tet 2 Posted May 21, 2022 Posted May 21, 2022 Could not connect to the local host after the update. After checking machine logs i found ARCH emby-server[8542]: It was not possible to find any compatible framework version ARCH emby-server[8542]: The framework 'Microsoft.AspNetCore.App', version '6.0.0' (x64) was not found. ARCH emby-server[8542]: - No frameworks were found. ARCH emby-server[8542]: You can resolve the problem by installing the specified framework and/or SDK. ARCH emby-server[8542]: The specified framework can be found at: ARCH emby-server[8542]: - https://aka.ms/dotnet-core-applaunch?framework=Microsoft.AspNetCore.App&framework_version=6.0.0> ARCH systemd[1]: emby-server.service: Main process exited, code=exited, status=150/n/a Emby has "dotnet-runtime" as dependency, but it also needs "aspnet-runtime" to work which needed to be installed manually. pacman -S aspnet-runtime
ferrvittorio 0 Posted July 1, 2022 Posted July 1, 2022 (edited) Hi! Seemingly I have still the same problem, a missing dependency in current community package 4.6.7.0-4 I do not dare touch dotnet files because I do not what to break system. Missing frame has now different name? : remove dotnet-runtime 6.0.2.sdk102-1, dotnet-host 6.0.2.sdk102-1; install dotnet-host-bin 6.0.6.sdk301-1, dotnet-runtime-bin 6.0.6.sdk301-1, aspnet-runtime-bin 6.0.6.sdk301-1; Quote × emby-server.service - Emby brings together your videos, music, photos, and live television. Loaded: loaded (/usr/lib/systemd/system/emby-server.service; enabled; vendor preset: disabled) Active: failed (Result: exit-code) since Sat 2022-05-28 14:14:36 CEST; 36s ago Process: 6044 ExecStart=/usr/bin/emby-server (code=exited, status=150) Main PID: 6044 (code=exited, status=150) CPU: 67ms mag 28 14:14:36 desktop systemd[1]: Started Emby brings together your videos, music, photos, and live television.. mag 28 14:14:36 desktop emby-server[6044]: It was not possible to find any compatible framework version mag 28 14:14:36 desktop emby-server[6044]: The framework 'Microsoft.AspNetCore.App', version '6.0.0' (x64) was not found. mag 28 14:14:36 desktop emby-server[6044]: - No frameworks were found. mag 28 14:14:36 desktop emby-server[6044]: You can resolve the problem by installing the specified framework and/or SDK. mag 28 14:14:36 desktop emby-server[6044]: The specified framework can be found at: mag 28 14:14:36 desktop emby-server[6044]: - https://aka.ms/dotnet-core-applaunch?framework=Microsoft.AspNetCore.App&framework_version=6.0.0&arch=x64&rid=manjaro-x64 mag 28 14:14:36 desktop systemd[1]: emby-server.service: Main process exited, code=exited, status=150/n/a mag 28 14:14:36 desktop systemd[1]: emby-server.service: Failed with result 'exit-code'. Edited July 1, 2022 by ferrvittorio
Luke 42246 Posted July 2, 2022 Posted July 2, 2022 On 7/1/2022 at 11:59 AM, ferrvittorio said: Hi! Seemingly I have still the same problem, a missing dependency in current community package 4.6.7.0-4 I do not dare touch dotnet files because I do not what to break system. Missing frame has now different name? : remove dotnet-runtime 6.0.2.sdk102-1, dotnet-host 6.0.2.sdk102-1; install dotnet-host-bin 6.0.6.sdk301-1, dotnet-runtime-bin 6.0.6.sdk301-1, aspnet-runtime-bin 6.0.6.sdk301-1; Hi there, what community package are you referring to? Emby Server 4.6.7 is built against .net core 3.1, not .net 6.0. We have never tested the 4.6 server with .net 6. The new Emby Server 4.7 release is built against .NET 6 though.
ferrvittorio 0 Posted July 3, 2022 Posted July 3, 2022 Hi, Sorry! I mistakenly wrote versions. I had to degrade to 4.6.7.0 - I find problems with 4.7.5.0 Quote https://archlinux.org/packages/?q=emby-server
Luke 42246 Posted July 3, 2022 Posted July 3, 2022 7 hours ago, ferrvittorio said: Hi, Sorry! I mistakenly wrote versions. I had to degrade to 4.6.7.0 - I find problems with 4.7.5.0 What problem?
ferrvittorio 0 Posted July 3, 2022 Posted July 3, 2022 I think I understood, will ask the mantainer then get back to you
Luke 42246 Posted July 3, 2022 Posted July 3, 2022 30 minutes ago, ferrvittorio said: I think I understood, will ask the mantainer then get back to you Let us know what you find. Thanks.
Luke 42246 Posted July 4, 2022 Posted July 4, 2022 8 hours ago, ferrvittorio said: It is ok now What was the solution?
ferrvittorio 0 Posted July 4, 2022 Posted July 4, 2022 The community package emby-server 4.7.5.0 looks now correctly built against .NET 6 ( https://archlinux.org/packages/community/x86_64/emby-server/ ), and in fact I can successfully start service
