Atlanta. I did notice that the dropouts do not happen on my Roku devices. They seem to be happening on Android/Google TV devices. Seems OK on Samsung TV native apps as well.
troyhough 61 Posted August 25, 2022 Posted August 25, 2022 (edited) 12 hours ago, Luke said: Are you still having an issue with this? Just tested my Android phone and a ATV device, neither will play ATSC3 stations on Emby still. Edited August 25, 2022 by troyhough
wesmckean 16 Posted August 26, 2022 Author Posted August 26, 2022 On 8/24/2022 at 11:20 PM, Luke said: Are you still having an issue with this? honestly, Luke, I think this is more hardware related. I was getting the sound drop outs on my dinky Roku TV in the kitchen, and I get it sometimes on the Chromecast with Google TV, but I can tell that is just network related. So, I think we can put this one to bed. 1
