Happy2Play 9814 Posted July 10, 2022 Posted July 10, 2022 Unless it is a different server, I got login page from Windows 7 and 11 with domain and port that was in previous link. It showed a valid ssl certificate. FF and Edge.
Luke 42287 Posted July 10, 2022 Posted July 10, 2022 10 hours ago, Happy2Play said: Unless it is a different server, I got login page from Windows 7 and 11 with domain and port that was in previous link. It showed a valid ssl certificate. FF and Edge. You connected to his server, or are you saying you tested this on your own?
Happy2Play 9814 Posted July 10, 2022 Posted July 10, 2022 7 minutes ago, Luke said: You connected to his server, or are you saying you tested this on your own? Connect to his server via the Domain/port that was in previous post.
moviefan 187 Posted July 10, 2022 Author Posted July 10, 2022 (edited) 1 hour ago, Happy2Play said: Connect to his server via the Domain/port that was in previous post. By the time you tried connecting I probably had already restored to 4.7.1.0 with the custom bits Luke provided earlier. If you think it's of value I could try to coordinate a time to test with it in the upgraded state but I can't imagine you are going to have any different results than I am. Edited July 10, 2022 by moviefan
Luke 42287 Posted July 15, 2022 Posted July 15, 2022 Can you please try this version? https://www.dropbox.com/s/ygb12gfv85omxgk/embyserver-win-x64-4.7.5.0.7z?dl=0 Thanks.
moviefan 187 Posted August 13, 2022 Author Posted August 13, 2022 @Luke I am pretty sure I tried that version. I think you sent me a direct message about it as well which I responded to. It did not solve the issue so I ended up upgrading my system to Win10 this week. Now I am just having the issue with editing metadata via the web client causing the entire system to freeze for about 30s. 1
