xucangui 1 Posted June 6, 2022 Posted June 6, 2022 5 hours ago, Luke said: How exactly are you swapping the database file? I deleted the old container and image, and used the same command to pull the latest version of the image to install. This has been done before without any problems.
Luke 42246 Posted June 7, 2022 Posted June 7, 2022 On 6/5/2022 at 9:26 PM, xucangui said: I deleted the old container and image, and used the same command to pull the latest version of the image to install. This has been done before without any problems. Hi, try pulling the latest again and see if that helps. Thanks.
Solution xucangui 1 Posted July 3, 2022 Solution Posted July 3, 2022 7 hours ago, Luke said: Hi @xucangui has this helped? No,but I later,I installed linuxserver/emby first,it also doesn't work and delete it,Install emby/embyserver_arm64v8 again,it's normal,(used the same old database),I do not know why
