bblackmoor 16 Posted May 24, 2022 Posted May 24, 2022 (edited) This is not a question: I found and fixed my problem. But I thought it might help someone else if I put the problem and the answer here, where they may search for it a year from now. The problem: I installed Emby, used it for ten months (thank you!), then uninstalled it because I thought I was switching to another application. After realizing that the other application was inadequate to my needs (your needs may be different), I uninstalled that and re-installed Emby. All went smoothly until the step to access the web dashboard. Failed to connect to localhost port 8096: Connection refused Netstat showed that Emby was not even listening. $ sudo netstat -tulpn | grep EmbyServer $ sudo netstat | grep 8096 $ Apache (on ports 80 and 443) worked fine. The solution: I renamed this file (which is a user library database): $ sudo mv /var/lib/emby/data/library.db /var/lib/emby/data/library.db.old I do not know why this fixed it. But it did. I hope that someone finds this useful. And searchable. Edited May 24, 2022 by bblackmoor So many typos...
Luke 42246 Posted May 24, 2022 Posted May 24, 2022 HI there, if you can attach the emby server log from when that happened, we might be able to determine why. 1
bblackmoor 16 Posted May 24, 2022 Author Posted May 24, 2022 8 minutes ago, Luke said: HI there, if you can attach the emby server log from when that happened, we might be able to determine why. I would be happy to. Note that I moved the library.db file at 15:03:51. org.mortshire.embyserver.zip 1
