ltdstudio 0 Posted July 17, 2024 Posted July 17, 2024 I support this idea because I desperately need this feature 我支持这个想法,因为我迫切需要这个功能I support this idea because I desperately need this feature
Ankio 0 Posted August 3, 2024 Posted August 3, 2024 emby服务使用了如下环境变量文件 : /etc/emby-server.conf 在该文件末尾添加配置如下: ALL_PROXY=http://192.168.100.11:7890 HTTP_PROXY=http://192.168.100.11:7890 HTTPS_PROXY=http://192.168.100.11:7890 里面的代理换成自己的。 然后重启emby-server:systemctl restart emby-server 如果是docker的话,把这个文件映射出来,重启emby容器应该就行。 只在宿主机测试过,没在docker测试过,应该大差不差。
Sabar 0 Posted August 4, 2024 Posted August 4, 2024 On 8/3/2024 at 6:47 PM, Ankio said: emby服务使用了如下环境变量文件 : /etc/emby-server.conf 在该文件末尾添加配置如下: ALL_PROXY=http://192.168.100.11:7890 HTTP_PROXY=http://192.168.100.11:7890 HTTPS_PROXY=http://192.168.100.11:7890 里面的代理换成自己的。 然后重启emby-server:systemctl restart emby-server 如果是docker的话,把这个文件映射出来,重启emby容器应该就行。 只在宿主机测试过,没在docker测试过,应该大差不差。 没找到这个文件emby-server.conf
Ankio 0 Posted August 5, 2024 Posted August 5, 2024 14 hours ago, Sabar said: 没找到这个文件emby-server.conf 那用systemctl status emby-server找一下emby-server的服务配置文件 服务配置文件里面应该有一行类似于这样的字段 EnvironmentFile=/xxxxx 后面跟随的就是就是环境变量文件 这边只在debain环境测试过,其他环境应该也类似。
1jian10 0 Posted August 6, 2024 Posted August 6, 2024 On 8/5/2024 at 10:29 AM, Ankio said: 那用systemctl status emby-server找一下emby-server的服务配置文件 服务配置文件里面应该有一行类似于这样的字段 EnvironmentFile=/xxxxx 后面跟随的就是就是环境变量文件 这边只在debain环境测试过,其他环境应该也类似。 我是用的是windows,并不能这么操作,我也查找了emby-server.conf和emby-server,电脑上没有这个文件或者类似的文件,在服务中查询也没有emby—server
zcracker 0 Posted January 27 Posted January 27 I also need this feature. Proxy is a must for those who use Emby on mainland.
zcracker 0 Posted January 27 Posted January 27 Can the addition of proxy functionality be put on the agenda?
ebr 16335 Posted January 27 Posted January 27 12 hours ago, zcracker said: I also need this feature. Proxy is a must for those who use Emby on mainland. There are a number of good proxies already available and it doesn't get much easier than Caddy. Can't you use one of those?
