Macca500 6 Posted May 24, 2022 Posted May 24, 2022 Hi everyone. I'm not sure this is the right forum but I am needed help accessing my emby (running off nas media center with unraid through kodi) All of this was set up for me by a friend however he is snowed under with work and unable to help. I have very little knowledge on how it runs etc but basically - I have a purpose built media centre which is on my network. I run kodi on my tv to watch it and recently had it set up to access remotely via emby. my media center decided to pack it in and has been replaced. I can see the media center on my network and access it at home on the tv through kodi however emby wont work remotely or on my network at all with the IP address that is designated to the media center. My router is a netgear Nighthawk X4S D7800. Is anyone able to give a step by step guide on what i need to do in very very simple terms please as I have about as much IT knowledge as a jar of mayonnaise Thanks for the help
Abobader 3485 Posted May 24, 2022 Posted May 24, 2022 Hello Macca500, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
datanet 133 Posted May 25, 2022 Posted May 25, 2022 How are you trying to access Emby outside of the Kodi install on your TV...since you said "or on my network at all with the IP address"? I'm trying to determine how you're trying to access Emby inside your network first since that will be necessary before we can tackle the second portion of making your Emby server remotely accessible through your firewall.
pwhodges 2025 Posted May 25, 2022 Posted May 25, 2022 You need to verify the IP address of the new media centre, and check that its firewall allows access to it. For remote access you also need to check the port forwarding settings in your router. A good starting point is to go through this summary her: https://support.emby.media/support/solutions/articles/44001849007-connectivity Paul
Luke 42186 Posted May 25, 2022 Posted May 25, 2022 @Macca500 please let us know if this helps. Thanks !
Macca500 6 Posted May 28, 2022 Author Posted May 28, 2022 On 5/25/2022 at 10:46 AM, datanet said: How are you trying to access Emby outside of the Kodi install on your TV...since you said "or on my network at all with the IP address"? I'm trying to determine how you're trying to access Emby inside your network first since that will be necessary before we can tackle the second portion of making your Emby server remotely accessible through your firewall. just by using the ip address of the server on my laptop on the network to look at settings etc. Won;t connect at all. I've verified the IP address is correct and also confirmed that it is connected and showing up in the router.
chef 3811 Posted May 29, 2022 Posted May 29, 2022 Hi there, You mention the IP address, but are you remembering to also add the port number to the url? http://xxx.xxx.x:8096
Luke 42186 Posted June 16, 2022 Posted June 16, 2022 hi @Macca500 were you able to get connected? Did you step through our Connection Troubleshooter? https://support.emby.media/support/solutions/articles/44001849007-connectivity Please try the steps listed there and let us know which ones succeed and which do not. Thanks !
