pwhodges 2037 Posted April 2, 2025 Posted April 2, 2025 New setting doesn't show in Windows client; ok in web and iOS. Paul 1
sa2000 700 Posted April 2, 2025 Posted April 2, 2025 19 minutes ago, pwhodges said: New setting doesn't show in Windows clien Thanks for the feedback. I will follow this up
Tank_Killer 7 Posted April 3, 2025 Posted April 3, 2025 is there a chance that the servers im trying to scrape the data from arent replying becuase they have ignored the ip range of nord VPN for security?
Tank_Killer 7 Posted April 17, 2025 Posted April 17, 2025 Is it possible to update to the latest beta in the server options somwhere? metadata not working is really screwing my library up
Neminem 1628 Posted April 17, 2025 Posted April 17, 2025 On 4/3/2025 at 5:22 AM, Tank_Killer said: becuase they have ignored the ip range of nord VPN for security? I guess Beta will not help you. If it works without Nord VPN, I guess you have your answer. Its not an Emby problem.
Tank_Killer 7 Posted April 17, 2025 Posted April 17, 2025 that was just a thought I had, however issue still could be ipv6/v4 traffic routing and would like to try the new option outlined in the beta.
pwhodges 2037 Posted April 17, 2025 Posted April 17, 2025 2 hours ago, Tank_Killer said: Is it possible to update to the latest beta in the server options somwhere? metadata not working is really screwing my library up You can simply install the beta over the stable release. However, you cannot go back the same way - to go back you need a full backup (of Emby, not the media!), or you need to start afresh and rebuild everything. This is because the beta changes the database, and so the stable version will have problems with it. Paul
Tank_Killer 7 Posted May 12, 2025 Posted May 12, 2025 I am having to manually refresh my metadata after disabling nord VPN which is getting really old, im getting close to switching projects as 4.8.11.0 doesnt work for my use case. sometimes when i ask it emby to refresh metadata for a whole series (saves me key strokes drilling down to the new EPS its missing data for) it wont refresh the whole series properly. is this becuase i am trying to refresh too many series sequentially and there is no queue system for the metadata? so its not done refreshing the series and i start to refresh another?
Luke 42263 Posted May 12, 2025 Posted May 12, 2025 Quote sometimes when i ask it emby to refresh metadata for a whole series (saves me key strokes drilling down to the new EPS its missing data for) it wont refresh the whole series properly. @Tank_Killer Hi there, please attach the Emby server log from when the problem occurred: How to Report a Problem Thanks!
