santi218 1 Posted May 22, 2022 Posted May 22, 2022 i have also noticed issues with the 4.7 version of emby server with lots of pauses while streaming. anybody can share to me a link to the old version pls. i want to rollback. thanks!
Luke 42186 Posted May 22, 2022 Posted May 22, 2022 HI there @santi218, we're happy to help. Can we please look at an example? Thanks !
santi218 1 Posted May 22, 2022 Author Posted May 22, 2022 (edited) All i can say is my server is my pc with ryzen 5 5600x 32G RAM, 3660 Ti and 1G line with ATT, i am also using a router ax11000. Im streaming with nvidia shield pro using wifi. I never had issues before and i noticed few days ago anything i play from webdl to remux bd i have lots of pauses or lags while streaming. So ive read in the forums people complaining too. I have also read a new version coming up, is it a fix? If not i would like to reroll to the old 4.6 version. Can i get a direct link to the .exe? Thanks Edited May 22, 2022 by santi218
Luke 42186 Posted May 22, 2022 Posted May 22, 2022 Can you please provide the information requested so that we can look at an example? This will assist us in giving you the best possible help that we can. Thanks.
Happy2Play 9800 Posted May 22, 2022 Posted May 22, 2022 It is better to try and figure out the issues as rolling back a major release is usually problematic.
santi218 1 Posted May 22, 2022 Author Posted May 22, 2022 Logs? Screenshots are useless coz as i said the movie just pause and resumes but its a long pause, no errors
Happy2Play 9800 Posted May 22, 2022 Posted May 22, 2022 Just now, santi218 said: Logs? Screenshots are useless coz as i said the movie just pause and resumes but its a long pause, no errors Logs show playback method which does provide relevant information. If direct playing it could be as simple as to high of bitrate and ISP throttling. But without more information all anyone can do is guess.
santi218 1 Posted May 22, 2022 Author Posted May 22, 2022 (edited) Well i will try to get the logs. But everytime i stream its always direct which i always go for. And i know net speeds are not my issues Edited May 22, 2022 by santi218
Happy2Play 9800 Posted May 22, 2022 Posted May 22, 2022 3 minutes ago, santi218 said: Well i will try to get the logs. But everytime i stream its always direct which i always go for. And i know net speeds are not my issues It is impossible to know your ISP is not the issues as there are several topics on the ISP being the issue throttling connections. I know my ISP throttles more in peak hours vs other times of the day. Just like I know my max download speed is nowhere near my true download speed of one item.
nospotify 186 Posted May 22, 2022 Posted May 22, 2022 I am noticing the same problem since upgrading to server 4.7, when streaming music, entirely on my home network. Simple mp3 files, no transcoding or anything, merely simple streaming from server computer to tablet. NOTHING has changed in my devices, files, or network, but now I get quick, intermittent playback pauses and glitches.
santi218 1 Posted May 22, 2022 Author Posted May 22, 2022 (edited) Im so conscious with my net speeds that i always check them frequently in a day and especially if i have connection issues. And i have not seen drop speeds when playback issues arises that is why i know its not my net speeds. Edited May 22, 2022 by santi218
OscarCalvo 0 Posted May 23, 2022 Posted May 23, 2022 Can you check how much memory does the EmbyService.exe is taking?
santi218 1 Posted May 23, 2022 Author Posted May 23, 2022 I would also like to add. I use plex for sideline and no issues at all. Looking forward to a fix coz i prefer emby over plex...
