fillidill 175 Posted May 25, 2022 Posted May 25, 2022 As you can see in the screenshots, the same movie gets darker for some reason when playing it in the browser Edge, in Chrome however it looks correct. After these images where taken I updated and tested both in latest version of stable and beta but same problem. I also attached an image of the dashboard when the movie was playing in both browser and it seems to differ. Why is that? Also please note that the one on the right is played in Edge even though Emby incorrectly says it's played in Chrome.
Luke 42240 Posted May 25, 2022 Posted May 25, 2022 Hi, looks like edge is direct playing. The browser doesn't support tone mapping hdr by itself so this can only be done via server transcoding.
fillidill 175 Posted May 25, 2022 Author Posted May 25, 2022 1 hour ago, Luke said: Hi, looks like edge is direct playing. The browser doesn't support tone mapping hdr by itself so this can only be done via server transcoding. Thanks for a quick reply Luke. Is there any fix? I have tried changing this setting but makes no difference.
Solution GrimReaper 4896 Posted May 25, 2022 Solution Posted May 25, 2022 (edited) 1 hour ago, fillidill said: Thanks for a quick reply Luke. Is there any fix? I have tried changing this setting but makes no difference. And it can't make any difference, as it is Direct Played in Edge. If you're keen on using Edge to play it, you need to force transcoding, i.e. lower in-app quality below item bitrate (while accepting loss in PQ). Else use different browser that doesn't Direct Play HEVC (Chrome, Firefox) and transcoding will be triggered automatically. Alternatively, you can disable Hardware accelleration in Edge System settings - note that that will apply to all HEVC content, causing transcoding on any HEVC flavor (8-bit, 10-bit, SDR, HDR). Edited May 25, 2022 by GrimReaper 1
Luke 42240 Posted May 25, 2022 Posted May 25, 2022 Eventually we'll have a better way of forcing the transcoding for hdr 1
fillidill 175 Posted May 25, 2022 Author Posted May 25, 2022 53 minutes ago, GrimReaper said: And it can't make any difference, as it is Direct Played in Edge. If you're keen on using Edge to play it, you need to force transcoding, i.e. lower in-app quality below item bitrate (while accepting loss in PQ). Else use different browser that doesn't Direct Play HEVC (Chrome, Firefox) and transcoding will be triggered automatically. Alternatively, you can disable Hardware accelleration in Edge System settings - note that that will apply to all HEVC content, causing transcoding on any HEVC flavor (8-bit, 10-bit, SDR, HDR). Thanks a lot for that detailed explanation I disabled hardware acceleration in Edge for now. 5 minutes ago, Luke said: Eventually we'll have a better way of forcing the transcoding for hdr Sounds good. You guys are doing really good work, can't say that enough. Been using Emby daily for a long while now and loving it. 1 1
ryderjj89 33 Posted May 4, 2023 Posted May 4, 2023 I know this is an old post but wanted to bump it. Seems even in 4.8.0.34, this issue persists in Edge where it will direct play instead of transcoding for HDR. The original file plays as it should when viewed outside of Emby in something like Windows Media Player. Any way to force this without having to disable hardware acceleration or lower quality?
Luke 42240 Posted May 4, 2023 Posted May 4, 2023 1 hour ago, ryderjj89 said: I know this is an old post but wanted to bump it. Seems even in 4.8.0.34, this issue persists in Edge where it will direct play instead of transcoding for HDR. The original file plays as it should when viewed outside of Emby in something like Windows Media Player. Any way to force this without having to disable hardware acceleration or lower quality? Hi, force what exactly? This sounds like an issue with the browser's video player.
ryderjj89 33 Posted May 4, 2023 Posted May 4, 2023 On 5/25/2022 at 11:17 AM, Luke said: Eventually we'll have a better way of forcing the transcoding for hdr 1 minute ago, Luke said: Hi, force what exactly? This sounds like an issue with the browser's video player. I'm referring back to your comment from 5/2022. The "forcing transcoding for hdr". Im aware it's probably Edge's issue but lowering the quality did force the transcode which then was the proper brightness. But I didn't get something in 4K to play it in lower quality. I'm using the Emby Theater app instead for now.
Luke 42240 Posted May 18, 2023 Posted May 18, 2023 On 5/4/2023 at 1:48 PM, ryderjj89 said: I'm referring back to your comment from 5/2022. The "forcing transcoding for hdr". Im aware it's probably Edge's issue but lowering the quality did force the transcode which then was the proper brightness. But I didn't get something in 4K to play it in lower quality. I'm using the Emby Theater app instead for now. OK yes, more options to control this are certainly possible. Thanks. 1
