NeverExists 21 Posted May 25, 2022 Posted May 25, 2022 One thing I miss about plex is the option to use a different Metadata provider by clicking on the TV series options, then a drop down menu where you can select to switch it from TVDB to TMDB. A lot of series look better using TMDB cause of the use of high resolution images instead of the lower quality TVDB ones. Then again some shows don't have images on TMDB so I dont really know why there isn't an option to switch on a per series bases. Unless I missed it.
seanbuff 1356 Posted May 25, 2022 Posted May 25, 2022 While not exactly what you're asking for, but the next best thing you can do is rank your preferred providers and anything that one provider doesn't have (images) will be attempted from the next one down.
