Prydwyn 6 Posted May 19, 2022 Posted May 19, 2022 Hope this is the right forum - and I've probably missed something obvious,bit hopefully some one can help... Yesterday I was able to access Emby remotely on my phone. Today, I couldn't. I thought that maybe my PC had restarted due to an update or power failure. However when I got home my PC was running normally. I checked again, and when connected to the local network with WiFi I could access the server, but when I switched to mobile data my phone wouldn't connect. The only thing I noticed was that in the early hours of this morning the Port Mapper plugin had updated... As nothing else has changed I can only think that the issue is related to this. Any help or suggestions appreciated. 1
Prydwyn 6 Posted May 19, 2022 Author Posted May 19, 2022 Here's my log. Thanks for looking. embyserver.txt
Happy2Play 9814 Posted May 19, 2022 Posted May 19, 2022 51 minutes ago, Prydwyn said: Here's my log. Thanks for looking. embyserver.txt 106.44 kB · 1 download Personally never use automatic port mapping but have you tried restarting your router? <errorDescription>ConflictInMappingEntry</errorDescription> Devs may have more info but disabling UPNP and manual port forwarding would resolve this issue.
Prydwyn 6 Posted May 19, 2022 Author Posted May 19, 2022 I have always had the ports manually forwarded. I have just tried turning on and off auto port mapping on the server, and enabling and disabling uPnP on my router. I restarted both server and router after each configuration change, but it hasn't helped. As I said originally, all was fine yesterday, but after the update of the Port Mapper plugin remote access has stopped working. Just a coincidence?
anonyms 2 Posted May 19, 2022 Posted May 19, 2022 already report to luke he is aware of this issue, wait for future update push for fixing the problem
Happy2Play 9814 Posted May 19, 2022 Posted May 19, 2022 17 minutes ago, Prydwyn said: As I said originally, all was fine yesterday, but after the update of the Port Mapper plugin remote access has stopped working. Just a coincidence? I would say yes but have no idea if one conflict with the other if you have manual and UPNP configured. Please try one method and let up know which method with a server log if it does not work. Test Emby ports via a site like canyouseeme.org At the same time"2022-05-19 17:31:59.739 Info NetworkManager: Detected local ip addresses" line does not look correct to me But am guess IPv6 is causing all the issues.
HtRabbit 11 Posted May 20, 2022 Posted May 20, 2022 i am also having issues related to portmapping embyserver(3).txt
Happy2Play 9814 Posted May 20, 2022 Posted May 20, 2022 46 minutes ago, HtRabbit said: i am also having issues related to portmapping embyserver(3).txt 38.78 kB · 1 download Just guessing but if you disable IPv6 do you still have an issue?
HtRabbit 11 Posted May 21, 2022 Posted May 21, 2022 (edited) i am new to linux , i am not 100 % sure how to. willing to be a guinea pig i have a log file here with debug on if it helpsembyserver_PNP_debugON.txt Edited May 21, 2022 by HtRabbit
HtRabbit 11 Posted May 21, 2022 Posted May 21, 2022 (edited) IPv6 turned off embyserver(1).txt i deleted the upnp port mapping on the router, after reboot of server the ports were recreated on the router Edited May 21, 2022 by HtRabbit
hustlehard 1 Posted May 23, 2022 Posted May 23, 2022 I'm having the same issue. Running Emby server on the Nvidia Shield TV. After port mapper update I can no longer access remotely.
hustlehard 1 Posted May 23, 2022 Posted May 23, 2022 I'm having the same issue after port mapper updated. Are you saying the auto port mapper is going to stay broken and I need to unistall it forward the ports manually. Or will there be an update to the auto port mapper?
arron1985 2 Posted May 23, 2022 Posted May 23, 2022 I also have the same problem. I uninstall portmapper and install an older version it works until it updates. I hope there is a fix for this.
Luke 42255 Posted May 23, 2022 Posted May 23, 2022 48 minutes ago, arron1985 said: install an older version it works until it updates. I hope there is a fix for this. Hi, what version did you install?
Luke 42255 Posted May 24, 2022 Posted May 24, 2022 18 hours ago, hustlehard said: I'm having the same issue after port mapper updated. Are you saying the auto port mapper is going to stay broken and I need to unistall it forward the ports manually. Or will there be an update to the auto port mapper? Hi there, please attach the emby server log. Thanks.
arron1985 2 Posted May 24, 2022 Posted May 24, 2022 I installed portmapper 1.0.3. There wasn't any reason why picked that one. I just thought I would give it a go and it work.
Luke 42255 Posted May 25, 2022 Posted May 25, 2022 On 5/24/2022 at 2:05 AM, arron1985 said: I installed portmapper 1.0.3. There wasn't any reason why picked that one. I just thought I would give it a go and it work. OK, I would try the latest version again. Thanks.
hustlehard 1 Posted May 26, 2022 Posted May 26, 2022 I'm having the same issue. Running Emby server on the Nvidia Shield TV. After port mapper update I can no longer access remotely. On the newest port mapper still can't access remotely. I added logs. embyserver.txt
hustlehard 1 Posted May 28, 2022 Posted May 28, 2022 Updated to Emby Android Server 4.7.1.0 and new Portmapper 1.1.4 still unable to connect remotely. I have added Logs embyserver.txt
hustlehard 1 Posted May 29, 2022 Posted May 29, 2022 I'm still unable to access my media remotely with Emby Server running on Nvidia Shield TV 4.7.1.0 and Port Mapper 1.1.6 everything was working fine until the port mapper updates started. So I updated my server thinking that would fix the issue but still no dice. embyserver.txt
Luke 42255 Posted May 29, 2022 Posted May 29, 2022 Hi, you do understand that you don't have to rely on the port mapper and can always just setup port forwarding in your router, right? Anyway, please try version 1.1.7 of the port mapper plugin that I just published. If there's still an issue then please attach the emby server log. Thanks.
hustlehard 1 Posted May 29, 2022 Posted May 29, 2022 (edited) Luke, you the man. You fixed my issue now using port mapper 1.1.7. I can access my media remotely again. Emby has been great. I really like the service and the help your team gives. Once you guys get the smart playlist features and faster search results I think a lot of user will only use Emby or Jellyfin. Emby is an nice service that's easy to use and configure and I don't have setup any ports. Thank you so much. Hopefully a lot of money is in store for you. embyserver (1).txt Edited May 29, 2022 by ebr Family policy
Luke 42255 Posted May 29, 2022 Posted May 29, 2022 10 hours ago, hustlehard said: Luke, you the man. You fixed my issue now using port mapper 1.1.7. I can access my media remotely again. Emby has been great. I really like the service and the help your team gives. Once you guys get the smart playlist features and faster search results I think a lot of user will only use Emby or Jellyfin. Emby is an nice service that's easy to use and configure and I don't have setup any ports. Thank you so much. Hopefully a lot of money is in store for you. embyserver (1).txt 28.55 kB · 0 downloads Thanks for the feedback.
