moviefan 187 Posted May 17, 2022 Posted May 17, 2022 After upgrading to 4.7.0.60 I was unable to connect over HTTPS to my system. Received browser warning that session was not encrypted. Couldn't find any way to proceed. Downgraded back to 4.6.7 and issue went away. Not sure what changed here in new version.
Happy2Play 9814 Posted May 17, 2022 Posted May 17, 2022 Not seeing an issue witn my ssl connection test. Probably need to see the server log for 4.7.0.60.
neik 874 Posted May 17, 2022 Posted May 17, 2022 There was some problem during the beta with Let's Encrypt certificates - currently on my smartphone and didn't find it quickly. If he upgraded from stable to stable then he might be experiencing that.
Luke 42287 Posted May 17, 2022 Posted May 17, 2022 Hi, yes, please attach the emby server log. Thanks.
moviefan 187 Posted May 17, 2022 Author Posted May 17, 2022 I don't have Let's Encrypt certificate. Just a wildcard CA certificate that I paid for. This looks like the log from when it was happening. embyserver-63788385384.txt
Luke 42287 Posted May 17, 2022 Posted May 17, 2022 it looks like you're using your web app over plain http. Try switching it to https instead.
moviefan 187 Posted May 18, 2022 Author Posted May 18, 2022 You're just seeing my connection that I manually used after HTTPS wasn't working. I guess I will just wait for more to upgrade and see if anyone else reports this behavior.
Mookdog 90 Posted May 18, 2022 Posted May 18, 2022 (edited) I had a problem with the past beta run where my ssl wasnt working. I removed portmapper and forwarded the ports in my router and the problem was solved Mook Edited May 18, 2022 by Mookdog Spell correction
deccat 1 Posted May 18, 2022 Posted May 18, 2022 I have the same issues. 4.6.7.0 https/ssl is OK. 4.7.0.60 https/ssl is not OK. Certutil "Encryption test passed".
Elsaya 1 Posted May 18, 2022 Posted May 18, 2022 I have the same issues. With 4.7.0.60 with a wildcard certificate
moviefan 187 Posted May 18, 2022 Author Posted May 18, 2022 Heh I came back to post more logs but seems like others are seeing this now. I upgraded again and experienced the same issue.
Painkiller88 250 Posted May 18, 2022 Posted May 18, 2022 I can't confirm any issues with 4.7.0.60 and my SSL. I use Emby on Win 10 Everything seems ok, tested it with my android phone and chrome browser from outside my network
moviefan 187 Posted May 18, 2022 Author Posted May 18, 2022 @Painkiller8818Is your cert a wildcard or FQDN?
Painkiller88 250 Posted May 20, 2022 Posted May 20, 2022 On 5/19/2022 at 12:34 AM, moviefan said: @Painkiller8818Is your cert a wildcard or FQDN? its a normal wildcard cert
moviefan 187 Posted May 22, 2022 Author Posted May 22, 2022 Thanks so same deal as me. I am running on Windows 7; how about you? What about others in this thread experiencing issue?
Painkiller88 250 Posted May 22, 2022 Posted May 22, 2022 11 hours ago, moviefan said: Thanks so same deal as me. I am running on Windows 7; how about you? What about others in this thread experiencing issue? i am running win 10 as win7 isn't suported anymore from windows. Maybe you should do an inplace upgrade to win 10 and make it work again.
Q-Droid 1011 Posted May 22, 2022 Posted May 22, 2022 (edited) 13 hours ago, moviefan said: Thanks so same deal as me. I am running on Windows 7; how about you? What about others in this thread experiencing issue? This is useful info. The devs could answer but it's possible that the latest release removed cipher suites and/or protocols that Windows 7 was still relying on for the HTTPS connections. Maybe the new release can no longer fallback to those ciphers/protocols. Edited May 22, 2022 by Q-Droid
moviefan 187 Posted May 22, 2022 Author Posted May 22, 2022 1 hour ago, Painkiller8818 said: i am running win 10 as win7 isn't suported anymore from windows. Maybe you should do an inplace upgrade to win 10 and make it work again. I'm not very inclined to upgrade operating systems unless we identify this as the reason it's not working. @deccat & @Elsaya can you confirm the operating systems you're running?
Elsaya 1 Posted May 22, 2022 Posted May 22, 2022 I use also Windows 7. But I downgraded back to 4.6.7, because the Mediaportal Plugin has also changed.
Luke 42287 Posted May 22, 2022 Posted May 22, 2022 Hmm. I wonder if the updated .NET runtime and aspnetcore are requiring something not supported by the older version of windows. 1
moviefan 187 Posted May 22, 2022 Author Posted May 22, 2022 7 hours ago, Luke said: Hmm. I wonder if the updated .NET runtime and aspnetcore are requiring something not supported by the older version of windows. This would allow the program to run but just not support HTTPS?
Luke 42287 Posted May 22, 2022 Posted May 22, 2022 Just now, moviefan said: This would allow the program to run but just not support HTTPS? If it's related to the tls version then possibly, yes, given that windows 7 doesn't support tls 1.2+.
deccat 1 Posted May 23, 2022 Posted May 23, 2022 13 hours ago, moviefan said: I'm not very inclined to upgrade operating systems unless we identify this as the reason it's not working. @deccat & @Elsaya can you confirm the operating systems you're running? I'm using Windows 10 as a server and finally solved the problem using a 3rd party reverse proxy.
deccat 1 Posted May 23, 2022 Posted May 23, 2022 You can use a reverse proxy such as nginx or caddy to replace emby's https function.
moviefan 187 Posted May 23, 2022 Author Posted May 23, 2022 So it's also not working in Windows 10? Is Win10 still officially supported by Emby?
