Luke 42241 Posted June 15, 2022 Posted June 15, 2022 6 hours ago, Biomorph said: Have attached log files, played an x264 file first with success and then an MPEG4 file that failed with the 'compatible streams' error. embyserver-63790919157.txt 45.41 kB · 1 download hardware_detection-63790919147.txt 138.12 kB · 0 downloads @Biomorph can you please attach the android app log by following the instructions in my link above? Thanks.
Biomorph 6 Posted June 16, 2022 Posted June 16, 2022 Sorry! Forgot that I had tried Emby Server for Android on this device and wasn't paying enough attention to the path. 144edf02-f322-4f86-8211-7cb88df17c38.log
Luke 42241 Posted June 16, 2022 Posted June 16, 2022 2 hours ago, Biomorph said: Sorry! Forgot that I had tried Emby Server for Android on this device and wasn't paying enough attention to the path. 144edf02-f322-4f86-8211-7cb88df17c38.log 33.93 kB · 0 downloads So you tried to play teen titans, is that correct?
Biomorph 6 Posted June 16, 2022 Posted June 16, 2022 Teen Titans (being x264) works, Married with Children fails and I can only assume because it's an old MPEG4 .avi
Luke 42241 Posted June 16, 2022 Posted June 16, 2022 And you can play the same file streaming from the server as opposed to the download?
Biomorph 6 Posted June 16, 2022 Posted June 16, 2022 Just tried then and it appears to transcode the video.
Luke 42241 Posted June 16, 2022 Posted June 16, 2022 OK so that probably explains it. you must have force downloaded the original file, right?
Biomorph 6 Posted June 16, 2022 Posted June 16, 2022 (edited) Yes, I'm sure I have have never had issues with .avi playing directly in the client prior. I don't often play them but have a couple of episodes offline for when I'm stuck with nothing to do so can't be sure of when the issue started. Edited June 16, 2022 by Biomorph
Biomorph 6 Posted June 20, 2022 Posted June 20, 2022 @Luke I have tried some prior versions and it seems MPEG4 playback worked on 3.1.xx and stopped from the 3.2 release.
Luke 42241 Posted July 8, 2022 Posted July 8, 2022 @Biomorph are you still seeing this with Emby for Android 3.2.52?
Luke 42241 Posted July 8, 2022 Posted July 8, 2022 34 minutes ago, Biomorph said: Yes, still the same issue. Well that's very odd. Can you please install this version: https://www.dropbox.com/s/u1obwrckg4lkjc8/emby-android-google-armeabi-v7a-release.apk?dl=0 And then provide a log from the android app: Thanks.
Biomorph 6 Posted July 8, 2022 Posted July 8, 2022 Log attached, played x264 file first, then the .avi that again failed. f853e686-35fc-4a39-9ad1-df4e8f74a548.log
Luke 42241 Posted July 8, 2022 Posted July 8, 2022 4 hours ago, Biomorph said: Log attached, played x264 file first, then the .avi that again failed. f853e686-35fc-4a39-9ad1-df4e8f74a548.log 37.77 kB · 0 downloads Just for quick comparison purposes, can you try downloading another video that's not an avi and see how that compares? Thanks.
Biomorph 6 Posted July 8, 2022 Posted July 8, 2022 Tried two other files, both played with no issue. 4bd1bae2-2f1a-4a9d-a283-a381687d7f2b.log 1
Luke 42241 Posted July 13, 2022 Posted July 13, 2022 OK, this should be resolved in 3.2.55+. Thanks. 1
brian5678 7 Posted March 13, 2023 Posted March 13, 2023 I am also having the "Playback Error" with download movie media. I attempted download the first season of "3rd Rock". About 1/3 of the episodes would play. I have deleted all downloads and attempted to just download episode #1. As like I have seen before with iOS app, the media downloaded that does NOT get transcoded has playback errors. Transcode is not occurring for this download. I can't figure out how to get around samsung's file secure to get at app log. App v3.2.92 run on new Samsung Galaxy Tab A8 - android v13 server is v4.8.0.21 - log attached WORKAROUND -- set download quality to 1.5Mbps then downloading to force transcoding to occur ** then episode will playback embyserver-short.txt
Luke 42241 Posted March 14, 2023 Posted March 14, 2023 8 hours ago, brian5678 said: I am also having the "Playback Error" with download movie media. I attempted download the first season of "3rd Rock". About 1/3 of the episodes would play. I have deleted all downloads and attempted to just download episode #1. As like I have seen before with iOS app, the media downloaded that does NOT get transcoded has playback errors. Transcode is not occurring for this download. I can't figure out how to get around samsung's file secure to get at app log. App v3.2.92 run on new Samsung Galaxy Tab A8 - android v13 server is v4.8.0.21 - log attached WORKAROUND -- set download quality to 1.5Mbps then downloading to force transcoding to occur ** then episode will playback embyserver-short.txt 17.07 kB · 1 download Are you forcing a download of the original file?
Luke 42241 Posted August 8, 2025 Posted August 8, 2025 @Biomorph are you still seeing this with Emby for Android 3.4.70+?
Biomorph 6 Posted August 9, 2025 Posted August 9, 2025 Nope, just tried the same files and had no playback issues under 3.4.74. 1
brian5678 7 Posted August 9, 2025 Posted August 9, 2025 (edited) 5 hours ago, Luke said: @Biomorph are you still seeing this with Emby for Android 3.4.70+? YES Downloaded 3rd Rock season 1 go to download folder, AND attempt to play episode 1 Playback Error No compatible streams are currently available. Please try again later or contact your system administrator for details. Got It (button) server version 4.8.11.0 (docker release) android client version 3.4.74 Edited August 9, 2025 by brian5678
Luke 42241 Posted August 9, 2025 Posted August 9, 2025 16 minutes ago, brian5678 said: YES Downloaded 3rd Rock season 1 go to download folder, AND attempt to play episode 1 Playback Error No compatible streams are currently available. Please try again later or contact your system administrator for details. Got It (button) server version 4.8.11.0 (docker release) android client version 3.4.74 @brian5678 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
