Guest Posted November 19, 2022 Posted November 19, 2022 13 hours ago, Luke said: Hi, what issue? The first video I tried was a DV. I wanted to make sure that gpu-next was functioning correctly. It wasn't. There was no tone mapping and was glitchy in operation. I tried several times, with no change. Only after restarting the app did it work.
poormanshummer 12 Posted November 21, 2022 Posted November 21, 2022 On 18/11/2022 at 21:12, Luke said: It's just a portable test build, so you unzip anywhere and just run it. Ah gotcha. So close!
poormanshummer 12 Posted November 21, 2022 Posted November 21, 2022 On 19/11/2022 at 07:42, generiq said: It needs to be gpu-next Yup. Tried that too. No luck with osd.
Luke 42237 Posted May 1, 2023 Posted May 1, 2023 22 hours ago, poormanshummer said: So how's that update coming?
Luke 42237 Posted September 7, 2023 Posted September 7, 2023 On 8/26/2023 at 1:32 AM, poormanshummer said: Bump Hi, our app contains an up to date mpv. What exactly are you asking? Here's an even more up to date test build with mpv 0.36: https://www.dropbox.com/s/tjmartey16d2ja1/emby-theater.zip?dl=0 @generiq
SmileFlower 21 Posted November 7, 2023 Posted November 7, 2023 On 19/11/2022 at 13:12, Luke said: It's just a portable test build, so you unzip anywhere and just run it. Older Intel graphics cards will reproduce this situation
Luke 42237 Posted November 7, 2023 Posted November 7, 2023 11 hours ago, SmileFlower said: Older Intel graphics cards will reproduce this situation HI, did you try the test build that I linked to?
SmileFlower 21 Posted November 8, 2023 Posted November 8, 2023 3 hours ago, Luke said: HI, did you try the test build that I linked to? The beta version still cannot solve this problem. As long as a GPU is selected, there will be no OSD display. This problem occurs in some older Intel graphics cards, such as HD3000 and UHD510 and below. If it is UHD630 and above, there is no such problem
SmileFlower 21 Posted November 8, 2023 Posted November 8, 2023 (edited) 3 hours ago, Luke said: HI, did you try the test build that I linked to? Perhaps this is because hardware acceleration is not compatible with early drivers, so using LibMPV mode is sufficient, after all, this old model of graphics card does not support the new video encoding format well, or it may be abandoned Edited November 8, 2023 by SmileFlower
Luke 42237 Posted November 8, 2023 Posted November 8, 2023 How have you configured video options in the app?
SmileFlower 21 Posted November 8, 2023 Posted November 8, 2023 6 minutes ago, Luke said: How have you configured video options in the app? Video output: gpu This setting will result in the problems mentioned above
Guest Posted November 8, 2023 Posted November 8, 2023 4 minutes ago, SmileFlower said: Video output: gpu This setting will result in the problems mentioned above Change video output to gpu-next
SmileFlower 21 Posted November 8, 2023 Posted November 8, 2023 2 minutes ago, generiq said: Change video output to gpu-next The driver is not compatible with this mode, which will result in continuous rotation and inability to play
Guest Posted November 8, 2023 Posted November 8, 2023 Go to: C:\Users\YOURNAME\AppData\Roaming\Emby-Theater\electronapp\libmpv\x64 Replace mpv-1.dll by downloading and extracting this file https://sourceforge.net/projects/mpv-player-windows/files/libmpv/mpv-dev-x86_64-20231105-git-7480efa.7z/download , Then renaming libmpv-2.dll to mpv-1.dll
