Seger 123 Posted May 17, 2022 Posted May 17, 2022 @ebr@Luke @all Direct Play MPEG4 on Emby not possible for Fire TV Stick and Nvidia Shield. This function is part of the basic equipment and already existed, when or will there be an update? Cross-loading of standard apps is not manageable because, firstly, there are too many clients and, secondly, not all users can technically implement this. I've already had a few conversations with you about this, but somehow we can't get a clear statement. Transcoding for a codec that also offers direct playback is also not the solution, as 70% of users certainly do not have a NAS with the function to transcode. Thank you for a statement on how, when and if we will soon get this again with the fire tv stciks and the shield. Thanks Seger
Luke 42245 Posted May 17, 2022 Posted May 17, 2022 HI, yes ultimately the TV app will catch up. Thanks.
Seger 123 Posted May 17, 2022 Author Posted May 17, 2022 OK, great that she will be, very good statement! Can you already say approximately when? It would help a lot of users and I can also promise it to my users. best regards seger
Seger 123 Posted May 18, 2022 Author Posted May 18, 2022 yes that's what I mean, did you mean Luke: E.g. the following file (just an example): Format : AVI Format/Info : Audio Video Interleave Dateigröße : 224 MiB Dauer : 24 min 53s Gesamte Bitrate : 1 258 kb/s verwendete Encoder-Bibliothek : VirtualDub build 18160/release Video ID : 0 Format : MPEG-4 Visual Format-Einstellungen : BVOP1 Format-Einstellungen für BVOP : 1 Format-Einstellungen für Qpel : Nein Format-Einstellungen für GMC : Keine warppoints Format-Einstellungen für Matrix : Default (H.263) Muxing-Modus : Packed bitstream Codec-ID : DX50 Codec-ID/Hinweis : DivX 5 Dauer : 24 min 53s Bitrate : 1 152 kb/s Breite : 640 Pixel Höhe : 480 Pixel Bildseitenverhältnis : 4:3 Bildwiederholungsrate : 25,000 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scantyp : progressiv Compression mode : Lossy Bits/(Pixel*Frame) : 0.150 Stream-Größe : 205 MiB (92%) verwendete Encoder-Bibliothek : DivX 5.2.1 Beta (UTC 2004-09-08) Audio ID : 1 Format : MPEG Audio Format-Version : Version 1 Format-Profil : Layer 3 Format-Einstellungen : Joint stereo / MS Stereo Codec-ID : 55 Codec-ID/Hinweis : MP3 Dauer : 24 min 53s Bitraten-Modus : konstant Bitrate : 96,0 kb/s Kanäle : 2 Kanäle Samplingrate : 32,0 kHz Compression mode : Lossy Video Verzögerung : 20 ms Stream-Größe : 17,1 MiB (8%) Ausrichtung : Aufteilung über Interleaves Interleave, Dauer : 40 ms (1,00 Video-Frame) Interleave, Vorlaufsdauer : 500 ms
Happy2Play 9812 Posted May 18, 2022 Posted May 18, 2022 Pretty sure it will come back to the "DX50 codec/DivX 5".
FizzWhistle 1 Posted November 15, 2022 Posted November 15, 2022 Hello, I had a little bit of trouble understanding the OPs question... But I had also noticed that my Fire Stick has trouble playing files that were encoded with the DX50. I am not a premium member, so I don't think there is any transcoding going on. They will play in an unwatchable way. It mostly looks like the wrong size was chosen so everything is slanted. Like it was using what VLC identifies as "Buffer Dimensions" instead of "Video resolution." I can provide examples if it helps. The files play fine on every other device I've tested, so I am not in a rush. What I had been trying to figure out was, is this was an issue with the Fire Stick or the Emby app for the Fire Stick? And... Is there a solution/work around available, am I just missing something, or do I just need to be patient?
ebr 16337 Posted November 15, 2022 Posted November 15, 2022 Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks.
