Painkiller88 250 Posted May 18, 2022 Posted May 18, 2022 Hi, Version 1.2.7 for Tizen seems to have a navigation bug, you can't reach the collections from the main window. I took the picture from the Download site just to explain it: At the bottom where you have all movies, favs, and collections, i can't navigate to collections anymore. I think this is not how it should be. thanks
Painkiller88 250 Posted May 18, 2022 Author Posted May 18, 2022 Just now, Luke said: Hi there, what exactly happens when you try? it just jumps over to the first movie on the right in the list, like the tab index were wrong I select all movies, go right to favs, and right again and i am on the first movie in my watching list.
FrostByte 5453 Posted May 18, 2022 Posted May 18, 2022 2 hours ago, Luke said: @FrostByte are you able to reproduce? Yes, when in horizontal mode you can't click on the Collections box for movies or the Upcoming box for TV shows. Basically, anything in the third square at the bottom won't let you navigate to it.
alonnitzan 0 Posted May 23, 2022 Posted May 23, 2022 I have a similar problem, but mine is under Live TV > Tags. You cannot browse the various options as it skips a page. This is on a Samsung Q70T (2020) tried this on a 2016 Tizen Samsung and the tag navigation is fine
Luke 42241 Posted May 23, 2022 Posted May 23, 2022 2 hours ago, alonnitzan said: I have a similar problem, but mine is under Live TV > Tags. You cannot browse the various options as it skips a page. This is on a Samsung Q70T (2020) tried this on a 2016 Tizen Samsung and the tag navigation is fine Hi there, can you please describe exactly what you mean? thanks.
alonnitzan 0 Posted May 23, 2022 Posted May 23, 2022 4 minutes ago, Luke said: Hi there, can you please describe exactly what you mean? thanks. Hi, Under Live Tv > Tags when navigating to the various tags instead of scrolling through the various tags it goes to the next tab and you cannot scroll 'choose' a tag
alonnitzan 0 Posted May 24, 2022 Posted May 24, 2022 Hi Guys, was my explanation sufficient or must i record a video of the bug. Thanks
Solution Luke 42241 Posted May 24, 2022 Solution Posted May 24, 2022 Please try the 1.2.8 release. Thanks.
FrostByte 5453 Posted May 24, 2022 Posted May 24, 2022 The navigation of the Home Screen while in horizontal mode works for me now, thanks. v1.2.8 1
Painkiller88 250 Posted May 24, 2022 Author Posted May 24, 2022 Yes i can confirm that. 1.2.8 fixes the issue. 1
