Guardian87 4 Posted May 21, 2022 Posted May 21, 2022 Hi everyone, I’m starting to set up Emby for my two kids slowly as well. The filtering of pg ratings works quite well, but for shared libraries like movies, there are the same posters in place sometimes show moon kid friendly pictures. Would it be possible to have these pictures only being generated from the content the user is allowed to view? Example (even though not kid unfriendly at this moment) Best regards
Solution GrimReaper 4852 Posted May 21, 2022 Solution Posted May 21, 2022 Nope, those are generated of all library content, regardless of access permissions; similar with Genre thumbs, they are created from ALL content, regardless of library. Your best bet is to manually assign Library/Genre images, lots of them in appropriate forum section: https://emby.media/community/index.php?/forum/70-fan-art-videos/
ebr 16307 Posted May 21, 2022 Posted May 21, 2022 Hi. Yes, I would suggest creating your own images for the libraries. Each library only has one image as opposed to different ones for different users. Thanks.
Guardian87 4 Posted May 21, 2022 Author Posted May 21, 2022 Thanks for the feedback. I would have preferred a different solution per user but it is what it is.
arrbee99 1834 Posted May 21, 2022 Posted May 21, 2022 You can probably create your own in the same Emby style if you don't mind creating a temporary library with a few images in from which Emby will create one. You than find and copy that image to replace ones you don't like. There was a method somewhere but can't spot it at the moment.
Luke 42186 Posted May 22, 2022 Posted May 22, 2022 Right you can just customize your own images for each library and then they won't see the auto generated ones.
