Guest Posted May 20, 2022 Posted May 20, 2022 Folks: All of sudden, Emby cannot be accessed by the Users that have been configured on my system. For a long time, that has been working perfectly. There have been no changes to any of my equipment or settings in Emby or anything else (at least nothing that I have changed). I have always used a VPN (Private Internet Access) and set it to a location that allows split tunneling. No changes have been made in the regard. I can connect through wifi when at my location. No problems. But I and none of my "authorized" users can connect remotely. When I turn off wifi on my cell phone and it connects to LTE and I open the Emby app, I get the home screen with My Media displayed. However, when I try to open an individual media file, nothing loads. I have no idea where to start to look. Suggestions please!!!
Guest Posted May 20, 2022 Posted May 20, 2022 Error update. Eventually on my cell phone I will get "content no longer available" error.
Guest Posted May 22, 2022 Posted May 22, 2022 Still searching for a solution. Any help would be appreciated. Only steps taken so far was to disable virus protection and microsoft firewall. Didn't make a difference.
Luke 42186 Posted May 22, 2022 Posted May 22, 2022 Hi there, have you configured port forwarding in your router? https://support.emby.media/support/solutions/articles/44002137137-remote-setup
Happy2Play 9800 Posted May 23, 2022 Posted May 23, 2022 22 minutes ago, superbobtv said: I believe this is correct. Am I right? Yes it looks correct? Are you still having issues? But from a vpn standpoint does your server allow port forwarding? From your true WAN address you shouldn't have an issue.
Solution Guest Posted May 23, 2022 Solution Posted May 23, 2022 My frustration in situations like this is that I didn't change anything and therefore wonder: has an update to windows, emby, my vpn, router and whatever else, caused the disconnect. Also, I say without hesitation that I am not very good at diagnosing these situations. On a hope and a prayer I disconnected the router power supply, waited a minute and then plugged it in. Viola--remote access is working again. Go figure!! Thanks to those that responded.
